Адаптация, кодирование VAG com для B6
    Golf Аватар для 3D_max
    Сургут
    Получено: 19
    По умолчанию Адаптация, кодирование VAG com для B6
    Создадим общую тему для этого дела с информативным первым постом? или уже было?
    мне например интересно можно ли в приборку вывести значение текущей температуры ОЖ или масла?
    RNS-510
    Byte 00 Radio Configuration I
    Bit 1 External CD Changer Connection active
    Bit 3 Parking Aid Monitoring inactive (Standard)
    Byte 01 Sound System Correction
    00 Sound System not installed
    01 Volkswagen Sound System
    02 Skoda Sound System
    05 Dynaudio Sound System
    Byte 02 Speaker Channels
    00 Sound System (active Speakers)
    02 2 Speaker Channels (Front only)
    04 4 Speaker Channels (Front and Rear)
    Byte 03 Radio Configuration II
    Bit 1 Microphone Diagnostics active (Japan/China only)
    Byte 04 Treble Speaker Monitoring
    01 Monitoring inactive
    02 Front Monitoring active / Rear Monitoring inactive
    04 Front and Rear Monitoring active
    Byte 05 Vehicle Specific Frequency Response
    00 Volkswagen/Skoda (all)
    01 Seat Altea (5P)
    02 Seat Leon (1P)
    03 Seat Toledo (5P)
    04 Seat Altea XL (5P)
    Byte 06 Radio Configuration III
    00 Standard/Not Relevant
    Byte 07 Navigation System Configuration I
    Bit 0 Multifunction Steering Wheel with Shortpress Buttons installed
    Bit 1 Voice Control inactive (NOT Japan/China)
    Bit 2 Speed Threshold for Destination Input active
    Bit 3 Speed Threshold for Speech Destination Input active
    Bit 4+5 Display Variant
    Byte 08 Navigation System Configuration II
    Есть еще такое, с картинками
    RNS 510 CODING
    At first, you should connect your laptop to the ECU (Electronic Control Unit) of the car using vag-com cable. The key must be in the ignition and in ON position.
    Then you should run vcds program. The very first time of running VCDS, be sure to go to "Options" menu and input a workshop code into the appropriate field or else the program won't let you make changes.
    Select the "Control Module" option and afterwards select "37-Navigation".
    Press the "Coding - 07" button.
    Afterwards select "Long Coding Helper".
    You choose nothing at the byte 0.
    At the first byte you choose "Sound System not installed" from the list box unless you have an amplifier.
    At the third byte you should check bit 1 "Microphone diagnostics active" if there is an installed microphone.
    At byte 4 select "Speaker Monitoring: Front and Rear active".
    At byte 5 select "Equalization: Linear".
    At byte 7, uncheck bit 1 if you an installed microphone.
    The bits 4-5 of byte 7 are responsible for the skin of RNS-510.
    The bit 7 of byte 7 (BAP) must be unchecked if the FIS display of the car is red.
    Finally, click on "Exit" and then click on "Do it". The message "Coding is accepted" will pop up.
    Для RCD-510
    кодировки и адаптации:
    1)
    long coding
    ; (Radio Configuration I)
    LC,00,1,CD-Changer/iPod/USB Connection Monitoring active
    LC,00,2,AUX-Input Connection Monitoring active
    LC,00,3,Parking Aid/Park SteerAssist Monitoring inactive
    ; (Sound System Correction)
    LC,01,0~7,00,Sound System not installed
    LC,01,0~7,01,Volkswagen Sound System
    LC,01,0~7,02,Skoda Sound System (CAN DSP)
    LC,01,0~7,05,Dynaudio Sound System
    LC,01,0~7,06,Volkswagen Sound System (BAP DSP)
    LC,01,0~7,07,Dynaudio Sound System (BAP DSP)
    ; (Speaker Channels)
    LC,02,0~7,00,Sound System (active Speakers)
    LC,02,0~7,02,2 Speaker Channels (Front only)
    LC,02,0~7,04,4 Speaker Channels (Front and Rear)
    ; (Radio Configuration II)
    LC,03,1,Microphone Diagnostics active
    LC,03,6,Back-Up Camera Low (without Control Module) installed
    ; (Treble Speaker Monitoring)
    LC,04,0~7,00,Not coded
    LC,04,0~7,01,Speaker Monitoring: inactive (Sound System)
    LC,04,0~7,02,Speaker Monitoring: Front active / Rear inactive
    LC,04,0~7,03,Speaker Monitoring: Front inactive / Rear active
    LC,04,0~7,04,Speaker Monitoring: Front and Rear active
    ; (Vehicle Specific Equalization)
    LC,05,0~7,00,Equalization: Linear
    LC,05,0~7,01,Equalization: Seat Altea (5P) / Skoda Octavia (1Z)
    LC,05,0~7,02,Equalization: Seat Leon (1P)
    LC,05,0~7,03,Equalization: Seat Toledo (5P)
    LC,05,0~7,04,Equalization: Seat Altea XL (5P) / Skoda Superb (3T)
    ; (Radio Configuration III)
    ; Byte 06 only for Audi
    ; (Navigation System Configuration I)
    LC,07,0,Shortpress Steering Wheel Buttons installed
    LC,07,1,Voice Control inactive
    LC,07,2,Speed Threshold for Destination Input active
    LC,07,3,Speed Threshold for Speech Destination Input active
    LC,07,4~5,00,Display Variant: Highline
    LC,07,4~5,10,Display Variant: Sportsline
    LC,07,4~5,20,Display Variant: Premium
    LC,07,7,Communication Instrument Cluster via Operation and Display Protocol (BAP)
    ; Byte 07 Bit 7: 0 = Display Data Protocol (DDP) / 1 = Operation and Display Protocol (BAP)
    ; (Navigation System Configuration II)
    LC,08,4,Logo Company FAW (ONLY Japan/China)
    перевод:
    Радио конфигурации I)
    LC, 00, 1, CD-чейнджер/iPod/USB подключение, мониторинг активных
    LC, 00, 2, AUX-ввод связи мониторинг активных
    LC, 00, 3, парковка помощи/парк SteerAssist мониторинг неактивные
    ; (Звуковая система коррекции)
    LC, 01, 0 ~ 7, 00, не установлена звуковая система
    LC, 01, 0 ~ 7, 01, Volkswagen звуковая система
    LC, 01, 0 ~ 7, 02, Skoda звуковая система (может DSP)
    LC, 01, 0 ~ 7, 05, Dynaudio звуковая система
    LC, 01, 0 ~ 7, 06, Volkswagen звуковая система (BAP DSP)
    LC, 01, 0 ~ 7, 07, Dynaudio звуковая система (BAP DSP)
    ; (Спикер каналов)
    LC, 02, 0 ~ 7, 00, звуковая система (активные носителей)
    LC, 02, 0 ~ 7, 02, 2 динамика каналов (только фронт)
    LC, 02, 0 ~ 7, 04, 4 оратор каналов (передние и задние)
    ; (Конфигурация II радио)
    LC, 03, 1, микрофон Диагностика активных
    LC, 03, 6, Back-Up камеры низкой (без модуля управления) установлен
    ; (Мониторинг ВЧ динамик)
    LC, 04, 0 ~ 7, 00, не закодирован
    LC, 04, 0 ~ 7, 01, спикер мониторинг: неактивных (звук система)
    LC, 04, 0 ~ 7, 02, спикер мониторинг: передние активные / задние неактивные
    LC, 04, 0 ~ 7, 03, спикер мониторинг: фронт неактивных / задних активных
    LC, 04, 0 ~ 7, 04, спикер мониторинг: спереди и сзади активных
    ; (Автомобиль конкретных уравнения)
    LC, 05, 0 ~ 7, 00, равных: линейный
    LC, 05, 0 ~ 7, 01, равных: место Altea (5 P) / Шкода Октавия (1Z)
    LC, 05, 0 ~ 7, 02, равных: Seat Leon (1 P)
    LC, 05, 0 ~ 7, 03, равных: место Толедо (5 П)
    LC, 05, 0 ~ 7, 04, равных: место Altea XL (5 P) / Skoda Superb (3Т)
    ; (Конфигурация III радио)
    ; Байт 06 только для Audi
    ; (Настройки системы навигации I)
    LC, 07, 0, Shortpress рулевое колесо кнопки установить
    LC, 07, 1, неактивные управления голосом
    LC, 07, 2, порог скорости для назначения вклада активного
    LC, 07, 3, порог скорости речи назначения ввода активного
    LC, 07, 4 ~ 5, 00, вариант отображения: Хайлайн
    LC, 07, 4 ~ 5, 10, вариант отображения: Sportsline
    LC, 07, 4 ~ 5, 20, вариант отображения: премиум
    LC, 07, 7, кластер инструмент коммуникации через операции и отображения протокол (БаП)
    ; Байт 07 бит 7: 0 = отображения данных протокол (НВУ) / 1 = операция и отображения протокол (БаП)
    ; (Навигационной системы конфигурация II)
    LC, 08, 4, логотип компании FAW (только Япония/Китай
    2)
    adaptation
    A010,0,Remote Control
    A010,5,Remote Control
    A010,6,0 = Playback disabled
    A010,7,1 = Playback enabled
    A010,8,
    A010,9,Note: After closing the Diagnostic Session/Communication
    A010,10,the Standard Value 0 is automatically being restored.
    A011,0,Remote Control: Source
    A011,5,Remote Control: Source
    A011,6,0 = FM
    A011,7,1 = AM
    A011,8,
    A011,9,Note: After closing the Diagnostic Session/Communication
    A011,10,the Standard Value 0 is automatically being restored.
    A012,0,Remote Control: Frequency FM
    A012,5,Remote Control: Frequency FM
    A012,6,The Frequency Adjustment is being carried out
    A012,7,incrementally starting with 0 = 88.3 MHz.
    A012,8,
    A012,9,Note: After closing the Diagnostic Session/Communication
    A012,10,the Standard Value 0 is automatically being restored.
    A013,0,Remote Control: Frequency AM
    A013,1,Remote Control: Frequency AM
    A013,6,The Frequency Adjustment is being carried out
    A013,7,incrementally starting with 0 = 540 kHz.
    A013,8,
    A013,9,Note: After closing the Diagnostic Session/Communication
    A013,10,the Standard Value 0 is automatically being restored.
    A014,0,Remote Control: Volume
    A014,5,Remote Control: Volume
    A014,6,Range: 0...100
    A014,7,Standard: 40
    A014,8,
    A014,9,Note: After closing the Diagnostic Session/Communication
    A014,10,the Standard Value 0 is automatically being restored.
    A015,0,Remote Control: Balance
    A015,5,Remote Control: Balance
    A015,6,Note: After closing the Diagnostic Session/Communication
    A015,7,the Standard Value 0 is automatically being restored.
    A016,0,Remote Control: Fader
    A016,1,Remote Control: Fader
    A016,6,Note: After closing the Diagnostic Session/Communication
    A016,7,the Standard Value 0 is automatically being restored.
    Замена задних колодок
    53 блок -> базовые настройки 04 -> выбираем группу 007 -> жмем выполнить - колодки развелись (можно менять)
    53 блок -> базовые настройки 04 -> выбираем группу 006 -> жмем выполнить - колодки подвелись к диску
    53 блок -> базовые настройки 04 -> выбираем группу 010 -> жмем выполнить - производится адаптация колодок
    17 блок - Комбинация приборов
    Изменение сервисного интервала
    17 блок -> Адаптация -10 -> канал 50 -> ставим необходимое значение из расчета 100=10000 км
    17 блок -> Адаптация -10 -> канал 51 -> ставим необходимое количество дней до прохрождения ТО
    19 блок - Диагностический интерфейс шин данных
    При установке новых устройств необходимо прописать их в Гейтвее
    19 блок -> Кодирование - 07 -> отметить все необходимое галочками
    37 блок - Навигационная система
    Изменение кода региона DVD
    37 блок -> Адаптация - 10 -> Канал:
    130 - Регион DVD
    Значения:
    0 - Все регионы
    1 - Канада, США
    2 - Западная Европа, Западная Азия, Египет, Япония, Южная Африка, Швейцария, Британские острова, Франция
    3 - Южная Азия, Южная Корея, Гон Конг
    4 - Центральная и южная Америка, Карибы, Мексика
    5 - Востояная Европа, Африка, Центральная и Южная Азия, Монголия, Северная Корея, Россия
    6 - Китай
    46 блок - Центральный модуль систем комфорта
    Комфортное закрытие стекол при закрытии машины (не удерживая кнопку закрытия и только для авто оснащенных сигнализацией Plus)
    46 блок -> Кодирование - 7 -> Длинное кодирование -> заходим в 6 байт активируем 1,2,3,6 биты, заходим в 7 байт активируем 1,4,5,6 и если люк заходим в 8 байт и отмечаем 3,4,5 биты
    Подтверждение закрытия/открытия авто через хорн
    46 блок -> Кодирование - 7 -> Длинное кодирование -> заходим в 10 байт активируем 3й бит, заходим в 11 байт активируем 3й бит
    далее заходим в Адаптация - 10 -> выбираем 07 канал -> жмем прочитать -> в окошке Новое значение прописываем 3 -> Тест - > Сохранить
    далее заходим в Адаптация - 10 -> выбираем 10 канал -> жмем прочитать -> в окошке Новое значение прописываем 3 -> Тест - > Сохранить
    Отключение центральных габаритов в задних фонарях
    09 блок -> Кодирование - 7 -> Длинное кодирование -> в 9 байте прописать все нули
    Кодировка блока 3С0-937-049-30H:
    Байт 0
    LC, 00, 1, ПТФ установлены
    LC, 00, 1, ксеноновые фары со шторкой установлен
    LC, 00, 2, освещение ног установлено
    LC, 00, 3, дневные ходовые огни (Скандинавия) активация
    LC, 00, 4, дневные ходовые огни(Северная Америка)
    LC, 00, 5, подмигивание дальним светом и путь к дому активны
    LC, 00, 6, дождь- / свет установлен датчик
    LC, 00, 7, путь к дому - активно
    Байт1
    LC, 01, 0, нахождение на задних сиденьях установлено
    LC, 01, 1, омыватель фар установлен
    LC, 01, 2, реле бензонасоса установлено
    LC, 01, 3, Задний стеклоочиститель установлен
    LC, 01, 7, Задний и передний стеклоочистители постоянно активные
    Байт 2
    LC, 02, 0, Задний и передний стеклоочистители периодически активные
    LC, 02, 1, сигналы поворота комфорт
    LC, 02, 2, холодная диагностика ламп активна
    LC, 02, 3, нагрузки управления активным
    LC, 02, 4, Путь к дому режим через (0 = персонально / 1 = датчик света)
    LC, 02, 6, бортовые огни поворота установлен
    LC, 02, 7, обогрев сидений установлен
    Байт3
    LC, 03, 0, зависимость от положения ключа зажигания установлена
    LC, 03, 1, задние противотуманные фонари (0 = 2 Задних противотуманных фонаря / 1 = 1 задний противотуманный фонарь)
    LC, 03, 2, фонари заднего хода (0 = 2 фонаря / 1 = 1 фонарь)
    LC, 03, 3, выключение фонарей заднего хода при открытии задней крышки
    LC, 03, 4, ксеноновые фары без шторки установлены (Би-ксеноновые)
    LC, 03, 5, распылитель для заднего окна активен
    LC, 03, 6, 2-ая батарея установлена
    Байт4
    LC, 04, 0, установка дополнительного обогревателя
    LC, 04, 4, активация обоих задних противотуманных фар
    LC, 04, 6, задние противотуманные фонари отключены
    LC, 04, 7, реле деформации установлено
    Байт5
    LC, 05, 0-7,50, Фаромыватель задержка
    LC, 05, 0-7,50, десятичное значение (разрешение 50 мс) (пример: 20-20 x 50 = 1000 мс)
    Байт6
    LC, 06, 0-7,50, время активации омывателя фар
    LC, 06, 0-7,50, десятичное значение (разрешение 50 мс) (пример: 16-16 x 50 = 800 МС)
    Байт7
    LC, 07, 0-7,1, поворотники передние левый/правый ,как парковочный свет левый/правый (США и Канада)
    LC, 07, 0-7,1, десятичное значение (разрешение: 1%)
    Байт8
    LC, 08, 0, деактивация обогрева сидений с активацией транспортного режима
    LC, 08, 1, деактивация дневного света (DRL) с активацией транспортного режима
    LC, 08, 2, деактивация освещения ног с активацией транспортного режима
    LC, 08, 3, Interlock отображения через CAN-инструменты активно
    LC, 08, 4, салонный свет от открытия задней крышки активен
    LC, 08, 6,деактивация задних ПТФ при движении с прицепом активно
    LC, 08, 7, деактивация дневного света (DRL) во время работы аварийки
    Байт9
    LC, 09, 0-7,1, фонарь тормоза , как парковкочный свет
    LC, 09, 0-7,1, десятичное значение (разрешение: 1%)
    Байт10
    LC, 10, 0-7,1, задние ПТФ ,как парковочный свет
    LC, 10, 0-7,1, десятичное значение (разрешение: 1%)
    Байт11
    LC, 11, 0-7,1, затемнение передних парковочных огней
    LC, 11, 0-7,1, десятичное значение (разрешение: 1%)
    Байт12
    LC, 12, 0-7,1, затемнение задних парковочных огней
    LC, 12, 0-7,1, десятичное значение (разрешение: 1%)
    Байт13
    LC, 13, 0-7,1, функция резерва: Задние сигналы поворота , как парковочный свет/фонарь тормоза
    LC, 13, 0-7,1, десятичное значение (разрешение: 1%)
    Байт14
    LC, 14, 0-7,1, функция резерва : Передние парковочные огни, как поворотники
    LC, 14, 0-7,1, десятичное значение (разрешение: 1%)
    Байт15
    LC, 15, 0-7,1, функция резерва: Задние парковкочные огни, как поворотники
    LC, 15, 0-7,1, десятичное значение (разрешение: 1%)
    Байт16
    LC, 16, 0-7,1, функция резерва: Передние ПТФ, как фары ближнего света
    LC, 16, 0-7,1, десятичное значение (разрешение 1%)
    Байт17
    LC, 17, 0, активация стоп сигналов ,как аварийка
    LC, 17, 1, деактивация подмигивания дальним светом с Биксеноновыми фарами
    LC, 17, 2, подогрев лобового стекла установка
    LC, 17, 3, активация диагностики без ключа зажигания
    LC, 17, 4, дневного света через противотуманные фонари
    LC, 17, 5, деактивация ПТФ с дальним светом
    LC, 17, 6, функция парковки света деативация (США/Канада)
    Байт18
    LC, 18, 0, холодная диагностика номерных огней активация
    LC, 18, 1, холодная диагностика тормозных огней активация
    LC, 18, 2, холодная диагностика передних противотуманных фонарей активация
    LC, 18, 3, холодная диагностика задних противотуманных фонарей активация
    LC, 18, 4, холодная диагностика дальнего света активация
    LC, 18, 5, холодная диагностика поворотников активация
    LC, 18, 6, холодная диагностика огней заднего хода активация
    LC, 18, 7, холодная диагностика боковых поворотников активация
    Байт19
    LC, 19, 0, холодная диагностика ламп ближнего света активация
    LC, 19, 1, холодная диагностика передних парковочных огней активация
    LC, 19, 2, холодная диагностика задних парковочных огней активация
    LC, 19, 3, диагностика задних парковочных огней активация
    LC, 19, 6, электрический стояночный тормоз установка
    Байт20
    LC, 20, 0-7,1, дневных ходовых огней затемнение
    LC, 20, 0-7,1, десятичное значение (разрешение: 1%)
    Байт21
    LC, 21, 4, задние ПТФ, как тормоз
    LC, 21, 6, оставление дома -вариант (0 = LH в LDS / 1 = не LH в LDS)
    LC, 21, 7, ближний свет всегда активный
    Байт22
    LC, 22, 0, персонализация (0 = вариант 1 / 1 = вариант 2).
    LC, 22, 2, деактивация стоп сигнала на задние ПТФ активация
    LC, 22, 3, Speed dependant Trunk Locking активация
    LC, 22, 4, скорость зависит от ствола блокировки активных
    LC, 22, 5, "свет & & зрение" меню неактивны
    LC, 22, 6, парковочные огни сзади ,как аварийка активация (Северная Америка)
    LC, 22, 7, диагностика тормозных огней неактивна (Северная Америка)
    Байт23
    LC, 23, 0, ксеноновые фары, неоднократно зажигания активация
    LC, 23, 1, формат обмена данными активация
    LC, 23, 2, алгоритм внутренней индикации поворотников активация
    LC, 23, 3 ~ 4, 00, включить огни не активен
    LC, 23, 3 ~ 4, 08, поворотники посредством ПТФ
    LC, 23, 3 ~ 4, 10, поворотники посредством дальнего света
    LC, 23, 3 ~ 4, 18, поворотники посредством шторку ксенон
    LC, 23, 5, Путь к дому логика (0 = старый / 1 = новый); long coding
    B6 2.0 FSI BVX 2007 6МКПП 4 motion
    Получено: 356
    Отправлено: 64
    Вопрос снят
    Никак не вывести.
    Сургут
    Получено: 19
    Ну и где?
    буду добавлять)
    Получено: 647
    Отправлено: 528
    COOLLER, САХАрный тут просил тебе передать ...
    Игорян напиша в теме про Адаптацию Фанекулеру что у меня приборка показывает температуру масла)))
    пусть его изжога ест))
    Kimi, передай ему, что он лузер. Он в бане с датчиком масла, а я на свободе
    САХА
    Получено: 647
    Отправлено: 528
    COOLLER, он прочитал
    Kimi, эспумизан ему передать?
    Polo Аватар для BoBaH
    Россия, Ростов-на-Дону
    Отправлено: 10
    парни, так на сколько я знаю, температура масла на рпиборку у всех выводится с конца 2009 года... или я не прав? т.е. зависит от типа приборки...
    Зато вот меня очень сильно волнует вопрос борьбы с омывателями фар. Находил много сообщений, о. том, что можно настроить в адаптации можно
    1) выставить длительность нажатия, после которой будут срабатывать омыватели. - у меня этого нет
    2) кол-во раз, после которых срабатывает омаватель фар ( по дефолту каждое 5 нажатие) - тоже нет у мну такого в адаптациии.
    3) Нашел только длительность работы омывателя, которая влияет по сути только на ко-во прокачиваемой жижи.
    такая вот фигня. Кто на авто начала 2010 г. настраивал подобную фигню, поделитесь опытом
    Golf IV, 2002 г.в. 1.8Т AUM, МКПП - радует нового владельца
    Passat B6, 2 TDI CBBB, 6МКПП, 2010г. Синий сарай в R-line by GutenVaG
    Россия, Москва ЮАО
    Получено: 643
    Отправлено: 171
    Никак не вывести.
    Температура масла выводится на белых приборках.
    СС 2009 2.0 TDI (CBAB), DSG
    Вне форума - Сергей.
    Получено: 601
    Отправлено: 460
    Классная тема чО еще можно интересного активировать?
    Получено: 356
    Отправлено: 64
    Bond178, а чО нужно?
    Россия, Москва ЮАО
    Получено: 643
    Отправлено: 171
    Запирание дверей с ключа при работающем двигателе
    46 блок кодирование, длинн. Кодирование, 13 байт . 1 бит поставить галочку.
    Сам не проверял.
    У меня белая, нет температуры масла.
    У Тохи тоже белая и тоже нет температуры.
    Получено: 601
    Отправлено: 460
    а чО нужно?
    да х.з. чо есть в более дорогой комплектации, того чего нет у меня и, что можно прописать.....
    Получено: 356
    Отправлено: 64
    х.з.
    означает ничО
    Получено: 601
    Отправлено: 460
    означает ничО
    вот это заинтересовало но где посмотреть какая у меня сигн?
    сигнализацией Plus
    Россия, Москва ЮАО
    Получено: 643
    Отправлено: 171
    http://www.youtube.com/watch?feature...AZ-AHGzlc#t=12
    может надо галочку в настройках поставить?
    Вот возвращался из РБ. Температура +3 за бортом. Температура масла при скорости вне населенки около 100 91-93 градуса...
    Нет там такой галочки
  1. Продам Продам шнур VAG-COM для Passat B5
    от kirycha в разделе Куплю-Продам Прочее
    Последнее сообщение: 31.07.2013, 09:44
  2. нужна помощь человека с VAG COM для b6
    от PAvl1k в разделе VW Passat B6/CC
    Последнее сообщение: 06.12.2010, 21:32
  3. адаптация брелка. Vag Com
    от Omnium в разделе Архив 2010г.
    Последнее сообщение: 16.06.2010, 12:02
  4. VAG COM для КПК
    от Воин551 в разделе Архив 2010г.
    Последнее сообщение: 21.03.2010, 13:47
  5. Ответов: 2
    Последнее сообщение: 15.09.2008, 11:24
