| Получено: 2,673 Отправлено: 2,225 |
Lucky3D
Жаль, если такой красавец уйдет из клуба. Миша![]()
Типа АП
Кто его знает.. может останется машинка в клубе..
>> B5 1997 AEB >> 2003-2009
Может и останется,моя вроде осталасьВо всяком случае наклейка пока висит и человек тут зарегистрировался.
Sales type: 3B23J5 ()
Дата выпуска: 03.11.1997
Модельный год: 1998
Код и номер двигателя: AEB XXXXXXX
Код КПП: DHW
Комбинация цветов интерьера: GP
Комбинация цветов кузова: Z4
Roof color: Z4
Комплектация автомобиля (код и наименование):
0DE installation differentiation for build status of vehicle class B5 (VW Passat)
0FA standard manufacturing sequence
0G1 gearshift lever
0JG weight category front axle weight range 7
0K0 without alternative drive module
0KA without stickers and badges
0LA without special plates/stickers/safety certificates
0NA without nameplate set (without model designation)
0RA without ignition/starter switch locking system
0SB labels/plates in German
0TA without floor mats
0Y1 standard climatic zones
0YC weight category rear axle weight range 3
1AH electronic differential lock (EDL)
1BA standard suspension/shock absorption
1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
1D0 without towing attachment
1E1 activated carbon canister
1EX special identification plate for EC
1G2 steel spare wheel with original equipment tires
1LB disc brakes, front
1PA standard wheel bolts
1SA without additional engine guard
1T2 warning triangle
1V0 without duty-free and cost-free tires
1VG installation parts for four-cylinder engine
1X0 front wheel drive
1Z0 initial standard fuel filling
2B1 additional exterior noise suppression
2G1 insert for the filling up of unleaded fuel
2JB standard bumpers
2PQ steering wheel for airbag system
2WA without additional tires
3B0 without additional child seat anchor
3C3 lap belt with retractor for the center rear seat
3CA without partition
3FA without roof insert (standard roof)
3GK without additional filler for plane trunk floor
3J7 articulated and height-adjustable headrests for front seats
3L3 manual height adjustment for front seats
3LD door and side panel trim
3MQ Ibolours floor covering
3NZ rear seat bench unsplit, backrest split folding
3Q1 rear headrests
3S0 without roof rails/roof load rack
3X0 without load-through provision
3Y0 without roll-up sun screen
4A3 seat heater for front seats separately controlled
4B1 protective side molding
4E0 tailgate/trunk lid unlocking from outside
4GH windshield tinted with windshield sunshield
4K3 radio remote controlled central locking operated from inside and safe securing
4L2 dipping breakaway inside rear view mirror
4M6 cup holder
4Q0 no flame retardent materials
4R3 power windows with comfort operation
4SD left vanity mirror illuminated
4TD right vanity mirror illuminated
4U1 luggage nets/pockets on backrests
4UE airbag f. driver a. front seat passenger
4W0 without cassette and CD storage unit
4X1 side airbag front
4ZE black moldings
5C0 without special body measures
5D1 carrier frequency 433.92 MHz
5K0 without paint preservative
5MA decorative inserts
5RQ outer right rear view mirror: convex
5SL outer left rear view mirror: non-spherical
6EP additional body covers, stone guard
6PA plastic hand brake lever handle
6Q1 plastic gearshift knob/handle
6QB locking rear seat catch
6R1 leatherette gearshift boot
6SD tufted trunk floor covering (dimensionally stable)
6U0 without additional seals outside
6W1 license plate bracket front (large)
6XD outer rear view mirrors: powered, heated
6Y0 without cruise control warning system
7A0 without CD changer/CD player
7AB electronic alarm system with vehicle immobilization device (for RoW)
7B2 12-volt socket in luggage boot
7CA without label for radio remote control
7E0 w/o heat accumulator/auxiliary heating
7P4 manually adjustable lumbar support in front seats
7Q0 without navigation device
7QA without CD ROM
7V0 standard dashboard illumination
8AC radio "beta"
8CC speedometer sensor without seal (electronic speedometer sensor)
8E2 local interference suppression for FM/AMradio reception
6E3 center armrest front
8F2 side turn signal lights
8GD alternator 90A
8JM twin headlamp for left-hand drive with integrated high-beam headlight
8K0 without special low beam mode
8KA w/o catalytic converter warning light
8N4 windshield wiper intermittent control with potentiometer (four speeds)
8NA without parking light warning light
8Q1 headlight-range adjustment
8R1 center high-mounted stop light
8RE four loudspeakers (passive)
8S4 two reading lights front, two rear
8SA taillight assemblies, standard design
8T0 without cruise control system (CCS)
8TC rear fog light for driving on the right
8WD integrated front fog light
8X0 without headlight washer system
8Z5 engine cooling system, type 1
9A0 without taxi alarm system
9AK "Climatronic" with impact pressure control free of cfc
9D0 without preparation for two-way radio installation
9F0 without sound combination for rotating emergency light and radio antenna preparation
9FA without automatic transmission indicator light
9HA without additional malfunction display
9J0 without supertone system and tone sequence control
9P0 without seat belt warning light
9Q1 multi-function indicator/trip computer
9T1 heated washer nozzles, front
9W8 car phone preparation
9X0 without heated door lock cylinder
9Y1 outdoor temperature gage
A8S standard equipment
B01 type approval Germany
B0A component parts set without country-specific design requirement
C05 operating permit, alteration 5
C0V steel wheels 6J x 15 offset 45 (five-hole)
E0A no special edition
F0A no special purpose vehicle, standard equipment
G0C 5-speed manual transmission
H6S tires 195/65 R 15 V
J1P battery 220 A (44 Ah)
K8B notchback
L0L left-hand drive vehicle
M9L 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, MVEG 2 base engine is T8B/T8C
N0U cut pile seat covering
PH2
PT2
Q1A standard front seats
RBB
SR6 Multivan demonstration campaign for Europe
T8B components for base engine, unit 058.D
U0C instrument insert with tachometer clock and km/h speedometer
V0A tires w/o specification of tire brand
WC1
WE1
WW1
| Получено: 0 Отправлено: 2 |
Lucky3D
Привет! А что за фары стоят? Я так, ради интереса. Мой такой же черный-смотрятся классно! Да, и как светят? А вообще, наверное до чертиков жалко такого красавца продавать?!Остается пожелать что бы машинка действительно осталась в рядах клуба! Удачи
| Получено: 12 Отправлено: 3 |
Lucky3D
Добрый вечер! Авто класный, желаю приобрести стоящую замену. Миша извени за вопрос, что за Дефлектор капота стоит.
| Получено: 10 Отправлено: 9 |
Жаль в Мск такого красавца продают...
B5 variant ADR МКПП тряпка, 98г. Голубой сарай.
Вышлии пожалуйста фотки на GrechanukAl СОБАКА yandex.ru, а то у меня на работе на прокси фаервол стоит, картинки не вижу! (я хотел красный или белый, но и черный посмотрю тоже хороший вариант)
Лёньчик Фары Sonar, Тайвань. Брал я их в Германии, когда в России их не было ище (~140 евро пара)... Линзованные, галоген, светят достаточно плохо ..неравномерная засветка.. Мне кажется, что штатный Бош светил лучше.. Но красота страшнаяночью..посмотри у меня в галерее...
Are$ дефлекторы на капот покупаю тока EGR (австралийская контора).. стоят ~$100. Отлично выглядят, правильно крепяться, не мешают аэродинамике..
Ребят, очень жалко машину продавать. Аж прям накатывают иногда слеза.. Но всему свое время.. я не езжу на ней, негде парковать, неудобно ездить (на дачу по проселку), да и самое главное - не хвататет времени, сил и желания заниматься поддержанием машины в тонусе.. а ведь она уже не молода.
Сегодня встал в 5:30, постоял в очереди и в 12:00 снял с учета..
Вроде сегодня до вечера обещали машину забарть.
| Получено: 78 Отправлено: 369 |
Вот такую машину за такие деньги и купить не стыдно!!!! А то выставляют ведра и ценик почти как за новый автомобиль. Уйдет быстро. Удачи!!!
звонков было 6-7. купил фактически первый, кто приехал смотреть.
всё. пойду напьюсь.. ох горе.. продал самую любимую мою игрушку![]()
болван..
..столько воспоминаний с ней связано ярких.. столько уже не будет.![]()
| Получено: 1,493 Отправлено: 2,114 |
Lucky3D
Миш, понимаю тебя. Мне тоже мой прошлый был дорог![]()
Ничего, возмешь следующую игрушку еще лучше![]()
Lucky3D
Миха, поздравляю что ли![]()
У самого слезы наворачивались, когда мой Касссатик уезжал... И уже не со мной![]()
В личке НЕ КОНСУЛЬТИРУЮ!
а где такую решетку приобрел???? и что это за фары????
Vasilich У этой машины был свой шарм. Первая машина, которую я купил сам.. выбрал сам.. пригнал сам.. мне настолько сейчас ничего не нравится.. Следующую придется брать скорее из практичных соображений.. Да и рано пока..
Axl Спасибо, Игорь.. поздравления с "днем без автомобиля" принимаются.
Mop решетку купил в магазине в ГерманииПро фары писал выше. и ещё долго и много на форуме..
Lucky3D
Поздравляю и, наверное, сочувствую... всегда жаль когда такие аппараты уходят... по машине видно что в нее вложено очень много сил и подарено не мало внимания... Достойному хоть хозяину передал? Или не успел заметить?
Нормальный парень, тока машины долго не держит.. посему думаю не очень ухаживает.. Но выбирать тут не приходится.
Машина осталась в Москве.. В клуб человек не захаживал, но может и зайдет.
