| Получено: 0 Отправлено: 4 |
Всем доброго дня.
Ставлю котел. Машина с климой. На форуме вычитал, что есть штатшые пины в разъеме климы для вебасты.
Есть у кого распиновка разъема климы?
... или может кто на память помнит?
Спасибо.
Может кто в Эльзе посмотрит? Там, вроде, должно быть...
Спасибо.
Passat B6 V6 3.2 FSI 4motion
Спасибо всем ответившим.
... т.е. мне самому.
Ответ найдет тут:
http://forums.tdiclub.com/showpost.p...7&postcount=52
Вдруг кому интересно:
climatronic is designed to work with the webasto/standheizung parking heater.
On the back of the climatronic head unit you have 4 connectors. Facing the back of the climatronic HU the connector on the left is a 16 pin connector with larger pins than the rest. For wiring up the webasto you will need to add a wire to pin 1 of those connector. This wire will provide power to the HU so it can run when the car is off. It powers the HU and the servo motors. The other end of this wire will get wired to the signal wire going to the fan relay in the climatronic harness.
The rest of the wiring is the same as for the manual AC vehicles. You simply need to find fuse 25, cut it and splice in the 2 wires going to the relay. This is the fuse for the climate control blower power and normally receives its power from 75x(swithched power). When the webaso isnt running the relay just allows power to pass through that circuit. When it is runing it provides power to the blower motor via the fuse with the webasto harness which gets wired to the battery. If you splice the 2 wires in backwards then the blower fan wont come on while the webasto is running..... (thats what I get for not reading directions).
When the heater is turned on and the car is off the control panel will be on and will show "HE" in place of the outside temperate. Saddly thats all it does. It doesnt automatically set the unit to defrost or up the temp or anything like that. I just keeps the settings it had when the car was shut off.
If you power the car on while the webasto it will change back to the normal mode and display the outside temp.
Not real technical but if you have any issues or questions with this just shoot me a PM.
