VIN Код - Страница 2
Тема: VIN Код
    Получено: 8,429
    Евгений К, идем сюда и пробиваем в VIN - декодере!
    Всё заработало! =D>
    https://passatworld.ru/index.php?option=co ... &Itemid=99
    Phaeton Аватар для SilverPass
    Получено: 62
    Отправлено: 48
    Евгений К,
    VIN: WVWZZZ3BZWP239404
    Sales type: 3B23E8 ()
    Дата выпуска: 04.11.1997
    Модельный год: 1998
    Код и номер двигателя: ADR 331912
    Код КПП: DMU
    Комбинация цветов интерьера: GQ
    Комбинация цветов кузова: K1
    Roof color: K1
    Комплектация автомобиля (код и наименование):
    0DE installation differentiation for build status of vehicle class B5 (VW Passat)
    0FG Mosel manufacturing sequence
    0G2 selector lever
    0JG weight category front axle weight range 7
    0K0 without alternative drive module
    0KA without stickers and badges
    0LA without special plates/stickers/safety certificates
    0PG nameplate set "1.8"
    0RA without ignition/starter switch locking system
    0SB labels/plates in German
    0TA without floor mats
    0Y1 standard climatic zones
    0YC weight category rear axle weight range 3
    1AH electronic differential lock (EDL)
    1BA standard suspension/shock absorption
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    1D0 without towing attachment
    1E1 activated carbon canister
    1EX special identification plate for EC
    1G2 steel spare wheel with original equipment tires
    1LZ front disc brakes, standard ventilation
    1PA standard wheel bolts
    1SA without additional engine guard
    1T2 warning triangle
    1V0 without duty-free and cost-free tires
    1VG installation parts for four-cylinder engine
    1X0 front wheel drive
    1Z0 initial standard fuel filling
    2B1 additional exterior noise suppression
    2G1 insert for the filling up of unleaded fuel
    2JB standard bumpers
    2PQ steering wheel for airbag system
    2WA without additional tires
    3B0 without additional child seat anchor
    3C3 lap belt with retractor for the center rear seat
    3CA without partition
    3FA without roof insert (standard roof)
    3GK without additional filler for plane trunk floor
    3J7 articulated and height-adjustable headrests for front seats
    3L3 manual height adjustment for front seats
    3LD door and side panel trim
    3MQ Ibolours floor covering
    3NZ rear seat bench unsplit, backrest split folding
    3Q1 rear headrests
    3S0 without roof rails/roof load rack
    3X0 without load-through provision
    3Y0 without roll-up sun screen
    4A3 seat heater for front seats separately controlled
    4B1 protective side molding
    4E0 tailgate/trunk lid unlocking from outside
    4F1 central locking system
    4GH windshield tinted with windshield sunshield
    4L2 dipping breakaway inside rear view mirror
    4M6 cup holder
    4Q0 no flame retardent materials
    4R3 power windows with comfort operation
    4SD left vanity mirror illuminated
    4TD right vanity mirror illuminated
    4U1 luggage nets/pockets on backrests
    4UE airbag f. driver a. front seat passenger
    4W0 without cassette and CD storage unit
    4X1 side airbag front
    4ZE black moldings
    5C0 without special body measures
    5D0 without carrier frequency
    5K0 without paint preservative
    5MA decorative inserts
    5RQ outer right rear view mirror: convex
    5SL outer left rear view mirror: non-spherical
    6E3 center armrest front
    6EP additional body covers, stone guard
    6PA plastic hand brake lever handle
    6Q1 plastic gearshift knob/handle
    6QB locking rear seat catch
    6R0 selector lever cover
    6SD tufted trunk floor covering (dimensionally stable)
    6U0 without additional seals outside
    6W1 license plate bracket front (large)
    6XD outer rear view mirrors: powered, heated
    6Y0 without cruise control warning system
    7A0 without CD changer/CD player
    7AA electronic vehicle immobilization device
    7B0 without socket
    7CA without label for radio remote control
    7E0 w/o heat accumulator/auxiliary heating
    7P4 manually adjustable lumbar support in front seats
    7Q0 without navigation device
    7QA without CD ROM
    7V0 standard dashboard illumination
    8AC radio "beta"
    8CC speedometer sensor without seal (electronic speedometer sensor)
    8E2 local interference suppression for FM/AMradio reception
    8F2 side turn signal lights
    8GD alternator 90A
    8JM twin headlamp for left-hand drive with integrated high-beam headlight
    8K0 without special low beam mode
    8KA w/o catalytic converter warning light
    8N4 windshield wiper intermittent control with potentiometer (four speeds)
    8NA without parking light warning light
    8Q1 headlight-range adjustment
    8R1 center high-mounted stop light
    8RE four loudspeakers (passive)
    8S4 two reading lights front, two rear
    8SA taillight assemblies, standard design
    8T0 without cruise control system (CCS)
    8TC rear fog light for driving on the right
    8WD integrated front fog light
    8X0 without headlight washer system
    8Z5 engine cooling system, type 1
    9A0 without taxi alarm system
    9AB manually controlled air conditioning
    9D0 without preparation for two-way radio installation
    9F0 without sound combination for rotating emergency light and radio antenna preparation
    9FB automatic transmission indicator light
    9HA without additional malfunction display
    9J0 without supertone system and tone sequence control
    9P0 without seat belt warning light
    9Q0 without multi-function indicator/on-board computer
    9T1 heated washer nozzles, front
    9W9 car phone installation
    9X0 without heated door lock cylinder
    9Y0 without outdoor temperature gage
    A8S standard equipment
    B01 type approval Germany
    B0A component parts set without country-specific design requirement
    C06 operating permit, alteration 6
    C0V steel wheels 6J x 15 offset 45 (five-hole)
    E0A no special edition
    F0A no special purpose vehicle, standard equipment
    G0E four-speed automatic transmission
    H6S tires 195/65 R 15 V
    J1L battery 280 A (60 Ah)
    K8B notchback
    L0L left-hand drive vehicle
    M51 4-cyl. gasoline engine 1.8 L/92 kW 20V with MVEG 2 base engine is T0V/T5Z
    N0U cut pile seat covering
    PH1
    PT1
    Q1A standard front seats
    RBB
    SR6 Multivan demonstration campaign for Europe
    T5Z components for base engine, unit 058.B
    U0C instrument insert with tachometer clock and km/h speedometer
    V0A tires w/o specification of tire brand
    WC1
    WW1
    Россия, Белгород
    SilverPassB5GPTDI, спасибо!!!
    Евгений К,
    Модельный год: 1998
    Код КПП: DMU
    Roof color: K1
    [/quote]
    Пробег на 2003.07.22 был 191822 км.
  1. Подскажите VIN код фар B5+ Американец
    от vitek112 в разделе Архив 2011г.
    Последнее сообщение: 01.07.2011, 09:33
  2. Vin код
    от Дон в разделе Другие марки Авто
    Последнее сообщение: 27.04.2011, 17:24
  3. Ответов: 3
    Последнее сообщение: 26.01.2011, 10:03
  4. VIN КОД
    от fenomenchik в разделе Архив 2009г.
    Последнее сообщение: 06.09.2009, 21:52
  5. VIN код
    от в разделе Архив 2005г.
    Последнее сообщение: 03.10.2005, 11:49
