1. #761
    Россия, Дмитров
    mark_V
    автомат
  2. #762
    Россия, Ногинск
    WHITE, если GCU, то - вот:
    VIN Number WVWZZZ9NZ3D060063;
    Sales type 9N11G3;
    Exterior color R8
    Roof color R8
    Interior trim code DC;
    Engine code & No. BBY165567;
    Transmission code GCU;
    Date of production 09.08.2002;
    Model year 2003;
    PR number:
    Расшифровка кодов комплектации
    Код Опция
    2G7 filler neck module 1 with insert
    4X0 without side airbag
    9Q0 without multi-function indicator/ on-board computer
    0TD front and rear floor mats
    9AP semi-automatic air conditioning
    8T0 without cruise control system (CCS)
    3L3 manual height adjustment for front seats
    0EL installation differentiation for transmission AG4 vehicle components
    1JB rear shock absorption for rough-road design
    1C2 antifreeze up to -35 degree celsius tolerance up to -40 degree C
    5N6 folding grab handles at roof frame soft fold-away
    4B1 protective side molding
    L0L left-hand drive vehicle
    8M1 rear window wiper and washer system with intermittent control
    4XF exterior pillar lining design 2
    8TC rear fog light for driving on the right
    2W0 fuel filler cap
    3LC foamed film and fabric door and side panel trim
    7A0 without CD changer/CD player
    1Z2 increase in initial standard fuel filling
    6KA radiator grille
    G0E four-speed automatic transmission
    0N2 heavy-duty rear axle
    L19 suspension range 19
    9JD smoking version, ashtray front
    2WA without additional tires
    QA0 without child seat
    7PA platform group class 1
    2P1 plastic trunk sill protection
    B0A component parts set without country-specific design requirement
    7AA electronic vehicle immobilization device
    0FK Bratislava manufacturing sequence
    G11 front shock absorption
    1D0 without towing attachment
    6SC tufted trunk floor covering
    0NA without nameplate set (without model designation)
    1KD disc brakes, rear
    1S7 tool kit and aluminum jack
    0G2 selector lever
    4R1 power windows
    3U1 foldable trunk cover
    7Q0 without navigation device
    8N4 windshield wiper intermittent control with potentiometer (four speeds)
    7B0 without socket
    AC1 long frame forestructure
    1SA without additional engine guard
    1L0 standard air cleaner
    4Z1 standard glove compartment
    Q2J comfort front seats
    3FA without roof insert (standard roof)
    2PQ steering wheel for airbag system
    AZ0 vehicle with standard production scope
    GA1 center sun visor
    7QA without CD ROM
    1T0 w/o first aid kit and warning triangle
    6EA without additional side body covers (stone guard)
    1E1 activated carbon canister
    T1Q components for base engine, unit 036.D
    E0A no special edition
    2B7 additional exterior noise suppression
    0VU information kit in Russian
    0GV emissions concept EU 2 (critical vapor pressure)
    4KC side and rear windows tinted
    5A6 full fleece trunk lining
    QJ1 chrome work package
    MN7 4-cyl. gasoline engine 1.4 L/55 kW 16V multi-point injection base engine is T1Q/T99/TK0
    7R3 side turn signal lights (white)
    6U0 without additional seals outside
    1LQ front disc brakes with integrated adapter
    8GG alternator 110A
    0P0 rear exhaust tailpipe (standard)
    9T0 without heated washer nozzles
    0A1 two doors
    9E1 luggage compartment lighting
    8W0 without washer fluid level indicator
    4L2 dipping breakaway inside rear view mirror
    4SD left vanity mirror illuminated
    VK0 air duct, standard
    3NW rear seat bench/backrest, split folding with center armrest
    J1L battery 280 A (60 Ah)
    2JF painted bumpers
    2C5 axial and vertical adjustable steering column
    6FF body-colored outer rear view mirror housings and various add-on parts
    9TC additional reflectors (door area)
    1EY special identification plate with weight data, but without general operating permit (ROW)
    8WA without front fog light
    8P1 heated rear window
    4E5 tailgate/trunk lid unlocking from outside
    C03 operating permit, alteration 3
    3H3 backrest release for front seat(s)
    1N2 power steering electro-hydraulic
    B37 type approval CIS (without the Baltic States, Ukraine and White Russia)
    U0C instrument insert with tachometer clock and km/h speedometer
    9U0 without brake pad wear indicator
    0AR front stabilizer
    6NF comfort molding roof liner unsplit
    8X0 without headlight washer system
    4TD right vanity mirror illuminated
    QS0 without electronic map cooling system
    3P1 bracket for first aid kit and warning triangle
    8AA without radio
    4M5 cup holder
    C0D steel wheels 5J x 14 offset 35
    2D0 without cd enhancing underbody panel
    1G2 steel spare wheel with original equipment tires
    1NC full wheel covers
    0Y3 cold zones
    NM1 engine cover
    4U0 without luggage nets/pockets on backrests
    H8P tires 165/70 R 14 81T
    4F1 central locking system
    9FB automatic transmission indicator light
    8Q1 headlight-range adjustment
    5C6 additional body measures
    7E0 w/o heat accumulator/auxiliary heating
    6W1 license plate bracket front (large)
    KG2 wheel housing liner front and rear
    0YA weight category rear axle weight range 1
    5K0 without paint preservative
    4N2 standard dashboard
    8Y1 two-tone horn
    3Q1 rear headrests
    4UF driver's and front passenger airbag with front passenger airbag deactivation
    3B0 without additional child seat anchor
    8QC key with light
    8BB halogen headlight for left-hand drive
    2LA fuel tank without special material treatment
    F0A no special purpose vehicle, standard equipment
    6P1 license plate bracket rear (ECE)
    6A0 without fire extinguisher
    5RQ outer right rear view mirror: convex
    0RB ignition/starter switch locking system
    5D0 without carrier frequency
    K8G hatchback
    8R1 center high-mounted stop light
    QM0 foot area lining without cover
    9GH interior light with door pillar switches
    0CL vehicle class differentiation - 6Q0- for build status Europe
    3J7 articulated and height-adjustable headrests for front seats
    6PA plastic hand brake lever handle
    1A1 fuel sys. for carburetor gasoline eng. w/ injector system without fuel return
    0KA without stickers and badges
    9W0 w/o car phone preparation/installation
    8RA without speakers
    8K0 without special low beam mode
    3C1 static lap belt, center rear
    3QT 3-point seat belts with tensioner and height adjustment, front
    8CC speedometer sensor without seal (electronic speedometer sensor)
    4GF windshield, tinted
    5SL outer left rear view mirror: non-spherical
    1PA standard wheel bolts
    6Q1 plastic gearshift knob/handle
    6XD outer rear view mirrors: powered, heated
    9P0 without seat belt warning light
    N0U cut pile seat covering
    3CA without partition
    A8M executive comfort equipment
    7V1 standard dashboard illumination (blue)
    QN3 drawers under front seats
    6Y0 without cruise control warning system
    V0A tires w/o specification of tire brand
    1AN lightweight anti-lock brake system (ABS)
    0SN labels/plates in Russian
    1Q0 without mass damper for steering wheel
    6QA rear seat catch
    6J1 special body treatment
    5TC without decorative inserts
    4A0 without seat heater
    4P2 rear floor panel module, type 3
    3ZB 3-point seat belts, outer rear with ECE label
    9PE windshield wiper arms/blades with spoiler wiper blade
    QG0 without service interval prolongation
    8L3 roof antenna
    2V1 dust and pollen filter
    8SG standard taillight assemblies (type 2)
    6R0 selector lever cover
    Нераспознанные коды
    PSW PF0 PH1
  3. #763
    Казахстан, Астана
    mark_V
    спасибо!!
  4. #764
    Россия, Дмитров
    mark_V
    спасибо!!
  5. #765
    Украина, Киев
    По умолчанию помогите мне по коду плиз!
    WVWZZZ3BZ2E109364
    помогите плиз узнать комплектацию
    вопрос для меня очень срочный
  6. #766
    Беларусь
    Будьте так любезны, окажите помощь.
    WVWZZZ3AZSE109273
    Заранее благодарен.
  7. #767
    Ижевск
    HELP!!!
    Помогите с VIN плз.
    WVWPD63B93E404859
  8. #768
    Россия, Ногинск
    sim_S4
    VIN Number WVWZZZ3BZ2E109364;
    Sales type 3B6268;
    Exterior color 7D
    Roof color 7D
    Interior trim code RW;
    Engine code & No. AVF103421;
    Transmission code FTS;
    Date of production 01.08.2001;
    Model year 2002;
    PR number:
    Код Опция
    4X1 side airbag front
    5MD decorative aluminum inserts
    8E2 local interference suppression for FM/AMradio reception
    FB3 surface, interior trim, soft-touch paint
    1YD transmission shafts for rear axle diameter 108
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    9Y0 without outdoor temperature gage
    4Q0 no flame retardent materials
    9J0 without supertone system and tone sequence control
    1Z0 initial standard fuel filling
    7P4 manually adjustable lumbar support in front seats
    0FA standard manufacturing sequence
    9JB smoking version, ashtray front and rear
    G0L six-speed manual transmission for four-wheel drive vehicle
    VX0 without hands-free system
    7X0 without park distance control
    8F2 side turn signal lights
    1ZC disc brakes, front (Geomet D)
    B0F component parts set, complying with vehicle type for Switzerland, various parts
    1D2 removable and lockable towing attachment
    0G1 gearshift lever
    4R3 power windows with comfort operation
    6SL tufted trunk floor covering (cut pile)
    C5E steel wheels 6J x 15 offset 37
    B13 type approval Switzerland
    7B3 12-volt socket(s)
    6E3 center armrest front
    9D0 without preparation for two-way radio installation
    4Z2 lockable glove compartment door
    0GE emissions concept EU 3
    1DH nameplate set "TDI 4MOTION" (pump-jet injection system)
    4K3 radio remote controlled central locking operated from inside and safe securing
    3MQ Ibolours floor covering
    8NA without parking light warning light
    7QA without CD ROM
    2B1 additional exterior noise suppression
    1E0 without activated charcoal canister
    1T2 warning triangle
    2PX leather trimmed sports steering wheel
    J0R battery 380 A (80 Ah)
    4ZB bright moldings
    D3E 4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system, EU 3base engine is T9J/TG0
    H6S tires 195/65 R 15 V
    QJ0 without aluminum/chrome work package
    T9J components for base engine, unit 038.K
    VC0 w/o remote-controlled garage door opener
    6EP additional body covers, stone guard
    8GL alternator 120A
    7K0 without tire pressure warning light
    2JB standard bumpers
    3GK without additional filler for plane trunk floor
    9M0 without auxiliary/parking heater
    4LA without controls
    1EX special identification plate for EC
    8WD integrated front fog light
    1N1 power steering
    Q4H comfort sports seats, front
    9F0 without sound combination for rotating emergency light and radio antenna preparation
    4M6 cup holder
    1V0 without duty-free and cost-free tires
    0Y1 standard climatic zones
    5C0 without special body measures
    9FA without automatic transmission indicator light
    3X0 without load-through provision
    0XX information kit in German (for export)
    4U5 luggage pockets on backrest
    8AR radio "gamma" with removable operating panel
    7E6 electric auxiliary air heater
    5K1 paint preservative (wax)
    1VG installation parts for four-cylinder engine
    3Q1 rear headrests
    4UE airbag f. driver a. front seat passenger
    0JJ weight category front axle weight range 9
    3B4 child seat anchor for child seat system ISOFIX
    8BG twin headlamp for left-hand drive with integrated high-beam headlight
    K8D Station Wagon Variant/Avant
    0K0 without alternative drive module
    0YS weight category rear axle weight range 16
    5D1 carrier frequency 433.92 MHz
    3Y0 without roll-up sun screen
    1WD transmission shaft for tripod joints
    6PC leatherette hand brake lever handle
    7N0 without tray on roof liner
    8Z5 engine cooling system, type 1
    3C3 lap belt with retractor for the center rear seat
    4GH windshield tinted with windshield sunshield
    1X1 four wheel drive
    6Q2 leather gearshift knob/handle
    0SB labels/plates in German
    N0N woven fabric seat covering
    0L2 electric throttle actuation
    8RM eight loudspeakers (passive)
    4W0 without cassette and CD storage unit
    9HA without additional malfunction display
    9A0 without taxi alarm system
    0DE installation differentiation for build status of vehicle class B5 (VW Passat)
    8KA w/o catalytic converter warning light
    6XN outer rear view mirrors: powered, separately heated
    8S4 two reading lights front, two rear
    1Q1 mass damper for steering wheel, 26.5Hz
    A8S standard equipment
    1AT electronic stabilization program (ESP)
    4P1 rear floor panel module, type 2
    0LF special plates/stickers/ safety certificates for Switzerland
    8SA taillight assemblies, standard design
    QV0 w/o TV reception/digital radio reception
    3S2 black roof rails
    8L3 roof antenna
    QG2 no possibility of activating service interval prolongation
    2G0 without insert for the filling up of fuel
    1BA standard suspension/shock absorption
    6R2 leather gearshift boot
    9AK Climatronic with impact pressure control free of cfc
    0TA without floor mats
    Нераспознанные коды
    PH2 RCH
    Добавлено спустя 7 минут 14 секунд:
    nejtral
    VIN Number WVWZZZ3AZSE109273;
    Sales type 3A52W5;
    Exterior color B4
    Roof color B4
    Interior trim code CN;
    Engine code & No. AAZ578664;
    Transmission code CHA;
    Date of production 07.11.1994;
    Model year 1995;
    PR number:
    Код Опция
    3L1 manual height adjustment for left front seat
    8E5 local interference suppression for FM radio reception
    0MA without label for starting an automatic
    9BA w/o additional electric safety package
    3LA fabric door and side panel trim
    Q1A standard front seats
    B01 type approval Germany
    G0C 5-speed manual transmission
    1K2 hydraulic clutch actuation
    4J1 floor tray, extension center console
    8U0 without additional instruments for distance measurement
    1KC drum brakes, rear
    4YA without stowage box rear (door and side panel)
    4R0 mechanical window regulator
    0ND nameplate set "TDI"
    3U0 without luggage compartment cover
    8N1 windshield wiper intermittent control
    3MB velveted fleece floor covering
    7B2 12-volt socket in luggage boot
    4Z0 without glove compartment door
    8V1 cigarette lighter
    3FE electric slide/tilt sunroof with sun screen/sunblind
    J0N battery 330 A (61 Ah)
    1LB disc brakes, front
    5A2 comfort trunk lining
    3V0 without child bench seat
    S4U engine identification code for Austria (for CKD/KD handling)
    3NA without rear seat bench/backrest
    1EC special identification plate
    1TE fuel tank vent line with gravity valve and second vent line with PVC breather hoses
    8GM alternator 70A
    2C0 standard steering column
    6FA components without special surface appearance
    T2N components for base engine, unit 028.D
    2JE partially painted bumpers
    4E0 tailgate/trunk lid unlocking from outside
    3H0 without backrest release for front seats
    8A0 standard calibration (ECE)
    6V1 rear trim panel (ECE)
    1N1 power steering
    5J0 without rear spoiler
    1MZ steering wheel for airbag system
    M90 4-cylinder diesel engine 1.9 L/55 kW with cat, turbocharger, EGR and MVEG 2 base engine is T2N
    3P0 without bracket for first aid kit and warning triangle
    8AB radio "alpha"
    1NE wheel center cover
    5C1 body measures for increased safety requirements
    1G7 space-saving spare wheel (radial tire)
    4F0 mechanical locking system
    C0P steel wheels 6J x 14
    3AD outer right rear view mirror: convex, manually adjustable from inside
    H1F tires 195/55 R 15 85H
    3Q0 without rear headrests
    8Y0 single-tone horn
    8QA key without LED
    2E0 base chassis
    0RA without ignition/starter switch locking system
    8R0 without center high-mounted stop light
    3BC outer left rear view mirror: flat, manually adjustable from inside
    3YB door pockets, front
    3C0 without center rear seat belts
    8CA speedometer cable without seal
    8RD 2 loudspeakers (passive)
    1X0 front wheel drive
    A8C comfort equipment
    1AC anti-lock brake system (ABS)
    N0P woven fabric seat covering
    8S1 reading light front
    6QA rear seat catch
    0DP installation differentiation for build status of vehicle class B4 (VW Passat) unit components
    9AA manually controlled heating system
    3ZA without outer rear seat belts
    3S0 without roof rails/roof load rack
    8L3 roof antenna
    6R1 leatherette gearshift boot
    1BB suspension/shock absorption for rough road design
    Нераспознанные коды
    PS2 RAF
    Добавлено спустя 2 минуты 46 секунд:
    ivan2712
    VIN Number WVWPD63B93E404859;
    Sales type 3B34K5;
    Exterior color F8
    Roof color F8
    Interior trim code GA;
    Engine code & No. AWM195430;
    Transmission code EZS;
    Date of production 27.03.2003;
    Model year 2003;
    PR number:
    Код Опция
    5MA decorative inserts
    9Q1 multi-function indicator/trip computer
    T6V components for base engine, unit 06B.A
    8T1 cruise control system (CCS)
    4X8 side airbag front with head airbag and optimized head impact elements (USA)
    1YA without transmission shafts f. rear axle
    9Y1 outdoor temperature gage
    4Q1 flame retardent materials
    8TA without rear fog light
    C4A cast alloy wheels 7J x 15 offset 37 (3B0 601 025 K)
    3LD door and side panel trim
    7A1 CD changer preparation
    4B9 body-colored protective side molding with trim stripe
    G0F five-speed automatic transmission
    1Z6 increase in initial standard fuel filling
    H5B all-weather tires 195/65 R 15 H (NAR)
    8F1 side marker lights
    B0D component parts set, complying with vehicle type for USA (without California), various parts
    6SD tufted trunk floor covering (dimensionally stable)
    7AG electronic alarm system with vehicle immobilization device (for USA)
    0NB nameplate set in base trim
    4QQ 3-point seat belts with tensioner height adjustment and US label front
    1KF disc brakes, rear
    0G7 Tiptronic
    4K0 radio remote controlled central locking operated from inside
    8US radio "Premium" (double-size standard radio)
    7QA without CD ROM
    0VM information kit in American English
    2B2 additional exterior noise suppression
    0GN emissions concept ULEV 1
    1E4 activated charcoal canister acc. to ORVRand siphoning device for filling up
    1LE disc brakes, front
    4ZB bright moldings
    8GD alternator 90A
    1EB without identification plate
    9T1 heated washer nozzles, front
    3NZ rear seat bench unsplit, backrest split folding
    2JN comfort bumpers with chrome-plated strip
    B34 legal requirements USA
    1N1 power steering
    C09 operating permit, alteration 9
    U0F instrument insert with tachometer clock and mph speedometer
    4M6 cup holder
    MW9 4-cyl. gasoline engine 1.8 L/125 kW 20V turbo base engine is T6V/T0L
    1NA without wheel covers
    8Q0 without headlight-range adjustment
    6W0 without license plate bracket front
    0YE weight category rear axle weight range 5
    4UB airbag for NAR
    5K6 paint preservative with additional transit coating measures
    2T1 double-sized standard (DIN)
    0JK weight category front axle weight range 10
    3B3 child seat anchor
    3Q6 three rear headrests
    K8B notchback
    5RR outer right rear view mirror: convex, US
    5D2 carrier frequency 315 MHz
    8BL halogen headlight for left-hand drive US design
    5ZH headrests for front seats, articulated and height-adjustable with integrated release function
    S84 depletion of discontinued parts
    9VG sound system "Monsoon" (NAR)
    5SH outer left rear view mirror: flat (USA)
    8K4 daytime running lights mode US version
    8Z6 engine cooling system, type 2
    3C7 3-point seat belt for center rear seat
    1PC wheel bolts with anti-theft protection (unlockable)
    A8F sports equipment
    0SC labels/plates in English
    1AJ anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
    9P7 seat belt warning light and acoustic, electric contact in buckle
    0LB special plates/stickers/ safety certificates for USA
    9AB manually controlled air conditioning
    4A3 seat heater for front seats separately controlled
    8L3 roof antenna
    2G1 insert for the filling up of unleaded fuel
    Нераспознанные коды
    RMA WW1
  9. #769
    Украина, Киев
    mark_V
    большое спасибо
  10. #770
    Украина, Киев
    расшифруйте плиз вин
    WAUZZZ4BZ2N000700
  11. #771
    Украина, Киев
    люди плиз вверху код
    нужна комплектация
  12. #772
    Расшифруйте пожалуйста, актуально до 18 числа до ночи.
    WVWZZZ3BZVE090691
  13. #773
    Съебёж, Эта Страна
    Получено: 10
    sim_S4
    VIN Number WAUZZZ4BZ2N000700;
    Sales type 4B50X9;
    Exterior color 4Z
    Roof color 4Z
    Interior trim code LF;
    Engine code & No. AKE 306;
    Transmission code FTL;
    Date of production 14.05.2001;
    Model year 2002;
    PR number:
    Код Опция
    9B0 without telepay device
    4X3 side airbag front with curtain airbag
    9Q2 multi-function indicator/on-board computer with check control
    0LW special plates/stickers/ safety certificates for Germany
    5TZ decorative inserts, gray birch vein
    FQ0 standard production wheels
    0F3 fuel system for diesel engine
    QH0 without voice control
    7P1 power adjustable lumbar support in frontseats
    7A2 CD changer
    0N6 rear axle with reduced tread
    7X1 ultrasonic park distance control
    FC0 without customized installation
    2A4 delivery equipment for shipment (transitcoating) with thick seat cover
    0G1 gearshift lever
    7Q2 navigation system with color screen
    6SS luggage compartment floor covering
    0VC information kit in German
    VY0 without danger alarm system
    4K4 radio remote controlled central locking operated from inside and separate trunk release
    9ZF preparation for cellular phone with hands-free speaking system
    7QB CD ROM (Germany)
    6M1 tie down straps
    1T3 first aid kit and warning triangle
    0W1 label for central electric German-speaking countries
    H6M tires 235/45 R 17 tire width restricted
    4ZB bright moldings
    5A5 trunk lining, with stowage trays
    1LT disc brakes, front
    J1G battery 450 A (92 Ah)
    4L6 breakaway inside rear view mirror automatically dimming
    3GD plane rear cargo area
    8GU alternator 140A
    6FB body-colored outer rear view mirror housings
    N5D Valcona leather seat covering
    2Z1 type sign at rear and "Quattro" nameplates respectively
    2K1 reinforced bumpers
    1N1 power steering
    NT0 transit coating (type 1)
    8X1 headlight washer system
    3HA without leather parts scope
    1G3 alloy spare wheel with original equipment tires
    3X1 load-through provision with ski bag
    2ZQ leather trimmed multi-function steering wheel for airbag system
    3PF electric height adjustment for both front seats
    C17 operating permit, alteration 17
    8AY radio/navigation system
    6W5 front license plate bracket
    1VH installation parts for six-cylinder engine
    4N0 standard dashboard
    7M1 scuff plates in door apertures with metal inserts
    0JM weight category front axle weight range 12
    A00 no self-collection
    0YU weight category rear axle weight range 18
    5RU outer right rear view mirror: convex (large viewing field)
    S0C introductory volume
    9NX without electronic logbook
    8JH ellipsoidal headlight for driving on the right
    U2B instrument insert with km/h speedometer,radio-controlled clock, tachometer, tripodometer and additional instruments
    C9X alloy wheels 7 1/2J x 17 10-hole style, offset 45
    T5T components for base engine, unit 059.B
    5E2 sill top with door cover
    MR1 6-cyl. diesel engine 2.5 L/132 kW 24V TDI with fuel distributor injection pumpbase engine is T1K/T5T
    3CB removable net partition
    FA0 control of standard production
    8RY speakers with BOSE sound
    0ST labels/plates in German and French
    0DS installation differentiation for build status of vehicle class 4B0 (AUDI)
    3S1 bright roof rails
    QV1 TV reception
    4A4 seat heater for front and rear seats separately controlled
    Нераспознанные коды
    RLB PRB PSH PLA PNB P21 PPA
    Synthetic
    VIN Number WVWZZZ3BZVE090691;
    Sales type 3B23J5;
    Exterior color Z4
    Roof color Z4
    Interior trim code JN;
    Engine code & No. AEB 84113;
    Transmission code DHW;
    Date of production 01.04.1997;
    Model year 1997;
    PR number:
    Код Опция
    4AB partially leather door and side panel trim
    5MG decorative burr walnut inserts
    7A2 CD changer
    1RT nameplate set "1.8 T"
    0G1 gearshift lever
    T8B components for base engine, unit 058.D
    7Q1 navigation system
    7B0 without socket
    4ZE black moldings
    8GD alternator 90A
    7CA without label for radio remote control
    J1P battery 220 A (44 Ah)
    4M6 cup holder
    8AD radio "gamma"
    4U1 luggage nets/pockets on backrests
    C0V steel wheels 6J x 15 offset 45 (five-hole)
    M9L 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, MVEG 2 base engine is T8B/T8C
    3Q1 rear headrests
    K8B notchback
    0YZ without determination of weight categoryfor rear axle
    0JZ without determination of weight categoryfor front axle
    N7K Alcantara/leather seat covering
    8JM twin headlamp for left-hand drive with integrated high-beam headlight
    9W9 car phone installation
    6Q3 wooden gearshift knob/handle
    1AH electronic differential lock (EDL)
    7V0 standard dashboard illumination
    6QB locking rear seat catch
    0LA without special plates/stickers/ safety certificates
    9X0 without heated door lock cylinder
    Нераспознанные коды
    PT1 RNA WH1 RCF
    04/AWT/GFY
  14. #774
    Mex@n!K
    Спасибо!
  15. #775
    Polo Аватар для Skang
    Если не трудно и вот этот,пожалуйста. VIN - WVWZZZ3BZ1P272717 Зараннее благодарен!
    VW PASSAT B5GP 1.8T AWT 2001г продан.
    VW PASSAT B6 2009г 1.8 TSI AКПП6 Highline.
  16. #776
    Съебёж, Эта Страна
    Получено: 10
    Skang
    VIN Number WVWZZZ3BZ1P272717;
    Sales type 3B30J1;
    Exterior color 3P
    Roof color 3P
    Interior trim code FP;
    Engine code & No. AWT 43522;
    Transmission code EHV;
    Date of production 20.03.2001;
    Model year 2001;
    PR number:
    Код Опция
    7P0 without lumbar support in front and rear seats
    1Z1 increase in initial standard fuel filling by 4 liters
    0FG Mosel manufacturing sequence
    0G1 gearshift lever
    8N3 windshield wiper intermittent control with rain sensor
    6E0 without center armrest front
    7QA without CD ROM
    4ZE black moldings
    B20 type approval Turkey
    8GD alternator 90A
    C02 operating permit, alteration 2
    1N1 power steering
    MW8 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo base engine is T0L/T16/T6V/T63
    0YD weight category rear axle weight range 4
    0JG weight category front axle weight range 7
    3Q1 rear headrests
    9V7 electronic vehicle immobilization devicewith anti-theft alarm system and passenger compartment control
    K8B notchback
    1WC transmission shaft w/ 108mm in diameter
    8L3 roof antenna
    Нераспознанные коды
    WE5 P15 RCH
    04/AWT/GFY
  17. #777
    Mex@n!K
    Спасибо!!!!
  18. #778
    Если не затруднит,пробейте пож-та этот VIN: WVWZZZ3BZXP319527
    Заранее спасибо!
  19. #779
    Съебёж, Эта Страна
    Получено: 10
    Леха
    VIN Number WVWZZZ3BZXP319527;
    Sales type 3B23J5;
    Exterior color X1
    Roof color X1
    Interior trim code JJ;
    Engine code & No. APU 1890;
    Date of production 27.01.1999;
    Model year 1999;
    PR number:
    Код Опция
    7AB electronic alarm system with vehicle immobilization device (for RoW)
    0G1 gearshift lever
    7QA without CD ROM
    4ZE black moldings
    H6U tires 205/55 R 16 91W
    8GD alternator 90A
    ST7 model year change, calendar week 02
    8AA without radio
    4M6 cup holder
    C0J alloy wheels 7J x 16 "Montreal" offset 45
    C10 operating permit, alteration 10
    SU9 tractor head with ABS for Al-KO company
    0YC weight category rear axle weight range 3
    3Q1 rear headrests
    K8B notchback
    3Y1 roll-up sun screen for rear window
    8K1 daytime running lights mode
    WW1 winter package heated front seats heated washer nozzles, front
    Нераспознанные коды
    WE1 WH2 PJ2
    04/AWT/GFY
  20. #780
    Спасибо тебе Mex@n!K
Страница 39 из 698 ПерваяПервая ... 2937383940414989139539 ... ПоследняяПоследняя
  1. Расшифруйте пожайлуста VIN
    от никола777 в разделе Архив 2009г.
    Последнее сообщение: 28.05.2009, 21:54
  2. Расшифруйте пожалуйста VIN
    Последнее сообщение: 15.01.2007, 23:32
  3. Расшифруйте пожалуйста VIN WVWZZZ3BZWE181630
    от Клаусщ в разделе Архив 2007г.
    Последнее сообщение: 09.01.2007, 08:43
  4. Расшифруйте пожалуйста VIN
    от Алексей19 в разделе Архив 2006г.
    Последнее сообщение: 08.04.2006, 19:39
  5. Расшифруйте плз. VIN
    от andy77 в разделе Архив 2006г.
    Последнее сообщение: 27.01.2006, 12:34
