Всем добрый день!Сегодня с утра ездил на диогностику по поваду дистанционного несрабатывания брелока на открывание и закрывание дверей.Вот что выдал комп :
VAG-COM Version: Release 607.3-UD
12345
Wednesday,15,April,2009,10:41:29
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN Number: WVWPD63B82P180471
Address 01: Engine
Part No SW: 4B0 906 018 CM HW: 8E0 909 018
Component: 1.8L R4/5VT G 0004
Coding: 0016501
Shop #: WSC 00028
5 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - Implausible Signal - Intermittent
16685 - Cylinder 1: Misfire Detected
P0301 - 008 - Implausible Signal - Intermittent
16687 - Cylinder 3: Misfire Detected
P0303 - 008 - Implausible Signal - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 008 - Implausible Signal - Intermittent
16686 - Cylinder 2: Misfire Detected
P0302 - 008 - Implausible Signal - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Part No: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00022
Shop #: WSC 02406
No fault code found.
Address 15: Airbags
Part No: 6Q0 909 605 C
Component: 09 AIRBAG VW6 04 0004
Coding: 12345
Shop #: WSC 00028
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments
Part No: 3B0 920 927 B
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 07135
Shop #: WSC 00000
WVWPD63B82P180471 VWZ7Z0A4204035
1 Fault Found:
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
Address 19: CAN Gateway
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
1 Fault Found:
Address 46: Central Conv.
Part No: 1C0 959 799 C
Component: 08 Komfortgerбt HLO 0001
Coding: 00258
Shop #: WSC 00028
Part No: 1C1959801
Component: 08 Tхrsteuer.FS KLO 0002
Part No: 1C1959802
Component: 08 Tхrsteuer.BF KLO 0002
Part No: 1C0959811
Component: 08 Tхrsteuer.HL KLO 0002
Part No: 1C0959812
Component: 08 Tхrsteuer.HR KLO 0002
Address 56: Radio
Part No: 3B7 035 180
Component: Radio NP2 0005
Coding: 00031
Shop #: WSC 00028
End -------------------------------------------------
Расшифруйте пожалуйста и подскажите как исправить?
| Получено: 4 Отправлено: 3 |
Друх, тема есть специальная. А так, от себя - первые - эт пропуски зажигния, коли по всем цилиндрам - где-то подсос воздуха походу.
VW Passat B5+ 2003г, 1,8Т AWM, АКПП... БЫЛ( ... К/К №01319 (ЕСТЬ)
противоугонка НЕ штатная стоИт ? магнитолла НЕ штатная ?Сообщение от Jaba
ошибки очень похожи на результат работы НЕ штатных устройств ...криминала никакого нет. (с твоей проблемой ошибок связанных нет...ты синхронизацию ключа делал ?)
Добавлено спустя 43 секунды:
и
Сообщение от Rihovich
Друх, тема есть специальная.![]()
Всё штатное, я делал синхронизацию но так и не сделал.А по поваду пропусков каждое утро когда заводишь в начале работает нормально потом 3-5 сек. троит и опять всё нормально.Чик не горит, давно так езжу.
Я бы сделал опресовку, выяснил где трЭщина пощёль...Сообщение от Jaba
Чик не горит, давно так езжу.![]()
Подскажите где тема про ошибки, чет не могу найти?
| Получено: 51 Отправлено: 0 |
VW Passat B5+ 2003 г. AWM 1.8T - проданMMC Pajero Pinin 2002г. MPI 1.8
Mazda Axela 1.5 2004г.
нужно на диагностику...(причин - оочень много...). своими силами можно проверить дтож, дмрв и сделать опресовку.Сообщение от Jaba
нужно искать обрыв шины.Сообщение от Jaba
Вообще авто едет и бензин расходует нормально, пропуски меня иало волнуют тем более это не всегда. вот зимой, когда холодно , заводится без пропусков.А вот где искать обрыв шины интересно?
