добрый день!
вообшем была ошибка:
00283 - Front Left ABS Wheel Speed Sensor (G47)
30-00 - Open or Short to B+
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-10 - - - Intermittent
поменял сенсор, стёр ошибки а они поивились вновь!!!![]()
| Получено: 2 Отправлено: 0 |
У нас есть отдельная тема по ошибкам, пиши сюдаСообщение от fircic
добрый день!
http://www.passatworld.ru/phpBB2/viewtopi ... start=2670
писал но нет ответа. решил попробывать удачу здесь....
| Получено: 817 Отправлено: 1,016 |
[code]0283 - ABS Wheel Speed Sensor Front Left (G47)
00283 - ABS Wheel Speed Sensor Front Left (G47): Signal Outside Specifications
00283 - ABS Wheel Speed Sensor Front Left (G47): Electrical Fault in Circuit
Possible Causes
Open Circuit in Wiring from/to ABS Wheel Speed Sensor Front Left (G47)
ABS Wheel Speed Sensor Front Left (G47) faulty
Possible Solutions
Check Wiring from/to ABS Wheel Speed Sensor Front Left (G47)
Check ABS Wheel Speed Sensor Front Left (G47)
00283 - ABS Wheel Speed Sensor Front Left (G47): Mechanical Malfunction
Possible Causes
Excessive Air Gap between ABS Wheel Speed Sensor Front Left (G47) and Rotor
Short Circuit in Wiring from/to ABS Wheel Speed Sensor Front Left (G47)
Possible Solutions
Check ABS Wheel Speed Sensor Front Left (G47) Installation
Check ABS Wheel Speed Sensor Front Left (G47)[/code]
[code]01203 - Electrical Connection between ABS and Instrument Cluster
01203 - Electrical Connection between ABS and Instrument Cluster: Open or Short to Ground
Possible Symptoms
ABS Malfunctions
Possible Causes
Wiring between ABS and Instrument Cluster defective
Instrument Cluster defective (rare)
Possible Solutions
Check Wiring between ABS and Instrument Cluster for Short to Ground/Open Circuit
Check Instrument Cluster
01203 - Electrical Connection between ABS and Instrument Cluster: No Signal
Possible Symptoms
ABS Malfunctions
Possible Causes
ABS incorrectly coded
Possible Solutions
Check Wiring between ABS and Instrument Cluster for Short to Plus
Check ABS Coding
Check Instrument Cluster[/code]
Инструкцию не нашелСообщение от fircic
P1848 - 35-10 - - - Intermittent![]()
Спасибо огромное!!!!!!!!буду искать!!!!!
тебе ещё в АВГУСТЕ про ошибку соединения АБС с панелью приборов всё написали... [-XСообщение от fircic
писал но нет ответа
к чему новые темы заводить ???
| Получено: 61 Отправлено: 14 |
я так понял, что в россии круче перцы чем в америке.+1![]()
Дело в том что я не мастер в т\о а просто пользуюсь авто в своё удовольствие и хочу однажды избавится от этого проклятого звука зумера.
Я снимал АБС паял всё как в том топике, после пропаике STOP check manual пропал дисплей вернулся но загорелась ASR лампочка и не выключается+зумер всё зумит и зумит а диагностика показывает те ошибки что написл выше...
и к слову сенсор АБС поменял 2 дня назад..... после стёр ошибки и снова проверил.....
поэтому и завожу....Сообщение от 1967s
Добавлено спустя 12 минут 53 секунды:
Добавлено спустя 5 минут 9 секунд:
я был бы рад если у меня получилось починить всё ето![]()
так как проблем и так хвотает....
Скорее всего, пока паял одно, повредил золотой волосок от колёсного датчика (это очень легко сделать, но трудно восстановить).Сообщение от fircic
Обрыв налицо.Сообщение от fircic
Open or Short to B+
Если датчик и проводка до блока в норме, то остаётся только это.
может быть.... если это те что прям рядом то возможно хотя вроде целые были......
ты просто делая одно - повредил другое там же...Сообщение от fircic
их повреждение просто так можно запросто не заметить...Сообщение от fircic
Сообщение от Чубук
fircic, 01203 - Electrical Connection between ABS and Instrument Cluster - этом основная проблема ИХМО, а как ты проверил что припаял? просто капнуть олово недостаточно - там нужен спец флюс - без него только видимость припайки создаётся
1999 1.8T AEB - ПРОДАН
R51 2.5 TD - 2012 - "Снежок"
Просто до припаики вообше не конектилось а после конектится и с радостью выдаёт эти ошибки и забыл сказать что при рескомнажатие на тормоз АБС какбы начинает бить в педаль и перестаёт и моментально выпрыгивает STOP abs fault и после трех секунд исчезает.....![]()
