1. #921
    Россия, Ногинск
    Polo Аватар для Maki
    Господа хорошие, поможите, пробейте VIN:
    WVWZZZ3BZYP369441
    Спасибо
    VW Passat В6 2.0 150 лс МКПП
    Кто понял жизнь, тот не спешит
  3. #923
    Touareg Аватар для SilverPass
    Получено: 23
    Отправлено: 23
    Maki
    WVWZZZ3BZYP369441
    Limousine ANA DWG 5S FD K1
    PR
    A8S standard equipment
    B01 type approval Germany
    B0A component parts set without country-specific design requirement C0V steel wheels 6J x 15 offset 45 (five-hole)
    C14 operating permit, alteration 14
    E0A no special edition F0A no special purpose vehicle, standard equipment
    G0C 5-speed manual transmission
    H6S Tires 195/65 R15 V J1P battery 220 A (44 Ah)
    K8B notchback L0L left-hand drive vehicle
    MQ5 4-cylinder gasoline engine 1.6 L/74 kW with multi-point injection and D4 base engine is T6U
    N0P woven fabric seat covering
    Q1A standard front seats
    QA0 without child seat
    QG1 service interval prolongation
    T6U 4-cylinder gasoline engine 1.6 L unit
    06B0.1 (aluminum)
    U0C instrument insert with tachometer clock and km/h speedometer
    V0A tires w/o specification of tire brand
    0DE installation differentiation for build status of vehicle class B5 (VW Passat)
    0FG Mosel manufacturing sequence
    0G1 gearshift lever
    0GH emissions concept D4
    0JD weight category front axle weight range 4
    0K0 without alternative drive module 0KA without stickers and badges 0L2 electric throttle actuation
    0LA without special plates/stickers/ safety certificates
    0NA without nameplate set (without model designation)
    0RA Without ignition/starter switch locking et_fd1.frm
    system
    0SB labels/plates in German
    0TA without floor mats 0Y1 standard climatic zones
    0YC Weight range 3 installation control only, no requirement forecast
    1AT electronic stabilization program (ESP)
    1BA standard suspension/shock absorption
    1C1 Antifreeze up to -25 degree celsius tolerance up to -30 degree C
    1D0 without towing attachment
    1E1 activated carbon canister
    1EX special identification plate for EC
    1G2 steel spare wheel with original equipment tires
    1PA standard wheel bolts 1SA without additional engine guard
    1T2 warning triangle 1V0 without duty-free and cost-free tires
    1VG installation parts for four-cylinder engine
    1WB transmission shaft w/ 100mm in diameter
    1X0 front wheel drive
    1YA without transmission shafts f. rear axle
    1Z0 initial standard fuel filling
    1ZJ disc brakes, front (Geomet D)
    2B0 without additional exterior noise suppression
    2G1 insert for the filling up of unleaded fuel 2JB standard bumpers
    2PQ steering wheel for airbag system
    2WA without additional tires
    3B4 child seat anchor for child seat system ISOFIX
    3C3 lap belt with retractor for the center rear seat
    3CA without partition 3FA without roof insert (standard roof)
    3GK Without additional lower part for luggage compartment floor
    3J7 articulated and height-adjustable headrests for front seats
    3L1 manual height adjustment for left front seat
    3LC foamed film and fabric door and side panel trim
    3MQ Ibolours floor covering
    3NZ rear seat bench unsplit, backrest split folding
    3Q1 rear headrests 3QT 3-point seat belts with tensioner and height adjustment, front
    3S0 without roof rails/roof load rack
    3X0 without load-through provision
    3Y0 without roll-up sun screen
    4A0 without seat heater
    4B1 protective side molding
    4E0 tailgate/trunk lid unlocking from outside
    4F1 central locking system
    4GH windshield tinted with windshield sunshield
    4L2 dipping breakaway inside rear view mirror
    4LA without controls
    4M0 without cup holder
    4P1 rear floor panel module, type 2
    4Q0 no flame retardent materials
    4R2 power windows front, mechanical window regulators rear
    4SD left vanity mirror illuminated
    4TD right vanity mirror illuminated
    4U0 without luggage nets/pockets on backrests
    4UE airbag f. driver a. front seat passenger 4W0 without cassette and CD storage unit
    4X1 side airbag front
    4ZE black moldings
    5C0 without special body measures
    5D0 without carrier frequency
    5K0 without paint preservative
    5MA decorative inserts
    5RQ outer right rear view mirror: convex
    5SL outer left rear view mirror: aspherical
    6A0 without fire extinguisher
    6E0 without center armrest front
    6EP Additional stone guard body covers
    6PA plastic hand brake lever handle
    6Q1 plastic gearshift knob/handle
    6QB locking rear seat catch
    6R1 leatherette gearshift boot
    6SD tufted trunk floor covering (dimensionally stable)
    6U0 without additional seals outside
    6W1 license plate bracket front (large)
    6XN outer rear view mirrors: powered, separately heated
    6Y0 without cruise control warning system
    7A0 without CD changer/CD player
    7AA electronic vehicle immobilization device
    7B0 without socket
    7E0 w/o heat accumulator/auxiliary heating
    7K0 without tire pressure warning light
    7P5 manually adjustable lumbar support for left front seat
    7Q0 without navigation device
    7QA Without CD/DVD for navigation
    7X0 without park distance control
    8AC radio "beta"
    8CC speedometer sensor without seal (electronic speedometer sensor) 8E2 local interference suppression for FM/AM radio reception
    8F2 side turn signal lights
    8GD alternator 90A
    8JM twin headlamp for driving on the right with integrated high-beam headlight
    8K0 without special low beam mode
    8KA w/o catalytic converter warning light
    8L3 roof antenna
    8N4 windshield wiper intermittent control with potentiometer (four speeds)
    8NA without parking light warning light
    8Q1 headlight-range adjustment
    8R1 center high-mounted stop light
    8RE four loudspeakers (passive)
    8S4 two reading lights front, two rear
    8SA taillight assemblies, standard design
    8T0 without cruise control system (CCS)
    8TC rear fog light for driving on the right
    8WD integrated front fog light
    8X0 without headlight washer system
    8Z5 engine cooling system, type 1
    9A0 without taxi alarm system
    9AK "Climatronic" with impact pressure control free of cfc
    9D0 without preparation for two-way radio installation
    9F0 without sound combination for rotating emergency light and radio antenna preparation
    9FA without automatic transmission indicator light
    9HA without additional malfunction display
    9J0 without supertone system and tone sequence control
    9M0 without auxiliary/parking heater
    9P0 without seat belt warning light
    9Q0 without multi-function indicator/ on-board computer
    9T0 without heated washer nozzles
    9W0 w/o car phone preparation/installation
    9Y0 without outdoor temperature gage
  4. #924
    SilverPassB5GPTDI
    Громадное спасибо, но к сожалению нет главного, когда машина была выпущена (месяц/год)???
  5. #925
    Россия, Рошаль (Моск. обл)
    Maki
    Смотрим личку.
  6. #926
    Maki
    Рашшн Вариант
    VIN: WVWZZZ3BZYP369441
    Код модели: 3B23A5 ()
    Дата выпуска: 20.04.2000
    Модельный год: 2000
    Код и номер двигателя: ANA 023800
    Код КПП: DWG
    Комбинация цветов интерьера: FD
    Комбинация цветов кузова: K1
    Цвет крыши: K1
    Комплектация автомобиля (код и наименование):
    0DE спецкомплект для платформы b5 vw passat
    0FG производство mosel
    0G1 рычаг механизма включения передач
    0GH соответствие нормам токсичности ог, d4
    0JD класс грузоподъемности передней оси - весовой диапазон 4
    0K0 без альтернативной системы привода
    0KA без наклеек и эмблем
    0L2 электрический привод дросс. заслонки
    0LA без спец. табличек/наклеек/сертиф. безопасности
    0NA без обозначения двигателя на задней части а/м
    0RA без системы блокировки замка зажигания и стартера
    0SB наклейки/таблички на нем. языке
    0TA без ковриков
    0Y1 стандартные климатические зоны
    0YC класс грузоподъемности задней оси - весовой диапазон 3
    1AT электронная программа стабилизации (esp), включая тормозной ассистент, abs, eds и asr
    1BA стандартные пружины и амортизаторы
    1C1 антифриз с темп. замерз. до -25 град. с, допуск до -30 град. с
    1D0 без тягово-сцепного устройства (фаркопа)
    1E1 противопылевой фильтр с угольным наполнением
    1EX табличка с vin-номером
    1G2 полноразмерное запасное колесо, стальной диск
    1PA стандартные колесные болты
    1SA без дополнительной защиты картера
    1T2 знак аварийной остановки в багажном отделении
    1V0 без бесплатных и не подлежащих пошлине шин
    1VG монтажные детали для 4-цил. двигателя
    1WB диаметр фланца вала кп 100 мм
    1X0 передний привод
    1YA без валов с фланцами кп для заднего моста
    1Z0 первая заправка серийным топливом
    1ZJ передние дисковые тормоза
    2B0 без дополнительной шумоизоляции
    2G1 вставка для заправки только неэтилированным бензином
    2JB бамперы в цвет кузова
    2PQ рулевое колесо (4 спицы)
    2WA без дополнительной резины
    3B4 подготовка для постзав. установки системы крепления isofix (система крепления 2 детских сидений на заднем сиденье)
    3C3 трехточ.ремни безоп. с автом.катушкой во 2-ом ряде сидений с регул. высоты и 1 поясн. ремень безоп. с автом.кат.
    3CA без перегородки
    3FA без люка (сплошная крыша)
    3GK без доп.нижн.части для пола багажн. отделения
    3J7 2 активных передних подголовника
    3L1 водительское сиденье с регулировкой высоты
    3LC тканевая обивка дверей
    3MQ велюровый ковровый настил пола с прошивным ворсом
    3NZ неразделенное задн. многоместн. сиденье, откидная спинка 1/3 к 2/3, с центр. подлокотником
    3Q1 2 задних подголовника
    3QT передн.трехточ.ремни безоп. с автомат.катушк. с регул. высоты и преднатяжители
    3S0 без релингов крыши
    3X0 без приспособл. для перевозки длинномерн. грузов
    3Y0 без солнцезащитной шторки
    4A0 без обогрева сидений
    4B1 черные боковые защитные накладки
    4E0 дистанц. отпирание крышки топл. бака
    4F1 центральный замок
    4GH серая тонировка в верхней части ветров. стекла
    4L2 затемняемое зеркало в салоне
    4LA без элемента управления
    4M0 без подстаканника
    4P1 модульное напольное покрытие, сзади, исп. 2
    4Q0 не трудно-воспламеняемые материалы
    4R2 передние электростеклоподъемники (при 4 дверях)
    4SD косметическое зеркало с подсветкой в водит.солнцезащитн. козырьке
    4TD космет.зеркало с подсветкой в солнцезащ.козырьке передн.пасс.
    4U0 без сетчатых сумок/карманов на спинках
    4UE подушка безоп.водителя и пер.пасс.
    4W0 без отсека для кассет/компакт-дисков
    4X1 бок. подушка безоп. водителя и передн.пасс.
    4ZE черные декор.накладки
    5C0 кузов без специальных размеров
    5D0 без несущей частоты
    5K0 без консервации окрашенной поверхности
    5MA декоративные вставки, блестящий пластик
    5RQ сферич.наружн.прав.зеркало со стор.передн.пасс.
    5SL асферич.наружн.зеркало на стороне водителя
    6A0 без огнетушителя
    6E0 без центрального переднего подлокотника
    6EP доп. облицовка для защиты от ударов камней
    6PA пластиковая рукоятка рычага стояночного тормоза
    6Q1 пластиковая рукоятка рычага кп
    6QB закрываемая на ключ блокировка спинки заднего сиденья
    6R1 чехол рычага кп из иск. кожи
    6SD текст. материал в качестве облиц.багажн.отделения
    6U0 без доп. наружн. уплотнителей
    6W1 передний держатель номерн. знака (итальянского типа)
    6XN электрорегулировка и раздельный обогрев наружн. зеркал
    6Y0 без ограничителя скорости круиз-контроля
    7A0 без cd-чейнджера/проигрывателя cd
    7AA электронный иммобилайзер
    7B0 без розетки
    7E0 без накопителя тепла/доп. обогрева
    7K0 без системы контроля давления в шинах
    7P5 опора поясничного позвонка в спинке водит. сиденья
    7Q0 без прибора навигации
    7QA без cd-rom
    7X0 без парковочного ассистента
    8AC магнитола “beta”
    8CC спидометр не опломбирован (электронный спидометр)
    8E2 ближнее подавление радиопомех для приема укв и св
    8F2 белые боковые указатели поворотов
    8GD генератор 90A
    8JM двойные фары с встроенными фарами дальнего света
    8K0 без спец. включения ближнего света
    8KA без контроля катализатора
    8L3 антенна крыши с электронным усилителем
    8N4 прерывистое включение стеклоочистителя ветрового стекла
    8NA без контроля стояночного света
    8Q1 регулировка угла наклона фар
    8R1 третий стоп-сигнал
    8RE 4 передних динамика: 2 х 2 канала
    8S4 салонн.плафон спереди и 2 салонн.плафона сзади с задержкой выключения и регулир.яркости, 2 плаф.для чтения спереди
    8SA комбинированный фонарь (стоп-сигнал, указатель поворота, стоян. фонарь и фонарь з.х.), стандартное исполнение
    8T0 без системы круиз-контроля
    8TC задний противотуманный фонарь
    8WD противотуманные фары
    8X0 без очистителя фар
    8Z5 система охл. дв-ля, исполнение 1
    9A0 без тревожн.сигнал.для такси
    9AK кондиционер "climatronic"
    9D0 без подготовки для постзаводской установки рации
    9F0 без подготовки для постзаводской установки комбинации спецсигналов и без антенны для рации
    9FA без индикатора автоматической трансмиссии
    9HA без доп. мультифункционального дисплея
    9J0 без высокого звук.сигнала/регулировкой последовательности включения звука
    9M0 без дополнительного/автономного отопителя
    9P0 без контроля ремней безопасности
    9Q0 без многофункционального дисплея/бортового компьютера
    9T0 без обогреваемых жиклеров стеклоомывателя
    9W0 без подготовки для постзаводской установки автотелефона/автотелефона
    9Y0 без индикации наружной температуры
    A8S исполнение standard
    B01 одобрение типа тс по внутр.регламенту, но в соотв.с реглам. ес в фрг
    B0A деталировка без спец. конструктивных предписаний для страны
    C0V стальные диски 6j x 15
    C14 разрешение на эксплуатацию, приложение 14
    E0A не спец. комплектация
    F0A не специальный а/м, стандартное исполнение
    G0C 5-ступ. механическая кп
    H6S шины 195/65 R15
    J1P аккумулятор 220A (44 А/ч)
    K8B седан
    L0L руль слева
    MQ5 4-цил.бенз. дв-ль 1,6 л/74 квт мрi, d4 базовый двигатель: t6u
    N0P тканевая обивка сидений, рисунок "line"
    PH2 air conditioning "climatic" instead of standard slide/tilt sunroof
    PNE navigation system plus (rns-e) withmmi operating logic, dvd (europe)and bose sound system (audio pilot)
    Q1A стандартн. сиденья
    QA0 без встроенных детских сидений
    QG1 продление интервала то
    RBA radio system "beta"
    T6U 4-цил. бенз.двиг. 1,6 л агрег. 06b.1 (алюм.)
    U0C панель приборов с электронным спидометром, суммирующий и суточный счетчик пройденного пути в км, тахометр
    V0A шины без определения марки производителя
  7. #927
    Цитата Сообщение от mark_V
    Спасибо, всё ок!
  8. #928
    Devinity а можно и мне расшифровать VIN только если можно так же красиво на нашем совковом языке....а то в английском я не селён.
    W V W Z Z Z 3 B Z W E 3 7 8 2 0 1
  9. #929
    Devinity, а какой прогой для перевода на русский пользуешся?
    Я попробовал пару программ, но получается не очень (машинный перевод).
  10. #930
    Россия, Одинцово
    Если не очень затруднит, то расшифруйте VIN на Audi, я ее продаю, но всетаки интересно, что она из себя представляет!
    WAUZZZ8DZYA108123
  11. #931
    slag
    Смотрим личку!
  12. #932
    Andrey706 а можно и мне расшифровать VIN только если можно так же красиво на нашем совковом языке....а то в английском я не селён.
  13. #933
    Andrey706
    Спасибо огромное
    Devinity
    Отдельное спасибо за русский вариант
    Короче всем откликнувшимся спасибо
  14. #934
    Россия, Сыктывкар
    Andrey706
    Мне, пожалуйста, расшифруй тоже (на английском языке).
    WVWZZZ3BZYE471620
    Заранее спасибо.
  15. #935
    Россия, Москва, САО
    AHTOH
    VIN-номер: WVWZZZ3BZYE471620;
    Название модели: 3B23L9;
    Цвет кузова: Z4;
    Цвет крыши: Z4;
    Код отделки салона: 14;
    Обозначение и № двигателя: ANB 27124;
    Код коробки передач: EBU;
    Дата изготовления: 13.07.2000;
    Код страны эксплуатации: X0A;
    Модельный год: 2000;
    Код Опция
    1BE sports suspension/shock absorption
    0TD front and rear floor mats
    5MD decorative aluminum inserts
    9Q2 multi-function indicator/on-board computer with check control
    8E2 local interference suppression for FM/AMradio reception
    3L3 manual height adjustment for front seats
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    9Y1 outdoor temperature gage
    7P0 without lumbar support in front and rear seats
    7A2 CD changer
    1Z2 increase in initial standard fuel filling
    G0F five-speed automatic transmission
    0FA standard manufacturing sequence
    N2Z seat covering for special editions
    7AB electronic alarm system with vehicle immobilization device (for RoW)
    1ZC disc brakes, front (Geomet D)
    1RT nameplate set "1.8 T"
    1D2 removable and lockable towing attachment
    T8B components for base engine, unit 058.D
    0G7 Tiptronic
    8N3 windshield wiper intermittent control with rain sensor
    7Q2 navigation system with color screen
    7B2 12-volt socket in luggage boot
    4K3 radio remote controlled central locking operated from inside and safe securing
    7QB CD ROM (Germany)
    2B2 additional exterior noise suppression
    4ZE black moldings
    H6T tires 205/60 R 15 V
    8GD alternator 90A
    6EP additional body covers, stone guard
    C6K alloy wheels 7J x 15 "Adelaide" offset 45 (five-hole)
    4L6 breakaway inside rear view mirror automatically dimming
    J1L battery 280 A (60 Ah)
    3GK without additional filler for plane trunk floor
    9FB automatic transmission indicator light
    E2M Edition
    8AY radio/navigation system
    0YB weight category rear axle weight range 2
    5K1 paint preservative (wax)
    0JG weight category front axle weight range 7
    3Q1 rear headrests
    K8B notchback
    0RA without ignition/starter switch locking system
    5D1 carrier frequency 433.92 MHz
    9VE digital sound package
    MQ6 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, D4 base engine is T8B
    1WD transmission shaft for tripod joints
    8JM twin headlamp for left-hand drive with integrated high-beam headlight
    5SL outer left rear view mirror: non-spherical
    1PC wheel bolts with anti-theft protection (unlockable)
    8L3 roof antenna
    6R0 selector lever cover
    9AK Climatronic with impact pressure control free of cfc
    Нераспознанные коды
    WE1 WEC WED P01 RHB PNE PH2
    Добавлено спустя 4 минуты 41 секунду:
    AHTOH
    Вариант на русском языке:
    VIN: WVWZZZ3BZYE471620
    Код модели: 3B23L9 ()
    Дата выпуска: 13.07.2000
    Модельный год: 2000
    Код и номер двигателя: ANB 027124
    Код КПП: EBU
    Комбинация цветов интерьера: 14
    Комбинация цветов кузова: Z4
    Цвет крыши: Z4
    0FA производство standart
    0G7 АКПП Tiptronic
    0JG класс грузоподъемности передней оси - весовой диапазон 7
    0TD коврики из текст. м-ла передн. и задн.
    0YB класс грузоподъемности задней оси - весовой диапазон 2
    1BE спорт.ход.часть, улучш.шумоизоляция, усил.подвеска, уменьш.дорожн.просвет приблиз. на 25 мм
    1D2 съёмное тягово-сцепное устройство
    1PC болты – секретки
    1RT надпись "1,8 t"
    1WD диаметр фланца вала кп для шарнира типа трипод
    1X0 передний привод
    1Z2 увеличение объема заправки серийным топливом
    1ZC передние вентилируемые дисковые тормоза
    2B2 дополнительная шумоизоляция
    3CA без перегородки
    3L3 передние сиденья с регулировкой высоты
    4K3 центральный замок с радиоуправлением, 2 складных радиоключа
    4L6 автоматически затемняющееся зеркало салона
    5D1 дистанционное управление и блокировка дверей
    5K1 консервация окрашенной поверхности (воск)
    5MD декор. вставки "alu-microtec" для передн. панели, крышки вещ.отс. и подлокотников дверей
    6R0 отделка рычага АКП
    7A2 cd-чейнджер на 6 дисков под сиденьем передн. пасс.
    7AB противоугонная система
    7B2 электророзетка в багажнике 12В
    7P0 без опоры поясничного позвонка в передних и задних сиденьях
    7Q2 цветн.диспл.сист.навигации наклоняется во все направления с изображением карты, cd-rom только для навигационного cd
    7QB cd-rom для фрг
    8AY акуст. система 4 x 20 вт, со звуковой и визуальной сигнализацией
    8GD генератор 90A
    8N3 датчик дождя
    9FB индикатор автоматической трансмиссии
    9Q2 многофункциональный дисплей (mfa) с check control
    9VE аудио-система high end 12/12 > 12-ти канальный усилитель, 12 динамиков > цифровая обработка сигнала
    9Y1 индикация наружной температуры
    C6K легкосплавные диски "adelaide" 7j x 15
    E2M "edition"
    G0F 5-ступ. акп
    H6T шины 205/60 r 15
    J1L аккумулятор 280A (60 A/ч)
    K8B седан
    L0L руль слева
    MQ6 4-цил.бенз. дв-ль 1,8 л/110 квт (20 кл.) turbo, eu4, баз. двиг.: t8b
    N2Z тканевая обивка сидений, рисунок "active"
    P01 integrated child seat
    RHB radio/navigation system with color multi-function display (mfd) for right-hand drive
    T8B 4-цил. бенз.двиг. 1,8 л агрег. 058.d
    WE1 equipment package for rear compartment
    WEC polo "cricket" for malta, right-hand drive
    WED equipment package for china
  16. #936
    Demakov к сожалению я в английском тоже не селён, за переводом к say или Devinity, а английский вариант в личке.
    say или Devinity скажите плиз какой прогой переводите?
  17. #937
    Россия, Сыктывкар
    say
    Моя благодарность будет безмерной в пределах разумного )
    Интересно почитать на чем ездишь...
  18. #938
    Россия, Москва, САО
    AHTOH
    Не на VW, я их только обслуживаю.
  19. #939
    Россия, Челябинск
    Парни,предлагают А6.Пробейте VIN пожалуйста
    WAUZZZ4B42N060010 , если можно на русском языке.
  20. #940
    Пробейте по VINу Пассат Б5.5 2.8
    WWWZZZ3BZ2E414862
    Заранее спасибо!
Страница 47 из 698 ПерваяПервая ... 3745464748495797147547 ... ПоследняяПоследняя
  1. Расшифруйте пожайлуста VIN
    от никола777 в разделе Архив 2009г.
    Последнее сообщение: 28.05.2009, 21:54
  2. Расшифруйте пожалуйста VIN
    Последнее сообщение: 15.01.2007, 23:32
  3. Расшифруйте пожалуйста VIN WVWZZZ3BZWE181630
    от Клаусщ в разделе Архив 2007г.
    Последнее сообщение: 09.01.2007, 08:43
  4. Расшифруйте пожалуйста VIN
    от Алексей19 в разделе Архив 2006г.
    Последнее сообщение: 08.04.2006, 19:39
  5. Расшифруйте плз. VIN
    от andy77 в разделе Архив 2006г.
    Последнее сообщение: 27.01.2006, 12:34
