Ошибки с встречи 28.01 (Москва)
    По умолчанию Ошибки с встречи 28.01 (Москва)
    Ребята, спасибо всем кто приехал!
    Спасибо за диски!
    Всю встречу ходил от машины к машине и тестил ошибки...
    Итак, выкладываю результаты:
    Angel:
    [code]VAG-COM Version: Release 311.2-N
    Chassis Type: 3B - VW Passat B5
    Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
    Address 01 -------------------------------------------------------
    Controller: 4B0 906 018 BB
    Component: 1.8L R4/5VT 0005
    Coding: 05551
    Shop #: WSC 00101
    7 Faults Found:
    17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
    P1113 - 35-10 - - - Intermittent
    17645 - Fuel Injector for Cylinder 1 (N30): Open Circuit
    P1237 - 35-10 - - - Intermittent
    17647 - Fuel Injector for Cylinder 3 (N32): Open Circuit
    P1239 - 35-10 - - - Intermittent
    17648 - Fuel Injector for Cylinder 4 (N33): Open Circuit
    P1240 - 35-10 - - - Intermittent
    17646 - Fuel Injector for Cylinder 2 (N31): Open Circuit
    P1238 - 35-10 - - - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-10 - - - Intermittent
    16686 - Cylinder 2 Misfire Detected
    P0302 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 02 -------------------------------------------------------
    Controller: 8D0 927 156 AL
    Component: AG5 01V 1.8l5VT RdW 2526
    Coding: 00003
    Shop #: WSC 00000
    No fault code found.
    Address 03 -------------------------------------------------------
    Controller: 8D0 907 389 D
    Component: ABS/ESP front D36
    Coding: 04277
    Shop #: WSC 00028
    Address 08 -------------------------------------------------------
    Controller: 3B1 907 044 D
    Component: CLIMATRONIC D2.1
    Coding: 05000
    Shop #: WSC 00028
    2 Faults Found:
    01206 - Signal for Duration of Ignition: OFF
    00281 - Vehicle Speed Sensor (G68)
    35-00 - -
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 3B0 920 822
    Component: B5-KOMBIINSTR. VDO V22
    Coding: 05145
    Shop #: WSC 00101
    IMMO-IDENTNR: VWZ7Z0X2044220
    Address 19 -------------------------------------------------------
    Controller: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00007
    Shop #: WSC 75329
    Address 46 -------------------------------------------------------
    Controller: 1J0 959 799 AH
    Component: 3C Zentral-SG Komf. 0001
    Coding: 04097
    Shop #: WSC 00028
    Address 56 -------------------------------------------------------
    Controller: 1J0 035 186 D
    Component: Radio BNO 0004
    Coding: 04403
    Shop #: WSC 00028
    End -------------------------------------------------------[/code]
    Axl:
    Controller: 8D0 907 557 T
    Component: 1.8L R4/5VT MOTR HS D06
    Coding: 04001
    Shop #: WSC 05314
    Controller: 8E0 614 111 B
    Component: ABS/EDS 5.3 FRONT D00
    Coding: 0273004283
    Shop #: BB 24332
    Controller: 3B1 907 044 A
    Component: CLIMATRONIC S 7.0
    Coding: 02000
    Shop #: WSC 05314
    Controller: 3B0 919 881 F
    Component: B5-KOMBIINSTR. VDO V10
    Coding: 04142
    Shop #: WSC 00000
    IMMO-IDENTNR: VWZ7Z0V0113880
    Controller: 1J0 959 799 J
    Component: 0E Zentral-SG Komf.0001
    Coding: 04097
    Shop #: WSC 05311
    4 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    37-00 - Faulty
    00943 - Heated Exterior Mirror: Driver Side (Z4)
    01358 - Internal Central Locking Switch: Driver Side (E150)
    27-10 - Implausible Signal - Intermittent
    00912 - Window Regulator Switch: Front Left (E40)
    Gusev:
    Component: 1.8L R4/5VT MOTR AT D06
    Coding: 04051
    Shop #: WSC 79197
    1 Fault Found:
    16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    P0116 - 35-10 - - - Intermittent
    Readiness: N/A
    Controller: 8D0 927 156 BK
    Component: AG5 01V 1.8l5VT RdW D70
    Coding: 00000
    Shop #: WSC 00000
    1 Fault Found:
    00526 - Brake Light Switch-F
    27-00 - Implausible Signal
    Coding: 0273004283
    Shop #: BB 24332
    Controller: 1J1 907 044
    Component: CLIMATRONIC S 6.0
    Coding: 02000
    Shop #: WSC 00028
    Controller: 3B0 919 880 C
    Component: B5-KOMBIINSTR. VDO V12
    Coding: 00142
    Shop #: WSC 00028
    IMMO-IDENTNR: VWZ7Z0V0099075
    Controller: 3B0 959 796 K
    Component: Zentral-SG Komfort V41
    Coding: 04097
    Shop #: WSC 00028
    4 Faults Found:
    37-00 - Faulty
    35-00 - -
    00944 - Heated Exterior Mirror: Passenger Side (Z5)
    35-00 - -
    00930 - Locking Module for Central Locking: Rear Left (F222)
    Judex:
    Controller: 4B0 906 018 CG
    Component: 1.8L R4/5VT G 0002
    Coding: 11551
    Shop #: WSC 01120
    WVWZZZ3BZ1E181883 VWZ7Z0A3355790
    5 Faults Found:
    16688 - Cylinder 4 Misfire Detected
    P0304 - 35-10 - - - Intermittent
    17544 - Fuel Trim: Bank 1 (Add): System too Lean
    P1136 - 35-10 - - - Intermittent
    16687 - Cylinder 3 Misfire Detected
    P0303 - 35-10 - - - Intermittent
    Controller: 8D0 927 156 DD
    Component: AG5 01V 1.8l5VT RdW 1314
    Coding: 00103
    Shop #: WSC 05311
    Component: ABS/ESP front D56
    Coding: 04277
    Shop #: WSC 05311
    Controller: 3B1 907 044 J
    Component: CLIMATRONIC B5GP 0002
    Coding: 17000
    Shop #: WSC 05311
    Controller: 3B0 920 805 E
    Component: KOMBI+WEGFAHRSP VDO V13
    Coding: 05125
    Shop #: WSC 00440
    1 Fault Found:
    01336 - Data Bus for Comfort System
    49-10 - No Communications - Intermittent
    Coding: 00006
    Shop #: WSC 05314
    1 Fault Found:
    Controller: 1C0 959 799 B
    Component: 10 Komfortgerat HLO 0002
    Coding: 00259
    Shop #: WSC 05311
    1 Fault Found:
    01141 - Luggage Compartment Unlocking Switch (E165)
    Komok_1965:
    Controller: 3B0 907 557 C
    Component: 1,6l R4/2V SIMOS HS D03
    Coding: 04001
    Shop #: WSC 00000
    1 Fault Found:
    00282 - Throttle Position Actuator (V60)
    44-10 - Short Circuit - Intermittent
    Readiness: N/A
    Controller: 8E0 614 111 AB
    Component: ABS 5.3 FRONT D00
    Coding: 0273004281
    Shop #: BB 24548
    Controller: 3B1 907 044 B
    Component: CLIMATRONIC S 0.3.2
    Coding: 02000
    Shop #: WSC 05314
    1 Fault Found:
    01274 - Air Flow Flap Positioning Motor (V71)
    Controller: 3B1 919 860
    Component: B5-KOMBIINSTR. VDO V01
    Coding: 04142
    Shop #: WSC 48747
    IMMO-IDENTNR: VWZ7Z0W0797027
    Controller: 1J0 959 799 R
    Component: 3A Zentral-SG Komf. 0001
    Coding: 00257
    Shop #: WSC 05311
    3 Faults Found:
    00928 - Locking Module for Central Locking: Front Driver Side (F220)
    35-00 - -
    35-00 - -
    Корефан:
    Chassis Type: 1J - VW G/J/B Mk4
    Scan: 01,02,03,08,15,17,19,22,35,46,56
    Controller: 038 906 018 J
    Component: 1,9l R4 EDC 00SG 1810
    Coding: 00002
    Shop #: WSC 01317
    3 Faults Found:
    01237 - Fuel Shut-Off Valve (N109)
    31-10 - Open or Short to Ground - Intermittent
    00575 - Intake Manifold Pressure
    17-10 - Control Difference - Intermittent
    00553 - Mass Air Flow Sensor (G70)
    31-00 - Open or Short to Ground
    Readiness: N/A
    Controller: 1J0 907 379 D
    Component: ABS 20 IE CAN 0001
    Coding: 03304
    Shop #: WSC 01317
    1 Fault Found:
    00285 - ABS Wheel Speed Sensor: Front Right (G45)
    Coding: 01000
    Shop #: WSC 01295
    Controller: 1J0 919 890 B
    Component: A4-KOMBIINSTR. VDO V06
    Coding: 20143
    Shop #: WSC 19411
    IMMO-IDENTNR: VWZ7Z0V0111171
    Component: 03 Zentral-SG Komf.0001
    Coding: 04097
    Shop #: WSC 01317
    6 Faults Found:
    35-00 - -
    00929 - Locking Module for Central Locking: Front Passenger Side (F221)
    35-00 - -
    00931 - Locking Module for Central Locking: Rear Right (F223)
    Pavel:
    Controller: 8D0 907 558 E
    Component: 1.8L R4/5VT MOTR HS D03
    Coding: 04001
    Shop #: WSC 05314
    Component: ABS/EDS 5.3 FRONT D10
    Coding: 0273004283
    Shop #: BB 24332
    Component: B5-KOMBIINSTR. VDO V34
    Coding: 04142
    Shop #: WSC 43681
    IMMO-IDENTNR: VWZ7Z0W0674870
    Component: 0E Zentral-SG Komf.0002
    Coding: 04097
    Shop #: WSC 05311
    1 Fault Found:
    Spawn:
    Component: 1.8L R4/5VT MOTR AT D02
    Coding: 04051
    Shop #: WSC 05314
    2 Faults Found:
    17972 - Throttle Actuator (J338): Under-Voltage during Basic Setting
    P1564 - 35-10 - - - Intermittent
    16515 - Oxygen (Lambda) Sensor B1 S1: Signal too Low
    P0131 - 35-10 - - - Intermittent
    Readiness: N/A
    Coding: 00000
    Shop #: WSC 00000
    3 Faults Found:
    00545 - Engine-Transmission Electrical Connection
    00638 - Engine/Transmission Electrical Connection 2
    30-10 - Open or Short to B+ - Intermittent
    Coding: 0273004283
    Shop #: BB 24332
    Component: CLIMATRONIC S 8.0
    Coding: 02000
    Shop #: WSC 05314
    1 Fault Found:
    01273 - Fresh Air Blower (V2)
    35-00 - -
    Controller: 3B0 919 881 G
    Coding: 04142
    Shop #: WSC 00000
    IMMO-IDENTNR: VWZ7Z0W0346725
    Coding: 04097
    Shop #: WSC 05311
    2 Faults Found:
    Ребята, желаю вам исправить все неполадки и чтоб машины больше не ломались!
    =)) Будем стараться! =)
    Получено: 270
    Отправлено: 151
    Андрей, спасибо за тесты
    У меня список ошибок круче всех =D>
    Остались только дети.
    кстати, ошибки это то где есь коды? ноприме это:00930 - Locking Module for Central Locking: Rear Left (F222)
    зарание спасибо =)
    Получено: 270
    Отправлено: 151
    Spawn
    Ошибки, это когда "х fault found", а дальше идут коды ошибок
    Получено: 8,416
    andrewju
    Спасибо Андрюх... =D>
    Знаю я, откуда у моих ошибок ноги растут...
    pavel
    ну ваще блин! молодца =))
    Всем пожалуйста!
    Кстати, расшифровка всех кодов ошибок (в т.ч. на русском языке) есть тут: http://www.lucky3d.ru/auto/VAG_code.htm
    Спасибо Lucky3D!
    Получено: 8,416
    andrewju
    А так же есть в FAQ-е
    andrewju
    Спасибо огромное :hello2: :hello2: :hello2: Кстати,пока доехал,пока всё установил,пошёл померял,по движку осталась только одна ошибка-давление в коллекторе
    Цитата Сообщение от Axl
    andrewju
    О! Точно, лучше в FAQ смотреть, а то Lucky предупреждал что таблица на его сайте может быть не долго.
    Когда ты уезжал, у тебя ни одной ошибки не было, т.к. я их стер. Но ошибка по давлению у тебя появляется сразу после езды. В общем, мы с тобой уже выяснили что дальше делать. Желаю удачи! Разберешься - напиши!
    Россия, Москва, САО
    andrewju
    Поставил бы VAG-COM на русском от MEN, народу было бы сразу всё понятно по ошибкам.
    say, я плохо понимаю русский в компьютере...
    Наверное, это привычка еще пятнадцатилетней давности - когда русского софта не было, а тот что был (переведенный) - был абсолютно непонятен. С тех пор мне технический английский гораздо удобнее и понятнее технического русского (имею в виду компьютеры и все что с ними связано).
    По аналогии стал разбираться и с машинами. Elsa вот тоже вся на английском (немецкий на таком уровне я, к сожалению, не понимаю), так что сопоставить описание ошибки с ее описанием в Elsa тоже просто.
    Как-то посмотрел я на русские ошибки - без перевода на английский ничего не понял. Поэтому все, кто диагностируется у меня, будут получать ошибки на английском. Я никого не заставляю, мне просто так удобнее. Русскоязычный софт я ставить не буду.
    Россия, Москва, САО
    say, не понял...
    Я ж говорю, по-русски плохо понимаю!
    Россия, Москва, САО
    andrewju
    And I understand in German though never it learned.
    Съебёж, Эта Страна
    Gut! Deutchland uber alles!
    04/AWT/GFY
    say, Ich Sprache Deutsch auch. Aber nicht sehr gut.
    Hipa после предварительного сброса имеющихся ошибок и последующей тест-поездки и нового опроса ошибок.
    Сорри, что только что. Интересует ошибка 01329 в комфорте. Эльза указывает на проводку, куда человеку лезть, в какую сторону копать.
    Controller: 8D0 907 558 F
    Component: 1,8L R4/5V MOTR HS D01
    Coding: 04001
    Shop #: WSC 00000
    Component: ABS 5.3 FRONT D11
    Coding: 0273004132
    Shop #: BB 24303
    Component: CLIMATRONIC S 4.0
    Coding: 02000
    Shop #: WSC 05319
    Controller: 3B0 919 860 A
    Component: B5-KOMBIINSTR. VDO V08
    Coding: 00142
    Shop #: WSC 00000
    IMMO-IDENTNR: VWZ7Z0V0028152
    Controller: 3B0 959 799 A
    Coding: 04097
    Shop #: WSC 05311
    3 Faults Found:
    01329 - Convenience System Data Bus in Emergency Mode
    35-00 - -
    35-00 - -
    35-00 - -
    Здравствуйте ВАМ!
    say, Вам будет смешно, но я с японского перевода на русский вообще в улете, НИ ЧЕГО не понимаю, а вот в тех англицком с трудом но выплываю. Породокс.
  1. ошибки со встречи в Питере 31 марта 2007
    от Dron в разделе Архив 2007г.
    Ответов: 13
    Последнее сообщение: 09.07.2007, 12:01
  2. Ошибки со встречи 26.05.07
    от Spaze в разделе Архив 2007г.
    Последнее сообщение: 29.05.2007, 01:34
  3. Ошибки со встречи в Питере февраль 2007
    Последнее сообщение: 24.02.2007, 21:10
  4. Ошибки со встречи Питер
    от Petrovich в разделе Архив 2006г.
    Последнее сообщение: 02.02.2006, 09:13
  5. Голосуем за место встречи 24.09. Москва
    от Саня на Пассате 111 в разделе Архив 2005г.
    Ответов: 34
    Последнее сообщение: 20.09.2005, 19:41
