Смена языка на БК
    Россия, Новочеркасск
    По умолчанию Смена языка на БК
    Как сменить язык на бортовом компе с немецкого на английский.
    TVR, задай вопрос ШАМАНУ
    Получено: 20
    как?
    Получено: 20
    Self-diagnosis of dash panel insert 05.99 >
    Adapting language variants for drivers instructions
    Language variants for driver information can be adapted only on Midline and Highline dash panel inserts.
    ‒ Connect fault reader V.A.G 1551, select operating mode 1 "Rapid data transfer", switch on ignition and enter address word 17 "Dash panel insert".
    After displaying the control unit identification.
    ‒ Press ⇒ key.
    → Indicated on display: Rapid data transfer HELP
    Select function XX
    ‒ Press keys 1 and 0. (10 selects the "Adaption" function.)
    → Indicated on display: Rapid data transfer Q
    10 - Adaption
    ‒ Confirm entry with key Q.
    → Indicated on display: Adaption
    Enter channel number XX
    ‒ Press keys 0 and 4.
    ‒ Confirm entry with the Q key.
    → Indicated on display: Channel 4 Adaption 1 ⇒
    (- 1 3-L
    Notes:
    ◆ Only the last character of the five position language variant code is shown on the display, e.g. 1 for German!
    ◆ A false entry terminates "Adaption" and it must be restarted with function "10 - Adaption"!
    ◆ Using the keys of the fault reader it is not possible to enter the code direct or in stages!
    Code table:
    Code
    Language variants
    00001
    German
    00002
    English
    00003
    French
    00004
    Italian
    00005
    Spanish
    00006
    Portuguese
    00008
    Czech
    Staged entry:
    ‒ The coding can be decreased with key 1 and increased with key 3, e.g. to 2 for language variant English.
    → Indicated on display: Channel 4 Adaption 2 Q
    (- 1 3-L
    Store amended value?
    → Indicated on display: Channel 4 Adaption 2 ⇒
    Amended value is stored
    ‒ End adapting language variant with ⇒key.
    Select function XX
    Direct entry:
    ‒ Press ⇒key.
    Enter adaption value XXXXX
    ‒ Enter desired 5 position code using keyboard => Page 01-222
    Example:
    Coding: 2 (English)
    Input value: 00002
    → Indicated on display: Channel 4 Adaption 1 Q
    Enter adaption value 00002
    → Indicated on display. Channel 4 Adaption 2 Q
    Select function XX
    ‒ Press keys 0 and 6. (The function "End output" is selected with 06.)
    06 - End output
    → Indicated on display: Rapid data transfer Help
    Enter address word XX
    The tester is now in basic function again.
    Получено: 20
    TVR, Вместо V.A.G 1551 эту процедуру можно сделать VAG-COMом
    TVR, сделай проще - заедь к в сервис к официальному дилеру, либо в любой другой приличный сервис, где есть данный прибор VAG-СOM, и тебе быстренько все переведут)
    Janet спасибо я так и думал. :hello2:
  1. смена языка БК
    от troomer в разделе Архив 2011г.
    Последнее сообщение: 11.03.2011, 09:02
  2. RNS MDF смена языка
    от REWERS в разделе Автозвук
    Последнее сообщение: 24.07.2009, 17:15
  3. Ответов: 10
    Последнее сообщение: 21.11.2005, 16:35
  4. Cмена языка приборки через K-line
    Последнее сообщение: 19.09.2005, 13:22
  5. Смена возд. фильтра на AEB с климатроник.
    Ответов: 13
    Последнее сообщение: 16.05.2005, 09:20
