| Получено: 2,432 Отправлено: 439 |
Чуток опоздал с "новостью"В «Washington Post» опубликована статья, в которой прямо говорится, что Грудинин является единственной надеждой США на свержение «ненавистного путинского режима».
https://www.washingtonpost.com/worl....c8d_story.html
Кулубникин - надежда миллионов американцев
| Получено: 2,104 Отправлено: 1,030 |
ну чё, молочага!
прям фонтанирует от счастья!а через 2 дня годовщина.
на 1:58:21
прям рад за него.
https://www.youtube.com/watch?v=ENzJRX8_nBI
| Получено: 944 Отправлено: 597 |
| Получено: 6,401 Отправлено: 1,619 |
12:54 иллюстрация построения частицы из волн
Корпускулярно-волновой эфир от Планка и Ко
https://youtu.be/-gp4NbVBWR0?t=776
А пожалуйста
MATTER IS MADE OF WAVES
This spherical standing wave system is an electron.
NO INCOMING WAVES.
Standing waves are not made of traveling waves. It is a totally different wave system which behaves in accordance with Hooke's law.
For calculation purposes, such waves can indeed be considered as two sets of waves traveling in opposite directions. This is a very useful method for computer programs, and I used it for the diagrams shown above.
However, one must observe what is really going on inside the medium substance when standing waves are present.
For instance, using a loudspeaker, one can produce standing waves inside a pipe. The traveling waves penetrate inside the pipe, and on condition that the wavelength is compatible, a resonance is obtained. This occurs because the pipe ends act like screens and do not allow all of the energy to get out in just one pulse.
Turning off the loudspeaker will not make the resonance stop immediately. Theoretically, a lossless system (no heat or energy loss) with both ends hermetically closed would continue to vibrate eternally. The air is simply compressed inside antinodes, then the pressure energy is transferred into kinetic energy, and so on. The same process occurs for lossless springs moving back and forth, as predicted by Hooke's law: the extension is proportional to the force. The point is: there are no more traveling waves there. Just standing waves. Especially, nodes are constant zero energy points, thus they are incompatible with traveling waves.
One may need incoming traveling waves in order to establish standing waves, but they are no longer needed once the system is well established.
Additionally, if some energy is actually radiated, it may be replaced by amplification. This is especially true for electronic oscillators.
The electron is a pulsating wave system.
For the same reason, electrons must have been created in the past using incoming waves. Such a situation is not likely to happen because aether waves frequency and phase very rarely coincide for a given point, but it is still possible. One chance out of billions and billions.
However, once it has been created, the electron can remain stable because its standing waves are constantly amplified by aether waves. This can be explained by a lens effect. For example, objects seen above a fire become more or less blurred because the speed of light is not the same for cold and hot air. For the same reason, the sound itself will also be scattered above a fire. Actually, any sound wave is surely scattered by spherical standing waves made of sound because this modifies the air density..."
В приведенном мною материале гораздо больше смысла, пользы и перспективы, чем в приведенных вами.
А Рязань ничем не хуже Перми и Ставрополя.
Тут один интересный вопрос на возник .... на флайтрадаре все наши самолеты (внутри российские рейсы) под флагом Бермуд ?
| Получено: 3,468 Отправлено: 4,292 |
| Получено: 1,527 Отправлено: 1,394 |
В казахстане могут русские занимать гос. должности, ключевые посты ?
P.S. У нас тут спор идет....
| Получено: 5,622 Отправлено: 1,761 |
внутри, не внутри, роли не играет.
есть и российской принадлежность - RA
но большинство, конечно, иностранной.
Но это ровным счетом не значит ничего особенного
