03.12.2008, 11:23 #1
- 25.08.2008
- Москва
- 45
- 113
Помогите расшифровать ошибки и вылечить авто
Address 56: Radio Labels: Redir Fail!
Part No SW: 8P0 035 186 HW: 8P0 035 186
Component: concert II EU H53 0060
Revision: 07S Serial number:
Coding: 0001001
Shop #: WSC 06435 000 00000
01317 - Can"t Decode, CODE File Not Loaded!
004 - Can"t Decode, CODE File Not Loaded! - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 225
Freeze Frame:
Bin. Bits: 10
01299 - Can"t Decode, CODE File Not Loaded!
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 225
01317 - Can't Decode, CODE File Not Loaded!
004 - Can't Decode, CODE File Not Loaded! - Intermittent
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 225
Freeze Frame:
Bin. Bits: 10
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 E
Component: EPS_ZFLS Kl.9 1202
Shop #: WSC 00000 000 00000
1 Fault Found:
02441 - Can"t Decode, CODE File Not Loaded!
013 - Can"t Decode, CODE File Not Loaded! - Intermittent
Freeze Frame:
Mileage: 4880 km
Temperature: 29.0°C
Voltage: 12.40 V
Voltage: 12.10 V
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H30 0501
Revision: 00030000 Serial number: 00000000390911
Coding: 038ECF0080141000000000000000000000
Part No: 8P1 955 119 A
Component: Wischer WWS Audi350 0170
Coding: 16711696
Shop #: WSC 00000
1 Fault Found:
00979 - Can"t Decode, CODE File Not Loaded!
010 - Can"t Decode, CODE File Not Loaded! - Intermittent
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
Part No: 8P0 959 802 A
Component: Tuersteuerger. H10 0010
Coding: 0000048
1 Fault Found:
00933 - Can't Decode, CODE File Not Loaded!
005 - Can't Decode, CODE File Not Loaded! – Intermittent
03.12.2008, 13:00 #2
- 13.04.2005
- Россия, Москва, ЮЗАО
- 57
- 22,541
Спасибо: Получено: 13
0Stich
ты чем их читал???
01317 0525 Блок управления в комбинации приборов-J285
01299 0513 Диагностический интерфейс шин данных-J533
02441 0989 Желтая аварийная лампа в комбинации приборов
00979 03D3 Лампа правой фары ближнего света-M31
00933 03A5 Электродвигатель стеклоподъемника на стороне переднего пассажира-V148
на что жалуемся???
03.12.2008, 13:03 #3
- 01.08.2006
- Россия, Москва, ЗАО
- 43
- 4,187
Спасибо: Получено: 10
0Сообщение от 1967s
03.12.2008, 14:02 #4
- 16.10.2005
- Россия, Санкт-Петербург
- 52
- 3,709
- Записей в дневнике
- 8
Спасибо: Получено: 243
Отправлено: 3,423
0Stich
привет!
а сам-то от куда родом? где находимся?Было: Passat B-5, 1.8T! Mondeo V6-2.5л.5АКПП, Passat В-6/ 2.0 TDi DSG, Superb Combi/ 2.0 TDi DSG-6
03.12.2008, 14:24 #5
- 25.08.2008
- Москва
- 45
- 113
0МСК
Варианты лечения вот этих 2-х болезний???
Добавлено спустя 1 минуту 21 секунду:
Сообщение от lw
03.12.2008, 14:34 #6
- 01.08.2006
- 43
- 4,187
0Stich
Не рискну, если у тебя шнурок-клон [-X , так как в нем бан-лист содержится.
А в комплекте не дали что ли?
ПОМОГИТЕ РАСШИФРОВАТЬ ОШИБКИ КЛИМЫ
от lexxx174 в разделе Архив 2010г.Ответов: 3Последнее сообщение: 09.04.2010, 16:00 -
Помогите расшифровать ошибки!!!
от Stich в разделе VW Passat B6/CCОтветов: 1Последнее сообщение: 16.12.2008, 07:57 -
OFF. Помогите расшифровать ошибки.
от Cartuning в разделе Архив 2007г.Ответов: 0Последнее сообщение: 26.06.2007, 23:28 -
от Cartuning в разделе Архив 2007г.Ответов: 0Последнее сообщение: 26.06.2007, 23:27 -
гуру! помогите расшифровать ошибки
от Timofey в разделе Архив 2006г.Ответов: 10Последнее сообщение: 07.10.2006, 07:04
