24.06.2009, 14:09 #1
- 05.06.2006
- Россия, Санкт-Петербург
- 46
- 3,452
Спасибо: Получено: 3
Диагностика и таблица кодов ошибок CLIMATRONICa.
нашол в базе знаний Диагностика и таблица кодов ошибок CLIMATRONICa.
список заканчивается на значении 44, а где взять расшифровку остальных?
24.06.2009, 14:15 #2
24.06.2009, 14:21 #3
- 15.06.2007
- Россия, Мытищи
- 41
- 7,758
- Записей в дневнике
- 1
Спасибо: Получено: 17
0Sultan_SPb
1 interior temperature °C
2 sun intensity retarded * 10 W/m2
3 sun intensity * 10 W/m2
4 external temp retards °C
5 external temp. Bumper °C
6 external temp. Suction port °C
7 blowing out temp. Floor space °C
8 blowing out temp. MAS °C
9 Target Geblaesespg. * 0.1 V
10 Be Geblaesespg. * 0.1 V
11 SOLL_Temp. flap Dig.
12 SOLL_Zental flap Dig.
13 SOLL_Uml./Staul. flap Dig.
14 SOLL_Fussr./Def. flap Dig.
15 engine running time S
16 driving speed km/h
17 START_AP Dig.
18 Uml./Frischluft threshold Dig. to
19 compressor out code see plant
20 PI_STELLMAX Ausbl moving. Dig.
21 INT_STELL Ausbl moving. Dig.
22 Epsilon Ausbl moving. Dig.
23 actual blowing out temp. °C
24 target blowing out being. °C
25 - Last detent temp flap Dig.
26 RMP_Temp. flap Dig.
27 + last detent temp flap Dig.
28 - Last detent central flap Dig.
29 RMP_Zental k. Dig. Dia. g. channel INDICATED SIZE OF DIMENSION 30 + last detent central flap Dig.
31 - Last detent Uml./Staul. flap Dig.
32 RMP_Uml/Staul. flap Dig.
33 + last detent Uml./Staul. flap Dig.
34 - Last detent Fussr./Def. flap Dig. 35
RMP_Fussr./Def. flap Dig.
36 + last detent Fussr./Def. flap Dig.
37 service life min. (255 = no telegram)
38 compressor PWM Dig (0... 200)
39 target evaporator being °C
40 actual evaporator temperature °C
41 i-placing evaporator Dig.
42 Epsilon evaporator Dig.
43 refrigerant pressure without
44 BiLevel/MAS threshold Dig. 45 engine temperature °C
46 actual compressor stream mA
47 target compressor stream mA
48 compressor max. stream mA
49 compressor number of revolutions 100/min
50 radiator exhaust heading for signal %
51 windshield wiper mode 0 = out; 1 = interval; 2 =
52 Fdk correction in Abh. of the windshield wiper - Dig.
53 Geblaesespg. correction in Abh. of the Scheibenw. * 0,1V
54 basic number
55 Volkswagen number
56 HELLA number
57 Test-1
58 Test-2
59 Test-3
60 Test-4 extended diagnostic channels for CAN variants dia. g. channel INDICATED SIZE OF DIMENSION receive data
61 freely
62 clamp 15 bits
63 hot light bit
64 external temp filtered °C
65 climatic disconnection bit 66 engine speed x10 U/min.
67 Dimmung %
68 characteristic diagram cooling bit
69 land variant the 2 = USA/1 = Japan/0 = remainder of transmit data
70 freely
71 Zuheizer (PTC) bit
72 compressor (compressor) bit
73 heating from bit
74 external temp. Wasserkasten not filtered °C
75 compressor load Nm 76 blower load of %
77 radiator exhausts of %
78 customer service errors bit (error memory)GT Avalanche + SEBA FR1 летом
24.06.2009, 14:21 #4
- 05.06.2006
- 46
- 3,452
0Mex@n!K
гы .... спасибо. начну переводить с пункта 41 ..... не понимаю я их заморского наречия ....
24.06.2009, 17:29 #5
- 08.01.2007
- Россия, Серов
- 44
- 138
0подскажите ,как сделать и на что нажать надо на раздельном климате ???? пробывал и не получается?!
24.06.2009, 17:46 #6
- 15.06.2007
- Россия, Мытищи
- 41
- 7,758
- 1
0Krash99
что значит раздельный климат?
Нажать "темп минус" + "вент минус" + екон.GT Avalanche + SEBA FR1 летом
24.06.2009, 23:09 #7
- 05.06.2006
- 46
- 3,452
045 группа показывает температуру двигателя! на сколько эти данные точны?
необходима расшифровка кодов ошибок
от navudo в разделе Архив 2011г.Ответов: 1Последнее сообщение: 08.04.2011, 11:25 -
Таблица ошибок отопителя(Eberspecher)
от kurS в разделе Архив 2010г.Ответов: 6Последнее сообщение: 09.01.2010, 12:58 -
Сканер для считывания кодов ошибок
от Vintyra в разделе Архив 2007г.Ответов: 1Последнее сообщение: 24.10.2007, 12:24 -
Исправленная таблица ошибок VAG-кодов
от @YS в разделе Архив 2006г.Ответов: 7Последнее сообщение: 26.07.2006, 23:07 -
Расшифровка кодов ошибок.
от Sergey в разделе Архив 2005г.Ответов: 15Последнее сообщение: 15.07.2005, 00:01
