Recall Circular Code: 26E5/R5-отзыв на бензиновые Б5 для США
    Touareg Аватар для FGCasper
    Получено: 39
    По умолчанию Recall Circular Code: 26E5/R5-отзыв на бензиновые Б5 для США
    кому надо, могу PDF прислать
    The repair information in this document is intended for use only by skilled technicians who have the proper tools, equipment and training to correctly and safely maintain your vehicle. These
    procedures are not intended to be attempted by “do-it-yourselfers,” and you should not assume this document applies to your vehicle, or that your vehicle has the condition described. To
    determine whether this information applies, contact an authorized Volkswagen dealer. ©2008 Volkswagen Group of America, Inc. and Volkswagen Canada Inc. All Rights Reserved.
    June 13, 2008 R5 - REVISED (26E5)
    Subject: 1999-2005 Passat & Passat Wagon (5th Generation)
    Equipped With Gas Engine
    Install Underbody Heat Shield(s); Inspect/Replace
    Fuel Line, Fuel Tank; Update Software, if Necessary June 13, 2008
    Revision Summary
    Part numbers and quantities updated on Criterion 2, 3, 5,
    6, 7 and 8
    Problem Description
    The affected vehicles with automatic transmissions may
    have an underbody heat shield that can become
    damaged. If a damaged heat shield contacts the exhaust
    system there is a risk of fire.
    Also, some 4Motion all-wheel drive vehicles can have a
    fuel tank ventilation valve that can leak due to fracture.
    Additionally, some manual and automatic transmission
    vehicles equipped with a 1.8T engine can have a fuel line
    that may fracture and leak. A fuel leak from a fuel line or
    fuel tank ventilation valve, in the presence of an ignition
    source, can lead to a vehicle fire.
    Corrective Action
    Dealers will install additional underbody heat shields to
    cover the possibly damaged areas and flash the 1.8T
    engines with a precautionary software update.
    Additionally, dealers will inspect the fuel line routing on
    1.8T vehicles and adjust the routing if necessary.
    Dealers will also inspect the fuel tank ventilation line and
    valve on 4Motion all-wheel drive vehicles to verify that the
    line is free of tension. Components will be replaced if
    necessary.
    VIN Range & Production Date of Affected Vehicles
    U.S.A.
    (Emden)
    WVW_ _ _3B_XE494025 - WVW_ _ _3B_5E172033
    (Mosel)
    WVW_ _ _3B_XP489411 - WVW_ _ _3B_5P060354
    Production date: June 1999 – May 2005
    CANADA
    (Emden)
    (Mosel)
    NOTE: Check ElsaWeb on the day of repair to verify
    vehicle eligibility and attach the screen print to the repair
    order. This is the only valid campaign inquiry and verification
    source. Some vehicles may be involved in an additional
    action(s); any additional work can be done while the vehicle
    is in for this action.
    Allocation Report of Affected Vehicles
    In the Service Manager’s Package, dealers with
    affected vehicles will receive a report containing the
    VIN, customer name, city, state and zip code.
    Dealers will not receive a report if they have no
    affected vehicles.
    Parts Information and Allocation
    Dealers will receive an allocation list for the V6 and W8
    cars, followed up at a later date with one for the 1.8T
    vehicles. You have already received an initial allocation
    of parts. Ensure that these parts are inventoried in a
    secure manner and are used ONLY for this campaign.
    If you have exhausted your allocated parts for vehicles
    affected by this safety recall, but have exceeded your
    weekly Upper Order Limit, please submit your requests
    for additional material via email to
    upperorderlimits@vw.com.
    Owner Notification Mailing
    Via first-class mail, owner notification will begin on or
    about June 13, 2008, using a staggered approach
    starting with V6 and W8 vehicles. The 26E5 service
    number will begin showing open on affected V6 and
    W8 vehicles on or about June 13, 2008. The 1.8T
    vehicles will show open at a later date. A sample copy
    of the owner letter is enclosed.
    Claim Entry Procedure
    Immediately upon completion of the repair work, enter
    the correct criteria code from one of the charts on the
    following pages. The applicable criteria code will be
    reflected in ElsaWeb. Claims will only be paid for
    vehicles that show this campaign open in ElsaWeb on
    the day of the repair. To help ensure prompt and
    proper payment, attach the screen print to the repair
    order.
    The information in this document is intended for use only by skilled technicians who have the proper tools, equipment and training to correctly and safely maintain your vehicle. These
    June 2008 R5 (26E5) Page 2 of 53
    26E5/R5 RECALL
    CRITERIA CODE CONTENTS
    Criteria 01 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Page 2
    Section A - Heat Shield Installation Page 17
    Criteria 02 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Page 2
    Section E - Fuel Tank Inspection (4Motion vehicles) Page 31
    Section F - Visual Inspection/Vent Line Check (4Motion vehicles) Page 32
    Section G - Fuel Tank Removal (4Motion vehicles) Page 33
    Section H - Fuel Sending Unit Removal (4Motion vehicles) Page 38
    Section J - Fuel Sending Unit Installation (4Motion vehicles) Page 41
    Criteria 03 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Page 3
    Section B - Fuel Line Bracket Removal and Fuel Line Inspection Page 22
    Section C - Fuel Line Foam Block Removal and Bracket Clipping Page 25
    (2000 – 2005 1.8T vehicles)
    Section D - Fuel Line Replacement Page 27
    Criteria 04 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Page 3
    Section A - Heat Shield Installation Page 20
    Section K - Software Update Using Software Version Management (SVM) Page 44
    (2000 – 2005 1.8T vehicles with automatic transmission)
    Criteria 05 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Page 4
    Criteria 06 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Page 5
    Criteria 07 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Page 5
    Criteria 08 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Page 5
    (2000 – 2005
    The information in this document is intended for use only by skilled technicians who have the proper tools, equipment and training to correctly and safely maintain your vehicle. These procedures are not
    intended to be attempted by “do-it-yourselfers,” and you should not assume this document applies to your vehicle, or that your vehicle has the condition described. To determine whether this information
    June 2008 R5 (26E5) Page 3 of 53
    Select from one of these six charts the applicable
    Criteria Code displayed in ElsaWeb:
    Saga Claim Entry Procedure ( CHART 1 of 6)
    Check in the system Service-Online, FISH (VSI), to determine whether the “26E5”
    campaign is open.
    Service No. : 26E5
    Damage Code : 0099
    Parts Manufacturer – Removed part: Use vendor code VWE.
    Sold vehicle = 7 10
    Unsold vehicle = 7 90
    HEAT SHIELD ONLY (1.8T AUTOMATIC )
    Criteria code 01
    - Install passenger side heat shield
    Repair operation: 2615 23 99 75 T.U.
    1 3B0 825 676 Heat shield (right)
    1 N 908 235 01 Sub frame bolt
    OR
    (2.8L & W8 – AUTOMATIC)
    - Install passenger & driver side heat shield
    Repair operation: 2615 24 99 75 T.U.
    1 3B0 825 675 Heat shield (left)
    FUEL TANK ONLY (4MOTION – MANUAL/ AUTOMATIC)
    Criteria code 02
    - Check ventilation line measurement, if greater than 36mm, No further work required
    Repair operation: 0183 00 99 20 T.U.
    OR
    -Ventilation line measurement less than 36mm and no fuel leak found
    Repair operation: 2010 05 99 50 T.U.
    OR
    - Found fuel leak - replace fuel tank
    Repair operation: 2010 55 99 350 T.U.
    1 3B0 201 075C/ BK Fuel tank
    2 8E0 919 133G Fuel pump seal
    1 4B0 919 133 Fuel sender seal
    3 N 024 122 2 Fuel line clamp
    4 N 909 813 01 Rear sub-frame bolts
    2 4B0 201 844 O-ring
    2 N 904 119 01 EVAP line clamp
    If Customer Refused Repairs
    Fax repair order to VWoA at (248) 754-5093 and provide VIN, applicable Service Number,
    Customer Info, Dealer Number and Date
    There is NO reimbursement for Vehicle Wash or Loaner Vehicle!
    June 2008 R5 (26E5) Page 4 of 53
    Saga Claim Entry Procedure ( CHART 2 of 6)
    campaign is open.
    Service No. : 26E5
    Damage Code : 0099
    Sold vehicle = 7 10
    FUEL LINE ONLY (1.8T– MANUAL/ AUTOMATIC)
    Criteria code 03
    - Remove fuel line, foam block (if necessary) & bracket and check fuel line
    Repair operation: 2038 21 99 20 T.U.
    OR
    - Found fuel leak - replace fuel line
    Repair operation: 2038 19 99 140 T.U.
    1 3B0 201 544BS Fuel line set
    3 N 024 1222 Fuel line clamp
    HEAT SHIELD & ECM UPDATE (1.8T – AUTOMATIC )
    Criteria code 04
    AND
    - Check ECM software; NO update required
    Repair operation: 2470 01 99 20 T.U.
    OR
    - Perform ECM software update
    Repair operation: 2470 25 99 50 T.U.
    June 2008 R5 (26E5) Page 5 of 53
    Saga Claim Entry Procedure (CHART 3 of 6)
    campaign is open.
    Service No. : 26E5
    Damage Code : 0099
    Sold vehicle = 7 10
    HEAT SHIELD, FUEL LINE & ECM UPDATE (1.8T – AUTOMATIC)
    Criteria code 05
    AND
    OR
    AND
    OR
    June 2008 R5 (26E5) Page 6 of 53
    Saga Claim Entry Procedure (CHART 4 of 6)
    Check in the system Service-Online, FISH (VSI), to determine whether the “26E5” campaign is open.
    Service No. : 26E5
    Damage Code : 0099
    Sold vehicle = 7 10
    HEAT SHIELD, FUEL LINE, FUEL TANK & ECM UPDATE (1.8T 4MOTION – AUTOMATIC)
    Criteria code 06
    AND
    OR
    AND
    OR
    OR
    AND
    OR
    Fax repair order to VWoA at (248) 754-5093 and provide VIN, applicable Service Number, Customer Info,
    June 2008 R5 (26E5) Page 7 of 53
    Saga Claim Entry Procedure (CHART 5 of 6)
    campaign is open.
    Service No. : 26E5
    Damage Code : 0099
    Sold vehicle = 7 10
    FUEL LINE & FUEL TANK (1.8T 4MOTION – MANUAL/AUTOMATIC ONLY)
    Criteria code 07
    OR
    AND
    OR
    - Ventilation line measurement less than 36mm and no fuel leak found
    OR
    June 13, 2008 R5 - REVISED (26E5) Page 8 of 53
    Saga Claim Entry Procedure (CHART 6 of 6)
    campaign is open.
    Service No. : 26E5
    Damage Code : 0099
    Sold vehicle = 7 10
    HEAT SHIELD & FUEL TANK (4MOTION – AUTOMATIC)
    Criteria code 08
    - Install passenger and driver side heat shield
    AND
    OR
    OR
    June 13, 2008 R5 - REVISED (26E5) Page 9 of 53
    Customer Letter Example (U.S.A.) (Vehicles with 26E5/R5 and 66C8/P9) June 2008
    Subject: Safety Recall 26E5/R5
    2001 and 2003-2005 Model Year Volkswagen Passat and Passat Wagon (5th Generation) Vehicles
    Install Underbody Heat Shields and Inspect/Replace Certain Fuel System Components if Necessary, and
    Service Action 66C8/P9
    Service Air Plenum Area to Improve Drainage & Install Improved Pollen Filter Seal
    Dear Volkswagen Owner:
    This notice is sent to you in accordance with the requirements of the National Traffic and Motor Vehicle Safety Act. Volkswagen
    has decided that a defect, which relates to motor vehicle safety, exists in some 2001 and 2003-2005 model year Volkswagen
    Passat and Passat Wagon (5th generation) vehicles. Our records show that you are the owner of one of these vehicles.
    What Is The Problem?
    Volkswagen has decided that some 2001 and 2003-2005 model year Volkswagen Passat and Passat Wagon (5th generation)
    vehicles with automatic transmissions may have an underbody heat shield that can become damaged. If a damaged heat shield
    contacts the exhaust system, there is risk of fire.
    Also, some 4Motion/all wheel drive vehicles can have a fuel tank ventilation valve that can leak due to fracture. Additionally,
    some manual and automatic transmission vehicles equipped with a 1.8T engine can have a fuel line that may fracture and leak.
    A fuel leak from a fuel line or fuel tank ventilation valve, in the presence of an ignition source, can lead to a vehicle fire.
    What Will Volkswagen Do?
    Dealers will install additional underbody heat shields on automatic transmission vehicles to cover the possibly damaged areas
    and flash affected 1.8T engines with a precautionary software update.
    Additionally, dealers will inspect the fuel line routing on 1.8T vehicles and adjust the routing if necessary. Dealers will also
    inspect the fuel tank ventilation line and valve on 4Motion all-wheel drive vehicles to verify that the line is free of tension.
    Components will be replaced if necessary.
    Precautions You Should Take
    Your vehicle can be driven until the inspection/repair is conducted. However, if you can smell fuel in your vehicle, we advise you
    to proceed immediately to the nearest authorized Volkswagen dealer or qualified workshop if you believe it is safe to do so, in
    order to have the fuel system on your vehicle inspected.
    Air Plenum Area Service and Pollen Filter Seal Installation
    We are also writing to inform you about a service to the air plenum area that we would like to perform for you at no cost. This
    service is not related to safety recall 26E5/R5.
    On some vehicles, moist debris might clog the air plenum drain area and water could leak into the passenger compartment. In
    order to prevent this condition, we will inspect, clean and modify the air plenum drain. We will also modify the sunroof drain (if
    equipped) and install an improved seal for the pollen filter on your vehicle.
    Additionally, this condition can be prevented by ensuring that the air plenum area is maintained regularly to keep it clear of dirt
    and debris. This helps to avoid the water drain holes from becoming blocked, and it prevents water from entering the vehicle
    through the heating and ventilation ducts. Please refer to your owner’s manual for additional information, including important
    warnings about working in and around the engine compartment and air plenum area.
    To help ensure that the air plenum area remains clear in the future, we recommend regular inspection and, when necessary,
    cleaning of the air plenum area shown in the picture below. Please be sure to keep this letter with your owner’s manual so it will
    be available for future reference.
    What We Would Like You to Do
    Please contact your authorized Volkswagen dealer and arrange for an appointment without delay.
    To help facilitate the repairs, please ensure that your vehicle has
    Россия, Краснодар
    я конечно понимаю что все здесь англичане, НО не до такой же степени!
    Получено: 39
    что у меня есть, то я выложил
    в кратце-на всех бензиновых Б5 которые шли на Штаты:
    установка доп кожухов теплозащиты над катализаторами
    на 1.8т замена бензо-линии
    на всех 4motion замена бака
    перепрошивка софта
    MOSRespect
    Эээээ.. куда подъезжать-то?))
    У меня американец...куда ехать?
    К дилеру?А он за спасибо сделает?
    Получено: 39
    АнатоличЪ
    COOLLER
    я только инфой снабжаю, а вы с вашими официалами сами бодайтесь... единственное что могу сделать, так это прислать оригинал документа
    Цитата Сообщение от MOSRespect
    АнатоличЪ
    COOLLER
    У нас с боданием глушняк))))
    Хотя вообще странно.Я так понимаю отзыв это бесплтная замена и ремонт?И это идет по всему миру на амер.пассаты?
    Вообще хочу позвонить в Ганзу или Руслан, интересно что скажут.А потом можно в представит.VW.
    Но с другой стороны машина ввезена не совсем офф, т.е не через дилера.
    Съебёж, Эта Страна
    MOSRespect
    Дим, кинь PDFку плиз если есть
    04/AWT/GFY
    Спасиб, дружище!
    Если б они мотор меняли на новый или акпп - енто да, имело б смысл заморочиться)
    Кстати, нет ничего на эту тему?;)
    Тогда лучше сразу машину на новенький хайлайовый Б6
    Получено: 39
    Mex@n!K
    нет ничего проще
    АнатоличЪ
    повеселил
    Съебёж, Эта Страна
    MOSRespect
    Thnx!
    04/AWT/GFY
    США
    перепрошивка софта
    на 1.8т замена бензолинии я так понял по факту осмотра?
    и меняют независимо от пробега? у меня на одном 120К миль на втором 77К... пока ничего неприслали, но я так понял 1.8Т они самым последним будут рассылать...
    Получено: 39
    DNF
    кинь в личку вин обеих машин, я тебе скажу, есть реколы на них или нет... дело в том, что они затягивают это дело, больше 400тыщ машин отзывается, если сразу всем отзыв прислать, так ты на ремонт очередь полгода ждать будешь
    Добавлено спустя 2 минуты 15 секунд:
    DNF
    рекол не зависит от пробега, хоть 500тыщ, поменяют полюбому. по поводу очередности россылки, пока 2.8 только приезжали так что, ты прав наверное...
  1. Отзыв о чип-тюнинге в Upsolute
    от BaraNeo в разделе Архив 2007г.
    Ответов: 49
    Последнее сообщение: 23.04.2007, 22:45
  2. Ответов: 25
    Последнее сообщение: 15.07.2006, 18:46
  3. Readiness code ???
    от andrewju в разделе Архив 2005г.
    Последнее сообщение: 12.11.2005, 16:11
  4. Ответов: 51
    Последнее сообщение: 29.08.2005, 21:06
  5. Ответов: 40
