1. #161
    Съебёж, Эта Страна
    Получено: 10
    harli_spb
    VIN Number WVWZZZ3BZYE266280;
    Sales type 3B23J5;
    Exterior color 7D
    Roof color 7D
    Interior trim code GP;
    Engine code & No. APU 54469;
    Transmission code EHV;
    Date of production 19.01.2000;
    Model year 2000;
    PR number:
    Код Опция
    5MA decorative inserts
    4X0 without side airbag
    9Q0 without multi-function indicator/ on-board computer
    8T0 without cruise control system (CCS)
    8E2 local interference suppression for FM/AMradio reception
    3L3 manual height adjustment for front seats
    1YA without transmission shafts f. rear axle
    1C2 antifreeze up to -35 degree celsius tolerance up to -40 degree C
    9Y0 without outdoor temperature gage
    4Q0 no flame retardent materials
    9J0 without supertone system and tone sequence control
    4B1 protective side molding
    L0L left-hand drive vehicle
    8TC rear fog light for driving on the right
    3LD door and side panel trim
    7A0 without CD changer/CD player
    G0C 5-speed manual transmission
    7P4 manually adjustable lumbar support in front seats
    1Z5 increase in initial standard fuel filling
    0FA standard manufacturing sequence
    7X0 without park distance control
    8F2 side turn signal lights
    2WA without additional tires
    QA0 without child seat
    B0A component parts set without country-specific design requirement
    7AA electronic vehicle immobilization device
    1ZC disc brakes, front (Geomet D)
    1D0 without towing attachment
    1RT nameplate set "1.8 T"
    6SD tufted trunk floor covering (dimensionally stable)
    T8B components for base engine, unit 058.D
    0G1 gearshift lever
    4R3 power windows with comfort operation
    7Q0 without navigation device
    8N4 windshield wiper intermittent control with potentiometer (four speeds)
    7B0 without socket
    1SB additional engine guard
    6E3 center armrest front
    Q2J comfort front seats
    0GD emissions concept EU 2 (MVEG 2)
    9D0 without preparation for two-way radio installation
    3MQ Ibolours floor covering
    8NA without parking light warning light
    3FA without roof insert (standard roof)
    2PQ steering wheel for airbag system
    7QA without CD ROM
    1T0 w/o first aid kit and warning triangle
    2B2 additional exterior noise suppression
    1E1 activated carbon canister
    E0A no special edition
    4ZE black moldings
    H6S tires 195/65 R 15 V
    8GD alternator 90A
    6U0 without additional seals outside
    6EP additional body covers, stone guard
    9T1 heated washer nozzles, front
    4L2 dipping breakaway inside rear view mirror
    4SD left vanity mirror illuminated
    7K0 without tire pressure warning light
    2JB standard bumpers
    J1L battery 280 A (60 Ah)
    3NZ rear seat bench unsplit, backrest split folding
    3GK without additional filler for plane trunk floor
    9M0 without auxiliary/parking heater
    4LA without controls
    4E0 tailgate/trunk lid unlocking from outside
    1EY special identification plate with weight data, but without general operating permit (ROW)
    8WA without front fog light
    B37 type approval CIS (without the Baltic States, Ukraine and White Russia)
    U0C instrument insert with tachometer clock and km/h speedometer
    9F0 without sound combination for rotating emergency light and radio antenna preparation
    8X0 without headlight washer system
    4TD right vanity mirror illuminated
    8AA without radio
    4M6 cup holder
    1V0 without duty-free and cost-free tires
    0Y1 standard climatic zones
    1G2 steel spare wheel with original equipment tires
    5C0 without special body measures
    9FA without automatic transmission indicator light
    3X0 without load-through provision
    4F1 central locking system
    8Q1 headlight-range adjustment
    4U5 luggage pockets on backrest
    C13 operating permit, alteration 13
    7E0 w/o heat accumulator/auxiliary heating
    C0V steel wheels 6J x 15 offset 45 (five-hole)
    6W1 license plate bracket front (large)
    5K0 without paint preservative
    M9L 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, MVEG 2 base engine is T8B/T8C
    0YC weight category rear axle weight range 3
    1VG installation parts for four-cylinder engine
    0JG weight category front axle weight range 7
    3Q1 rear headrests
    4UE airbag f. driver a. front seat passenger
    3B4 child seat anchor for child seat system ISOFIX
    F0A no special purpose vehicle, standard equipment
    K8B notchback
    6A0 without fire extinguisher
    8BG twin headlamp for left-hand drive with integrated high-beam headlight
    5RQ outer right rear view mirror: convex
    0K0 without alternative drive module
    0RA without ignition/starter switch locking system
    5D0 without carrier frequency
    3Y0 without roll-up sun screen
    8R1 center high-mounted stop light
    3J7 articulated and height-adjustable headrests for front seats
    6PA plastic hand brake lever handle
    1WC transmission shaft w/ 108mm in diameter
    0KA without stickers and badges
    9W0 w/o car phone preparation/installation
    8RA without speakers
    8K0 without special low beam mode
    3QT 3-point seat belts with tensioner and height adjustment, front
    8CC speedometer sensor without seal (electronic speedometer sensor)
    8Z5 engine cooling system, type 1
    3C3 lap belt with retractor for the center rear seat
    5SL outer left rear view mirror: non-spherical
    1X0 front wheel drive
    4GH windshield tinted with windshield sunshield
    1PA standard wheel bolts
    6Q1 plastic gearshift knob/handle
    0L2 electric throttle actuation
    4W0 without cassette and CD storage unit
    9P0 without seat belt warning light
    9HA without additional malfunction display
    9A0 without taxi alarm system
    1AH electronic differential lock (EDL)
    0DE installation differentiation for build status of vehicle class B5 (VW Passat)
    N0U cut pile seat covering
    3CA without partition
    8KA w/o catalytic converter warning light
    6XN outer rear view mirrors: powered, separately heated
    8S4 two reading lights front, two rear
    V0A tires w/o specification of tire brand
    6Y0 without cruise control warning system
    0SN labels/plates in Russian
    A8S standard equipment
    6QB locking rear seat catch
    0LA without special plates/stickers/ safety certificates
    4P1 rear floor panel module, type 2
    3S0 without roof rails/roof load rack
    8SA taillight assemblies, standard design
    4A3 seat heater for front seats separately controlled
    8L3 roof antenna
    QG2 no possibility of activating service interval prolongation
    2G1 insert for the filling up of unleaded fuel
    6R1 leatherette gearshift boot
    1BB suspension/shock absorption for rough road design
    9AK Climatronic with impact pressure control free of cfc
    0TA without floor mats
    WW1 Winter package heated front seats heated washer nozzles, front
    PH2 Air con, “Climatronic”, free of cfc
    WC1 “Comfortline” equipment package
    04/AWT/GFY
  2. #162
    Цитата Сообщение от Mex@n!K
    Mex@n!K
    Спасибо огромное.
  3. #163
    Россия, Волгоград
    Помогите пожалуйста расшифровать VIN - WVWZZZ3BZWE103125
    Заранее спасибо огромное.
  4. #164
    Россия, Екатеринбург
    и мне пож-та распишите вин W V W Z Z Z 3 B Z V E 0 2 8 4 8 4
  5. #165
    Получено: 2,315
    Отправлено: 1,372
    vol_smail
    VIN Number WVWZZZ3BZWE103125;
    Sales type 3B23J5;
    Exterior color J8
    Roof color J8
    Interior trim code JJ;
    Engine code & No. AEB117390;
    Transmission code DHW;
    Date of production 24.07.1997;
    Model year 1998;
    Расшифровка кодов комплектации
    Код Опция
    0TD front and rear floor mats
    9Q1 multi-function indicator/trip computer
    5MD decorative aluminum inserts
    4AB partially leather door and side panel trim
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    9Y1 outdoor temperature gage
    1Z0 initial standard fuel filling
    7AB electronic alarm system with vehicle immobilization device (for RoW)
    0G1 gearshift lever
    8N1 windshield wiper intermittent control
    1SA without additional engine guard
    7B2 12-volt socket in luggage boot
    4K3 radio remote controlled central locking operated from inside and safe securing
    7QA without CD ROM
    3FE electric slide/tilt sunroof with sun screen/sunblind
    2B1 additional exterior noise suppression
    1LB disc brakes, front
    2PX leather trimmed sports steering wheel
    4ZE black moldings
    8GD alternator 90A
    6U1 additional dust seal outside
    9T0 without heated washer nozzles
    7CA without label for radio remote control
    J1P battery 220 A (44 Ah)
    8WD integrated front fog light
    C04 operating permit, alteration 4
    Q4H comfort sports seats, front
    4M6 cup holder
    8AD radio "gamma"
    4U1 luggage nets/pockets on backrests
    B47 type approval the Baltic States
    5K1 paint preservative (wax)
    3Q1 rear headrests
    3B0 without additional child seat anchor
    K8B notchback
    5D1 carrier frequency 433.92 MHz
    0YZ without determination of weight categoryfor rear axle
    0JZ without determination of weight categoryfor front axle
    N7K Alcantara/leather seat covering
    6PC leatherette hand brake lever handle
    8JM twin headlamp for left-hand drive with integrated high-beam headlight
    4GF windshield, tinted
    8Z6 engine cooling system, type 2
    6Q2 leather gearshift knob/handle
    6XD outer rear view mirrors: powered, heated
    0SB labels/plates in German
    8RM eight loudspeakers (passive)
    7V0 standard dashboard illumination
    9X0 without heated door lock cylinder
    4A0 without seat heater
    9AB manually controlled air conditioning
    1BA standard suspension/shock absorption
    6R2 leather gearshift boot
    Нераспознанные коды
    WE1 WH2 PH1 RCF
    Добавлено спустя 2 минуты 21 секунду:
    Crazy
    VIN Number WVWZZZ3BZVE028484;
    Sales type 3B23E5;
    Exterior color J8
    Roof color J8
    Interior trim code JL;
    Engine code & No. ADR209934;
    Transmission code DHZ;
    Date of production 21.11.1996;
    Model year 1997;
    Код Опция
    4X1 side airbag front
    M51 4-cyl. gasoline engine 1.8 L/92 kW 20V with MVEG 2 base engine is T0V/T5Z
    B01 type approval Germany
    0G1 gearshift lever
    H5Z tires 195/65 R 15 V (ultra-light)
    7QA without CD ROM
    1T2 warning triangle
    4ZE black moldings
    8GD alternator 90A
    1EX special identification plate for EC
    0PG nameplate set "1.8"
    C01 operating permit, alteration 1
    4M6 cup holder
    8AD radio "gamma"
    1G3 alloy spare wheel with original equipment tires
    C1A alloy wheels 6J x 15
    3Q1 rear headrests
    K8B notchback
    9W9 car phone installation
    1PC wheel bolts with anti-theft protection (unlockable)
    1AC anti-lock brake system (ABS)
    T5Z components for base engine, unit 058.B
    S1X special built-in parts (w/o police) in cust. serv. shop contr. distrib. type 02a. calcul. by sep. cust. serv. invoice
    Нераспознанные коды
    WE1 PT1 WW1 WH2 PH2 RCF PJ3
  6. #166
    Axl
    спасибо огромное
  7. #167
    привет! может, примете еще одного новобранца! Помогите разобраться с VIN, ни где не могу пробить. : (
    Добавлено спустя 4 минуты 6 секунд:
    Во , нормально, а VIN написать забыл, а он такой WVWZZZ3BZXP484401 ?
  8. #168
    Россия, Ногинск
    аТАС
    VIN Number WVWZZZ3BZXP484401;
    Sales type 3B23C5;
    Exterior color K1
    Roof color K1
    Engine code & No. AHL368363;
    Transmission code DWG;
    Date of production 20.04.1999;
    Model year 1999;
    Код Опция
    T6U components for base engine, unit 06B.1
    M4T 4-cylinder gasoline engine 1.6 L/74 kW w/ multi-point injection a. MVEG 2/EU 3Dbase engine is T6U
    SB0 Sharan promotional measures
    S32 conquest-sales special edition/trade-in
    1K1 mechanical clutch actuation
    SJ1 alloy wheels C0M instead of C6W
    0FG Mosel manufacturing sequence
    0NB nameplate set in base trim
    0G1 gearshift lever
    AC0 short frame forestructure
    7B0 without socket
    7QA without CD ROM
    2B0 without additional exterior noise suppression
    4ZE black moldings
    UU0 engine stop by cable
    VC1 remote-controlled garage door opener
    8GD alternator 90A
    1LZ front disc brakes, standard ventilation
    CV0 alloy wheels 7J x 17 offset 38 (1C0 601 025 M)
    4M6 cup holder
    8AC radio "beta"
    C10 operating permit, alteration 10
    AF0 without stowage compartment
    0JD weight category front axle weight range 4
    3Q1 rear headrests
    CH6 steel wheels 7 1/2J x 17 offset 53
    K8B notchback
    0RB ignition/starter switch locking system
    1WB transmission shaft w/ 100mm in diameter
    8RE four loudspeakers (passive)
    0L0 mechanical throttle actuation
    1Q2 mass damper for steering wheel, 31Hz
    1B0 without spare wheel bracket
    S9G 4N2, 3LC, 9TC instead of 4N0, 3LA, 9TA
    Нераспознанные коды
    AHL TN0 PK8 AS3 23C WW1 2S9 10D JQA 836 041 401 PH1 RBA WC1 484 AG0 UPH BL0 ZXP LM4 GT6 999 Z3B 1WW 0E0 AWC WZZ
  9. #169
    ну и мне до кучи пробейте VIN плиз
    WVWZZZ3BZ1P069913
  10. #170
    Россия, Ногинск
    JH, легко:
    VIN Number WVWZZZ3BZ1P069913;
    Sales type 3B32J5;
    Exterior color 3P
    Roof color 3P
    Interior trim code RW;
    Engine code & No. AWT 21644;
    Transmission code FEV;
    Date of production 29.11.2000;
    Model year 2001;
    Код Опция
    NP1 standard grab handles, rear
    T6V components for base engine, unit 06B.A
    8T1 cruise control system (CCS)
    C4A cast alloy wheels 7J x 15 offset 37 (3B0 601 025 K)
    3LC foamed film and fabric door and side panel trim
    1Z2 increase in initial standard fuel filling
    G0F five-speed automatic transmission
    VX0 without hands-free system
    1KD disc brakes, rear
    8N0 without windshield wiper intermittent control
    0G7 Tiptronic
    8N3 windshield wiper intermittent control with rain sensor
    7B6 12-volt socket(s)
    2PJ steering wheel with reduced diameter forpower steering (hollow rim) for FORD
    7QA without CD ROM
    4ZB bright moldings
    0GV emissions concept EU 2 (critical vapor pressure)
    4KC side and rear windows tinted
    QJ0 without aluminum/chrome work package
    H6T tires 205/60 R 15 V
    VC0 w/o remote-controlled garage door opener
    7C0 without entry grab handle on rear pillar
    8GD alternator 90A
    4L6 breakaway inside rear view mirror automatically dimming
    C00 operating permit, initial registration
    AE0 without camping stove
    1N1 power steering
    8X1 headlight washer system
    8AA without radio
    MW8 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo base engine is T0L/T16/T6V/T63
    9FB automatic transmission indicator light
    8Q3 automatic headlight-range adjustment dynamic (self-adjusting while driving)
    0YD weight category rear axle weight range 4
    3Q1 rear headrests
    0JJ weight category front axle weight range 9
    K8B notchback
    3Y1 roll-up sun screen for rear window
    8BV twin headlamp, for driving on the right,(gas discharge) w/ integrated high beam
    1WD transmission shaft for tripod joints
    N0N woven fabric seat covering
    1Q0 without mass damper for steering wheel
    QV0 w/o TV reception/digital radio reception
    8L3 roof antenna
    6R0 selector lever cover
    Нераспознанные коды
    AWT P3P AB3 000 001 PSW 164 WW1 5PH TJ1 LK8 Z1P 112 32J P15 0C4 PH2 913 AG0 BL0 Z3B FH6 PXE 069 WZZ PJ1 LMW
  11. #171
    Спасибо, Mark!
  12. #172
    mark_V
    Спасибо!
  13. #173
    Украина
    Помогите с расшифровкой: WVWZZZ3BZXE096274
    Только приобрел.
    Спасибо
  14. #174
    Россия, Волгоград
    9Y1 наружный температурный датчик
    Можед я чтото незнаю , или не доконца разобрался в функциях, но у меня нет показаний температуры окружаюшей среды!!!
  15. #175
    Получено: 2,315
    Отправлено: 1,372
    Только приобрел.
    Спасибо
    Giant
    VIN Number WVWZZZ3BZXE096274;
    Sales type 3B53E5;
    Exterior color E2
    Roof color E2
    Engine code & No. ADR444918;
    Date of production 02.07.1998;
    Model year 1999;
    Код Опция
    S31 control number (in-plant)
    Q1A standard front seats
    0G1 gearshift lever
    6SL tufted trunk floor covering (cut pile)
    7B0 without socket
    7QA without CD ROM
    4ZE black moldings
    8GD alternator 90A
    3NW rear seat bench/backrest, split folding with center armrest
    C08 operating permit, alteration 8
    8AA without radio
    4M6 cup holder
    0JF weight category front axle weight range 6
    3Q1 rear headrests
    K8D Station Wagon Variant/Avant
    0SC labels/plates in English
    6QA rear seat catch
    B69 type approval Gibraltar
    3S5 black roof rails
    Нераспознанные коды
    PH1 WC1
  16. #176
    Украина
    Axl
    Спасибо
  17. #177
    расшифруйте и мне плиз
    WVWZZZ3BZWP234492
    так и не пойму, бразилец или немец ?????
  18. #178
    Россия, Самара
    Ребяты, вы волшебники!!!
    Помогите и мне тож, плиз.
    WVWZZZ3BZYP044074
  19. #179
    Получено: 2,315
    Отправлено: 1,372
    WVWZZZ3BZWP234492
    nUHaTpuk
    VIN Number WVWZZZ3BZWP234492;
    Sales type 3B2335;
    Exterior color Z4
    Roof color Z4
    Interior trim code FC;
    Engine code & No. AHU191862;
    Transmission code DHL;
    Date of production 15.10.1997;
    Model year 1998;
    Код Опция
    3L1 manual height adjustment for left front seat
    7P0 without lumbar support in front and rear seats
    0G1 gearshift lever
    T0T components for base engine, unit 028.M
    4R2 power windows front, mechanical window regulators rear
    SR6 Multivan demonstration campaign for Europe
    7B0 without socket
    6E0 without center armrest front
    7QA without CD ROM
    1E0 without activated charcoal canister
    J0R battery 380 A (80 Ah)
    4ZE black moldings
    H6R tires 195/65 R 15 T
    8GL alternator 120A
    2QK nameplate set "TDI"
    M0T 4-cyl. turbo diesel engine 1.9 L/66 kW direct injection base engine is T0T
    C05 operating permit, alteration 5
    4M0 without cup holder
    8AA without radio
    4U0 without luggage nets/pockets on backrests
    7E3 sheathed type glow plug heater
    3Q1 rear headrests
    K8B notchback
    N0P woven fabric seat covering
    2G0 without insert for the filling up of fuel
    Нераспознанные коды
    WW1 PH1
    Добавлено спустя 3 минуты 7 секунд:
    WVWZZZ3BZYP044074
    Lexxx....
    VIN Number WVWZZZ3BZYP044074;
    Sales type 3B2379;
    Exterior color X1
    Roof color X1
    Interior trim code HZ;
    Engine code & No. AJM 34321;
    Transmission code EDC;
    Date of production 10.06.1999;
    Model year 2000;
    Код Опция
    S2N service interval prolongation without display in instrument cluster, without oil level sensor
    0NA without nameplate set (without model designation)
    0G7 Tiptronic
    2PA leather steering wheel for airbag systemwith mass damper
    0GE emissions concept EU 3
    7QA without CD ROM
    4ZE black moldings
    8GD alternator 90A
    8AA without radio
    4M6 cup holder
    C11 operating permit, alteration 11
    3Q1 rear headrests
    T4N components for base engine, unit 038.A
    K8B notchback
    M3L 4-cyl. turbo diesel engine 1.9 L/85 kW TDI with pump-jet injection system base engine is T4N/TD0
    1AJ anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
    SW8 fleet business with Libya
    6XP outer rear view mirrors: powered, separately heated, electrically foldable
    8L3 roof antenna
    Нераспознанные коды
    WT1 WE1 WW1 PH2
  20. #180
    Россия, Самара
    Ай шаман...
    =D>
    Гран спасибо!
    Ещё вопросик, если можно. Судя по кодам (1AJ) у меня стоит система электронной блокировки дифференциала EDL. Вот здесь http://www.passat-b5.ru/index.php?optio ... &Itemid=27 пишут что "...Она срабатывает автоматически при пробусковке колес, но предусмотрено и принудительное включение". Но я чё-т никаких элементов управления этой системой у себя не вижу. Есть только кнопка ASR. Может я чё не так понял? ](*,)
Страница 9 из 698 ПерваяПервая ... 78910111959109509 ... ПоследняяПоследняя
  1. Расшифруйте пожайлуста VIN
    от никола777 в разделе Архив 2009г.
    Последнее сообщение: 28.05.2009, 21:54
  2. Расшифруйте пожалуйста VIN
    Последнее сообщение: 15.01.2007, 23:32
  3. Расшифруйте пожалуйста VIN WVWZZZ3BZWE181630
    от Клаусщ в разделе Архив 2007г.
    Последнее сообщение: 09.01.2007, 08:43
  4. Расшифруйте пожалуйста VIN
    от Алексей19 в разделе Архив 2006г.
    Последнее сообщение: 08.04.2006, 19:39
  5. Расшифруйте плз. VIN
    от andy77 в разделе Архив 2006г.
    Последнее сообщение: 27.01.2006, 12:34
