| Получено: 0 Отправлено: 1 |
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Friday,28,October,2016,16:49:47:62939
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ2E373025 Mileage: 232060km/144195miles
Address 01: Engine Labels: 038-906-019-AVB.lbl
Part No: 038 906 019 GL
Component: 1,9l R4 EDC 0000SG 1495
Coding: 00002
Shop #: WSC 05314
VCID: 67DD5D1705980F26359-4A3A
WVWZZZ3BZ2E373025 VWZ7Z0A4690163
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 1728
Coding: 04255
Shop #: WSC 05311
VCID: 2541171FBF14DD36C75-5072
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 H
Component: CLIMATRONIC B5GP 0008
Coding: 17000
Shop #: WSC 05311
VCID: 26431013C212D62ECEF-5072
4 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
35-10 - - - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
35-00 - -
01272 - Positioning Motor for Central Flap (V70)
35-00 - -
01274 - Air Flow Flap Positioning Motor (V71)
35-00 - -
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 B
Component: 0A AIRBAG VW51 04 0004
Coding: 12353
Shop #: WSC 05311
VCID: 23450907B1202306A91-5000
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 807 A
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 05115
Shop #: WSC 49548
VCID: 204F060BA036381EB43-5000
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 05314
VCID: F0EFB64BB056489EE43-5000
1 Fault Found:
00463 - Control Module for Digital Sound Package (J525)
49-00 - No Communications
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 10 Komfortgerбt HLO 0003
Coding: 00259
Shop #: WSC 05311
VCID: 3663C05312B2A6AE7EF-4A3A
Subsystem 1 - Part No: 1C1959801
Component: 10 Tхrsteuer.FS KLO 0002
Subsystem 2 - Part No: 1C1959802
Component: 10 Tхrsteuer.BF KLO 0002
Subsystem 3 - Part No: 1C0959811
Component: 10 Tхrsteuer.HL KLO 0004
Subsystem 4 - Part No: 1C0959812
Component: 10 Tхrsteuer.HR KLO 0004
2 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-00 - Implausible Signal
00930 - Locking Module for Central Locking; Rear Left (F222)
27-10 - Implausible Signal - Intermittent
End
pavel.d, Что скажете по моим ошибкам ?
| Получено: 5 Отправлено: 0 |
По двигателю ошибок нет. Остальные по блоку климата - сервоприводы заслонок (это норма, поищите тему в бз). По блоку комфорта - ошибки центрального замка водителя и заднего левого пассажира, если стоит сигнала то вероятно неправильно подключено или провода проверять, имеют свойство гнить. Возможно из-за сигналуи с двигателем косяки
Проблема с сигналкой может отражаться на работе двигателя ? Я правильно понял ?
На VAGах возможно всё. Когда ошибок нет - смотреть показания по группам: 3,4,8,10
Ремень ГРМ - или пора менять или угол отрегулировать
В 4 группе во 2м и 4м окне в идеале должен быть 0, а с такими показаниями похоже или растянут или неправильно выставлен. Отсюда и проблемы с заводом
pavel.d, А что скажите по 23 группе ?
Показания, несомненно, высоки, но и коррекция впрыска в 13 группе радует и косвенно свидетельствует о хорошей компрессии и общем состоянии поршневой и самих форсунок. Двигатель прогрет выше 88С? Я бы проверил метки и углы грм для начала и НЕ ЕЗДИЛ при таком рассинхроне. Насос-форсунки живучие на наших двиглах, а грм рекомендовано менять каждые 80000км/50000миль. Если пробег 232ткм реален и вы лично не меняли его еще ни разу, то 100℅ - начать следует именно с него!!! Рекомендую сразу и помпу поменять, чтоб не лазить несколько раз. Я вам отправлял ссылку на русский ваг ком, там более понятны будут группы и их показания.
Еще вопрос егр заглушен?
как проверить ? Стоит , но я не знаю заглушен он или нет
Я из китая заказывал , а там только английский язык (((. С помощью добрых людей , на просторах инета , справляюсь![]()
у меня тоже ваг ком из китая, программу качал, куда вас отправил. а набор lbl файлов с этого форума установил.
по егр ищите тему "глушим egr avf". вообще, тут много тем именно на avf двигателя, но большая часть применима к нашему avb, поскольку avf - форсированный двиг avb, отличие в форсунках и турбине, и еще некоторые нюансы, но в целом проблемы и их решения одинаковы для обоих двигателей
| Получено: 0 Отправлено: 2 |
почитал но непонял какие трубки надо менять на прозрачные чтоб определить падсос воздуха в систему? черканите если не трудно.
| Получено: 2,875 Отправлено: 2,845 |
трубки на топливном фильтре,со стороны моторного щита две трубки одна будет приходящая а вторая обратка.трубки не менять ,а наростить прозрачными
2004продан, Ауди Q7 WAUZZZ4L0DD019696 не стой на месте, ищи новые тупики.
pavel.d у меня тоже ваг ком из китая, программу качал, куда вас отправил. а набор lbl файлов с этого форума установил.
Не нашёл ссылки . Где искать ?![]()
спс попробую наростить. и ещё вопросик гуру, : Утром после 3-4 раз манипуляцией ключём (нагрев свечей накала) потом покрутив стартером 5-6 сек. заводиться, но при этом выходит облако серого дыма (как будто перекачал педалькой газа) при этом педаль не трогаю совсем.(запах не сгоревшей соляры).но работает дальше ровно без рывков и прочих нареканий. что это? может подскажите если в курсе..![]()
андрей_40rus, сразу вопроссколько масла подъедает.На своей делал непосредственную промывку форсунок ликвимолем,чуть меньше стало дымить при запуске,но все равно есть едучий дым на холодном запуске
масло подливаю от замены до замены 7-8 тысяч км 1- 1.5л. но у меня ещё подкапывет с кулера с турбинки гонит, грешу на это.
