PR коды, как расшифровать?
    Россия, Москва, ЗАО
    По умолчанию PR коды, как расшифровать?
    имеем сервисную книжку от авто 2002г
    там наклейка, где есть вин, код двигателя, код коробки, окраска.
    дальше 4 строки по 8 кодов,
    пока разгадал тока 1 -- 1BA - европейская подвеска
    где взять расшифровки остальных?
    Kosmonavt
    Лучше кинь ВИн в тему http://www.passatworld.ru/phpBB2/viewtopic.php?t=11982
    Сербия, Белград
    Часть того что тебе интересуеть
    1 0DE L AED installation differentiation for build status of vehicle class B5
    2 0FA L FAD standard manufacturing sequence
    3 0G7 L GES Tiptronic
    4 0JL L GKV weight category front axle weight range 11
    5 0K0 L ASY without alternative drive module
    6 0KA L KAE without stickers and badges
    7 0L0 L GAB mechanical throttle actuation
    8 0LA L SIZ without special plates/stickers/ safety certificates
    9 0NA E SZU without nameplate set (without model designation)
    10 0RA L ZSS without ignition/starter switch locking
    11 0SB L SAU labels/plates in German
    12 0TD P ZFM front and rear floor mats
    13 0Y1 L KLZ standard climatic zones
    14 0YS L GKH weight category rear axle weight range 16
    15 1AH L BRS electronic differential lock (EDS)
    16 1BA L DAE standard suspension/shock absorption
    17 1C1 L FRO antifreeze up to -25 degree celsius tolerance up to -30 degree C
    18 1D2 E AHV removable and lockable towing attachment
    19 1E1 L AKB activated carbon canister
    20 1EX L TYP special identification plate for EC
    21 1G2 L RER steel spare wheel with original
    22 1LB L BAV disc brakes, front
    23 1PC L ABR wheel bolts with anti-theft protection (unlockable)
    24 1SA L TWU without additional engine guard
    25 1T2 L VBK warning triangle
    26 1V0 L ZRE without duty-free and cost-free tires
    27 1VH L TWL installation parts for six-cylinder
    28 1WD L GFW transmission shaft for tripod joints
    29 1X1 L ATA four wheel drive
    30 1YC L GFH transmission shafts for rear axle diameter 100
    31 1Z0 L KRM initial standard fuel filling
    32 2B2 L GRD additional exterior noise suppression
    33 2G1 L EBB insert for the filling up of unleaded
    34 2JC L STF comfort bumpers
    35 2PX P LRA leather steering wheel for airbag system
    36 2WA L ZBR without additional tires
    37 3B4 L ZKV child seat anchor for child seat system ISOFIX
    38 3C3 L SHM lap belt with retractor for the center rear seat
    39 3CX L TRW net partition
    40 3FE E DEI electric sliding/pop-up glass sun roof with sun screen/sunblind
    41 3GK L LBH without additional filler for plane
    42 3J7 L KOV articulated and height-adjustable headrests for front seats
    43 3L3 L SIE manual height adjustment for front seats
    44 3MQ L BOB Ibolours floor covering
    45 3NW L HIS rear seat bench/backrest, split folding with center armrest
    46 3Q1 L KOH rear headrests
    47 3QT L RSV 3-point seat belts with tensioner and height adjustment, front
    48 3S5 E DAR black roof rails with locking brackets
    49 3X0 L DLS without load-through provision
    50 3Y0 L SSR without roll-up sun screen
    51 4A3 P SIH seat heater for front seats separately controlled
    52 4AB P TSV partially leather door and side panel
    53 4B2 L SSL body-colored protective side molding
    54 4E0 L SDH tailgate/trunk lid unlocking from outside
    55 4GH L WSS windshield tinted with windshield sunshield
    56 4K3 L TKV radio remote controlled central locking operated from inside and safe securing
    57 4L2 L IRS dipping breakaway inside rear view
    58 4LA L BED without controls
    59 4M6 L BEH cup holder
    60 4P1 L PBH rear floor panel module, type 2
    61 4Q0 L SES no flame retardent materials
    62 4R3 L FEH power windows with comfort operation
    63 4SD L MSL left vanity mirror illuminated
    64 4TD L MSR right vanity mirror illuminated
    65 4U5 L GNF luggage pockets on backrests
    66 4UE L AIB airbag f. driver a. front seat passenger
    67 4W0 L KBO without cassette and CD storage unit
    68 4X1 L SAB side airbag front
    69 4ZE L ZIE black moldings
    70 5C0 L KSA without special body measures
    71 5D1 L TRF carrier frequency 433.92 MHz
    72 5K1 L LAC paint preservative
    73 5MG P EIH decorative burr walnut inserts (with bright surface)
    74 5RQ L ASR right outside rear view mirror, convex
    75 5SL L ASL left outside rear view mirror
    76 6E3 L MAS center armrest front
    77 6EP L ZKS additional body covers, stone guard
    78 6PC P HBV leatherette hand brake lever handle
    79 6Q3 P SAG wooden gearshift knob
    80 6QA L VRH rear seat catch
    81 6R0 L SHV selector lever cover
    82 6SL L KBB tufted trunk floor covering (cut pile) with plastic sliding strips
    83 6U1 L ZTD additional dust seal outside
    84 6W1 L KZV licence plate bracket front (large)
    85 6XN L ASE power mirror, separately heated
    86 6Y0 L GWA without cruise control warning system
    87 7A2 E CDW CD changer
    88 7AB E EDW electronic alarm system with vehicle immobilization device (for RoW)
    89 7B2 L STD 12-volt socket in trunk
    90 7E0 L WSA w/o heat accumulator/auxiliary heating
    91 7P4 L LOR manually adjustable lumbar support in front seats
    92 7Q0 L NAV without navigation device
    93 7QA L CDR without CD ROM
    94 7X0 L EPH without park distance control (parking
    95 8AD P RAO radio "gamma"
    96 8CC L TWP speedometer sensor without seal (electronic speedometer sensor)
    97 8E2 L ENT local interference suppression for FM/AM
    98 8F2 L SLE side turn signal lights
    99 8GL P GEN alternator 120A
    100 8JG P HSW headlight with gas discharge lamp for left-hand drive
    101 8K0 L FLS without special low beam mode
    102 8KA L KUE w/o catalytic converter warning light
    103 8N4 L SWS windshield wiper intermittent control with potentiometer (four speeds)
    104 8NA L STK without parking light warning light
    105 8Q2 P LWR automatic headlight-range adjustment
    106 8R1 L HBL center high-mounted stop light
    107 8RM P LSE eight loudspeakers (passive)
    108 8S4 L LEL two reading lights front, two rear
    109 8SB L SBR taillight assembly w. dark colored lens
    110 8T1 E GRA cruise control system (CCS)
    111 8TC L NEL rear fog light for left-hand drive
    112 8WA L NES without front fog light
    113 8X1 P SWR headlights washer/wiper system
    114 8Z5 L MKU engine cooling system, type 1
    115 9A0 L TAA without taxi alarm system
    116 9AK P HKA Climatronic with impact pressure controlfree of cfc
    117 9D0 L VEF without preparation for two-way radio
    118 9F0 L VRT without sound combination for rotating emergency light and radio antenna
    119 9FB L AKA automatic transmission indicator light
    120 9HA L FFA without additional malfunction display
    121 9J0 L STA without super-tone system and tone
    122 9P0 L SGK without seat belt warning light
    123 9Q1 L MFA multi-function indicator/trip computer
    124 9T1 P BWD heated washer nozzles front
    125 9W0 L VTV w/o car phone preparation/installation
    126 9Y1 L ATE outdoor temperature gage
    127 A8H I AUS top sports equipment
    128 B01 L TPL type approval Germany
    129 B0A L BLB component parts set without country-specific design requirement
    130 C08 E COC operating permit, alteration 8
    131 C0J L RAD alloy wheels 7J X 16 "Montreal" offset 45
    132 E0A L AAU no special edition
    133 F0A L FZS no special purpose vehicle, standard
    134 G0Q I GSP five-speed automatic transmission for 4Motion
    135 H6U L REI tires 205/55 R 16 W
    136 J0L L BAT battery 340A (70Ah)
    137 K8D I KAR wagon Variant/Avant
    138 L0L L LEA left-hand drive vehicle
    139 MT4 I MOT 6-cylinder gasoline engine 2.8l/142kW V65-valve with EU 3 (provisional solution)base engine is T7F
    140 N7K P SIB Alcantara/leather seat covering
    141 PH2 G air con "Climatronic", free of cfc
    142 PNW G burr walnut wood trim including wood gearshift knob
    143 PXE G xenon light twin headlamp with washer/wiper system and automatic headlight-range adjustment
    144 Q4H P VOS comfort sports seats, front
    145 QA0 L KIS without child seat
    146 RCA G radio "gamma"
    147 S8Q E SNR model year change calendar week KW 32
    148 ST2 E SNR control PP98191P, new seat sew pattern for station wagon, model changeover in
    149 T7F I GMO components for base engine, unit 078.2
    150 U0C L INS instrument insert with tachometer clock and km/h speedometer
    151 V0A L REL tires w/o specification of tire brand
    152 WHB G "Highline" equipment package black or blue + black interior trim including winter package
    153 X0A G Landessetzung Deutschland
  1. как расшифровать VIN
    от порка в разделе Архив 2011г.
    Последнее сообщение: 02.05.2011, 19:37
  2. КОДЫ для ВАГ КОМА что и как можно менять
    от nitroman в разделе Архив 2009г.
    Ответов: 13
    Последнее сообщение: 04.09.2009, 15:17
  3. Помогите расшифровать коды ошибок.
    от alex_factor в разделе Архив 2009г.
    Последнее сообщение: 05.08.2009, 09:09
  4. Как расшифровать записи в Карфакс и Авточек?
    от Бычкова в разделе Архив 2008г.
    Последнее сообщение: 20.06.2008, 06:59
  5. Ответов: 7
    Последнее сообщение: 12.12.2006, 21:03
