Ну вот, сегодня в первый раз подключил к машине VagCom...
Я немного ошарашен![]()
VAG-COM Version: Release 311.2-N
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
Address 01 -------------------------------------------------------
Controller: 4B0 906 018 AG
Component: 1.8L R4/5VT G01 0005
Coding: 05001
Shop #: WSC 05311
3 Faults Found:
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-10 - - - Intermittent
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00 - -
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 B
Component: ABS/EDS 5.3 FRONT D00
Coding: 0273004283
Shop #: BB 24332
1 Fault Found:
00287 - ABS Wheel Speed Sensor: Rear Right (G44)
30-00 - Open or Short to B+
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 C
Component: CLIMATRONIC C 0.5.0
Coding: 05000
Shop #: WSC 05311
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 3B0 920 822
Component: KOMBI+WEGFAHRS. BOO V17
Coding: 05145
Shop #: WSC 64998
Ident.-Nr. WEGFAHRS.:VWZ6Z0X1065253
1 Fault Found:
01176 - Key
07-10 - Signal to Low - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00004
Shop #: WSC 05314
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AH
Component: 3C Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 05311
8 Faults Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
01329 - Convenience System Data Bus in Emergency Mode
35-00 - -
01333 - Door Control Module: Rear Left (J388)
49-10 - No Communications - Intermittent
00930 - Locking Module for Central Locking: Rear Left (F222)
54-10 - Incorrectly Equipped - Intermittent
00928 - Locking Module for Central Locking: Front Driver Side (F220)
27-00 - Implausible Signal
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
27-10 - Implausible Signal - Intermittent
00931 - Locking Module for Central Locking: Rear Right (F223)
Address 56 -------------------------------------------------------
Controller: 1J0 035 152 E
Component: Radio 0001
Coding: 00001
Shop #: WSC 00028
2 Faults Found:
00852 - Loudspeaker(s): Front
44-10 - Short Circuit - Intermittent
00856 - Radio Antenna
36-00 - Open Circuit
End -------------------------------------------------------
Что можете сказать по этому?
Есть непонятки с ключем. Он у меня прямоугольный с двумя кнопками замок открыт и закрыт соответственно.Но как-то работет странно то щелкает но не закрывается, то только багажник открывается![]()
Это все из за блока комфорта?
Заранее благодарен!
04/AWT/GFY
Mex@n!KСообщение от Mex@n!K
P0411 - 35-00 - -
18014 - Блок управления ABS: сбой в электрической цепи
16795 - Система подачи вторичного воздуха: снижение пропускной способности
16500 - ДТОЖ
С ДТОЖ у меня такое же...![]()
Причем не могу уловить от чего происходит!!!![]()
Поменял год назад, через полгода опять начала эта ошибка вылезать!
На поведение машины АБСОЛЮТНО никак не влияет...
Пока забил...
Задний, правый датчик АВС!Сообщение от Mex@n!K
Либо обрыв, либо закорочен.
Сигнал от ключа слабый...Сообщение от Mex@n!K
01176 - Key
Батарейку поменяй!
01329 - Шина данных-комфорт работает в аварийном режиме!!!Сообщение от Mex@n!K
35-00 - -
Все остальные ошибки из-за этого...
Бери сачок и вылавливай из болота Блок комфорта!!!
Пропаивай все гнилые провода!![]()
00852 - Динамики, передние!Сообщение от Mex@n!K
Обрыв, либо замыкание.
00856 - Антенна!
Обрыв, либо замыкание!
Неплохой букет!!!![]()
Стирай все ошибки, заводи, прокатись, и опять снимай!![]()
В личке НЕ КОНСУЛЬТИРУЮ!
Спасибо!
Как я понимаю достать из-под ковра блок комфорта и пропаять всю проводку?Бери сачок и вылавливай из болота Блок комфорта!!!
04/AWT/GFY
Mex@n!K, поздравляю с покупкой (сорри, в той ветке не поздравил)!
По теме:
1. Стереть все ошибки, кататься и смотреть что из этого снова появится.
2. Залезть под водительский ковер и высушить болото в районе блока комфорта. Сгнившие соединения восстановить.
3. Если с ключем по-прежнему будут проблемы или если будет та же ошибка (Signal too low) - поменять батарейку.
4. На Secondary Air Injection System можно пока забить - она не критична для работы двигателя, ею займешься когда остальные проблемы вылечишь.
Мне кажется что в машине стояла нештатная музыка. Перед продажей ее сняли и поставили назад штатную (отсюда многие "непостоянные" ошибки). Поставили наверняка кое-как. Ну либо просто антенна отгнила (судя по ошибке) - лечится сложно, если у тебя седан.
Добавлено спустя 4 минуты 5 секунд:
Игорь, неправильный перевод. Incorrect flow detected = "обнаружен неправильный поток", если быть точным. Это либо помпа, либо просто трубки в районе насоса потрескались. Но, как я сказал, на это пока можно забить и бороться с более важными проблемами.Сообщение от Axl
Да, забыл! Это тоже надо проверять одним из первых. ABS все-таки...Сообщение от Axl
Сообщение от andrewju
Incorrect flow detected = "обнаружен неправильный поток", если быть точным.Андрюх, перевод правильный в обоих случаях, но зависит от конкретного случая, чем вызвана ошибка...Сообщение от andrewju
снижение пропускной способности![]()
Mex@n!K
Вот эта ошибка:
Скорее всего следствие этой:Сообщение от Mex@n!K
P1606 - 35-10 - - - IntermittentСообщение от Mex@n!K
Игорь, перевод неправильный, я настаиваю!Сообщение от Axl
А чем вызвана - это уже вопрос... И все же я предлагаю на нее забить - в машине более серьезных проблем хватает.
[quote=Axl]Вот эта ошибка:
P1606 - 35-10 - - - Intermittent[/quote:16t4vjof]Сообщение от "Mex@n!K":16t4vjof
Ммм... С датчиком надо разбираться.
А вот по первой ошибке - для начала надо ее стереть, а там уже видно будет, связаны они или нет.
andrewjuСообщение от andrewju
Хорошо, уговорил!![]()
Согласен, что на данный момент ошибка совсем некритична!![]()
В первую очередь - комфорт и АВС!![]()
Вот и хорошоВот и договорились
Шина комфорта в аврийном это точно ,но это может быть не только из-за болота под ногами,но и из-за перерубленой шины скажем в задних дверях.
Связь АБС - двигатель проверить проводку в кожухе ,но сначала надо устранить ошибку АБС т.е. датчик.
Спасибо Вам!
Сейчас залез в ELSA (andrewju что бы я без тебя делал ;) ) по поводу ошибки 18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction. Там указано что надо проверить резистор в ЭБУ (58-60 контакт) который нужен для CAN шины...Если сопротивление в допуске то смотреть проводку если нет...менять ЭБУЯ всё же надеюсь что это с АБС связана... Да кстати как я понял у меня ASB + EDS?
04/AWT/GFY
Mex@n!K Молодец! Проверь ,но скорее всего к Павлу придеться обращаться. (Только с комфортом такую операцию не проделывай),ABC+EDC -минимальная комплектация.
В твоем случае эта ошибка непостоянная. Она вообще могла быть случайной! Так что разберись с датчиком ABS, сотри ошибки, а там будешь смотреть по обстановке. Есть ненулевая верятность того что эта ошибка вообще больше не появится.Сообщение от Mex@n!K
Axl, мир, дружба, жвачка!![]()
Я вообще удивляюсь...Смотрю ELSA по ВИНу мой модельный год 2000, но приборка как в 2001 (т.е. полностью круглые указатели температуры и бензина) странно...или нет?![]()
04/AWT/GFY
andrewju Правильно ,надо успокоить человека(как себя когда-то).
Dick, ну да, зачем раньше времени человеку на деньги попадать... Всему свое время!![]()
А что про датчик скорости? Можно уже заказывать?
04/AWT/GFY
Mex@n!K, все чинится, когда знаешь, где проблемы.
К Павлу рано! Сначала проверяй правый задний датчик АБС.Сообщение от Axl
http://www.passatworld.ru/phpBB2/alb...php?pic_id=241
На рисунке - это пластиковая "пробка" с проводом в ступице. Откручивать ничего не надо. Снизу подлезть и подбить слегка его внутрь ступицы. Разъем от этого датчика найдешь под задним сиденьем (если придется искать обрыв). А начинать лучше с прозвонки этого датчика на разъеме блока АБС (возде горловины бачка для омывайки). Вот его контакты http://www.passatworld.ru/phpBB2/alb...php?pic_id=242.
Назначение контактов (нумерация внешнего разъема - на фишке жгута):
1- ЗП (задний правый) колесный датчик G44
2- не используется
3- ЗП (задний правый) колесный датчик G44
4- ПП (передний правый) колесный датчик G45
5- ПП (передний правый) колесный датчик G45
6- ПЛ (передний левый) колесный датчик G47
7- ПЛ (передний левый) колесный датчик G47
8- ЗЛ (задний левый) колесный датчик G46
9- ЗЛ (задний левый) колесный датчик G46
Звонить тестером между 1 и 3 контактами. Должно быть несколько десятков Ом (сравнишь с другими).
Если обрыв или коротыш на массу, то искать разъем под седеньем и т.д. Только потом - менять. Он не дешевый
А кнопки на дверях у тебя от кнопки (от ключа) управления опускаютс/поднимаются?
Спасибо за подробный ответ!
Докладываю: на всех датчиках сопротивление между контактами (1-3 4-5 6-7 8-9) равно 1.15 кОм...Значит виновен датчик?
Кнопки вроде опускаются, хотя вроде было так: щелчок есть а кнопка неподвижна.
04/AWT/GFY
Я не помню точно, сколько должно бытьСообщение от Mex@n!K
на всех датчиках сопротивление между контактами (1-3 4-5 6-7 8-9) равно 1.15 кОм, но результат положительный - обрывов нет. Но проверь еще оба контакта на замыкание на массу. (а если есть осциллограф
, то можно его подключить и покрутить колесо...)
Сигнал от датчика зависит от его положения относительно зубчатки. Теперь лезь, подбивай датчик внутрь (несильно). Грязь туда вряд ли попадет... Сбрасывай ошибку (если еще этого не сделал) и катайся. Кстати, если проблема по датчику уйдет, то лампочки погаснут (а они горят у тебя?) при запуске двигателя - можно и не ездить, а включать зажигание и смотреть. учти, что могут быть тайм-ауты, не спеши и подожди. Может не сразу погаснет.
Из-за этого и ошибки. Причины тебе сказали, где искать.Сообщение от Mex@n!K
Mex@n!K, ты ошибки стер?
Сотри и проверь еще раз...
| Получено: 817 Отправлено: 1,016 |
У меня такой же сигнал. Смотрел указанные вещи-все чисто как с новья.Сообщение от Dick
Mex@n!K
если найдешь причину - сбрось инфу пож-та.Сообщение от Mex@n!K
