Angel
VAG-COM Version: Release 311.2-N
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
Address 01 -------------------------------------------------------
Controller: 4B0 906 018 BB
Component: 1.8L R4/5VT 0005
Coding: 05551
Shop #: WSC 00101
No fault code found.
Address 02 -------------------------------------------------------
Controller: 8D0 927 156 AL
Component: AG5 01V 1.8l5VT RdW 2526
Coding: 00003
Shop #: WSC 00000
Address 03 -------------------------------------------------------
Controller: 8D0 907 389 D
Component: ABS/ESP front D36
Coding: 04277
Shop #: WSC 00028
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 D
Component: CLIMATRONIC D2.1
Coding: 05000
Shop #: WSC 00028
1 Fault Found:
00281 - Vehicle Speed Sensor (G68)
35-00 - -
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 3B0 920 822
Component: B5-KOMBIINSTR. VDO V22
Coding: 05145
Shop #: WSC 00101
IMMO-IDENTNR: VWZ7Z0X2044220
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00007
Shop #: WSC 75329
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AH
Component: 3C Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 00028
Address 56 -------------------------------------------------------
Controller: 1J0 035 186 D
Component: Radio BNO 0004
Coding: 04403
Shop #: WSC 00028
End -------------------------------------------------------
Evgeny23
Controller: 8D0 907 557 T
Component: 1.8L R4/5VT MOTR HS D06
Coding: 04001
Shop #: WSC 05314
4 Faults Found:
01249 - Fuel Injector for Cylinder 1 (N30)
26-10 - Output Open - Intermittent
01250 - Fuel Injector for Cylinder 2 (N31)
01251 - Fuel Injector for Cylinder 3 (N32)
01252 - Fuel Injector for Cylinder 4 (N33)
Readiness: N/A
Controller: 8E0 614 111 B
Component: ABS/EDS 5.3 FRONT D00
Coding: 0273004283
Shop #: BB 24332
Controller: 1J1 907 044
Component: CLIMATRONIC S 6.0
Coding: 02000
Shop #: WSC 05314
Controller: 3B0 919 880 A
Component: B5-KOMBIINSTR. M73 V07
Coding: 00142
Shop #: WSC 65538
IMMO-IDENTNR: VWZ5Z0U4282767
1 Fault Found:
00771 - Fuel Level Sensor (G)
30-10 - Open or Short to B+ - Intermittent
Controller: 3B0 959 796 K
Component: Zentral-SG Komfort V41
Coding: 04097
Shop #: WSC 05311
14 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
37-00 - Faulty
49-10 - No Communications - Intermittent
00668 - Supply Voltage Terminal 30
07-10 - Signal to Low - Intermittent
01331 - Door Control Module: Driver Side (J386)
37-00 - Faulty
00960 - Switch for Central Locking: Driver Side (F59)
29-00 - Short to Ground
00943 - Heated Exterior Mirror: Driver Side (Z4)
35-00 - -
00944 - Heated Exterior Mirror: Passenger Side (Z5)
35-00 - -
00931 - Locking Module for Central Locking: Rear Right (F223)
27-00 - Implausible Signal
Версия VAG-COM: Релиз 311.2-N
Polak
Шасси: 3B - VW Passat B5
Скан: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58,76,77
Адрес 01 -------------------------------------------------------
Контроллер: 038 906 019 GL
Компонент: 1,9l R4 EDC 0000SG 1495
Кодирование: 00002
Код Сервиса: WSC 05314
WVWZZZ3BZ2E316002 VWZ7Z0A4502615
Кодов не найдено.
Адрес 03 -------------------------------------------------------
Контроллер: 4B0 614 517 G
Компонент: ABS/ESP front 1728
Кодирование: 04255
Код Сервиса: WSC 05311
1 Неисправности:
00526 - Выключатель стоп-сигнала-F
27-10 - недостоверный сигнал - Спорадическая
Адрес 08 -------------------------------------------------------
Контроллер: 3B1 907 044 H
Компонент: CLIMATRONIC B5GP 0008
Кодирование: 17000
3 Найдены неисправности:
00603 - Электродвигатель заслонки пространства для ног и заслонки размораживателя-V85
35-10 - - - Спорадическая
01272 - Электродвигатель центральной заслонки-V70
01274 - Электродвигатель заслонки воздухозаборника-V71
Пропуск адреса 15-Аэрбэки
Адрес 17 -------------------------------------------------------
Контроллер: 3B0 920 847 E
Компонент: KOMBI+WEGFAHRSP VDO V06
Кодирование: 21115
Код Сервиса: WSC 00000
Кодов не найдено.
Адрес 19 -------------------------------------------------------
Контроллер: 6N0 909 901
Компонент: Gateway K<->CAN 0001
Кодирование: 00006
Кодов не найдено.
Адрес 37 -------------------------------------------------------
Контроллер: 1J0 919 887 A
Компонент: Navigation BNO 0206
Кодирование: 00000
Код Сервиса: WSC 35262
Кодов не найдено.
Адрес 46 -------------------------------------------------------
Контроллер: 1C0 959 799 B
Компонент: 10 Komfortgerбt HLO 0003
Кодирование: 00258
Кодов не найдено.
Адрес 56 -------------------------------------------------------
Контроллер: 1J0 035 152 G
Компонент: Radio BNO 0206
Кодирование: 05405
Кодов не найдено.
Конец ----------------------------------------------------
ewt
Контроллер: 038 906 018 P
Компонент: 1,9l R4 EDC G00AG 1629
Кодирование: 00001
Кодов не найдено.
Адрес 02 -------------------------------------------------------
Контроллер: 01N 927 733 CN
Компонент: AG4 Getriebe 01N 3815
Кодирование: 00000
Кодов не найдено.
Контроллер: 8E0 614 111 AB
Компонент: ABS 5.3 FRONT D00
Кодирование: 0273004281
Код Сервиса: BB 24548
Кодов не найдено.
Контроллер: 3B1 907 044 A
Компонент: CLIMATRONIC S 9.0
Кодирование: 02000
1 Неисправности:
01273 - Приточный вентилятор-V2
Контроллер: 3B0 919 881 P
Компонент: B5-KOMBIINSTR. VDO V34
Кодирование: 04140
Код Сервиса: WSC 19411
IMMO-IDENTNR: VWZ7Z0W0578110
2 Найдены неисправности:
00779 - Датчик температуры наружного воздуха-G17
30-10 - обрыв цепи/к.з. на плюс - Спорадическая
29-10 - к.з. на массу - Спорадическая
Контроллер: 1J0 959 799 J
Компонент: 0E Zentral-SG Komf.0002
Кодирование: 04097
9 Найдены неисправности:
00849 - Контакт S выключателя зажигания и стартера-D
25-10 - неопределенное состояние переключателя - Спорадическая
01329 - Шина данных-комфорт работает в аварийном режиме
01334 - Блок управления задней правой двери-J389
49-10 - нет связи - Спорадическая
01333 - Блок управления задней левой двери-J388
01332 - Блок управления передней пассажирской двери-J387
01331 - Блок управления двери водителя-J386
00928 - Привод центрального замка двери водителя-F220
00912 - Выключатель переднего левого стеклоподъемника-E40
00930 - Привод центрального замка задней левой двери-F222
27-00 - недостоверный сигнал
Контроллер: 1J0 035 186 B
Компонент: Radio 0001
Кодов не найдено.
mik-
Кодирование: 00001
Код Сервиса: WSC 00028
Кодов не найдено.
Контроллер: 01N 927 733 DG
Компонент: AG4 Getriebe 01N 4147
Кодирование: 00000
Кодов не найдено.
Контроллер: 8E0 614 111 B
Компонент: ABS/EDS 5.3 FRONT D00
Кодирование: 0273004283
Код Сервиса: BB 24332
Кодов не найдено.
Контроллер: 3B1 907 044 B
Компонент: CLIMATRONIC V 1.0.0
Кодирование: 02000
Кодов не найдено.
Компонент: B5-KOMBIINSTR. VDO V30
Кодирование: 04140
Код Сервиса: WSC 36110
IMMO-IDENTNR: VWZ7Z0W0483252
Кодов не найдено.
Контроллер: 1J0 959 799 AH
Компонент: 3C Zentral-SG Komf. 0001
Кодирование: 04097
00944 - Нагревательный элемент наружного зеркала со стороны переднего пассажира-Z5
35-00 - -
Кодирование: 04401
Кодов не найдено.
ed
Контроллер: 8D0 907 558 B
Компонент: 1,8L R4/5V MOTR HS D03
Кодирование: 04201
16500 - Датчик температуры охлаждающей жидкости-G62: недостоверный сигнал
P0116 - 35-10 - - - Спорадическая
00561 - Адаптация смеси
15-00 - выход из диапазона адаптации, меньшего нижнего предела (на холостых оборотах)
01165 - Блок дроссельной заслонки-J338
17-10 - диапазон регулирования - Спорадическая
Готовность: Нет данных
Компонент: ABS/EDS 5.3 QUATTRO D00
Кодирование: 0273004284
Код Сервиса: BB 24334
Кодов не найдено.
Компонент: CLIMATRONIC S 7.0
Кодирование: 02000
Кодов не найдено.
Контроллер: 3B0 919 890 J
Компонент: B5-KOMBIINSTR. VDO V07
Кодирование: 20142
IMMO-IDENTNR: VWZ7Z0V0167520
Кодов не найдено.
Компонент: 0E Zentral-SG Komf.0001
Кодирование: 04097
1 Неисправности:
01358 - Выключатель блокировки дверей из салона, со стороны водителя-E150
AndreyB5TDI
VW Polo
Ошибка: 65535-FFFF-Steuergerat defekt (неисправен блок управления)
Evgeny23 ,ewt пора лезть в" подпол"Кстати Evgeny23 я знаю на что стоит у тебя блокировка сигнализациии ,можно взламывать
. ed Надо разобраться с диагностикой блока упр. двигателя ,ошибка гадкая.
| Получено: 270 Отправлено: 151 |
spawn
Контроллер: 8D0 907 558 E
Компонент: 1.8L R4/5VT MOTR AT D02
Кодирование: 04051
1 Неисправности:
16519 - Ряд 1-зонд 1: сбой в электрической цепи подогрева
P0135 - 35-00 - -
Контроллер: 8D0 927 156 BK
Компонент: AG5 01V 1.8l5VT RdW D70
Кодирование: 00000
00545 - Электрическое соединение двигателя и коробки передач
31-10 - обрыв цепи/к.з. на массу - Спорадическая
00638 - Электрическое соединение 2 двигателя и коробки передач
Кодов не найдено.
Компонент: CLIMATRONIC S 8.0
Кодирование: 02000
Кодов не найдено.
Контроллер: 3B0 919 881 G
Компонент: B5-KOMBIINSTR. VDO V10
Кодирование: 04142
IMMO-IDENTNR: VWZ7Z0W0346725
Кодов не найдено.
Кодирование: 04097
Остались только дети.
modest, спасибобольшое за найденные ошибки!
Dick, я знаю, что коллекция не совершенная, но мы поработаем! ;)
Dick
А я то же знаю на что у Evgeny23 блокировка стоит![]()
ewt
Не у тебя ошибка одна, с ней и разбирайся. Удачи.
Ну вот...
Чёрные листы выложили...![]()
В личке НЕ КОНСУЛЬТИРУЮ!
Dick
А чё мне с ней делать?
Ed
Мы же тебе потерли все ошибки и дросельную заслонку адаптировали. У тебя ничего нет. Я тебе скинул ошибки, что бы "было" на будующее.
modest У какой нехороший! Ed Датчик температуры ОЖ поменяй.
Dick
Я чего-то пропустил![]()
| Получено: 2 Отправлено: 0 |
А вот это к чему относится?
Я так понимаю это глюк датчика скорости вентилятора климатроника?
OleG60, это глюк датчика скорости автомобиля (разъем, провода. Он стоит на коробке возле левого фланца), в зависимости от которой климатроник регулирует поток воздуха (прикрывает заслонку при увеличении скорости).
| Получено: 4 Отправлено: 0 |
Блин...стоко всего можно найти ...давайте-ка я на следующе встрече тоже оттестю свою "пасю" ... надо довести все до совершенства, а то я чую что что-тоне так!!!![]()
Чубук Его сразу видно? Как выглядит? Может какие-нибудь приметы?![]()
Если ты про датчик спидометра, то на схемеСообщение от OleG60
http://www.elcats.ru/vw/parts.asp?mdl=221&unit=34F0B61F
это деталь номер 9.
Фото разъема этого датчика где-то есть, только дома.
| Получено: 817 Отправлено: 1,016 |
Знатоки! Подскажите пож-та, какой датчик (алгоритм) формирует указанный сигнал. Я словил тот же. Внешнее проявление- не управляется стекло вверх с кнопки пассажирской двери пр. зад. (обе кнопки только вниз)-связано ли с этой ошибкой?. С пульта водителя N.Сообщение от modest
И на что же у меня стоит блокировка? Самому интересно ?Сообщение от modest
Dick
| Получено: 38 Отправлено: 0 |
И тебе тот же совет - лезь в "подпол", ищи гнилые и окисленные провода, че не найдешь в "подполе" - ищи в дверных проводках - место перегиба при открывании/закрывании двери (+-20 см от дверной петли в обоих направлениях дверного жгута)Сообщение от pavel1
И будет Сщазьтье!!!
Evgeny23
Смотри ЛС.![]()
