14.06.2010, 17:26 #1
- 30.03.2010
- Беларусь Минск
- 39
- 278
- Записей в дневнике
- 1
Спасибо: Получено: 3
VagCom. Подскажите по ошибкам пожалуйста
протестил на ошибки свою машинку. Сразу вклюкил автоскан. Просканила, потом нажал стереть ошибки и сохранил лог. Подскажите пож-та:
Monday,14,June,2010,14:50:51:13314
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Mileage: 285300km/177277miles
Address 01: Engine Labels: Redir Fail!
Part No: 3B0 907 557 C
Component: 1,6l R4/2V SIMOS HS D03
Coding: 04001
Shop #: WSC 00028
2 Faults Found:
00515 - Camshaft Position (Hall) Sensor (G40)
03-00 - No Signal
00537 - Lambda (Oxygen Sensor) Regulation
18-10 - Upper Limit - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl
Part No: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Shop #: BB 24548
1 Fault Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
35-10 - - - Intermittent
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 607 A
Component: AIRBAG VW3 S V04
Coding: 00065
Shop #: WSC 00028
7 Faults Found:
01217 - Side Airbag Igniter; Driver Side (N199)
32-10 - Resistance too High - Intermittent
28-10 - Short to Plus - Intermittent
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
29-10 - Short to Ground - Intermittent
00588 - Airbag Igniter; Driver Side (N95)
01218 - Side Airbag Igniter; Passenger Side (N200)
32-00 - Resistance too High
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 3B0-919-xxx-17.lbl
Part No: 3B1 919 860
Component: B5-KOMBIINSTR. VDO V01
Coding: 04142
Shop #: WSC 00000
Part No: IMMO
Component: IDENTNR: VWZ7Z0X1371034
IMMO-IDENTNR: VWZ7Z0X1371034
2 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
00771 - Fuel Level Sensor (G)
30-00 - Open or Short to Plus
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 R
Component: 3A Zentral-SG Komf. 0001
Coding: 00257
Shop #: WSC 05311
Part No: 1J1959801D
Component: 3A Tхrsteuerger. FS0001r
Part No: 1J1959802E
Component: 3A Tхrsteuerger. BF0001r
9 Faults Found:
01329 - Convenience System Data Bus in Emergency Mode
35-00 - -
01332 - Door Control Module; Passenger Side (J387)
49-10 - No Communications - Intermittent
01331 - Door Control Module; Driver Side (J386)
00930 - Locking Module for Central Locking; Rear Left (F222)
27-00 - Implausible Signal
00931 - Locking Module for Central Locking; Rear Right (F223)
01038 - Central Locking Thermal Protection
00928 - Locking Module for Central Locking; Front Driver Side (F220)
01358 - Internal Central Locking Switch; Driver Side (E150)
27-10 - Implausible Signal - Intermittent
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
End ---------------------------------------------------------------------
Monday,14,June,2010,15:24:37:13314
Coding: 04001
Shop #: WSC 00028
1 Fault Found:
03-00 - No Signal
Readiness: N/A
Shop #: BB 24548
No fault code found.
Coding: 00065
Shop #: WSC 00028
Coding: 04142
Shop #: WSC 00000
Part No: IMMO
1 Fault Found:
Coding: 00257
Shop #: WSC 05311
Part No: 1J1959801D
Part No: 1J1959802E
1 Fault Found:
35-00 - -
14.06.2010, 17:35 #2
- 23.11.2009
- Питер
- 46
- 22,236
Спасибо: Получено: 3,844
Отправлено: 86
0Привет. Пиши в тему Все ошибки на В5 расшифровываются здесь!!!
14.06.2010, 17:57 #3
- 19.02.2009
- Россия, Санкт-Петербург
- 44
- 6,280
Спасибо: Получено: 355
Отправлено: 64
0И заодно напиши, что именно беспокоит.
14.06.2010, 18:16 #4
- 05.08.2008
- Россия, Волгоград
- 43
- 9,338
Спасибо: Получено: 800
Отправлено: 10
0Ну и букет ты собрал, а она у тебя ездит?
А теперь по делу. Покатайся пару дней еще раз просканируй и выкладывай, тогда и думать будем.B5.5, АWM,типтроник,вся фигня,пиндос,2002
, VAG COM
15.06.2010, 11:54 #5
- 30.03.2010
- Беларусь Минск
- 39
- 278
- 1
0Chassis Type: 3B - VW Passat B5
Coding: 04001
Shop #: WSC 00028
2 Faults Found:
03-00 - No Signal
Readiness: N/A
Якобы Лямбда (кислородный сенсор) регулировка Верхний лимит - прерывистый.
здесь незнаю в чем вопрос. Но чувствуется что машина стала немного больше бензина кушать. И какая то тяга непостоянная (иногда нормально иногда при разгоне только на высоких оборотах резко увеличивается тяга и скорость) . Также изза того что датчик на топливо не работает пару раз вставал без бензина (доливал с канистры которую с собой вожу). Может поэтому?
Shop #: BB 24548
1 Fault Found:
когда разгоняюсь киллометров до 120 и выше на приборке загорается лампочка АБС. Когда останавливаюсь выкл/вкл зажигание - пропадает. Сегодня при торможении начал шипеть именно этот передний правый диск - видимо колодка стерлась или чтото попало туда? Может вылечится когда поменяю колодки?
Coding: 00065
Shop #: WSC 00028
7 Faults Found:
тут когда тестил - были выключены подушки сидений, т.к. разбирал салон.
Coding: 04142
Shop #: WSC 00000
Part No: IMMO
Если это иммобилайзер, то не могу привязать брелок. на вкладке 46.10.01 выдает еррор.
2 Faults Found:
Здесь не показывают 2 датчика, топлива и температуры. Както оба сразу отказали - не знаю что с ними делать, в чем причина? Мот на панели че перегорело?
Coding: 00257
Shop #: WSC 05311
Part No: 1J1959801D
Part No: 1J1959802E
9 Faults Found:
35-00 - -
По поводу дверей, задние пока были отключены - делал микрики. По поводу передних - не знаю в чем проблема. Они работают - и ЦЗ и стеклоподъемники. Предыстория: была вода в салоне. Сгорел БК. Поменял в аналогичными цифрами и буквами. Как писалось выше не могу прописать брелок.
Coding: 04001
Shop #: WSC 00028
1 Fault Found:
03-00 - No Signal
Readiness: N/A
Shop #: BB 24548
Coding: 00065
Shop #: WSC 00028
Coding: 04142
Shop #: WSC 00000
Part No: IMMO
1 Fault Found:
Coding: 00257
Shop #: WSC 05311
Part No: 1J1959801D
Part No: 1J1959802E
1 Fault Found:
35-00 - -
подскажите пожалуйста по проблемам, т.к. шнурок не мой и нужно отдавать (ехать за ним 120 км, итак вчера упросил оставить). Заранее спасибо.
15.06.2010, 12:27 #6
- 20.07.2009
- Эстония, Таллин
- 48
- 412
15.06.2010, 12:50 #7
- 30.03.2010
- Беларусь Минск
- 39
- 278
- 1
15.06.2010, 13:01 #8
- 19.02.2009
- 44
- 6,280
Отправлено: 64
0По двигателю: делай опрессовку на предмет дыры во впуске и меняй датчик распредвала (Холла).
По блоку комфорта(46): Сотри ошибку и проверь не вылезет ли она снова. Если вылезет - рой проводку на предмет обрыва шины. Она сейчас работает у тебя в однопроводном режиме. Тупо размотай косу блока комфорт и проверь нет ли перегнивших мест. Да и если под ковриком сыро будет - высуши.
С датчиком топлива, я думаю, сам поймёшь, что делать
15.06.2010, 14:49 #9
- 30.03.2010
- Беларусь Минск
- 39
- 278
- 1
15.06.2010, 14:58 #10
- 19.02.2009
- 44
- 6,280
Отправлено: 64
0Хм... Даже не знаю, что ответить...
15.06.2010, 15:30 #11
- 30.03.2010
- Беларусь Минск
- 39
- 278
- 1
0Спасибо большое что отозвался, поеду сегодня на сервис датчик поменяю (оч сильно волнует мотор, все остальное как-то второстепенно). А возможно такое, что с датчика распредвала (Холла) просто оторвались какие нить провода или это нереально? И еще: делай опрессовку на предмет дыры во впуске - я так понимаю это лямбду нужно чтобы проверили?
15.06.2010, 15:55 #12
15.06.2010, 16:12 #13
- 03.04.2010
- Москва, ЮЗАО
- 171
Спасибо: Получено: 1
0Omnium, Для начала залезь под водительский коврик и проверь состояние блока комфорта, скруток и "фауны" вокруг него)
15.06.2010, 16:20 #14
- 30.03.2010
- Беларусь Минск
- 39
- 278
- 1
0Залез, сейчас там немного сырости. Идут дожди и просушить не получается (нет гаража). Проводку я перебирал на выходных. Все скрутки (по подительской стороне) перебрал и пропаял. Единственное я не лазил там где педали и вверх (там где штейкеров много)). Вода протекала из под мозгов. Также в БК идет два разьема с проводами. Так вот, внутри этих разьемов все окислено. Может в этом вся проблема. (не знаю как разобрать их - вытянуть и прочистить контакты).
15.06.2010, 16:40 #15
Подскажите по ошибкам VAGCOM.
от Andrus в разделе Архив 2007г.Ответов: 17Последнее сообщение: 28.01.2007, 19:39 -
Ребята подскажите по ошибкам плиз!!!
от Muzisubani в разделе Архив 2006г.Ответов: 8Последнее сообщение: 04.09.2006, 12:09 -
от MadHeaD в разделе Архив 2006г.Ответов: 3Последнее сообщение: 01.04.2006, 12:25 -
от MadHeaD в разделе Архив 2006г.Ответов: 20Последнее сообщение: 06.03.2006, 14:53 -
Народ! Подскажите по ошибкам VAG-COM
от Валерич в разделе Архив 2005г.Ответов: 11Последнее сообщение: 26.10.2005, 13:53
