05.09.2011, 12:25 #6041
- 21.04.2011
- 14
спасибо! попробую! )) тока я еще не знаю как!
05.09.2011, 12:33 #6042
- 16.07.2011
- Зеленоград
- 180
Спасибо: Получено: 1
05.09.2011, 19:55 #6043
- 07.07.2011
- Казахстан, г.Атырау
- 43
- 380
- Записей в дневнике
- 1
Спасибо: Получено: 8
Отправлено: 61
0Доброго времени суток!
Сделал диагностику ВАГ-КОМОМ - вот что выдало:
VAG-COM Version: Release 311.2-N
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58,76,77
Address 01 -------------------------------------------------------
Controller: 071 906 018 P
Component: MOTRONIC M3.8.3 HS V04
Coding: 00000
Shop #: WSC 05311
4 Faults Found:
00525 - Oxygen Sensor (G39)
27-00 - Implausible Signal
00553 - Mass Air Flow Sensor (G70)
31-10 - Open or Short to Ground - Intermittent
00527 - Intake Manifold Temperature Sensor (G72)
29-10 - Short to Ground - Intermittent
00522 - Engine Coolant Temperature Sensor (G62)
Readiness: 0000 1001
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 B
Component: ABS/EDS 5.3 FRONT D00
Coding: 0273004283
Shop #: BB 24332
1 Fault Found:
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 B
Component: CLIMATRONIC V 1.0.0
Coding: 05000
Shop #: WSC 05311
2 Faults Found:
01206 - Signal for Duration of Ignition: OFF
35-10 - - - Intermittent
00281 - Vehicle Speed Sensor (G68)
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AH
Component: 3C Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 05311
7 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
01134 - Alarm Horn (H12)
01131 - Control Circuit for Turn Signals
00928 - Locking Module for Central Locking: Front Driver Side (F220)
00913 - Window Regulator Switch: Front Right Driver (E81)
27-10 - Implausible Signal - Intermittent
00944 - Heated Exterior Mirror: Passenger Side (Z5)
35-00 - -
00931 - Locking Module for Central Locking: Rear Right (F223)
End -------------------------------------------------------
Ошибки потер, буду кататься дальше - но по лямбде каждый раз вылазит (не первый раз делаю диагностику уже)
Потом, чтобы посмотреть всякие аддитивы и мультипликативы и прочее смесеобразование, какие тесты нужно провести и вообще на что обратить внимание? Подскажите пожалуйста, уважаемые гуру! Заранее весьма благодарен!VW Passat 3B5 Variant 1999, AGZ VR5 2,3л, МКПП
06.09.2011, 08:27 #6044targitayГость
0Dilandau, по ЛЗ прочитай мой пост №6032...
06.09.2011, 09:00 #6045
- 07.07.2011
- 43
- 380
- 1
Отправлено: 61
0targitay, спасибо, прочитал, распечатал, буду пробовать. А по всему остальному не подскажешь пожалуйста?
06.09.2011, 09:07 #6046targitayГость
06.09.2011, 11:47 #6047
0Добрый день, вчера делал диагностику Vag com, chek на приборке не горит а ошибку в компе выдаёт 16804 p0420 ряд 1, система катализаторов, снижение эффективности. Это значит что катализатор скоро умрёт?...........
VW Passat 2002 1.8T 170 p.s. AWM АКПП
06.09.2011, 12:27 #6048
- 19.02.2009
- Россия, Санкт-Петербург
- 45
- 6,280
Спасибо: Получено: 355
Отправлено: 64
0b.aleksei039, это значит, что эффективность его работы снижена и он выбрасывает в атмосферу больше вредных веществ чем должен.
06.09.2011, 13:08 #6049
0спасибо!
06.09.2011, 14:29 #6050
- 06.09.2011
- 40
- 357
Спасибо: Получено: 2
0доброе время суток.
вот ошибки по сканеру. уже повторные. первые были такие же. между сканами было около 200 км.
Address 01: Engine Labels: None
Part No: 8D0 906 018 G
Component: 1.8L R4/5V MOTR 0005
Coding: 05531
Shop #: WSC 01523
VCID: 2B5E05F2B55F2644
5 Faults Found
18001 - Altitude Adaptation: Signal Out of Tolerance
P1593 - 35-00 - -
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 35-10 - - - Intermittent
17535 - Fuel Trim; Bank 1 (Mult): System too Rich
P1127 - 35-00 - -
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-00 - -
Readiness: 0000 0000
Address 02: Auto Trans Labels: None
Part No: 01N 927 733 ED
Component: AG4 Getriebe 01N 4533
Coding: 00000
Shop #: WSC 00000
VCID: 77F6E982399752A4
1 Fault Found
01192 - Torque Converter Lock-Up Clutch
04-10 - Mechanical Malfunction - Intermittent
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 D
Component: ABS/ESP front D36
Coding: 04177
Shop #: WSC 00028
VCID: 346C1E8E686179BC
1 Fault Found
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 D
Component: CLIMATRONIC D2.1
Coding: 05000
Shop #: WSC 00028
VCID: 2240E8D6C295E70C
1 Fault Found
00792 - A/C Pressure Switch (F129)
35-00 - -
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 B
Component: 03 AIRBAG VW5 0004
Coding: 12339
Shop #: WSC 00028
VCID: 366824867E1D6BAC
No fault code found.
Address 17: Instruments Labels: 3B0-920-xx2-17.lbl
Part No: 3B0 920 822
Component: B5-KOMBIINSTR. VDO V25
Coding: 05145
Shop #: WSC 64980
VCID: DCBC162E207111FC
Part No: IMMO
Component: IDENTNR: VWZ7Z0X2170407
IMMO-IDENTNR: VWZ7Z0X2170407
2 Faults Found
00779 - Outside Air Temp Sensor (G17)
30-10 - Open or Short to Plus - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00005
Shop #: WSC 00028
VCID: F0E4529EDCF9859C
1 Fault Found
01044 - Control Module Incorrectly Coded
35-00 - -
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Coding: 04097
Shop #: WSC 00028
VCID: 840C0E4EF841893C
Part No: 1J1959801D
Component: 3C Tхrsteuerger. FS0002r
Part No: 1J1959802E
Component: 3C Tхrsteuerger. BF0002B
Part No: 1J4959811D
Component: 3C Tхrsteuerger. HL0002H
Part No: 1J4959812D
Component: 3C Tхrsteuerger. HR0002r
3 Faults Found
00953 - Interior Light Time limit
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00913 - Window Regulator Switch; Front Right Driver (E81)
End ---------------------------------------------------------------------
06.09.2011, 14:53 #6051targitayГость
0bobster, а что за автомобиль то?
Чей то сил не хватает угадать Видать никудышный из меня экстрасенс...
06.09.2011, 15:24 #6052
- 06.09.2011
- 40
- 357
0Volkswagen Passat 1.8 AКПП ARG 125лс 2000г
06.09.2011, 15:57 #6053targitayГость
0делать опрессовку; проверять ДМРВ под нагрузкой; проверять полностью топливоподачу; лямбды.
снимал клемму с аккумулятора или он разряжен.
Вполне возможно из-за сдохшего ДМРВ
проверь давление в контуре климатической установки
проверяй проводку к датчику наружного воздуха
Я бы смотрел проводку...
P.S. А как ошибки сбрасывал?
06.09.2011, 16:13 #6054
- 06.09.2011
- 40
- 357
0"делать опрессовку; проверять ДМРВ под нагрузкой; проверять полностью топливоподачу; лямбды." - ДМРВ заменил на новый но стало работать еще хуже, вот и решил сканировать машину. буду менять назад посмотрим что будет
"снимал клемму с аккумулятора или он разряжен." - клемму снимал когда менял ДМРВ, но думаю зарядка не помещает
"проверь давление в контуре климатической установки" - кондера нет, поршень заклинил. жду новый из за бугра
"проверяй проводку к датчику наружного воздуха" - к датчику ДМРВ?
"Я бы смотрел проводку..." - зеркало и ЦЗ время от времени зависают, но это уже второстепенные цели.
спасибо за то что разжевал. примерно стало понятнее
06.09.2011, 17:20 #6055
06.09.2011, 20:19 #6056
- 20.02.2011
- нижний новгород
- 45
- 286
Отправлено: 12
0здравствуйте!подскажите выдает ошибку 0456 и 0300?
пассик 1.8т автомат AWM 2002г.VIN:WVWPD63B63P260854 ауди а4 2.0 тdi автомат CAGA 2009г.VIN:WAUZZZ8K89N032344
06.09.2011, 20:47 #6057
- 16.12.2007
- 36
- 61
0всем привет! подскажите пожалуйста как вылечить 02403 00778 00576 16352 03200
Суббота,06,Август,2011,20:46:54:10074
VCDS Версия: Beta 11.2.0
Адрес 53: Стояночный тормоз Label: 5N0-907-801.lbl
Номер блока управления: 3C0 907 801 J HW: 3C0 907 801 J
Компонент и/или версия: J540 EPB3 VW-09393 0009
Кодировка: 0000056
Код мастерской: WSC 00028 028 00001
VCID: 295DF997FB39
2 Найдены неисправности:
03200 - Switch for Electric Parking Brake (E538)
012 - Electrical Fault in Circuit - Индикатор неисправности ВКЛ
Стоп-кадр:
Статус неисправности: 11101100
Приоритет неисправности: 1
Частота неисправности: 1
Сброс счетчика: 166
Пробег: 175405 km
Отсчет времени: 0
Стоп-кадр:
Напряжение: 11.90 V
Счет: 10
Скорость: 0.0 km/h
Hex значение: 0x1270
Hex значение: 0x0001
Hex значение: 0x0101
16352 - Control Module - Electrical Error
014 - Defective - Индикатор неисправности ВКЛ
Стоп-кадр:
Статус неисправности: 11101110
Сброс счетчика: 166
Пробег: 175405 km
Отсчет времени: 0
Стоп-кадр:
Напряжение: 11.90 V
Счет: 42
Скорость: 0.0 km/h
Hex значение: 0x1260
06.09.2011, 20:49 #6058
- 01.02.2006
- Великий Новгород
- 61
- 8,001
- 3
Спасибо: Получено: 815
Отправлено: 1,013
16840/P0456/001110 - EVAP System: Very Small Leak Detected
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Fuel Cap not fully attached
Evaporative Emission (EVAP) System leaking/faulty
Possible Solutions
Check Fuel Cap
Check Evaporative Emission (EVAP) System16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
Possible Causes
Air Intake System leaking
Fuel Supply faulty
Injector(s) faulty
Ignition Cable(s) and/or Spark Plug(s) faulty
Ignition Coil(s) faulty
Exhaust Gas Recirculation (EGR) Valve (N18) stuck/open
Camshaft Position Sensor (G40) faulty
Possible Solutions
Check Misfire Recognition
Check Air Intake System
Check Fuel Supply
Check Injector(s) and Injector Sealing
Check Ignition Cable(s) and Spark Plug(s)
Check Ignition Coil(s)
Check Exhaust Gas Recirculation (EGR) Valve (N18)
Check Camshaft Position Sensor (G40)
Special Notes
This DTC indicates that one or multiple cylinders are misfiring, but the ECU fails to identify the cylinder.
16840/P0456/001110 - Система испарителя: Очень Маленькая Обнаруженная Утечка
Возможные Признаки
Индикатор сбоя активный (МИЛ)
Возможные Причины
Топливная Крышка, не полностью приложенная
Выделение паров топлива (испаритель) Системная утечка / дефектный
Возможные решения
Проверьте Топливную Крышку
Проверьте Выделение паров топлива (испаритель) Система
16684/P0300/000768 - Случайная/Многократная Цилиндрическая Обнаруженная Осечка
Возможные Причины
Системная утечка Воздухозаборника
Дефектное Топливоснабжение
Дефектный инжектор (ы)
Кабель (и) зажигания и/или дефектная Свеча (и) зажигания
Дефектная Катушка (ки) зажигания
Система повторного сжигания отработанных газов (EGR) Клапан (N18) заедала/открывалась
Позиционный датчик распредвала дефектный (G40)
Возможные решения
Проверьте Признание Осечки
Проверьте Систему Воздухозаборника
Проверьте Топливоснабжение
Проверьте Уплотнение Инжектора (ов) и Инжектора
Проверьте Кабель (и) Зажигания и Свечу (и) зажигания
Проверьте Катушку (ки) зажигания
Проверьте Систему повторного сжигания отработанных газов (EGR) Клапан (N18)
Проверьте Позиционный датчик Распредвала (G40)
Специальные замечания
Этот DTC указывает, что один или многократные цилиндры дают осечку, но ЭКЮ не в состоянии идентифицировать цилиндр.APT, 1,8 универсал- 14 лет-продан, шкодавод А7
07.09.2011, 09:48 #6059
- 06.09.2011
- 40
- 357
07.09.2011, 12:51 #6060
- 01.11.2009
- Украина, Днепропетровск
- 39
- 187
- 1
017564 P1156 Датчик давления во впускном коллекторе-G71: обрыв цепи/короткое замыкание на плюс
17811 P1403 Система рециркуляции ОГ, диапазон регулирования
16514 P0130 Ряд 1-зонд 1: сбой в электрической цепи
Все ЛОГИ расшифровываются ЗДЕСЬ!!!
от audrius в разделе VW Passat B5/В5+Ответов: 21890Последнее сообщение: 01.05.2024, 22:42 -
Все о катализаторах и пламягасителях здесь!!!
от Devinity в разделе VW Passat B5/В5+Ответов: 2225Последнее сообщение: 03.04.2021, 10:17 -
Подскажите по климату. Тут нашёл не все ошибки (
от TIP в разделе Архив 2009г.Ответов: 1Последнее сообщение: 21.04.2009, 01:02 -
attention, achtung, увага, внимание-ВСЕ ОШИБКИ в одном файле
от SerV в разделе Архив 2008г.Ответов: 40Последнее сообщение: 18.09.2008, 00:00 -
Диагностика ADR 97-98г.г. не все ошибки показывает.....
от alex77 в разделе Архив 2006г.Ответов: 9Последнее сообщение: 10.05.2006, 15:50
