омраченное утро
    Golf Аватар для 3D_max
    Сургут
    Получено: 19
    По умолчанию омраченное утро
    Вышел сегодня заводить,
    на приборке загорелось:epc,esp,ручник и пиктограмма круиза с восклицательным знаком
    Ошибки:
    VCDS Version: Release 11.11.2
    Data version: 20120126
    Monday,10,February,2014,07:47:47:62939
    Chassis Type: 3C0
    Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 53 56 62 72
    VIN: WVWZZZ3CZ7E247192
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: Malfunction 0010
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 06F 906 056 GQ HW: 06F 906 056 DQ
    Component: MED9.5.10 G02 3371
    Revision: 68H03--- Serial number: VWZCZ000000000
    Coding: 0000172
    Shop #: WSC 00160 935 176946
    VCID: 7EF3187329EC543
    Part No: 06F 907 807 H
    Component: NOX 0704230017 001 0409
    06F907807H NOX 0704230017 001 0409
    1 Fault Found:
    005445 - Throttle Valve Controller
    P1545 - 008 - Malfunction
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 135674 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 07:43:12
    Freeze Frame:
    RPM: 1000 /min
    Load: 36.5 %
    Speed: 0.0 km/h
    Temperature: 54.0°C
    Readiness: 1110 0101
    Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
    Part No SW: 3C0 614 109 HW: 3C0 614 109
    Component: ESP 440 C4 H018 0001
    Revision: H018 Serial number: 0775404016
    Coding: 0013722
    Shop #: WSC 05311 000 00000
    VCID: DBB5F1E71A3E21B
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 3
    Fault Frequency: 9
    Reset counter: 80
    Mileage: 135674 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 07:30:26
    Address 08: Auto HVAC Labels: 3C0-907-044.lbl
    Part No SW: 3C0 907 044 BC HW: 3C0 907 044 BC
    Component: ClimatronicPQ46 112 0606
    Revision: 00112021 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 63C54907A24E99B
    1 Fault Found:
    00819 - High Pressure Sensor (G65)
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00111001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 135149 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 20:12:55
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 3C0 937 049 AG HW: 3C0 937 049 AG
    Component: Bordnetz-SG H52 2002
    Revision: 00H52000 Serial number: 00000007037956
    Coding: F58C8F0700041A00470A00000F000000001D5D435C0001
    Shop #: WSC 05311 123 12345
    VCID: 6ED32833798C243
    Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
    Component: Wischer 250407 003 0205
    Coding: 00049045
    Shop #: WSC 05311
    Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
    Component: RLS 090507 020 0105
    Coding: 00208933
    Shop #: WSC 05311
    2 Faults Found:
    00061 - Footwell Lights
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 81
    Mileage: 131583 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 12.05 V
    OFF
    ON
    OFF
    OFF
    OFF
    00059 - Terminal 30 for Interior Lighting
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 101
    Mileage: 135191 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 14.25 V
    ON
    OFF
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
    Component: 0B AIRBAG VW8 032 2522
    Revision: 12032000 Serial number: 003B1P9MFMJ+
    Coding: 0012354
    VCID: 306FF64BA338723
    No fault code found.
    Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
    Part No SW: 3C0 953 549 L HW: 3C0 953 549 L
    Component: Lenksдulenmodul 006 0010
    Revision: 00006000 Serial number: 3C9953507AH
    Coding: 0000014
    VCID: 3561C75F5C5A57B
    Address 17: Instruments
    Cannot be reached
    Address 19: CAN Gateway Labels: 3C0-907-530.lbl
    Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
    Component: Gateway 007 0040
    Revision: 00007000 Serial number: 0700C0750407C6
    Coding: BDFD0C04C22002
    VCID: 2149030FF8D2CBB
    Address 22: AWD Labels: 1K0-907-554.lbl
    Part No: 1K0 907 554 K
    Component: Haldex 4Motion 1118
    Coding: 0000001
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
    Component: IMMO 042 0383
    Revision: 00042000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: 3979CB6F7042B3B
    Part No: 3C0 905 861 G
    Component: ELV 027 0380
    3C0905861G ELV 027 0380
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
    Component: J386 TUER-SG FT 1131
    Revision: 32008001 Serial number: 00000011078501
    Coding: 0000245
    VCID: 3B75D1677A7E81B
    1 Fault Found:
    00120 - Outside Warning Light/Door exit Light Driver Side
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 77
    Reset counter: 121
    Mileage: 135342 km
    Time Indication: 0
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K1 909 144 L
    Component: EPS_ZFLS Kl.134 H07 1806
    Shop #: WSC 02069 000 90108
    VCID: 3467FA5B57204E3
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Component: KSG PQ46 ELV 042 0472
    Coding: 0091020051034E7230049C1D70084F0E707CA0
    Part No: 1K0 951 605 D
    Component: LIN BACKUP HORN H07 9001
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
    Component: J387 TUER-SG BT 1131
    Revision: 32008001 Serial number: 00000546378504
    Coding: 0000244
    VCID: 3C77D27B7F70863
    1 Fault Found:
    00121 - Outside Warning Light/Door exit Light Passenger Side
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 67
    Reset counter: 121
    Mileage: 135342 km
    Time Indication: 0
    Address 53: Parking Brake Labels: 3C0-907-801-53.clb
    Part No SW: 3C0 907 801 E HW: 3C0 907 801 E
    Component: EPB VC8HC003 013 0003
    Revision: 013
    Coding: 0000011
    VCID: 24470A1BE7C0DE3
    2 Faults Found:
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 6
    Fault Frequency: 4
    Reset counter: 121
    Mileage: 135560 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:25:36
    Freeze Frame:
    Voltage: 7.87 V
    Count: 202
    02443 - Control Head
    012 - Electrical Fault in Circuit - MIL ON
    Freeze Frame:
    Fault Status: 11101100
    Fault Priority: 2
    Fault Frequency: 13
    Reset counter: 81
    Mileage: 135328 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 07:11:00
    Freeze Frame:
    Voltage: 14.18 V
    Count: 40
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 1K0 035 186 T
    Component: Radio GR0 020 0023
    Revision: 0002006S Serial number: VWZ2Z2G3622811
    Coding: 0040402
    Shop #: WSC 05314 000 00000
    VCID: 377DCD574656A5B
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
    Component: J388 TUER-SG HL 1119
    Revision: 11006001 Serial number: 00000001689811
    Coding: 0000208
    VCID: 3D71DF7F646A8FB
    1 Fault Found:
    00122 - Outside Warning Light/Door exit Light; Rear Left
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 120
    Mileage: 135342 km
    Time Indication: 0
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
    Component: J389 TUER-SG HR 1119
    Revision: 11006001 Serial number: 00000001694898
    Coding: 0000208
    VCID: 3E73D873696C943
    1 Fault Found:
    00123 - Outside Warning Light/Door exit Light; Rear Right
    Freeze Frame:
    Fault Status: 00111100
    Fault Priority: 5
    Fault Frequency: 9
    Reset counter: 120
    Mileage: 135342 km
    Time Indication: 0
    End ---------------------------------------------------------------------
    Ошибки не сбрасывались, обороты больше 2000 не поднимались!
    После 20 минут прогрева, заглушил -завел.
    на приборке все погасло, ошибки стер.
    что это было?
    B6 2.0 FSI BVX 2007 6МКПП 4 motion
    Когда ДЗ чистилась последний раз с адаптацией?
    Polo Аватар для z17atlet
    Россия, Киров
    Получено: 9
    С большой долей вероятности необходима чистка ДЗ
    VW Passat B6, 2.0 FSI BVY, АКПП, 2006
    VW Passat B5, 1.6 AHL, МКПП, 1998
    Сургут
    Получено: 19
    планировал при следующей замене масла)
    кроме прокладки под ДЗ и компа, что еще нужно?
    кстати с кодированием блоков чтоб не ругались на диодные лапочки подсветки не поможешь?
    Насчет лампочек ХЗ
    Прокладка и все. Чисти лучше. Адаптация потом в принципе не нужна, она сама адаптируется. Но для чистоты души можешь сделать
    Сургут
    Получено: 19
    оно?
    Адаптация дроссельной заслонки:
    1.Зажигание включить ON
    2.Двигатель OFF
    3.Напряжение на АКБ не ниже 11.0 V.
    4.Зайти в блок упр двигателя:
    [Select]
    [01 - Engine]
    5.Выбрать:
    [Basic Settings - 04]
    Group 060
    [Go!]
    Aктивировать базовую установку дроссельной заслонки.
    [ON/OFF/Next]
    В четвёртом окошке должно появиться "ADP. O.K.".
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    Выключить зажигание OFF.
    оно?
    Да
  1. Ответов: 40
    Последнее сообщение: 04.05.2010, 00:30
  2. Ответов: 7
    Последнее сообщение: 02.10.2009, 16:09
  3. Ответов: 11
    Последнее сообщение: 23.12.2008, 19:11
  4. Ответов: 0
    Последнее сообщение: 18.09.2006, 10:04
  5. Хорошее утро. 500 с утра отдал и свободен!!
    от Андрей гарант в разделе Архив 2005г.
    Ответов: 26
    Последнее сообщение: 28.09.2005, 10:48
