| Получено: 361  Отправлено: 217  |
					здоровье не купишь не за какие деньги
| Получено: 266  Отправлено: 245  |
					скажи номер контроллера ЭБУД - посмотрю что есть
для контроллера 8D0-907-557 (ADR|ADP):
; measuring block information
000,0,Basic Function
000,1,Coolant Temperature,Specification: 170...204 (80..105 °C)
000,2,Engine Load,Specification: 20...55 (1.0...2.5 ms)
000,3,Engine Speed,Specification: 76...96 (760...960 RPM)
000,4,Supply Voltage,Specification: 176...212 (12.0...14.5 V)
000,5,Throttle Valve Angle,Specification: 0...12 (0.5 <°)
000,6,Idle Air Control,Specification: 122...144 (-4.0...+4.0 kg/h)
000,7,Idle Air Control (learned),Specification: 122...144 (-4.0...+4.0 kg/h)
000,8,Lambda Regulation (learned),Specification: 115...143 (-10.0...+10.0 %)
000,9,Lambda Regulation (learned - additive),Specification: 243...255 / 0...13 (-0.64...+0.64 %)
000,10,Lambda Regulation (learned - multiplicative),Specification: 118...138 (-8...+8 %)
001,0,Basic Function
001,1,Engine Speed,,Specification (idle): 760...960 RPM
001,2,Engine Load,,Specification: 1.0...2.5 ms
001,3,Throttle Body Angle,,Specification: 0...5 <°
001,4,Ignition Angle,,Specification: 12 °BTDC
002,0,Basic Function
002,1,Engine Speed,,Specification (idle): 760...960 RPM
002,2,Injection Period,(theoretical),Specification: 1.0...2.5 ms
002,3,Injection Period,(corrected),Specification: 2.0...5.0 ms
002,4,Intake Air Mass,,Specification: 2.0...4.0 g/s
003,0,Basic Function
003,1,Engine Speed,,Specification (idle): 760...960 RPM
003,2,Supply Voltage,,Specification: 12.0...14.5 V
003,3,Coolant,Temperature,Specification: 80..105 °C
003,4,Intake Air,Temperature,Specification: approx. outside Temperature
004,0,Idling Speed Stabilisation
004,1,Throttle Body Angle,,Specification: 0...5 <°
004,2,Intake Air Mass,(idle),Specification: -1.1...1.1 g/s
004,3,Intake Air Mass,(load),Specification: -1.1...1.1 g/s
004,4,Operating Mode,,Specification: Idle/Throttle/Enrich
005,0,Idling Speed Stabilisation
005,1,Engine Speed,(actual),Specification (idle): 760...960 RPM
005,2,Engine Speed,(specified),Specification: 860 rpm
005,3,Idle Regulation,,Specification: -10.0...+10.0 %
005,4,Intake Air Mass,,Specification: 2.0...4.0 g/s
006,0,Idling Speed Stabilisation
006,1,Engine Speed,,Specification (idle): 760...960 RPM
006,2,Idle Regulation,,Specification: -10.0...+10.0 %
006,3,Lambda,Regulation,Specification: -10.0...+10.0 %
006,4,Ignition Angle,,Specification: 12 °BTDC
007,0,Lambda Control
007,1,Lambda,Regulation,Specification: -10.0...+10.0 %
007,2,Lambda Probe,Voltage,Specification: -0.1...+1.1 V
007,3,Charcoal Filter,Solenoid Valve,Specification: 0.0...99.0 %
007,4,Lambda Correction,Factor,Specification: 0.3...1.2
008,0,Lambda learnt Values
008,1,Injection Period,(corrected),Specification: 2.0...5.0 ms
008,2,Lambda Regulat.,(learned - additive),Specification: -10.0...+10.0 %
008,3,Lambda Regulat.,(learned - multipl.),Specification: -8.0...+8.0 %
008,4,Fuel Tank,Venting
009,0,Lambda learnt Values
009,1,Engine Speed,,Specification (idle): 760...960 RPM
009,2,Lambda,Regulation,Specification: -10.0...+10.0 %
009,3,Lambda Probe,Voltage,Specification: -0.1...+1.1 V
009,4,Lambda Regulat.,(learned - additive),Specification: -10.0...+10.0 %
010,0,Fuel Tank Breather
010,1,Charcoal Filter,Solenoid Valve,Specification: 0.0...99.0 %
010,2,Lambda Correction,Factor,Specification: 0.3...1.2
010,3,Charcoal Filter,Charge Level,Specification: -3...+30
010,4,Fuel Tank Venting,Purge Rate,Specification: 0.0...0.3
011,0,Fuel Consumption
011,1,Engine Speed,,Specification (idle): 760...960 RPM
011,2,Engine Load,,Specification: 1.0...2.5 ms
011,3,Vehicle Speed,,Specification: 0 km/h
011,4,Fuel Consumption,,Specification: 0.5...1.5 l/h
012,0,Fuel Consumtion (during Idling)
012,1,Engine Speed,,Specification (idle): 760...960 RPM
012,2,Supply Voltage,,Specification: 12.0...14.5 V
012,3,Fuel Consumption,,Specification: 0.5...1.5 l/h
012,4,Ignition Angle,,Specification: 12 °BTDC
013,0,Knock Control (Timing Retardation - Cylinder 1 - 4)
013,1,Timing Retardation,Cylinder 1,Specification: 0...15 °BTDC
013,2,Timing Retardation,Cylinder 2,Specification: 0...15 °BTDC
013,3,Timing Retardation,Cylinder 3,Specification: 0...15 °BTDC
013,4,Timing Retardation,Cylinder 4,Specification: 0...15 °BTDC
014,0,Knock Control (Timing Retardation - Cylinder 1 && 2)
014,1,Engine Speed,,Specification (idle): 760...960 RPM
014,2,Engine Load,,Specification: 0.5...1.5 ms
014,3,Timing Retardation,Cylinder 1,Specification: 0...15 °BTDC
014,4,Timing Retardation,Cylinder 2,Specification: 0...15 °BTDC
015,0,Knock Control (Timing Retardation - Cylinder 3 && 4)
015,1,Engine Speed,,Specification (idle): 760...960 RPM
015,2,Engine Load,,Specification: 0.5...1.5 ms
015,3,Timing Retardation,Cylinder 3,Specification: 0...15 °BTDC
015,4,Timing Retardation,Cylinder 4,Specification: 0...15 °BTDC
016,0,Knock Control (Sensor Signal - Cylinder 1 - 4)
016,1,Knock Sensor,Cylinder 1,Specification: 0.6...1.4 V
016,2,Knock Sensor,Cylinder 2,Specification: 0.6...1.4 V
016,3,Knock Sensor,Cylinder 3,Specification: 0.6...1.4 V
016,4,Knock Sensor,Cylinder 4,Specification: 0.6...1.4 V
017,0,Not relevant for AEB (catalytic converter too close to engine)
018,0,Altitude Correction
018,1,Engine Speed,,Specification (idle): 760...960 RPM
018,2,Engine Load,(bef. Correction),Specification: 0.5...1.5 ms
018,3,Engine Load,(aft. Correction)
018,4,Altitude Correction,Factor,Specification: -30...+25 %
019,0,Torque Reduction (only with automatic transmission)
019,1,Engine Speed,,Specification (idle): 760...960 RPM
019,2,Engine Load,,Specification: 0.5...1.5 ms
019,3,Ignition Angle,Retardation
019,4,Ignition Angle,,Specification: 12 °BTDC
020,0,Operating States
020,1,Engine Speed,,Specification (idle): 760...960 RPM
020,2,Selector Lever,Position,Display Range: Neutral/Gear ENG.
020,3,Air Conditioning,Operating Mode,Display Range: A/C High/Low
020,4,Air Conditioning,Status,Display Range: Compr. ON/OFF
021,0,Lambda Control
021,1,Engine Speed,,Specification (idle): 760...960 RPM
021,2,Engine Load,,Specification: 0.5...1.5 ms
021,3,Coolant,Temperature,Specification: 80..105 °C
021,4,Lambda Control,Operating Mode,Display Range: Reg. ON/OFF
023,0,Throttle Body Adaptation Information
023,1,Adaptation Status,,Specification: 100000
; 0xxxxx - Throttle Potentiometer adjustment with Idling Potentiometer not OK
; x1xxxx - Throttle Body Adaptation not OK
; xx1xxx - Learning process Max. Position Throttle Potentiometer not OK
; xxx1xx - Learning process Min. Position Throttle Potentiometer not OK
; xxxx1x - Learning process Max. Position Idling Potentiometer not OK
; xxxxx1 - Learning process Min. Position Idling Potentiometer not OK
023,2,Throttle Body,Min. Position,Specification: 70...93 %
023,3,Throttle Body,Emergency Stop,Specification: 67...83 %
023,4,Throttle Body,Max. Position,Specification: 8...39 %
024,0,Knock Control
024,1,Engine Speed
024,2,Engine Load,,Specification: 0.5...1.5 ms
024,3,Ignition Angle
024,4,Timing Retardation,Sum of Cyl. 1-4
025,0,Charge Pressure Control (Wastegate)
025,1,Engine Load,(bef. correction),Specification: 3.0...8.0 ms
025,2,Engine Load,(aft. correction),Specification: 3.0...8.0 ms
025,3,Engine Load,(actual),Specification: 0.5...8.0 ms
025,4,Charge Pressure,Solenoid Valve,Specification: 0.0...99.0 %
026,0,Idling Air Demand
026,1,Idle Regulation,,Specification: -10.0...+10.0 %
026,2,Intake Air Mass,,Specification: 1.8...4.0 g/s
026,3,Coolant,Temperature,Specification: 80..105 °C
026,4,Engine Speed,,Specification (idle): 760...960 RPM
027,0,Load Reduction (through Knock Control)
027,1,Engine Load,(Reduction),Specification: 0.0...5.0 ms
027,2,Engine Load,(aft. correction),Specification: 0.5...8.0 ms
027,3,Engine Speed
027,4,Charge Pressure,Solenoid Valve,Specification: 0.0...99.0 %
098,0,Throttle Body Adaptation (Basic Setting)
098,1,Throttle Valve,Potentiometer,Specification: 0.5...4.9 V
098,2,Idling Positioner,Potentiometer
098,3,Operating Mode,,Specification: Idle/Throttle/Enrich
098,4,Adaption Status,,Specification: ADP OK\nDisplay Range: ADP OK/ADP RUN/ERROR
099,0,Lambda Control (Basic Setting)
099,1,Engine Speed
099,2,Coolant,Temperature,Specification: 80..105 °C
099,3,Lambda,Regulation,Specification: -10.0...+10.0 %
099,4,Status Lambda,Regulation,Display Range: Reg. ON/OFF
					у меня 8D0-906-018 R. это ты откуда взял инфу? не с лбл файла?
у тебя нет для моего контроллера? скажи где надыбал, может сам нарою.
и если не ошибаюсь там групп должно быть 255, разве не так?
| Получено: 796  Отправлено: 794  |
					Всем привет!!!
					щас поеду за лавром и силиконом в спортавто. пора делать уже мероприятия помощи своему коню.![]()
| Получено: 2,275  Отправлено: 3,009  |
					ну почему же просто так.
под поляну с некими горючими жидкостями![]()
					да, это лбл файл... у меня такого нет... посмотри на просторах инета -- точно найдешь.. в файле ищи параметр Missfire - пропуски зажигания.. если есть - значит скорее всего есть возможность посмотреть пропуски.. если нет - увы...
групп то 255, но на каждом контроллере используются только определенные... у меня на АХЛ вообще было доступно только групп 20-30... остальные - для более крутых (читай "напичканых электроникой") моторов..![]()
					у меня есть лбл для моего мотора щас мосмотрю там вроде такого вообще нет как ты написал
					в Вологде сегодня рейд, снова весь город стоит
					нет у меня просмотра пропусков зажигания..
я был на ленинградке дак сразу за мостом перед гончарной столкнулись 3или4 машины там какой то круза тойота легковая какая то митсубиси и что то еще . и мены на форде приехали.из за этого опять затор туда
вчера на это месте в час ночи тож авария была. реанимация приезжала даже
					дочку спать укладывал
в кресло положишь и поехал сразу засыпает а так ни в какую
люди,как проверить ДТОЖ?
					да чета больше никак не получается.
					сначала на ухо наарет . потом как начнет лягаться. тут уснешь.ага. книжку послушает.
| Получено: 1,108  Отправлено: 823  |
					Добрый вечер.![]()
