Вот нашёл в инете такую хрень:
U281 CAN VW/AUDI Memo Scanner for Volkswagen/Audi
Цена: $32.18 бесплатная доставка - т.е. всего 1000 руб...Manufacturer's product description:
U281 is a kind of auto device for reading and erasing trouble code in vehicles, sometimes called car reader. Though so small, light and handy, which is dynamic and fashionable in design, competitive in price and easy to use.
U281 is specially designed for car owners or DIY. With a U281, you may quickly find out trouble causes (troubleshooter) of electronically controlled systems on your car, by simply connecting U281 with the diagnostic socket, via reading the trouble code (DTC) shown on U281, identifying, locating and checking out trouble causes with attached user's manual.
Features and Benefits
1.Works with Volkswagen and Audi (Audi/Seat/Skoda/Jetta/Golf/Beetle/Touareg/GTI/ Passat and more) sold worldwide of 1990 or CAN Protocol cars.
2.Reads and erases Diagnostic Trouble Codes (DTCs) of Engine, ABS, Airbags and Automatic Transmission.
4.Turns off check engine light.
5.Highly reliable and accurate.
6.Easy-to-read crystal-clear backlit 2-line LCD display.
Easy to use with one plug-in.
7.Stand-alone unit with no need for an additional laptop computer to operate.
8.Small in size and conveniently fits in your palm.
9.Performs continuous DTC scan.
10.Specially designed for DIYers and car-owners.
11.Safely communicates with the on-board computer.
12.No batteries needed-power provided via detachable OBD II cable.
13.User's manual contains VW/AUDI Diagnostic Trouble Code Definitions.
14.One-year warranty.
Dimensions:
• 55cm*15cm*3cm. Extension Cable length = 80 cm
• Specification: 16-pin OBDII Standard Socket
• Voltage: DC 10V~12V
• Temperature: -20'c-50'c
• Display: 2line LCD
Кто-нибудь такое использовал?
Есть у меня такой, или какой-то аналогичный (внешне - один в один, прошивка может чуть другая)...
Читает ошибки, показывает их коды на экране (только цифры, без текстовой расшифровки), позволяет их стереть. Правда на Volvo он видит только ошибки по двигателю, на VAG'ах должен увидеть больше (но не факт что все блоки).
Другими словами с VAG-COM'ом или с аналогичным софтом для КПК эта штука не сравнится. Ну а если кому-то надо просто время от времени читать/стирать ошибки ("гасить Check"), такая штука может пригодиться в качестве бюджетного решения проблемы. Как показывает практика, несколько раз поиграешься - и либо забъешь (т.к. не особо информативно и функций крайне мало), либо перейдешь на что-то более серьезное (тот же VAG-COM, например).
Кстати, подобные вещи уже обсуждались тут, по-моему даже неоднократно.
P.S. По поводу DealExtreme - хороший магазин. Заказывал у них много вещей, и не один раз. Иногда на несколько дней задерживают с отправкой, но в целом нареканий нет - все всегда приходило, и все работало, в точности совпадая с описанием.
Там у них вот какая штука появилась:
VAG5053 Super Memo Scanner for Volkswagen/Audi
Price: $93.87 т.е. приблизительно 2950 руб.Manufacturer's product description:
1. Applications:
VAG5053 is a powerful, affordable handy scanner designed for all VW, AUDI, SKODA, and SEAT vehicles. It is small in size, robust in design, competitive in price and easy to use. With only 10% of the cost of a large special tool, it can nearly do the same work as that of a VAG1551/1552. This is a stand alone unit; it does not need a laptop computer to operate.
2. Available Functions:
Control Unit Information
Read Fault Codes
Measuring Blocks
Clear Fault Codes
Basic Setting
Adaptation
Single Reading
Output Tests
Code Module
Login
Service Oil Reset
Code Modes
Dealership Code Set
3. Supported Systems:
VAG5053 can support the following systems:
Engine
Transmission
Airbag, etc.
there are 78 systems available.
4. Main Features:
Low price: the price is only about 10% of that for a large special tool
Powerful functions: it can nearly do the same work as that of a VAG1551/1552
Powered via diagnostic connector, no additional power is needed
Plug and play, ease to use
High reliable and accurate
действительно хреньСообщение от BOV
оно будет работать - да, но по функциональности - лучше vag-com нет.
зачем избретаешь велосипед? по диагностике ну все уже обсосали как только можно...
Ну да, 100 баксов...
Все такие вещи достаточно специфичны и ограничены по функционалу. С компьютером (и даже с КПК) им спорить тяжело. Тем, у кого нет ноутбука или КПК, это может быть интересно (хотя, опять-таки - ЗАЧЕМ?!). Остальным скорее будет интересен какой-нибудь такой адаптер:
http://www.dealextreme.com/details.dx/sku.16921
andrewju
Привет!
Интересненько...
Медленный - это как? И почему только про ODB?I had to use it through my PDA...
I connected the device to my PDA by BT. Then I installed GpsGate on my laptop and PDA. This software sends what it reads on your PDA serial ports (GPS, Bluetooth, ...) to your computer. Finally it writes data to virtual serial ports on your computer.
Just configure your OBD software to use the virtual port, and you're set!
But it is still slow...
Андрей, никто из наших не купил ещё?![]()
Интересно бы попробовать с MonoScan-ом.
Не, чисто ради искусства...
Чубук, превед!![]()
Один из вольвоводов себе такую штуку ставил, вот:
http://forum.clubvolvo.ru/showthread.php?t=33117
О попытках использования этого адаптера на VAG'ах я не слышал.
Себе хотел как-то заказать, но потом раздумал. Мне интересно пощупать эту штуку вживую, но пользоваться я ею не буду - себе хочу проводной адаптер прикрутить, если решусь поставить CarPC.
Дим, если интересно - я ее закажу для экспериментов, ради искусства!![]()
Только я в отпуск планирую через пару недель уехать, так что заказывать буду либо после отпуска, либо непосредственно перед отъездом, а то вдруг почта меня не дождется и отправит покупку назад, чего доброго...![]()
Ну дык, это ж другое делоСообщение от andrewju
себе хочу проводной адаптер прикрутить, если решусь поставить CarPC![]()
Андрей, отдыхай спокойно.Сообщение от andrewju
если интересно - я ее закажу для экспериментов, ради искусства! Только я в отпуск планирую через пару недель уехать
Вернёшься - тогда видно будет. Может ещё лучше варианты появятся![]()
Мне сейчас тоже не до него, если честно.
Но интересно...
Может кто ещё попробует?
| Получено: 3 Отправлено: 2 |
У меня есть похожий, немного другой. Он показывает номер ошибки и расшифровку, правда на английском языке. Штука удобная. На нем можно не только ошибки читать, но и еще много чего. Просто мы не все знаем как использовать. А в дороге всегда под рукой. Легче и меньше ноута.Чубук, превед!![]()
VW Passat B5.5, 2001, 1.8T,AWM, 170hP, кожа, АКПП, америкос был. Теперь стал обладателем В7 1.4TSI, САХА, 6-ст МКПП, трендлайн.
| Получено: 2,550 Отправлено: 4,115 |
да чип ELM 327+ bluetooth
купил(Генадий) подобное, только проблемы с софтом(комплекте не было), брали на ebay. Но так как хозяин в Риге, а мне нет времени заняться поиском софта, то тема отстановилась
http://www.carobd.com/featobd.html нашел такой проект, но нет времени попробовать
Добрый, день ВСЕМ - интерисующимся и не...
Есть у меня такой адаптер (купил для интереса ещё в январе), и хочу кратенько поделиться своими впечатлениями. Извиняюсь, что с подробными эмоциями.
1. Внешний вид адаптера поразил меня сразу, как только распечатал коробочку. Корпус разъёма представлял собой
перекошенную трапецию с множеством неровностей и не понятных выступов и остатков пластмассы
от штамповки. Пришлось много поработать ножичком, напильником и надфилем. В разъём на машине не входит,
размеры чуть не совпадают, пришлось подгонять (надфилем и скальпелем) разъём адаптера.
2. Софт, на вложенном CD, дремучий и весь DEMO, а для КПК нет даже этого.
3. На ноут поставил ScanMaster 2.0 RUS и DIGIMOTO v5.0, по функционалу они одинаковые, шкурки разные. По очереди соединился, протестировал двигатель, посмотрел картинки, графики и т.п. , наглядность впечатляет и не более.
У меня 1.9 TDi, информации намного меньше, чем на VAG-COM, это моё мнение.
Ну а для бензиновых двигателей - всего не меряно, программы серьёзнаые. В течении двух часов работы, соединение было устойчиво.
Потом ВЫКЛ, потерял интерес.
3. Нашел более-менее подходящюю для КПК (N560) программку (OBD Gauga). Адаптер с КПК по ВТ соединяется без проблем,
а дальше - тупик, прога не соединялась. Порты на КПК почти все заняты, а свободные к пограмме не подходили. Напрягаться не стал. На время эксперимент отложил.
Вернулся к этой проблеме после поста WADIM_M на форуме (через 3 месяца). Дошло сразу - убрал GPS c СОМ7, а для проги, оказалось, он-то и нужен.
Всё соединилось. Информаци не очень много, но всё-же...
4. Скрины прилагаются. О полезности можно поговорить в теме, преимущество - ВТ и наличие серьёзной проги (ScanMaster 2.0 RUS и DIGIMOTO v.5.0) для ELM.
Отчёт и мнение - ЛЮБИТЕЛЬСКИЕ!
С MonoScan и VAG-Check, у меня адаптер не работает, они его не видят, Hound Dog, на своём сайте, подтвердил, что и не должны.
Ну вот, пожалуй, пока всё. Ещё раз извиняюсь за подробности.
P.S. Вложения не принимаются, не корректны (RAR архив). Разберусь-размещу позже.
Скрины к отчёту по тесту ELM-327 на КПК N560
