Настройки блока комфорта(46 контроллер)
    Беларусь, Минск
    По умолчанию Настройки блока комфорта(46 контроллер)
    Может будет интересно для владельцев KL-адаптеров,настройки блока комфорта :razz: :
    Radio wave remote control functional variations 06.98 >
    03 Auto lock/unlock: Vehicles will be locked when a speed of 15 km/h is reached
    on=1
    off= 0
    04 Auto lock/unlock: Vehicles will be unlocked when the ignition key is withdrawn from the ignition lock
    on=1
    off= 0
    05 IM switch-off: Interior monitoring is activated or deactivated by operating central locking closed twice
    on=1
    off= 0
    06 Horn sounds when unlocking: Confirmation signal when unlocking1)
    on=1
    off= 0
    07 Horn sounds when locking: Confirmation signal when locking1)
    on=1
    off= 0
    08 Turn signals flash when unlocking: Unlocking is confirmed by turn signals flashing twice
    on=1
    off= 0
    09 Horn sounds when locking: Locking is confirmed by turn signals flashing once
    on=1
    off= 0
    10 Setting for alarm horn: Programming the horn operation when the alarm is triggered appropriate to the legislation of the countries
    1= Rest of Europe
    2= Germany
    3= Great Britain
    Radio wave remote control function variations >05.98
    The various functions listed in the table can be called up and adapted by selecting the channel numbers 03...10.
    03 Auto-lock The vehicle will be locked at a speed of 15 km/h (approx. 9.5 mph)
    on=1
    off=0
    04 Auto-unlock The vehicle will be locked at a speed of 15 km/h (approx. 9.5 mph) and unlocked when ignition key is removed
    on=1
    off=0
    05 Interior monitoring switch-off
    on=1
    off=0
    08 unlock = turn signals flash
    on=1
    off=0
    09 lock = turn signals flash
    on=1
    off=0
    10 SettingsAlarm horn
    1=Rest Eur.
    2=Germany
    3=GB
    Можно включить и выключить данные функции,процедура следущая:
    1 запускаем VAG_COM
    2 выбираем 46 контролер(центр удобств)
    3 выбираем 10 адаптацию
    4 выбираем любой канал от 03 до 10
    5 устанавливаем необходимое нам значение(0 или 1,т.е. выключено или включкно)
    6 сохраняем значение(при сохранении спрашивает уверены ли мы)
    7 выходим
    P.S. Извеняюсь что не перевёл в английском неселён ,но думаю и так понятно
    Съебёж, Эта Страна
    1=Rest Eur.
    2=Germany
    3=GB
    Интерестно что это? Настройки гудка для разных стран?
    04/AWT/GFY
    Беларусь, Минск
    Mex@n!K это настройки алгоритма срабатывания,не громкость не тон не меняются,лучше оставить 1,т.к. 2 или 3 (не помню точно) отключает датчики объёма,а 3 или 2 отключает сигнал при заводе без открытия двери .
    Россия, Тверь
    bawtrik, инфа интересная.
    Получено: 20
    Aleksander,
    инфа интересная.
    В Эльзе много интересного есть
    Беларусь, Минск
    oleg-kv спасибо ещё раз за помощь в регулировке угла ТНВД :hello2: ,сейчас и у меня появилась Эльза вот потихоньку ее и изучаю
    Россия, Тверь
    oleg-kv, да есть то оно есть, а так и искать не надо!
    on=1
    off= 0
    Это у всех будет работать? иил только у тех у кого есть штатная сигналка?
    Получено: 20
    КОМРАД,
    Адаптер у тебя есть, машина для тестирования тоже
    bawtrik, А после включения 15-км закрытия дверей в 3 группе наблюдаются приятные (или не приятные) последствия. Замок багажника закрывается через 30 секунд после открытия дверей с кнопки.
    Немцы, что ли просчитались?
    Беларусь, Минск
    КОМРАД проверял всего на 2 машшинах ,у обоих штатные сигналки,на сайте VAG-COM вот что написано:
    46 - Central Covenience: -- KWP1281
    Only on vehicles with power windows. VAG-COM fine. There are numerous options/ features that can be set.
    Selective Unlocking:
    [Select]
    [46 - Cent. Conv.] (35 - Cent. Locking for manual window cars)
    [Recode - 07]
    Write down the existing coding for future reference.
    Enter 5-digit code from below
    [Do It!]
    Look at the existing Soft. Coding. If you have selective unlocking (press the unlock button on the remote once to open the driver's door, twice to open all the doors) the last digit of your coding should be an odd number. To make all doors unlock, add 1 to the coding.
    Lock/Unlock Horn/Flash:
    [Select]
    [Adaptation - 10]
    Channel (03..08)
    Adaptation Value (1 = on, 0 = off)
    [Save]
    Channel 03 Auto Lock
    Channel 04 Auto Unlock
    Channel 05 Unlock, horn sounds
    Channel 06 Lock, horn sounds
    Channel 07 Unlock, turn signals flash
    Channel 08 Unlock, turn signals flash
    должно работать даже в машинах с ручными стеклоподемниками,правда проделывать нужно всё с 35 контроллером =D>
    Беларусь, Минск
    Sergey B5/V5 по поводу замка багажника буду смотреть пока не проверял,но если машину отпереть кнопкой то она не закрывается,а закрывается только если скорость превысит 15км.вч.
    Беларусь, Минск
    Sergey B5/V5,вчера проверил :cool: ,при открытии дверей кнопкой багажник действительно закрывается через 30 сек. если ключ находится в замке,а если ключ не в замке ,то всё остаётся открытым(что по моему вполне логично )
    bawtrik, Спасибо !Полезная информацыя.
    Промт прикалывается.
    3=GB Дистанционное управление радиоволны функциональные изменения 06.98>
    03 Авто блокируйте/разблокируйте: Транспортные средства будут блокированы, когда скорость 15 км/ч достигнута
    on=1
    прочь = 0
    04 Авто блокируйте/разблокируйте: Транспортные средства будут разблокированы, когда ключ зажигания забран от блокировки воспламенения
    on=1
    прочь = 0
    05 IM выключают: Внутренняя область, контролирующая активизирована или дезактивирована, управляя центральной блокировкой, закрытой дважды
    on=1
    прочь = 0
    06 Хорн звучит, разблокируя: сигнал Подтверждения, когда unlocking1)
    on=1
    прочь = 0
    07 Хорн звучит, блокируя: сигнал Подтверждения, когда locking1)
    on=1
    прочь = 0
    08 Сигналы поворота, перепрограммируемые, разблокируя: Разблокирование подтверждено по очереди сигналы, вспыхнувшие дважды
    on=1
    прочь = 0
    09 Хорн звучит, блокируя: Блокировка подтверждена по очереди сигналы, высвечивающие однажды
    on=1
    прочь = 0
    10 Установка для сигнального Хорна: Программирование операции Хорна, когда тревога вызвана соответствующая законодательству стран
    1= Отдых Европы
    2= Германия
    3= Великобритания
    Радиоволна отдаленные изменения функции управления> 05.98
    Различным функциям, перечисленным в таблице можно звонить и приспосабливаться выбором канал, номер 03... 10.
    03 Автоблокировка транспортное средство будет блокирована со скоростью 15 км/ч (приблизительно 9.5 миль в час)
    on=1
    off=0
    04 Авторазблокируйте транспортное средство, будет блокирован со скоростью 15 км/ч (приблизительно 9.5 миль в час) и разблокирован, когда ключ зажигания удален
    on=1
    off=0
    05 Внутренняя область, контролирующая выключает
    on=1
    off=0
    08 разблокируйте = перепрограммируемые сигналы поворота
    on=1
    off=0
    09 блокируйте = перепрограммируемые сигналы поворота
    on=1
    off=0
    10 Хорн SettingsAlarm
    1=Отдых Eur.
    2=Германия
    3=ГБАЙТ
  1. демонтаж блока комфорта
    от AUG в разделе Архив 2006г.
    Последнее сообщение: 19.08.2006, 12:16
  2. Вчера добрался до блока комфорта...
    от Mex@n!K в разделе Архив 2006г.
    Последнее сообщение: 12.04.2006, 20:36
  3. Ответов: 4
    Последнее сообщение: 17.02.2006, 22:09
  4. Ответов: 13
    Последнее сообщение: 17.10.2005, 11:10
  5. Как добраться до "блока комфорта"?
    от bosses в разделе Архив 2005г.
    Последнее сообщение: 11.06.2005, 20:07
