1. #5941
    Россия, Гатчина
    помогите мне тупенькому владельцу vw passat b5 2002 г в awm 1.8t американец разобраться с этими ошибками и как с ними бороться,а то надоело носить в сервис свои кровные и отдавать их навсегдMonday,25,July,2011,20:00:01:46862
    VCDS Version: Release 10.6.0
    Data version: 20100630
    Chassis Type: 3B - VW Passat B5
    Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
    VIN: WVWPD63B82P287147 Mileage: 120320km/74763miles
    Address 01: Engine Labels: 06B-906-018-AWM.lbl
    Part No SW: 4B0 906 018 CM HW: 8E0 909 018
    Component: 1.8L R4/5VT G 0006
    Coding: 0016551
    Shop #: WSC 08146 444 54280
    VCID: 6ED8CCE646CD136C
    6 Faults Found
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 - Upper Limit Exceeded - Intermittent
    16686 - Cylinder 2: Misfire Detected
    P0302 - 001 - Upper Limit Exceeded - Intermittent
    16688 - Cylinder 4: Misfire Detected
    P0304 - 001 - Upper Limit Exceeded - Intermittent
    16795 - Secondary Air Injection System: Incorrect Flow Detected
    P0411 - 002 - Lower Limit Exceeded - Intermittent
    16804 - Catalyst System; Bank 1: Efficiency Below Threshold
    P0420 - 002 - Lower Limit Exceeded
    17884 - EVAP Leak Detection Pump: Malfunction / Insufficient Vacuum
    P1476 - 002 - Lower Limit Exceeded
    Readiness: 0000 0100
    Address 02: Auto Trans Labels: 01V-927-156.lbl
    Part No: 3B0 927 156 AH
    Component: AG5 01V 1.8l5VT USA 0810
    Coding: 0001104
    VCID: 6CDCC6EE70D1E17C
    No fault code found.
    Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
    Part No: 3B0 614 111
    Component: ABS/ASR 5.3 FRONT D00
    Coding: 00021
    Shop #: WSC 00028
    VCID: D3AEFD124DAFDE84
    1 Fault Found
    01203 - Electrical Connection between ABS and Instrument Cluster
    03-10 - No Signal - Intermittent
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 C
    Component: 09 AIRBAG VW61 04 0001
    Coding: 12345
    Shop #: WSC 00028
    VCID: 244CEECED881E93C
    7 Faults Found
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    00595 - Crash Data Stored
    35-00 - -
    00588 - Airbag Igniter; Driver Side (N95)
    32-00 - Resistance too High
    00589 - Airbag Igniter 1; Passenger Side (N131)
    32-10 - Resistance too High - Intermittent
    33-00 - Resistance too Low
    29-10 - Short to Ground - Intermittent
    01299 - Diagnostic Interface for Data Bus (J533)
    49-10 - No Communications - Intermittent
    Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
    Part No: 3B0 920 927 B
    Component: KOMBI+WEGFAHRSP VDO V06
    Coding: 07135
    Shop #: WSC 00050
    WVWPD63B82P287147 VWZ7Z0A4476439
    1 Fault Found
    00779 - Outside Air Temp Sensor (G17)
    30-00 - Open or Short to Plus
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 00028
    VCID: F0E4529EDCF9859C
    Address 46: Central Conv. Labels: 1C0-959-799.lbl
    Part No: 1C0 959 799 C
    Component: 08 Komfortgerбt HLO 0001
    Coding: 00258
    Shop #: WSC 00028
    VCID: 37762982791792A4
    Part No: 1C1959801
    Component: 08 Tхrsteuer.FS KLO 0004
    Part No: 1C1959802
    Component: 08 Tхrsteuer.BF KLO 0004
    Part No: 1C0959811
    Component: 08 Tхrsteuer.HL KLO 0004
    Part No: 1C0959812
    Component: 08 Tхrsteuer.HR KLO 0004
    Address 56: Radio Labels: 3B7-035-1xx-56.lbl
    Part No: 3B7 035 180
    Component: Radio NP2 0055
    Coding: 00031
    Shop #: WSC 00028
    VCID: DDBA1B2A3B6B18F4
  2. #5942
    Passat Аватар для Дмитрий WV
    Москва СЗАО
    Отправлено: 23
    Цитата Сообщение от Дмитрий WV Посмотреть сообщение
    Всем привет
    Подскажите касаемо ошибки, «180010-напряжение питания на клапан 30: напряжение слишком низкое»
    Аккумулятор?
    Подскажет кто?
  3. #5943
    Краснодар
    Получено: 43
    Отправлено: 29
    Всем привет
    Аккумулятор?
    ОТВЕТ
  4. #5944
    Москва СЗАО
    Отправлено: 23
    Цитата Сообщение от Xctr Посмотреть сообщение
    ОТВЕТ
    Ок. ЗАВТРА ПРОВЕРЮ
  5. #5945
    Polo Аватар для AlexMit
    Россия, Брянск
    Доброго времени суток!
    Подскажите и мне немного, пожалуйста. После поездки в Крым (в дороге никаких проблем не было), машина стала плохо заводится (через три нормальных раза, один раз заводится плохо). Долго не схватывает, а потом кое-как заводится и двигатель как-то подтраивает, при нажатии на газ, чуть ли не глохнет, обороты не набирает. Если машину заглушить, то потом заводится и работает нормально. Почитал ошибки:
    Версия VAG-COM: Релиз 311.2-N
    Шасси: 3B - VW Passat B5
    Скан: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58,76,77
    Адрес 01 -------------------------------------------------------
    Контроллер: 3B0 907 557 C
    Компонент: 1,6l R4/2V SIMOS HS D03
    Кодирование: 04001
    Код Сервиса: WSC 00028
    1 Неисправности:
    00513 - Датчик оборотов двигателя-G28
    03-10 - нет сигнала - Спорадическая
    Готовность: Нет данных
    Адрес 03 -------------------------------------------------------
    Контроллер: 8E0 614 111 AB
    Компонент: ABS 5.3 FRONT D00
    Кодирование: 0273004281
    Код Сервиса: BB 24548
    Кодов не найдено.
    Адрес 08 -------------------------------------------------------
    Контроллер: 3B1 907 044 A
    Компонент: CLIMATRONIC S 8.0
    Кодирование: 02000
    Кодов не найдено.
    Пропуск адреса 15-Аэрбэки
    Адрес 17 -------------------------------------------------------
    Контроллер: 3B0 919 861 B
    Компонент: B5-KOMBIINSTR. VDO V10
    Кодирование: 04142
    Код Сервиса: WSC 00000
    IMMO-IDENTNR: VWZ7Z0W0348440
    Кодов не найдено.
    Адрес 46 -------------------------------------------------------
    Контроллер: 1J0 959 799 F
    Компонент: 0A Zentral-SG Komf.0001
    Кодирование: 00257
    5 Найдены неисправности:
    00930 - Привод центрального замка задней левой двери-F222
    27-00 - недостоверный сигнал
    00931 - Привод центрального замка задней правой двери-F223
    27-10 - недостоверный сигнал - Спорадическая
    00943 - Нагревательный элемент наружного зеркала со стороны водителя-Z4
    35-00 - -
    00912 - Выключатель переднего левого стеклоподъемника-E40
    00944 - Нагревательный элемент наружного зеркала со стороны переднего пассажира-Z5
    35-00 - -
    Конец ----------------------------------------------------
    Собсвенно вопрос: 00513 - Датчик оборотов двигателя-G28 это из-за него?
    Passat B6, 2008, 2.0 TDI CBAB, Highline, МКПП
    Passat B5, 1998, 1.6 AHL, climatronic, МКПП - продан.
  6. #5946
    г. Ноябрьск, ЯНАО
    Получено: 11
    У меня были такие же симптомы. ДЗ чистил давно? У меня в итоге оказался ДМРВ, хотя на сервисе меня уверяли что дело не в нем. Попробуй поставить заведомо рабочий датчик.
  7. #5947
    Приобрел VW Passat 1,6. 2002 года. Проездил 2 месяца, загорелась лампочка. Протестировал, вылезла вот эта ошибка. Кто подскажет как ее исправить. Буду весьма признателен
    Номер Контроллера: 3B1 907 044 J
    Компонент и/или версия: CLIMATRONIC B5GP 0004
    Кодирование: 17000
    1 Неисправности:
    01271 - Электродвигатель заслонки управления температурой воздуха-V68
    37-00 - неисправен
    Последний раз редактировалось shum; 19.08.2011 в 08:30.
  8. #5948
    Отправлено: 9
    Привет всем!Подскажите пожалуйста!
    Скан: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58 ,76,77
    Контроллер: 8D0 907 558 S
    Компонент: 1,8L R4/5V MOTR HS D01
    Кодирование: 04001
    Код Сервиса: WSC 05314
    2 Найдены неисправности:
    00515 - Датчик Холла-G40
    29-00 - к.з. на массу
    00561 - Адаптация смеси
    12-00 - выход из диапазона адаптации, больше верхнего предела (под нагрузкой)
    Кодов не найдено.
    Компонент: KOMBI+WEGFAHRS. MM4 V13
    Кодирование: 04142
    Ident.-Nr. Wegfahrs.:VWZ5Z0W4281113
    1 Неисправности:
    00667 - Сигнал наружной температуры
    30-00 - обрыв цепи/к.з. на плюс
    Компонент: 0A Zentral-SG Komf.0002
    Кодирование: 00257
    Код Сервиса: WSC 05311
    35-00 - -
    Не совсем понимаю о чем система пишет?Что значит:Адаптация смеси 12-00 - выход из диапазона адаптации, больше верхнего предела (под нагрузкой)???
    30-00 - обрыв цепи/к.з. на плюс это о чем???
    Спасибо!)))
    VW Passat 1.8 ADR Variant
  9. #5949
    г. Ноябрьск, ЯНАО
    Получено: 11
    Цитата Сообщение от Andrey240 Посмотреть сообщение
    Здравствуйте! Расшифруйте пожалуйста ошибки если есть возможность у товарища Шкода Октавия, ошибки следующие:
    Шасси: 1Z - Skoda Octavia II
    Скан: 01,02,03,08,09,0F,15,16,17,18,19,22,25,36,37,3D,42 ,44,46,47,52,55,56,57,62,69,72,76,77,7D
    Контроллер: 06A 906 033 HA
    Компонент: SIMOS71 1.6l 2V 1039
    Кодирование: 0004071
    Код Сервиса: WSC 24800
    16556 - Ряд 1, система определения параметров топливо-возд.смеси: смесь слишком богатая
    P0172 - 007 - к.з. на массу - Спорадическая
    17658 - Слишком низкий уровень топлива в баке
    P1250 - 000 -
    Куда подевались наши умные головы? Кто нибудь отзовитесь!
  10. #5950
    Россия Кемерово
    здрасти вот такие ошибки вылазят:
    00520 - Расходомер воздуха/Потенциометр расходомера воздуха-G70/G19
    31-10 - обрыв цепи/к.з. на массу - Спорадическая
    01243 - Клапан системы изменения геометрии впускного коллектора-N156
    29-10 - к.з. на массу - Спорадическая
    помогите советом
  11. #5951
    г. Ноябрьск, ЯНАО
    Получено: 11
    По этой ошибке нужно обратить внимание на работоспособность флейты http://passat-b5.ru/showthread.php?t=165436 по остальному не подскожу
  12. #5952
    Всем привет)))Приехал с командировки и сразу вузялся за ремонт авто)))(троение и мигание чека)
    465А Напряжение питания слишком высокое
    412С Опознаны перебои процесса сгорания
    4130 Опознаны перебои процесса сгорания Цилиндр 4
    412Е Опознаны перебои процесса сгорания Цилиндр 2
    465Е Информация о плохих дорожн. услов. ном.(треб.) момент мотора ABS-SG Электрическая неисправность
    412Е Опознаны перебои процесса сгорания цилиндр 2
  13. #5953
    Россия Кемерово
    флейта срабатывает как часы... не раз смотрел как она срабатывает изменяя обороты тросиком ДЗ и но видемо все таки иногда он не срабатывает ибо иногда идут ужасные провалы мощности на 1,6 это очень заметно... при этом когда отпускаешь педаль газа и заново нажимаешь машина может начать ехать нормально в общем не понятно...
  14. #5954
    Россия, Брянск
    Не думаю что это ДЗ (хотя ни разу не чистил), т.к. если машину заглушить и заново завести, то все начинает работать отлично, а вот за идею проверить ДМРВ спасибо.
  15. #5955
    Россия, Чебоксары
    Всем привет, конечно не Пассат, но Тот же VAG , как устранить ошибки:
    01616 - Signal Wire to Interior Monitor (Сигнальный провод системы охраны салона)
    29-00 - Short to Ground
    01366 - Opened Due to Crash Signal (Открытие из-за поступления сигнала удара)
    35-00 - -
    01333 - Door Control Module; Rear Left (J388) (Блок управления задней левой двери-J388)
    80-00 - Single-Wire Operation
    00850 - Control Output Active; Radio Amplifier (Выход управления активного усилителя магнитолы)
    00878 - Connection to Speaker Front Left (Соединение с передними левыми динамиками)
    44-00 - Short Circuit
    00879 - Connection to Speaker Front Right (Соединение с передними правым динамиками)
  16. #5956
    targitay
    Гость
    привет
    начать с проверки проводки, блока под ногами... наличием воды в отсеке АКБ...
  17. #5957
    Россия, Чебоксары
    привет
    Вода была в отсеке с АКБ, я её вычерпал оттуда.... На что повлияло?
  18. #5958
    targitay
    Гость
    На что повлияло?
    На проводку, снимай полы, смотри блок и проводку....
    А также смотри здесь
  19. #5959
    Россия, Чебоксары
    СПС дренажные отверстия были почищены, при вычерпывании воды
    Я не электрик, сам что нибудь смогу разглядеть в блоке? Или лучше к спецам обратиться?
  20. #5960
    targitay
    Гость
    Для начала просуши блок, проверь жгуты, если ни чего не найдешь, обращайся к спецам...
Страница 298 из 718 ПерваяПервая ... 198248288296297298299300308348398 ... ПоследняяПоследняя
  1. Все ЛОГИ расшифровываются ЗДЕСЬ!!!
    от audrius в разделе VW Passat B5/В5+
    Ответов: 16460
    Последнее сообщение: Вчера, 23:09
  2. Ответов: 2132
  3. Ответов: 1
    Последнее сообщение: 21.04.2009, 00:02
  4. Ответов: 40
    Последнее сообщение: 17.09.2008, 23:00
  5. Ответов: 9
    Последнее сообщение: 10.05.2006, 14:50
