Дергает машину при нагрузке,VAG com чето о бензонасосе говорит
    Украина, Киев
    Печаль Дергает машину при нагрузке,VAG com чето о бензонасосе говорит
    Подергивает 1,8t awt 2004 мех 220000 ,особенно на невысоких оборотах при разгоне, на хх ровно работает.
    Monday,19,March,2012,17:52:53:60804
    VCDS Version: Release 10.6.0
    Data version: 20100630
    Chassis Type: 3B - VW Passat B5
    Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
    VIN: WVWZZZ3BZ4E263964 Mileage: 220720km/137149miles
    Address 01: Engine Labels: 06B-906-018-AWT.lbl
    Part No: 4B0 906 018 DJ
    Component: 1.8L R4/5VT 0002
    Coding: 26001
    Shop #: WSC 00270
    VCID: 6CDC414636E3
    WVWZZZ3BZ4E263964 VWZ7Z0D9135494
    1 Fault Found:
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
    Part No: 8E0 614 111 B
    Component: ABS/EDS 5.3 FRONT D10
    Shop #: BB 24332
    VCID: 1D3A5C82BDD9
    No fault code found.
    Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
    Part No: 3B1 907 044 J
    Component: CLIMATRONIC B5GP 0006
    Coding: 17000
    Shop #: WSC 05311
    VCID: 28547D56E29B
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 601 A
    Component: 14 AIRBAG VW51 0008
    Coding: 12596
    Shop #: WSC 05311
    VCID: 1E385B8EB0DF
    Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
    Part No: 3B0 920 829
    Component: KOMBI+WEGFAHRSP VDO V04
    Coding: 05125
    Shop #: WSC 00000
    VCID: E3CEAA7A5B3D
    2 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    49-10 - No Communications - Intermittent
    00476 - Control Module for Fuel Pump (J538)
    49-00 - No Communications
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00004
    Shop #: WSC 05311
    VCID: F0E4D5369ACB
    3 Faults Found:
    00463 - Control Module for Digital Sound Package (J525)
    Address 46: Central Conv. Labels: 1C0-959-799.lbl
    Part No: 1C0 959 799 B
    Component: 03 Komfortgerбt HLO 0003
    Coding: 00259
    Shop #: WSC 05311
    VCID: 3668A32E382F
    Part No: 1C1959801
    Component: 03 Tхrsteuer.FS KLO 0202
    Part No: 1C1959802
    Component: 03 Tхrsteuer.BF KLO 0202
    Part No: 1C0959811
    Component: 03 Tхrsteuer.HL KLO 0202
    Part No: 1C0959812
    Component: 03 Tхrsteuer.HR KLO 0202
    6 Faults Found:
    53-10 - Supply Voltage Too Low - Intermittent
    01336 - Data Bus for Comfort System
    37-00 - Faulty
    00950 - Central Locking Motor - tailgate (V53); UNLOCK
    25-10 - Unknown Switch Condition - Intermittent
    01131 - Control Circuit for Turn Signals
    00953 - Interior Light Time limit
    00928 - Locking Module for Central Locking; Front Driver Side (F220)
    27-10 - Implausible Signal - Intermittent
    End ---------------------------------------------------------------------
    Получено: 6,744
    Отправлено: 4,720
    edwiin, для начала нужны данные 032 группы + логи. идеально - сделать замер давления топлива под нагрузкой. в ошибках нет ничего связанного с описываемыми симптомами.
    Украина, Киев
    Понял.Спасибо
    Получено: 6,744
    Отправлено: 4,720
    Coding: 00004
    Shop #: WSC 05311
    VCID: F0E4D5369ACB
    3 Faults Found:
    сюда не смотри. это либо программный глюк либо неправильная кодировка шлюза.
  1. Ответов: 7
    Последнее сообщение: 23.02.2011, 22:43
  2. Ответов: 23
    Последнее сообщение: 04.02.2011, 23:53
  3. Ответов: 2
    Последнее сообщение: 23.12.2008, 20:00
  4. Можно ли при помощи VAG-COM...?
    от mazepa в разделе Архив 2008г.
    Последнее сообщение: 10.11.2008, 14:49
  5. Как изменить обороты Х/Х при помощи VAG-COM
    от bumblebee в разделе Архив 2007г.
    Ответов: 25
    Последнее сообщение: 26.06.2007, 14:13
