25.07.2011, 08:28 #5821targitayГость
25.07.2011, 22:05 #5822
- 21.12.2009
- Россия, Гатчина
- 45
- 10
0помогите мне тупенькому владельцу vw passat b5 2002 г в awm 1.8t американец разобраться с этими ошибками и как с ними бороться,а то надоело носить в сервис свои кровные и отдавать их навсегдMonday,25,July,2011,20:00:01:46862
VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWPD63B82P287147 Mileage: 120320km/74763miles
Address 01: Engine Labels: 06B-906-018-AWM.lbl
Part No SW: 4B0 906 018 CM HW: 8E0 909 018
Component: 1.8L R4/5VT G 0006
Coding: 0016551
Shop #: WSC 08146 444 54280
VCID: 6ED8CCE646CD136C
6 Faults Found
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded - Intermittent
16686 - Cylinder 2: Misfire Detected
P0302 - 001 - Upper Limit Exceeded - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 001 - Upper Limit Exceeded - Intermittent
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 002 - Lower Limit Exceeded - Intermittent
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 002 - Lower Limit Exceeded
17884 - EVAP Leak Detection Pump: Malfunction / Insufficient Vacuum
P1476 - 002 - Lower Limit Exceeded
Readiness: 0000 0100
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 3B0 927 156 AH
Component: AG5 01V 1.8l5VT USA 0810
Coding: 0001104
VCID: 6CDCC6EE70D1E17C
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Part No: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00021
Shop #: WSC 00028
VCID: D3AEFD124DAFDE84
1 Fault Found
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 C
Component: 09 AIRBAG VW61 04 0001
Coding: 12345
Shop #: WSC 00028
VCID: 244CEECED881E93C
7 Faults Found
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
00595 - Crash Data Stored
35-00 - -
00588 - Airbag Igniter; Driver Side (N95)
32-00 - Resistance too High
00589 - Airbag Igniter 1; Passenger Side (N131)
32-10 - Resistance too High - Intermittent
33-00 - Resistance too Low
29-10 - Short to Ground - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
49-10 - No Communications - Intermittent
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 927 B
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 07135
Shop #: WSC 00050
WVWPD63B82P287147 VWZ7Z0A4476439
1 Fault Found
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
VCID: F0E4529EDCF9859C
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 08 Komfortgerбt HLO 0001
Coding: 00258
Shop #: WSC 00028
VCID: 37762982791792A4
Part No: 1C1959801
Component: 08 Tхrsteuer.FS KLO 0004
Part No: 1C1959802
Component: 08 Tхrsteuer.BF KLO 0004
Part No: 1C0959811
Component: 08 Tхrsteuer.HL KLO 0004
Part No: 1C0959812
Component: 08 Tхrsteuer.HR KLO 0004
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180
Component: Radio NP2 0055
Coding: 00031
Shop #: WSC 00028
VCID: DDBA1B2A3B6B18F4
25.07.2011, 22:15 #5823
- 28.10.2010
- Десногорск
- 41
- 573
019537-Слишком низкая температура двигателя
Спасибо!
25.07.2011, 23:31 #5824
- 18.07.2011
- Россия, Москва, ВАО
- 42
- 474
Спасибо: Получено: 5
0Подскажи, достала ОДНА ошибка!!!
Адрес 01 -------------------------------------------------------
Контроллер: 4B0 906 018 DJ
Компонент: 1.8L R4/5VT 0001
Кодирование: 26551
Код Сервиса: WSC 00116
WVWZZZ3BZ4E308485 VWZ7Z0D9466800
1 Неисправности:
16683 - Регулятор давления наддува, выход из диапазона регулирования(меньше нижнего предела)
Машина при этом совсем не тянет((( других ошибок нет (только пара спорадических). Вот думаю это ошибка указывает на замену регулятора????
Стирание ошибки не помогает, после не большого пробега тут же выскакиваетB3 88 RP ; B5 98 AEB ; В5+ 2004г.в. AWT 1,8T АКПП Tiptronic, чип ABT
В миру АЛЕКСАНДР!
26.07.2011, 11:27 #5825
- 31.01.2011
- г. Ноябрьск, ЯНАО
- 42
- 240
Спасибо: Получено: 11
0Друзья, подскажите по ошибкам, куда копать, на холодную еле заводится, потом вроде все в норме, отключал ДТОЖ, не помогает. Спасибо.
Версия VAG-COM: Релиз 311.2-N
Шасси: 3B - VW Passat B5
Скан: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58,76,77
Контроллер: 8D0 906 018 G
Компонент: 1.8L R4/5V MOTR 0005
Кодирование: 04031
Код Сервиса: WSC 30011
1 Неисправности:
17536 - Ряд 1, адаптация смеси (под нагрузкой): переобеднение смеси в системе
P1128 - 35-00 - -
Готовность: 0000 0000
26.07.2011, 11:40 #5826targitayГость
0Andrey240, покури поиск, много тем, я бы в первую очередь стал копать в сторону ДМРВ
26.07.2011, 12:09 #5827
- 13.11.2007
- Санкт-Петербург и область
- 4,227
- Записей в дневнике
- 3
Спасибо: Получено: 64
Отправлено: 62
26.07.2011, 12:46 #5828
26.07.2011, 19:01 #5829
- 13.09.2010
- Нижний Новгород
- 39
- 313
Спасибо: Получено: 4
0Привет всем, помогите где копать?
8 Найдены неисправности:
16804 - Ряд 1, система катализаторов: снижение эффективности
P0420 - 35-10 - - - Спорадическая
17704 - u6O‚]{Kоq$`о$VrMyЩhxFх‚c` оMЏну:н"ЋR/ZистJ$ц0"
P1296 - 35-00 - BаUеeh>хД
16795 - ДлM°д<sJk5AG5[Zи~Џ&+l#пк*'оhг"ужнPЫtD-@Z)"+ц~я
P0411 - 35-00 - BаUеeh>хД
17511 - N9NэTGSpEиe"rа+^`…dсo|ѓкLm`&ЮB\жн<Ь2KA"HтраL,я
P1103 - 35-10 - BаUеeh>хД - Спорадическая
16684 - >лGЛzj9_"иa8вVR.яФвсoM®=!:оP°н*IoэAL4SFтqO22v
P0300 - 35-10 - BаUеeh>хД - Спорадическая
16686 - ДZ9Иu3кX[.роваgPqч-/еG°к7}Jmэ\Z1VWЩqJ'2x$?а2+я
P0302 - 35-10 - BаUеeh>хД - Спорадическая
17544 - t(я®д;J3.bрj;qнw0ґвejOё;5iU7зMJжнаѕ!е|-GтTEsиZ
P1136 - 35-10 - BаUеeh>хД - Спорадическая
16687 - ,z)ШRZ,одирdZn:'!ЬPaе,№Na9_KчVDжlOд*l5'с63а|+0
P0303 - 35-10 - BаUеeh>хД - Спорадическая
26.07.2011, 19:04 #5830
- 05.08.2008
- Россия, Волгоград
- 43
- 9,357
Спасибо: Получено: 804
Отправлено: 10
0Andrey240,Копай в сторону бензанасоса, регулятора давления и топливного фильтра. По уму надо давление в рампе для начала проверить и произвозительность бензанасоса.
evgen281, На английски переключай, абракодабра .
Ventgrad,Сними лог по далению наддува, похоже турба совсем померла.B5.5, АWM,типтроник,вся фигня,пиндос,2002
, VAG COM
26.07.2011, 19:31 #5831
26.07.2011, 19:54 #5832
- 05.08.2008
- Россия, Волгоград
- 43
- 9,357
Отправлено: 10
0Ventgrad,Она дует максимум 1,4 при запросе в 1,8. В теме про логи ответил.
, VAG COM
28.07.2011, 07:27 #5833
- 27.05.2008
- Россия, Москва, ЮЗАО "ЮЖНОЕ БУТОВО"
- 47
- 92
Спасибо: Получено: 3
0Что случилось с КПП, вчера днем стоял на садовом потом началось движение начал ускорятся, а КПП дальше 2 не переключается (или 1) и на табло высветилась вся линейка передач.
Заглушил завел все нормально.
Ошибка вылезла такая:
Номер VAG 3B0 927 156 AH
Компонент AG5 01V1.8I5VT USA 0810
17114- Контроль передачи и и передаточного отношения: неправильное передаточное отношение
Р0730- 030- Механическая неисправность
?? что это было??
28.07.2011, 08:28 #5834targitayГость
28.07.2011, 10:34 #5835
Все ЛОГИ расшифровываются ЗДЕСЬ!!!
от audrius в разделе VW Passat B5/В5+Ответов: 21892Последнее сообщение: 04.06.2024, 15:56 -
Все о катализаторах и пламягасителях здесь!!!
от Devinity в разделе VW Passat B5/В5+Ответов: 2225Последнее сообщение: 03.04.2021, 10:17 -
Подскажите по климату. Тут нашёл не все ошибки (
от TIP в разделе Архив 2009г.Ответов: 1Последнее сообщение: 21.04.2009, 01:02 -
attention, achtung, увага, внимание-ВСЕ ОШИБКИ в одном файле
от SerV в разделе Архив 2008г.Ответов: 40Последнее сообщение: 18.09.2008, 00:00 -
Диагностика ADR 97-98г.г. не все ошибки показывает.....
от alex77 в разделе Архив 2006г.Ответов: 9Последнее сообщение: 10.05.2006, 15:50
