ВСЕ ошибки на В5 расшифровываются здесь!!! - Страница 273
  1. #5441
    2pavel1
    спасибо,пошел за словарем)))
  2. #5442
    Мурманская волость.
    Отправлено: 18
    Парни надеюсь на вашу помощь!
    VCDS Version: Release 10.6.0
    Data version: 20100630
    Friday,27,May,2011,12:27:04:46862
    Chassis Type: 7H - VW Transporter
    Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
    57 6E 76 77 78 7D
    VIN: WV2ZZZ7HZ4H002791 Mileage: 220170km/136807miles
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 070 906 016 A HW: 028 101 073 3
    Component: R5 2,5L EDC G000SG 5220
    Revision: 12345678 Serial number: VWZ7Z0B6492092
    Coding: 0001072
    Shop #: WSC 01287 111 53343
    VCID: 0E18AC66260D736C
    1 Fault Found
    16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
    P0234 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 3087 /min
    Torque: 408.0 Nm
    Speed: 136.0 km/h
    Load: 100.0 %
    Voltage: 14.21 V
    Bin. Bits: 00001000
    Absolute Pres.: 2366.4 mbar
    Absolute Pres.: 2590.8 mbar
    Readiness: 0 0 X X X
    Address 03: ABS Brakes Labels: 7H0-907-37x-ESP-F.lbl
    Part No: 7H0 907 379 D
    Component: ESP FRONT MK25 0102
    Coding: 0006187
    Shop #: WSC 02771 785 00200
    VCID: 366824867E1D6BAC
    No fault code found.
    Address 08: Auto HVAC Labels: Redir Fail!
    Part No: 7H5 907 040 B
    Component: CLIMAtronic T5 X 2113
    Coding: 0000000
    Shop #: WSC 02737 785 00200
    VCID: 2A5000F6BAA53F4C
    6 Faults Found
    00657 - Positioning Motor for Central Vents (V102)
    000 - -
    Freeze Frame:
    01186 - Rear Air Distribution Flap Motor (V136)
    000 - -
    Freeze Frame:
    00898 - Control Circuit A/C compressor
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Current: 2.550 A
    RPM: 8160 /min
    Absolute Pres.: 255.0 bar
    Load: 127.5 %
    Temperature: 155.0°C
    Load: 127.5 %
    00668 - Supply Voltage Terminal 30
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    01592 - Air Quality Sensor (G238)
    Freeze Frame:
    00565 - Rear A/C Control Head (Climatronic) (E265)
    004 - No Signal/Communication
    Freeze Frame:
    Address 09: Cent. Elect. Labels: 7H0-937-049.lbl
    Part No: 7H0 937 049 F
    Component: BORDNETZ SGVER 1.0 1801
    Coding: 0000357
    Shop #: WSC 02760 785 00200
    VCID: 356A238A631B60B4
    5 Faults Found
    00967 - Left Turn Signals
    011 - Open Circuit - Intermittent
    01336 - Data Bus for Comfort System
    004 - No Signal/Communication - Intermittent
    01598 - Drive Battery Voltage
    001 - Upper Limit Exceeded
    002 - Lower Limit Exceeded
    00968 - Right Turn Signals
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 F
    Component: X3 AIRBAG VW61 XRXS 0001
    Coding: 22579
    Shop #: WSC 02760
    VCID: 2756F9C2A9B70224
    Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
    Part No: 7H5 920 870 Q
    Component: KOMBI+WEGFAHRSP VDO X53
    Coding: 07112
    Shop #: WSC 00000
    VCID: 3F8641A25127AAE4
    WV2ZZZ7HZ4H002791 VWZ7Z0B6492092
    4 Faults Found
    49-10 - No Communications - Intermittent
    80-10 - Single-Wire Operation - Intermittent
    01322 - Control Module for Multi-Function Unit (MFA) (J501)
    01300 - Control Module for Navigation with CD-Rom (J401)
    49-00 - No Communications
    Address 18: Aux. Heat Labels: None
    Part No: 7H0 819 008 B
    Component: Standheizung 0127
    Shop #: WSC 00000 000 00000
    VCID: 2B5E05F2B55F2644
    2 Faults Found
    00664 - Fuel gauge
    002 - Lower Limit Exceeded - Intermittent
    00457 - Control Module for Network (J519)
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 02737
    VCID: F0E4529EDCF9859C
    5 Faults Found
    00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
    Address 46: Central Conv. Labels: 6Q0-959-433.lbl
    Part No: 6Q0 959 433 E
    Component: Komfortgerбt 0002
    Coding: 00079
    Shop #: WSC 02737
    VCID: 3D7A3BAA5B2BB8F4
    Part No: 7H1959801
    Component: Tхrsteuer.FS KLO 0001
    Part No: 7H1959802
    Component: Tхrsteuer.BF KLO 0001
    1 Fault Found
    Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
    Part No: 7L6 919 044 E
    Component: DACHDISPLAY 0529
    Revision: 00000529 Serial number: 2009266.01
    VCID: 39722FBA4F0384D4
    Address 77: Telephone Labels: None
    Part No: 7H0 035 729
    Component: CIB PAH HW 200 SW* 0230
    VCID: E9D23FFAFF237454
    End ---------------------------------------------------------------------
  3. #5443
    Отправлено: 20
    Всем привет! Вот получил долгожданный шнурок! Спасибо Юрий1561! Первый раз подключился, сделал авто-скан, скопировал ошибки и села батарейка.... Что да как дальше, подскажите, не пинайте , я в этой теме пока не бум бум !
    Версия VAG-COM: Релиз 311.2-N
    Шасси: 3B - VW Passat B5
    Скан: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58,76,77
    Адрес 01 -------------------------------------------------------
    Контроллер: 4B0 906 018 DF
    Компонент: 1.8L R4/5VT 0001
    Код: 26051
    Сервиса №: WSC 00539
    WVWZZZ3BZ2P229581 VWZ7Z0A4244829
    1 Неисправности:
    18010 - Напряжение питания на кл. 30: напряжение слишком низкое
    P1602 - 35-10 - - - Спорадическая
    Готовность: 0000 0000
    Адрес 02 -------------------------------------------------------
    Контроллер: 8D0 927 156 DD
    Компонент: AG5 01V 1.8l5VT RdW 1314
    Код: 00103
    Сервиса №: WSC 00028
    1 Неисправности:
    18258 - Шина данных-привод: отсутствие сообщений от блока управления двигателя
    P1850 - 35-10 - - - Спорадическая
    Адрес 03 -------------------------------------------------------
    Контроллер: 8E0 614 111 B
    Компонент: ABS/EDS 5.3 FRONT D10
    Код: 0273004283
    Сервиса №: BB 24332
    Кодов не найдено.
    Адрес 08 -------------------------------------------------------
    Контроллер: 3B1 907 044 J
    Компонент: CLIMATRONIC B5GP 0004
    Код: 17000
    2 Найдены неисправности:
    01272 - Электродвигатель центральной заслонки-V70
    37-00 - неисправен
    01274 - Электродвигатель заслонки воздухозаборника-V71
    37-00 - неисправен
    Пропуск адреса 15-Аэрбэки
    Адрес 17 -------------------------------------------------------
    Контроллер: 3B0 920 807 E
    Компонент: KOMBI+WEGFAHRSP VDO V01
    Код: 05125
    Сервиса №: WSC 00000
    3 Найдены неисправности:
    01176 - Ключ
    07-10 - слишком низкий уровень сигнала - Спорадическая
    01314 - Блок управления двигателя
    49-10 - нет связи - Спорадическая
    00462 - Блок управления регулировки положения заднего сиденья (с функцией запоминания)-J522
    49-00 - нет связи
    Адрес 19 -------------------------------------------------------
    Контроллер: 6N0 909 901
    Компонент: Gateway K<->CAN 0001
    Код: 00004
    49-00 - нет связи
    00463 - Блок управления цифровой аудиосистемы-J525
    49-00 - нет связи
    Адрес 46 -------------------------------------------------------
    Контроллер: 1C0 959 799 B
    Компонент: 0Z Komfortgerбt HLO 0001
    Код: 00259
    1 Неисправности:
    01358 - Выключатель блокировки дверей из салона, со стороны водителя-E150
    27-10 - недостоверный сигнал - Спорадическая
    Адрес 55 -------------------------------------------------------
    Контроллер: 4Z7 907 357
    Компонент: dynamische LWR D06
    Код: 00007
    Кодов не найдено.
    Адрес 76 -------------------------------------------------------
    Контроллер: 3B0 919 283
    Компонент: Parkingsyst. PA RDW D01
    Код: 01104
    Кодов не найдено.
    Конец ----------------------------------------------------
    Куда дальше смотреть и что с этим делать?
  4. #5444
    Получено: 237
    Отправлено: 60
    Захаркин Андрей Алексеевич, Gots, вы сначала их сбросте, а чуть позже почитайте , а то такой букет скорее всего от "времени"
  5. #5445
    Мурманская волость.
    Отправлено: 18
    terco, они постоянно появляются, даже после сбрасывания.
  6. #5446
    Украина г.Полтава
    Получено: 32
    Отправлено: 10
    Всем доброго дня.
    Подскажите в моей машине при движении по бортовому компу загорелась надпись "ABGAS WERKSTATT" и загорелся значек двигателя.
    Двигатель работает нормаль. Все залито по уровню. В чем может быть причина?
    На СТО прочитал ошибку.
    Получил вот такую ошибку - 4065.
    Что это? Где копать?
  7. #5447
    Великий Новгород
    Получено: 815
    Отправлено: 1,013
    Все коды пятизначные, уточни снова номер
  8. #5448
    Отправлено: 20
    А как их сбрасывать? А то я эту вещь только в руки взял. Не разобрался еще...
    Да еще ко всему только успел ошибки считать и аккумулятор в ноуте сел.
  9. #5449
    СВЕРДЛОВСКАЯ ОБЛ
    растолкуйте пожайлуста.
    Контроллер: 3B0 906 018
    Компонент: 1,6l/2V SIMOS3 00HS0009
    Кодирование: 08021
    Код Сервиса: WSC 05311
    9 Найдены неисправности:
    18044 - Шина данных-привод: отсутствие сообщений от блока управления подушек безопасности
    P1636 - 35-00 - -
    17526 - Ряд 1-зонд 2: обрыв электрической цепи подогрева
    P1118 - 35-00 - -
    16524 - Ряд 1-зонд 2: нет активности
    P0140 - 35-00 - -
    17924 - Клапан системы изменения геометрии впускного коллектора-N156: обрыв цепи
    P1516 - 35-00 - -
    16955 - Включатель стоп-сигнала-F: недостоверный сигнал
    P0571 - 35-00 - -
    17524 - Ряд 1-зонд 1: обрыв электрической цепи подогрева
    P1116 - 35-00 - -
    17840 - Клапан управления подачей вторичного воздуха-N112: обрыв цепи
    P1432 - 35-00 - -
    16725 - Датчик положения распредвала=>датчик-G40: недостоверный сигнал
    P0341 - 35-10 - - - Спорадическая
    16514 - Ряд 1-зонд 1: сбой в электрической цепи
    P0130 - 35-10 - - - Спорадическая
    Готовность: 1010 1001
    где находиться датчик положения распредвала???
  10. #5450
    СВЕРДЛОВСКАЯ ОБЛ
    никто не поможет мне в проблеме???
  11. #5451
    Получено: 237
    Отправлено: 60
    https://passatworld.ru/showthread.php?t=152173
  12. #5452
    Phaeton Аватар для wertolet
    Россия, Москва, ЗАО
    Получено: 16
    доброго дня клубни!
    помогите... тачка встала и не заводится
    Address 01: Engine Labels: None
    Part No: 3B0 907 551 Q
    Component: 2.8L V6/5V G 0003
    Coding: 04251
    Shop #: WSC 05311
    VCID: 3162179A97734C94
    1 Fault Found
    17931 - Crash Signal from Airbag Controller: Implausible Signal
    P1523 - 35-10 - - - Intermittent
    Readiness: 0000 0000
  13. #5453
    Получено: 355
    Отправлено: 64
    wertolet, А встала она, случаем, не в результате столкновения с неподвижным предметом?
  14. #5454
    не поможете куда копать с такими ошибками? 18001 и 18010 дв 1.8 ARG B5 заведется и сразу глохнет
  15. #5455
    г. Ноябрьск, ЯНАО
    Получено: 11
    Товарищи, нужны ваши комментарии :
    Контроллер: 8D0 906 018 G
    Компонент: 1.8L R4/5V MOTR 0005
    Кодирование: 04031
    Код Сервиса: WSC 30011
    18001 - Адаптация высоты: сигнал за пределами допуска
    P1593 - 35-10 - - - Спорадическая
    17536 - Ряд 1, адаптация смеси (под нагрузкой): переобеднение смеси в системе
    P1128 - 35-00 - -
    17545 - Ряд 1, адаптация смеси (на холостом ходу): переобогащение смеси в системе
    P1137 - 35-10 - - - Спорадическая
    Контроллер: 1J0 959 799 Q
    Компонент: 38 Zentral-SG Komf. 0001
    Кодирование: 04097
    1 Неисправности:
    00849 - Контакт S выключателя зажигания и стартера-D
    25-10 - неопределенное состояние переключателя - Спорадическая
  16. #5456
    Passat Аватар для Xctr
    Краснодар
    Получено: 43
    Отправлено: 24
    P1128 - 35-00 - -
    скорее всего дыры во впуске
    VW Passat B5+ 2002 AWT АКПП 193 HP ПРОДАН
    MB CLK 240 2003 Tiptronic ПРОДАН
    VW Passat B5+ 2003 AWT МКПП 150HP
  17. #5457
    Россия, Республика Хакасия, Абакан
    Добрый день!
    Понимаю, что не по теме, но прошу подсказать, как правильно считывать ошибки ВАГ-КОМом, при включенном зажигании, на холостом ходу или при движении?
  18. #5458
    Краснодар
    Получено: 43
    Отправлено: 24
    Цитата Сообщение от Cortez Посмотреть сообщение
    Добрый день!
    VW Passat B5+ 1.8T AWT 2002, немец с а
    достаточно просто включить зажигание
  19. #5459
    Россия, Москва, ЗАО
    Получено: 16
    в меня въехали недавно, сигналка подсказала, а сам ни-ни
  20. #5460
    Получено: 355
    Отправлено: 64
    wertolet, и после стирания ошибки всё равно не заводится?
Страница 273 из 758 ПерваяПервая ... 173223263271272273274275283323373 ... ПоследняяПоследняя
  1. Все ЛОГИ расшифровываются ЗДЕСЬ!!!
    от audrius в разделе VW Passat B5/В5+
    Ответов: 21889
    Последнее сообщение: 22.04.2024, 12:10
  2. Ответов: 2225
    Последнее сообщение: 03.04.2021, 10:17
  3. Ответов: 1
    Последнее сообщение: 21.04.2009, 01:02
  4. Ответов: 40
    Последнее сообщение: 18.09.2008, 00:00
  5. Ответов: 9
    Последнее сообщение: 10.05.2006, 15:50
