1. #681
    Россия, Павловский Посад
    По умолчанию Расшифруйте плиз.
    Можно мне расшифровать плиз.
    WVWZZZ3BZWP083709
  2. #682
    Россия, Москва, САО
    InFerNo
    VIN-номер: WVWZZZ3BZWP083709;
    Название модели: 3B2335;
    Цвет кузова: Z4;
    Цвет крыши: Z4;
    Код отделки салона: GP;
    Обозначение и № двигателя: AHU 36838;
    Код коробки передач: DHL;
    Дата изготовления: 10.07.1997;
    Код страны эксплуатации: X0A;
    Модельный год: 1998;
    Код Опция
    5MA decorative inserts
    4X1 side airbag front
    9Q1 multi-function indicator/trip computer
    8T1 cruise control system (CCS)
    8E2 local interference suppression for FM/AMradio reception
    3L3 manual height adjustment for front seats
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    4Q0 no flame retardent materials
    9J0 without supertone system and tone sequence control
    9Y1 outdoor temperature gage
    4B1 protective side molding
    L0L left-hand drive vehicle
    8TC rear fog light for driving on the right
    3LD door and side panel trim
    7A0 without CD changer/CD player
    1Z0 initial standard fuel filling
    Q1A standard front seats
    B01 type approval Germany
    G0C 5-speed manual transmission
    7P4 manually adjustable lumbar support in front seats
    0FG Mosel manufacturing sequence
    8F2 side turn signal lights
    2WA without additional tires
    B0A component parts set without country-specific design requirement
    7AB electronic alarm system with vehicle immobilization device (for RoW)
    1D0 without towing attachment
    6SD tufted trunk floor covering (dimensionally stable)
    0G1 gearshift lever
    T0T components for base engine, unit 028.M
    4R3 power windows with comfort operation
    8N1 windshield wiper intermittent control
    7Q0 without navigation device
    1SA without additional engine guard
    7B2 12-volt socket in luggage boot
    6E3 center armrest front
    9D0 without preparation for two-way radio installation
    3MQ Ibolours floor covering
    4K3 radio remote controlled central locking operated from inside and safe securing
    8NA without parking light warning light
    3FA without roof insert (standard roof)
    2PQ steering wheel for airbag system
    7QA without CD ROM
    2B1 additional exterior noise suppression
    1T2 warning triangle
    1E0 without activated charcoal canister
    E0A no special edition
    J0R battery 380 A (80 Ah)
    4ZE black moldings
    H6R tires 195/65 R 15 T
    6U0 without additional seals outside
    6EP additional body covers, stone guard
    8GL alternator 120A
    2QK nameplate set "TDI"
    9T1 heated washer nozzles, front
    4L2 dipping breakaway inside rear view mirror
    1LZ front disc brakes, standard ventilation
    4SD left vanity mirror illuminated
    7CA without label for radio remote control
    2JB standard bumpers
    3NZ rear seat bench unsplit, backrest split folding
    3GK without additional filler for plane trunk floor
    4E0 tailgate/trunk lid unlocking from outside
    1EX special identification plate for EC
    8WD integrated front fog light
    M0T 4-cyl. turbo diesel engine 1.9 L/66 kW direct injection base engine is T0T
    C04 operating permit, alteration 4
    U0C instrument insert with tachometer clock and km/h speedometer
    9F0 without sound combination for rotating emergency light and radio antenna preparation
    8X0 without headlight washer system
    4TD right vanity mirror illuminated
    4M6 cup holder
    8AD radio "gamma"
    1V0 without duty-free and cost-free tires
    0Y1 standard climatic zones
    1G2 steel spare wheel with original equipment tires
    5C0 without special body measures
    4U1 luggage nets/pockets on backrests
    9FA without automatic transmission indicator light
    3X0 without load-through provision
    8Q1 headlight-range adjustment
    C0V steel wheels 6J x 15 offset 45 (five-hole)
    6W1 license plate bracket front (large)
    7E3 sheathed type glow plug heater
    5K0 without paint preservative
    1VG installation parts for four-cylinder engine
    3Q1 rear headrests
    4UE airbag f. driver a. front seat passenger
    3B0 without additional child seat anchor
    F0A no special purpose vehicle, standard equipment
    K8B notchback
    5RQ outer right rear view mirror: convex
    0K0 without alternative drive module
    0RA without ignition/starter switch locking system
    5D1 carrier frequency 433.92 MHz
    3Y0 without roll-up sun screen
    8R1 center high-mounted stop light
    0YZ without determination of weight categoryfor rear axle
    0JZ without determination of weight categoryfor front axle
    3J7 articulated and height-adjustable headrests for front seats
    6PA plastic hand brake lever handle
    0KA without stickers and badges
    9W0 w/o car phone preparation/installation
    8JM twin headlamp for left-hand drive with integrated high-beam headlight
    8K0 without special low beam mode
    4GF windshield, tinted
    8CC speedometer sensor without seal (electronic speedometer sensor)
    8Z5 engine cooling system, type 1
    3C3 lap belt with retractor for the center rear seat
    5SL outer left rear view mirror: non-spherical
    1X0 front wheel drive
    1PA standard wheel bolts
    6Q1 plastic gearshift knob/handle
    6XD outer rear view mirrors: powered, heated
    1AC anti-lock brake system (ABS)
    0SB labels/plates in German
    8RM eight loudspeakers (passive)
    9P0 without seat belt warning light
    4W1 cassette storage unit
    9HA without additional malfunction display
    9A0 without taxi alarm system
    0DE installation differentiation for build status of vehicle class B5 (VW Passat)
    N0U cut pile seat covering
    3CA without partition
    8KA w/o catalytic converter warning light
    7V0 standard dashboard illumination
    8S4 two reading lights front, two rear
    V0A tires w/o specification of tire brand
    6Y0 without cruise control warning system
    A8S standard equipment
    6QB locking rear seat catch
    0LA without special plates/stickers/ safety certificates
    9X0 without heated door lock cylinder
    3S0 without roof rails/roof load rack
    8SA taillight assemblies, standard design
    4A3 seat heater for front seats separately controlled
    2G0 without insert for the filling up of fuel
    6R1 leatherette gearshift boot
    1BA standard suspension/shock absorption
    9AK Climatronic with impact pressure control free of cfc
    0TA without floor mats
    Нераспознанные коды
    WE1 WW1 PH2 WC1 RCF
  3. #683
    Цитата Сообщение от say
    InFerNo
    Нераспознанные коды
    WE1 WW1 PH2 WC1 RCF
    СПАСИБО!!!
  4. #684
    Получено: 574
    Отправлено: 100
    И мне пожалуйста расшифруйте...
    http://www.vw-club.ru/vw/vin/ не береть...
    WVWzzz3BZWE386619
    Pathfinder
  5. #685
    Россия, Москва, САО
    Mixxxa
    VIN-номер: WVWZZZ3BZWE386619;
    Название модели: 3B53E5;
    Цвет кузова: N4;
    Цвет крыши: N4;
    Код отделки салона: FD;
    Обозначение и № двигателя: ADR399675;
    Код коробки передач: DHZ;
    Дата изготовления: 12.03.1998;
    Код Опция
    9Q0 without multi-function indicator/ on-board computer
    8T0 without cruise control system (CCS)
    3L1 manual height adjustment for left front seat
    M51 4-cyl. gasoline engine 1.8 L/92 kW 20V with MVEG 2 base engine is T0V/T5Z
    9Y0 without outdoor temperature gage
    7P0 without lumbar support in front and rear seats
    3LC foamed film and fabric door and side panel trim
    0FA standard manufacturing sequence
    7AA electronic vehicle immobilization device
    0G1 gearshift lever
    4R2 power windows front, mechanical window regulators rear
    6SL tufted trunk floor covering (cut pile)
    8N4 windshield wiper intermittent control with potentiometer (four speeds)
    7B0 without socket
    6E0 without center armrest front
    7QA without CD ROM
    2B2 additional exterior noise suppression
    1E1 activated carbon canister
    4ZE black moldings
    H6S tires 195/65 R 15 V
    8GD alternator 90A
    9T0 without heated washer nozzles
    3NW rear seat bench/backrest, split folding with center armrest
    J1P battery 220 A (44 Ah)
    0PG nameplate set "1.8"
    C07 operating permit, alteration 7
    4M0 without cup holder
    8AC radio "beta"
    4U0 without luggage nets/pockets on backrests
    4F1 central locking system
    7E0 w/o heat accumulator/auxiliary heating
    0YD weight category rear axle weight range 4
    0JE weight category front axle weight range 5
    3Q1 rear headrests
    K8D Station Wagon Variant/Avant
    5D0 without carrier frequency
    8RE four loudspeakers (passive)
    4GH windshield tinted with windshield sunshield
    N0P woven fabric seat covering
    T5Z components for base engine, unit 058.B
    6QA rear seat catch
    4A0 without seat heater
    9AB manually controlled air conditioning
    3S2 black roof rails
    2G1 insert for the filling up of unleaded fuel
    3CX net partition
    Нераспознанные коды
    PH1 RBB
  6. #686
    Получено: 574
    Отправлено: 100
    say Огромное тебе спасибо!!!
    И с днем рождения!!!!
    Pathfinder
  7. #687
    Приветствую всех!
    помогите с номером WVWZZZ1HZSW097587
    ETKA 6.31 rus у меня ошибки выдает (почему?)
  8. #688
    Помогите пожалуйста!
    http://www.vw-club.ru/vw/vin/ тоже не помогает
  9. #689
    Россия, Красноярск
    Здравствуйте! Подскажите пожалуйста:WVWZZZ3BZ2E278341
    Спасибо.
  10. #690
    Россия, Москва, САО
    Ok
    У тебя слишком старая машина. Тогда ещё не было учёта комплектаций.
    tommy
    VIN-номер: WVWZZZ3BZ2E278341;
    Название модели: 3B31D1;
    Цвет кузова: 1W;
    Цвет крыши: 1W;
    Код отделки салона: GB;
    Обозначение и № двигателя: AZM 19528;
    Код коробки передач: EMV;
    Дата изготовления: 24.11.2001;
    Код страны эксплуатации: X7W;
    Модельный год: 2002;
    Код Опция
    4X0 without side airbag
    0TD front and rear floor mats
    1YA without transmission shafts f. rear axle
    FB3 surface, interior trim, soft-touch paint
    B76 type approval Belarus (White Russia)
    1C2 antifreeze up to -35 degree celsius tolerance up to -40 degree C
    1Z2 increase in initial standard fuel filling
    9JB smoking version, ashtray front and rear
    VX0 without hands-free system
    7X0 without park distance control
    QA0 without child seat
    1ZC disc brakes, front (Geomet D)
    1KD disc brakes, rear
    T10 components for base engine, unit 06B.J
    0G1 gearshift lever
    C5E steel wheels 6J x 15 offset 37
    1SB additional engine guard
    7B3 12-volt socket(s)
    1DB nameplate set "2.0"
    Q2J comfort front seats
    4Z2 lockable glove compartment door
    7QA without CD ROM
    3FE electric slide/tilt sunroof with sun screen/sunblind
    0VU information kit in Russian
    4ZB bright moldings
    0GV emissions concept EU 2 (critical vapor pressure)
    4KC side and rear windows tinted
    SS8 control of pre-series vehicles and SOP 45/01 with related model year change points
    QJ0 without aluminum/chrome work package
    VC0 w/o remote-controlled garage door opener
    8GD alternator 90A
    7K0 without tire pressure warning light
    J1L battery 280 A (60 Ah)
    9M0 without auxiliary/parking heater
    4LA without controls
    1EY special identification plate with weight data, but without general operating permit (ROW)
    C05 operating permit, alteration 5
    1N1 power steering
    8AA without radio
    4M6 cup holder
    1NC full wheel covers
    4U5 luggage pockets on backrest
    0JG weight category front axle weight range 7
    3Q1 rear headrests
    3B4 child seat anchor for child seat system ISOFIX
    8BG twin headlamp for left-hand drive with integrated high-beam headlight
    K8B notchback
    6A0 without fire extinguisher
    1WC transmission shaft w/ 108mm in diameter
    3QT 3-point seat belts with tensioner and height adjustment, front
    7N0 without tray on roof liner
    0L2 electric throttle actuation
    4W0 without cassette and CD storage unit
    6XN outer rear view mirrors: powered, separately heated
    0SN labels/plates in Russian
    1Q0 without mass damper for steering wheel
    4P1 rear floor panel module, type 2
    QV0 w/o TV reception/digital radio reception
    8L3 roof antenna
    MK6 4-cylinder gasoline engine 2.0 L/85 kW base engine is T04/T10/T11/T51
    QG2 no possibility of activating service interval prolongation
    1BB suspension/shock absorption for rough road design
    Нераспознанные коды
    WE1 PSW WW1 PH2
  11. #691
    say
    Да не может быть, - 95 года.
    Причем я другие гольфы начиная с 92 года Еткой пробивал запросто, а этот ВИН ни в какую
  12. #692
    Россия, Москва, САО
    Ok
    Думаю, что VIN перебитый. Поменял 8 на 0 и VIN легко пробился.
    Ну-ка, проверь:
    VIN-номер: WVWZZZ1HZSW097507;
    Название модели: 1H1334;
    Цвет кузова: Z4;
    Цвет крыши: Z4;
    Код отделки салона: DM;
    Обозначение и № двигателя: 1Z 334715;
    Код коробки передач: ASD;
    Дата изготовления: 22.09.1994;
    Код страны эксплуатации: X4A;
    Модельный год: 1995;
    Код Опция
    6Z1 yellow turn signal lights
    0MA without label for starting an automatic
    4AR foamed film and circular-knit door and side panel trim
    8M1 rear window wiper and washer system with intermittent control
    H4V tires 185/60 R 14 T
    6KA radiator grille
    1K2 hydraulic clutch actuation
    0UA without special color trim
    N2M fabric seat covering
    0N2 heavy-duty rear axle
    9R0 WITHOUT CONTROL CHECK PACKAGE
    4J1 floor tray, extension center console
    3M0 without special measures
    2P1 plastic trunk sill protection
    B0B component parts set, complying with vehicle type for Austria, various parts
    1KB drum brakes, rear
    6SC tufted trunk floor covering
    Q1W standard front seats with integrated storage trays
    4R1 power windows
    4YB stowage box rear (door and side panel)
    0G4 cable gearshift
    3U1 foldable trunk cover
    8N2 windshield wiper intermittent control infinitely variable
    B12 type approval Austria
    4Z3 lockable glove compartment door, with light
    E7G Golf GL "Europe"
    7Y0 without additional cooling system/ headpipe cooling/headpipe insulation
    6EA without additional side body covers (stone guard)
    C5Y steel wheels 6J x 14 offset 45
    J0N battery 330 A (61 Ah)
    2B5 additional exterior noise suppression
    2PY steering wheel for airbag system (RoW) (lightweight design)
    5A2 comfort trunk lining
    1LL disc brakes, front
    3NC rear seat bench/backrest, split folding
    1TB fuel tank vent line with gravity valve and PVC breather hose
    1EB without identification plate
    8GL alternator 120A
    0A2 four doors
    9E1 luggage compartment lighting
    T2F components for base engine, unit 028.C
    3GA without cargo area
    S5F Caddy "Topline"
    2C1 height adjustable steering column
    2QV nameplate set "GL TDI"
    2JE partially painted bumpers
    6FE body-colored outer rear view mirror housings and tailgate grab strip
    0AB front stabilizer
    9TA without additional warning lights
    3W0 without additional noise suppression measures for passenger compartment
    8WA without front fog light
    3H0 without backrest release for front seats
    1N1 power steering
    6NA unsplit molding roof liner
    0Q0 without label for brake-proportioning values
    5J0 without rear spoiler
    9U0 without brake pad wear indicator
    3P1 bracket for first aid kit and warning triangle
    8PB ashtray light
    8AA without radio
    7L0 without inertia benefit system/ deceleration fuel cut-off/idle stop valve
    S6H CPU scope 1, Mosel (water-soluble paint)
    2D0 without cd enhancing underbody panel
    0BA without rear stabilizer
    1G6 space-saving spare wheel
    1NG wheel center cover and wheel trim ring
    8Q0 without headlight-range adjustment
    3AF outer right rear view mirror: convex, powered, heated
    5K1 paint preservative (wax)
    9V0 without anti-theft protection system
    4N1 padded dashboard
    4UC airbag for driver
    8Y1 two-tone horn
    3Q1 rear headrests
    8QC key with light
    8BB halogen headlight for left-hand drive
    2LA fuel tank without special material treatment
    2E0 base chassis
    6P1 license plate bracket rear (ECE)
    1H1 load-sensitive proportioning valve
    M2K 4-cyl. turbo diesel eng. 1.9 L/66 kW TDIand MVEG 2 base engine is T2F
    K8G hatchback
    8R0 without center high-mounted stop light
    1WB transmission shaft w/ 100mm in diameter
    5L1 front spoiler
    3C1 static lap belt, center rear
    3BS outer left rear view mirror: non-spherical, powered, heated
    3YH door pockets, front
    6B0 without tie-down eyes for load restraint
    A8D luxury equipment
    6Q4 comfort gearshift knob/handle
    8S1 reading light front
    0DG installation differentiation for build status of vehicle class A3 (VW Golf/ Vento/Variant), unit components
    0KZ stickers for special editions
    V0F CONTINENTAL tires
    9AA manually controlled heating system
    8L1 bright rod antenna
    3ZE 3-point seat belts, outer rear with height adjustment and ECE label
    6R3 rubber gearshift boot
    Нераспознанные коды
    PE9 PF1 W1T WL2
  13. #693
    say
    нет, совсем не она
    сервисная книжка есть, модель 1H13H4
    думаю, что еткой другой надо смотреть, 6.31 модель 1H13H4 не знает, поэтому и сбоит, хотя ELSA знает такую модель
  14. #694
    Россия, Москва, САО
    Ok
    Если есть большое желание пробить этот номер, то могу в воскресенье (если не забуду) попробовать его пробить в ELSA.
    Интересно, а какой другой ETKA ты собираешься пробивать? Я пробовал 6.31.612 и в ЕТКА US 6.31.696.
  15. #695
    say
    Да, если можно. Заранее спасибо.
    ну не знаю, у меня в доступности только 6.31.529 да к тому же русская, просто высказал предположение, что в более свежих обновлениях модель добавлена.
  16. #696
    Россия, Красноярск
    say: спасибо тебе БОЛЬШОЕ! Будем переводить, что у нас за мафын
  17. #697
    ЮАР
    А где-нибудь в инете есть расшифровка? Я где-то откопал такой сайт, но потом балбес потерял
  18. #698
    Россия, Москва, САО
    Ok
    Данные по автомобилю
    Марка: V
    VIN-номер: WVWZZZ1HZSW097587
    Код страны: DEU
    Модельный год: 1995
    Описание: GOLF GL L266 EG1 5G
    Регион: 141
    Название модели: 1H13H4
    Дата изготовления: 1994-09-22
    Номер дилера: 31054
    Бук.обоз.дв.: ABS
    Дата поставки: 1994-10-13
    Бук.обоз.КП: CHB
    Цветовое исполнение
    Тип Код цвета Описание
    наружн. W7/W7 dragon green perleffekt/dragon green perleffekt
    внутр. JE schwarz/schwarz/schwarz
    Коды комплектаций
    Текущий номер № Происхождение Серия Описание
    1 5K0 without paint preservation
    2 E7G Golf GL "Europe"
    3 PD4 Warning system, immobiliser
    4 PE9 Airbag at driversside
    5 RAB Radio "alpha", Telescopic
    6 S5F Sticker 'Already with Catalyst Technology'
    7 S6H Weiterlauf von Motoren MJ 94 in MJ 95
    8 WE2 Golf GL "Europe" -Inland-
    9 X0A Landessetzung Deutschland
  19. #699
    Получено: 9
    VIN номер раз: WVWZZZ31ZME185192
    Номер два: VWVZZZ32ZCB121865
    Интересно, пробьется или нет.....
  20. #700
    Россия, Ногинск
    Spaze, Паш, у меня не бьются (неизвестный номер шасси).
Страница 35 из 698 ПерваяПервая ... 2533343536374585135535 ... ПоследняяПоследняя
  1. Расшифруйте пожайлуста VIN
    от никола777 в разделе Архив 2009г.
    Последнее сообщение: 28.05.2009, 21:54
  2. Расшифруйте пожалуйста VIN
    Последнее сообщение: 15.01.2007, 23:32
  3. Расшифруйте пожалуйста VIN WVWZZZ3BZWE181630
    от Клаусщ в разделе Архив 2007г.
    Последнее сообщение: 09.01.2007, 08:43
  4. Расшифруйте пожалуйста VIN
    от Алексей19 в разделе Архив 2006г.
    Последнее сообщение: 08.04.2006, 19:39
  5. Расшифруйте плз. VIN
    от andy77 в разделе Архив 2006г.
    Последнее сообщение: 27.01.2006, 12:34
