1. #7461
    всем приветище! посмотрите сможет кто помочь?
    Address 01: Engine Labels: 06B-906-018-AWT.lbl
    Control Module Part Number: 4B0 906 018 DC
    Component and/or Version: 1.8L R4/5VT 0001
    Software Coding: 11551
    Work Shop Code: WSC 00181
    Additional Info: WVWZZZ3BZ2E058634 VWZ7Z0A3698627
    VCID: 65C5B5A7D7A1
    7 Faults Found:
    17887 - Brake Boost Vacuum System: Mechanical Failure
    P1479 - 35-00 - -
    16804 - Catalyst System; Bank 1: Efficiency Below Threshold
    P0420 - 35-00 - -
    16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
    P0140 - 35-10 - - - Intermittent
    16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    P0118 - 35-00 - -
    17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
    P1114 - 35-10 - - - Intermittent
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
    P0130 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Wednesday,27,June,2012,21:01:18:10074
    VCDS Version: Beta 11.2.0
    Data version: 20110305
    Address 03: ABS Brakes Labels: 4B0-614-517.lbl
    Control Module Part Number: 4B0 614 517 G
    Component and/or Version: ABS/ESP front 1328
    Software Coding: 04277
    Work Shop Code: WSC 05311
    VCID: 2545F5A79721
    1 Fault Found:
    00285 - ABS Wheel Speed Sensor; Front Right (G45)
    30-00 - Open or Short to Plus
    Wednesday,27,June,2012,21:05:07:10074
    Address 55: Xenon Range Labels: 4Z7-907-357.lbl
    Control Module Part Number: 4Z7 907 357
    Component and/or Version: dynamische LWR D06
    Software Coding: 00007
    VCID: 040388233CDB
    Fault Codes have been Erased
    1 Fault Found:
    6 - Level Control System Sensor; Left Front (G78)
    31-00 - Open or Short to Ground
    Wednesday,27,June,2012,21:19:59:10074
    VCID: 65C5B5A7D7A1
    1 Fault Found:
    P0118 - 35-00 - -
    Readiness: 0110 1101
    Заранее благодарен!
  2. #7462
    Phaeton Аватар для kalex
    Получено: 231
    Цитата Сообщение от ВЛАДИМИР 525 Посмотреть сообщение
    предохранитель целыйбуду искать глубже
    Значит проверяй куда потерялись 12V
    в цепи после него. Твой набор ошибок однозначно говорит об этом...
  3. #7463
    Адыгея МАЙКОП
    нет питания на носос вторичной подачи воздухапроверил реле №373-работает предохранитель№34 целый
    все заработало , промыл спиртом все контакты , снял насос подачи воздуха вылил из него воду промыл в спирте массовик все ошибки ушли
  4. #7464
    Красногорск
    Что,никто не поможет?
  5. #7465
    Модератор Аватар для AWAS
    Россия, Ухта
    Получено: 336
    Отправлено: 613
    Цитата Сообщение от andrei7117 Посмотреть сообщение
    17544 - Ряд 1, адаптация смеси (на холостом ходу): переобеднение смеси в системе
    Опрессовка.
    18010 - Напряжение питания на кл. 30: напряжение слишком низкое
    Сбросить и забыть на некоторое время. Потом наблюдать. Возможно ошибка появилась при отключении аккумулятора.
    17887 - Вакуумная система усилителя тормозов механическая неисправность
    Опрессовка.
  6. #7466
    Lupo Аватар для галкин сергей
    Франция , Страсбург
    Отправлено: 28
    всем привет , просканировал машину, вылезли такие ошибки , машина пассат б5+ 2.5 TDI , 150 л.с. ,Tiptronik
    ВАСЯ диагност версия: диагност 1.1
    Понедельник, 25 Июнь 2012, 13:41:21:21528
    Шасси: 3B - VW Passat B5
    Список: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58,75,76,77
    Адрес 01: Электроника двигателя Labels: 059-907-401-AKE.LBL
    Блок управления: 3B1 907 401 B
    Компонент: 2.5l/4VTEDC G000AG D01
    Кодировка: 03011
    Мастерская #: WSC 00028
    VCID: 1D4D0E6F84BF
    00014 C150_1.V5A864867511
    2 Найдены неисправности:
    00550 - Регулятор начала впрыска
    08-10 - выход из диапазона регулирования (больше верхнего предела) - Непостоянно
    18057 - Шина данных-привод: отсутствие сообщений от блока управления ABS
    P1649 - 35-00 - -
    Готовность: Нет данных
    Адрес 02: Электроника КП Labels: 01V-927-156.LBL
    Блок управления: 8D0 927 156 DP
    Компонент: AG5 01V 2.5lTDI RdW 3131
    Кодировка: 00103
    VCID: 7E8F29E369F9
    1 неисправность:
    18265 - Сигнал нагрузки: сообщение об ошибке от блока управления двигателя
    P1857 - 35-00 - -
    Адрес 03: Электроника тормозной системы Labels: 4B0-614-517.LBL
    Блок управления: 4B0 614 517 G
    Компонент: ABS/ESP front 1328
    Кодировка: 04457
    Мастерская #: WSC 08901
    VCID: 253D268FACEF
    1 неисправность:
    P1857 - 35-10 - - - Непостоянно
    Адрес 08: Электроника кондиционера / отопителя Labels: 3Bx-907-044.LBL
    Блок управления: 3B1 907 044 J
    Компонент: CLIMATRONIC B5GP 0003
    Кодировка: 17000
    VCID: 28232FBBDBFD
    Неисправности не найдены.
    Адрес 15: Подушки безопасности Labels: 6Q0-909-605-VW5.LBL
    Блок управления: 1C0 909 605 B
    Компонент: 0A AIRBAG VW51 04 01
    Кодировка: 12353
    VCID: 23393897A2DB
    Адрес 17: Комбинация приборов Labels: 3B0-920-xx5-17.LBL
    Блок управления: 3B0 920 826 A
    Компонент: KOMBI+WEGFAHRSP VDO V01
    Кодировка: 05115
    Мастерская #: WSC 08906
    VCID: 2135329FB8C7
    WVWZZZ3BZ2P018080 VWZ7Z0A3679473
    Адрес 19: Диагностический интерфейс шин данных Labels: 6N0-909-901-19.LBL
    Блок управления: 6N0 909 901
    Компонент: Gateway K<->CAN 0001
    Кодировка: 00006
    VCID: F09387DBA3AD
    Адрес 36: Регулировка положения сиденья водителя Labels: 3B1-959-760.LBL
    Блок управления: 3B1 959 760 D
    Компонент: Sitzverstellung 0101
    Кодировка: 0000000
    Мастерская #: WSC 00000
    VCID: 2E2FD9A3F919
    Адрес 46: Центральный модуль систем комфорта Labels: 1C0-959-799.LBL
    Блок управления: 1C0 959 799 B
    Компонент: 03 Komfortgerбt HLO 0001
    Кодировка: 00259
    VCID: 361FF1C30149
    Адрес 56: Магнитола Labels: 1J0-035-18x-56.LBL
    Блок управления: 1J0 035 186 E
    Компонент: Radio BNO 0005
    Кодировка: 04403
    VCID: 27212C87D6E3
    1 неисправность:
    00855 - Соединение с CD-чейнджером
    49-00 - нет связи
    Адрес 76: Парковочный ассистент Labels: 3B0-919-283.LBL
    Блок управления: 3B0 919 283
    Компонент: Parkingsyst. PA RDW D01
    Кодировка: 01104
    VCID: E5BDE68F6C6F
    Конец --------------------------------------------------------------------------------------------------
    посоветуйте , что делать , где искать, как лечить,
    машина заводиться отлично, расход топлива на холостых 1,3
    иногда машина подтупливает, или ето у меня такое ощущение, что подтупливает
    Последний раз редактировалось галкин сергей; 29.06.2012 в 20:09.
  7. #7467
    Баку
    подскажите пожалуйста Заранее благодарю. 1.8T 2002
    P1114 - 008 - Implausible Signal - Intermittent
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 008 - Implausible Signal - Intermittent
    17964 - Charge Pressure Control: Negative Deviation
    P1556 - 002 - Lower Limit Exceeded - Intermittent
    16523 - Oxygen (Lambda) Sensor B1 S2: Response too Slow
    P0139 - 004 - No Signal/Communication - Intermittent
    16955 - Brake Switch (F): Implausible Signal
    P0571 - 008 - Implausible Signal - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 008 - Implausible Signal - Intermittent
    16687 - Cylinder 3: Misfire Detected
    P0303 - 008 - Implausible Signal - Intermittent
  8. #7468
    Адыгея МАЙКОП
    попробуй промыть блок дросельной заслонки , предварительносняв его
  9. #7469
    Франция , Страсбург
    Отправлено: 28
    Кодировка: 03011
    VCID: 1D4D0E6F84BF
    P1649 - 35-00 - -
    Кодировка: 00103
    VCID: 7E8F29E369F9
    1 неисправность:
    P1857 - 35-00 - -
    Кодировка: 04457
    VCID: 253D268FACEF
    1 неисправность:
    Кодировка: 17000
    VCID: 28232FBBDBFD
    Кодировка: 12353
    VCID: 23393897A2DB
    Кодировка: 05115
    VCID: 2135329FB8C7
    Кодировка: 00006
    VCID: F09387DBA3AD
    Кодировка: 0000000
    VCID: 2E2FD9A3F919
    Кодировка: 00259
    VCID: 361FF1C30149
    Кодировка: 04403
    VCID: 27212C87D6E3
    1 неисправность:
    49-00 - нет связи
    Кодировка: 01104
    VCID: E5BDE68F6C6F
    есть дизелисты на форуме способные помочь ?
    Последний раз редактировалось галкин сергей; 29.06.2012 в 22:53.
    passat B6,европеец,2.0 TDI,noEGR/noDPF,МКПП,2010 г,диск 16,ксенон,сарайка
  10. #7470
    Модератор Аватар для terco
    Россия, пока Санкт-Петербург
    Получено: 181
    Отправлено: 54
    галкин сергей,
    как вариант
    проверить регулировку ТНВД
    проверить датчик хода иглы G80 и провода с разъемом
  11. #7471
    ни кто не может помочь?
  12. #7472
    Получено: 181
    Отправлено: 54
    чем помочь?
    поменяй ДТОЖ, ЛЗ, проверь проводку, разъемы, клеммы аккумулятора
  13. #7473
    Франция , Страсбург
    Отправлено: 28
    галкин сергей,
    как вариант
    terco , а не подскажешь как проверить регулировку ТНВД и датчик хода иглы и где он находится (этот датчик )?
    Последний раз редактировалось галкин сергей; 30.06.2012 в 16:29.
  14. #7474
    Адыгея МАЙКОП
    Опрессовка.
    Опрессовка.
    Cегодня другу делал Пассат1.8Т с такими же ошибками вылечил но надолго ли 1) снял блок дросельной заслонки хорошо его пормыл (чтоб внем небыло нагара) 2) снял датчик массового расхода воздуха , разобрал его, сам датчик опустил в банку со спиртом минут на50-60 потом продул его и все собрал обратно ошибки не появляются проехали 140 км
  15. #7475
    Россия, Ухта
    Получено: 336
    Отправлено: 613
    ДЗ мыть надо и полезно а вот ДМРВ не надо и вредно для него
  16. #7476
    Здравствуйте форумчане!
    Предыстория такова - попал в аварию (лобовой удар), долго долго чинил авто, после починки пришел забирать - загорелась красная масленка. Поехал к официалам, продиагностировали, замерили давление масла манометром, давление в норме , но нашли, что разъем датчика давления папа-мама не встал на место. Исправили и масленка погасла.
    Далее ездил некоторое время нормально, но однажды заметил - мокро под радиатором. Поехал к знакомому - оказывается замененный радиатор охлаждения двигателя оказался пробитым по охлаждению масла АКПП. Заменили радиатор на новый - долили масла в АКПП где то 3,5 л (ATF ориг.).
    После этого врубился аварийный режим работы АКПП - авто назад норм.едет, а вперед еле разгоняется, после 40 км\ч нормально.
    Опять поехал к официалам.
    Диагностика АКПП Показала след.ошибки:
    Автоматическая 5-ти ступ. коробка передач 01V
    3 события
    17114 P0703 003
    Контроль передачи\передаточного отношения
    , неверное передаточное отношение
    17125 P0741 003
    Муфта блокировки гидротрансформатора
    , передача крутящего момента не осуществляется
    18114 P1706 003
    КП неисправна
    Я в шоке, официалы порекомендовали заменить коробку - цена вопроса 350 000 р.
    Есть ли какой-нибудь другой выход? или необходимо менять АКПП?
    Авто Volkswagen Passat B5+ AWM 1.8T американец 2001г.в.
  17. #7477
    Адыгея МАЙКОП
    мне помогло стал работать а там посмотрим куда вылезет
  18. #7478
    Украина,Львов
    Отправлено: 18
    Конечно есть. Официалы никогда не ремонтируют коробку, по этому и приговорили к замене.
    1) бери с разборки и сам меняй, или в другом месте.
    2) ремонтируй свою в другом месте.
  19. #7479
    Москва кожухово
    По умолчанию Надоели они мне!
    Ошибки стирал все равно появляются (( искал по темам но почти все в архииве и не все понятно( ВЫРУЧАЙТЕ)
    1.я так понимаю передув?
    Контроллер 01: Двигатель Описания: 038-906-019-AVF.clb
    Номер детали: 038 906 019 GQ
    Компонент:: 1,9l R4 EDC 0000AG 1582
    Кодировка: 00001
    Код сервиса:: WSC 05314
    VCID: 6CDDD3C01C90D63
    WVWZZZ3BZ3E316253 VWZ7Z0B6657491
    1 Ошибка найдена:
    17965 - Контроль давления наддува
    P1557 - 35-00 - выход из диапазона регулирования (больше верхнего предела)
    2.Из за этого может машина ехать не больше 140км/ч?
    Контроллер 02: АКПП Описания: 01V-927-156.clb
    Номер детали: 3B0 927 156 S
    Компонент:: AG5 01V 1.9l-PD RdW 2224
    Кодировка: 00103
    Код сервиса:: WSC 05311
    VCID: 366931A8125C5C3
    1 Ошибка найдена:
    17125 - Муфта блокировки гидротрансформатора
    P0741 - 35-00 - отсутствует передача крутящего момента
    3.адаптировать пробовал все равно вылезает(
    Контроллер 08: Климат-контроль Описания: 3Bx-907-044.clb
    Номер детали: 3B1 907 044 H
    Компонент:: CLIMATRONIC B5GP 0009
    Кодировка: 17000
    VCID: 2649E1E8C2FC2C3
    3 ошибок найдено:
    01271 - Исполнительный электродвигатель заслонки управления температурой воздуха-V68
    35-10 - - - Периодически
    01272 - Исполнительный электродвигатель центральной заслонки-V70
    01274 - Исполнительный электродвигатель заслонки воздухозаборника-V71
    4.Вот с этим вообще непонятно что делать?! вроде все играет!
    Контроллер 56: Радио Описания: 3B0-035-186.clb
    Номер детали: 1J0 035 152 G
    Компонент:: Radio BNO 0106
    Кодировка: 05405
    VCID: 2241FDF8AED4D03
    1 Ошибка найдена:
    00852 - Динамики, передние
    44-00 - короткое замыкание
  20. #7480
    Passat Аватар для ALeha
    Россия, Когалым
    Получено: 19
    Отправлено: 22
    Парни подскажите в каких группах снять логи для диагностики дизельного Транспортёра Т4, причина плохой заводки (возможно датчик t двигателя?) и дымит при перегазовке
    B5 99г.в. 380т.км 1.9 TDI AHH ; B5+ 01г.в. 280т.км 1.8Т AWT
Страница 374 из 721 ПерваяПервая ... 274324364372373374375376384424474 ... ПоследняяПоследняя
  1. Все ЛОГИ расшифровываются ЗДЕСЬ!!!
    от audrius в разделе VW Passat B5/В5+
    Ответов: 16827
    Последнее сообщение: Вчера, 23:42
  2. Ответов: 2132
  3. Ответов: 1
    Последнее сообщение: 21.04.2009, 00:02
  4. Ответов: 40
    Последнее сообщение: 17.09.2008, 23:00
  5. Ответов: 9
    Последнее сообщение: 10.05.2006, 14:50
