Vot chto esti!! A s mosta skidovati nehocu!!!vrode kak cioto ponimaiu no vseotaki mojno uslishati mnenie PROFI
VAG-COM Version: Release 311.2-N
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58,76,77
Address 01 -------------------------------------------------------
Controller: 4B0 906 018 BH
Component: 1.8L R4/5VT G 0006
Coding: 07551
Shop #: WSC 00028
9 Faults Found:
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
17524 - Oxygen (Lambda) Sensor Heating: B1 S1: Open Circuit
P1116 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity P0134 - 35-00 - -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 35-10 - - - Intermittent
16687 - Cylinder 3 Misfire Detected
P0303 - 35-10 - - - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 35-10 - - - Intermittent
16688 - Cylinder 4 Misfire Detected P0304 - 35-10 - - - Intermittent [/color]17658 - Fuel Level too Low
P1250 - 35-00 - -
Readiness: 0010 1101
Address 02 -------------------------------------------------------
Controller: 8D0 927 156 AN
Component: AG5 01V 1.8l5VT USA 3132
Coding: 00104
Shop #: WSC 00028
1 Fault Found:
18158 - Supply Voltage too Low P1750 - 35-10 - - - Intermittent
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AH
Component: ABS/ASR 5.3 FRONT D10
Coding: 00021
Shop #: WSC 00028
3 Faults Found:
00283 - Front Left ABS Wheel Speed Sensor (G47)
30-00 - Open or Short to B+
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-10 - - - Intermittent
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AJ
Component: 6W Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00028
3 Faults Found:
00943 - Heated Exterior Mirror: Driver Side (Z4)
35-00 - -
01358 - Internal Central Locking Switch: Driver Side (E150)
27-10 - Implausible Signal - Intermittent
00944 - Heated Exterior Mirror: Passenger Side (Z5)
35-00 - -
fircic
я не профи, но имхо замена лямбда-зонда, переднего левого датчика, зарядка АКБ тебе помогут
Добавлено спустя 1 минуту 3 секунды:
да, и сотри потом ошибки, они может уже 7 лет висят![]()
A ESLI STERETI SEICEAS PERED ZAMENOI POEAVITSEA POTOM TOLIKO REALINO TE KOTORIE ESTI TAK?![]()
Для начала очисть все текущие ошибки![]()
так конечно, но зачем кричать?![]()
Этого хватит.Сообщение от tecro
Остальное может быть из-за нештатной сигналки.
