Доброго времени суток!
После затопления водой блока комфорта в салоне, провел сам диагностику. Вот такие результаты:
Saturday,28,May,2011,16:36:23:46862
VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ3E120138 Mileage: 166870km/103688miles
Address 01: Engine Labels: 06B-906-018-AWT.lbl
Part No: 4B0 906 018 DJ
Component: 1.8L R4/5VT 0001
Coding: 26001
Shop #: WSC 00539
VCID: 6CDCC6EE70D1E17C
WVWZZZ3BZ3E120138 VWZ7Z0B5766474
4 Faults Found
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 B
Component: ABS/EDS 5.3 FRONT D10
Shop #: BB 24332
VCID: 1D3ADB2AFBEBD8F4
No fault code found.
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 J
Component: CLIMATRONIC B5GP 0005
Coding: 17000
Shop #: WSC 05311
VCID: 2854FAFEA4A90D5C
4 Faults Found
00603 - Footwell/defroster Flap Positioning Motor (V85)
37-10 - Faulty - Intermittent
01272 - Positioning Motor for Central Flap (V70)
37-00 - Faulty
01274 - Air Flow Flap Positioning Motor (V71)
01336 - Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 601 A
Component: 0J AIRBAG VW51 0004
Coding: 12362
Shop #: WSC 05311
VCID: 1E38DC26F6EDC3EC
1 Fault Found
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 827 X
Component: KOMBI+WEGFAHRSP VDO V05
Coding: 05125
Shop #: WSC 50000
VCID: 39722FBA4F0384D4
5 Faults Found
01316 - ABS Control Module
49-00 - No Communications
49-10 - No Communications - Intermittent
01330 - Central Control Module for Central Convenience (J393)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 54400
VCID: F0E4529EDCF9859C
8 Faults Found
01320 - Control Module for Climatronic (J255)
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 A
Component: 7W Komfortgerбt HLO 0003
Coding: 00067
Shop #: WSC 05311
VCID: 356A238A631B60B4
Part No: 1C1959801
Component: 7W Tхrsteuer.FS KLO 0004
Part No: 1C1959802
Component: 7W Tхrsteuer.BF KLO 0004
5 Faults Found
00954 - Starter Inhibitor Relay (J433)
28-10 - Short to Plus - Intermittent
01141 - Luggage Compartment Unlocking Switch (E165)
27-10 - Implausible Signal - Intermittent
01044 - Control Module Incorrectly Coded
35-00 - -
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-00 - Implausible Signal
End ---------------------------------------------------------------------
Из того,что заметил сам:
дверь заднего левого пассажира не выходит из режима блокировки, дверь багажника открывается только ключом, и не работает дистанционный штатный брелок.
Если кто знает, прокомментируйте и посоветуйте как чинить.
в населенном пункте нет толковых электриков, для ремонта надо ехать в другой город.
Заранее спасибо)
| Получено: 356 Отправлено: 64 |
Для ошибок существует специальная тема.
