1. #641
    Россия, Екатеринбург
    посмотрите, пожалуйста:
    WVWPD63B82P064624
  2. #642
    И мне посмотрите,пожалуйста,если нетрудно:
    WVWZZZ3BZWP400976
  3. #643
    Россия, Москва, САО
    Romario
    VIN-номер: WVWPD63B82P064624;
    Название модели: 3B34K1;
    Цвет кузова: F8;
    Цвет крыши: F8;
    Код отделки салона: VA;
    Обозначение и № двигателя: AWM 71586;
    Код коробки передач: EZG;
    Дата изготовления: 19.06.2001;
    Код страны эксплуатации: X9A;
    Модельный год: 2002;
    Код Опция
    5MA decorative inserts
    0TD front and rear floor mats
    9Q1 multi-function indicator/trip computer
    4X3 side airbag front with curtain airbag
    T6V components for base engine, unit 06B.A
    8T1 cruise control system (CCS)
    8E2 local interference suppression for FM/AMradio reception
    3L3 manual height adjustment for front seats
    1YA without transmission shafts f. rear axle
    FB3 surface, interior trim, soft-touch paint
    1C2 antifreeze up to -35 degree celsius tolerance up to -40 degree C
    9Y1 outdoor temperature gage
    9J0 without supertone system and tone sequence control
    4Q1 flame retardent materials
    L0L left-hand drive vehicle
    8TA without rear fog light
    C4A cast alloy wheels 7J x 15 offset 37 (3B0 601 025 K)
    7A1 CD changer preparation
    G0C 5-speed manual transmission
    7P4 manually adjustable lumbar support in front seats
    4B9 body-colored protective side molding with trim stripe
    3LJ foamed film door and side panel trim inserts in leatherette
    1Z6 increase in initial standard fuel filling
    9JB smoking version, ashtray front and rear
    VX0 without hands-free system
    0FG Mosel manufacturing sequence
    H5B all-weather tires 195/65 R 15 H (NAR)
    8F1 side marker lights
    7X0 without park distance control
    2WA without additional tires
    QA0 without child seat
    B0D component parts set, complying with vehicle type for USA (without California), various parts
    1D0 without towing attachment
    6SD tufted trunk floor covering (dimensionally stable)
    7AG electronic alarm system with vehicle immobilization device (for USA)
    0NB nameplate set in base trim
    0G1 gearshift lever
    4QQ 3-point seat belts with tensioner height adjustment and US label front
    1KF disc brakes, rear
    4R3 power windows with comfort operation
    7Q0 without navigation device
    8N4 windshield wiper intermittent control with potentiometer (four speeds)
    1SA without additional engine guard
    7B3 12-volt socket(s)
    6E3 center armrest front
    4K0 radio remote controlled central locking operated from inside
    Q2J comfort front seats
    9D0 without preparation for two-way radio installation
    4Z2 lockable glove compartment door
    3MQ Ibolours floor covering
    8NA without parking light warning light
    7QA without CD ROM
    3FE electric slide/tilt sunroof with sun screen/sunblind
    0VM information kit in American English
    1T0 w/o first aid kit and warning triangle
    2B2 additional exterior noise suppression
    0GN emissions concept ULEV 1
    E0A no special edition
    1LE disc brakes, front
    1E4 activated charcoal canister acc. to ORVRand siphoning device for filling up
    J0R battery 380 A (80 Ah)
    4ZB bright moldings
    4KC side and rear windows tinted
    QJ0 without aluminum/chrome work package
    VC1 remote-controlled garage door opener
    8GD alternator 90A
    6U0 without additional seals outside
    6EP additional body covers, stone guard
    1EB without identification plate
    9T1 heated washer nozzles, front
    4L2 dipping breakaway inside rear view mirror
    4SG left vanity mirror illuminated extractable sun visor
    7K0 without tire pressure warning light
    3NZ rear seat bench unsplit, backrest split folding
    3GK without additional filler for plane trunk floor
    9M0 without auxiliary/parking heater
    2JN comfort bumpers with chrome-plated strip
    8WD integrated front fog light
    4LF radio and CCS controls
    C03 operating permit, alteration 3
    B34 legal requirements USA
    1N1 power steering
    U0F instrument insert with tachometer clock and mph speedometer
    9F0 without sound combination for rotating emergency light and radio antenna preparation
    8X0 without headlight washer system
    4TG right vanity mirror illuminated extractable sun visor
    4M6 cup holder
    2ZB leather trimmed multi-function steering wheel
    MW9 4-cyl. gasoline engine 1.8 L/125 kW 20V turbo base engine is T6V/T0L
    1V0 without duty-free and cost-free tires
    1NA without wheel covers
    0Y1 standard climatic zones
    1G2 steel spare wheel with original equipment tires
    5C1 body measures for increased safety requirements
    9FA without automatic transmission indicator light
    3X0 without load-through provision
    8Q0 without headlight-range adjustment
    4U5 luggage pockets on backrest
    7E0 w/o heat accumulator/auxiliary heating
    6W0 without license plate bracket front
    1VG installation parts for four-cylinder engine
    0YE weight category rear axle weight range 5
    4UB airbag for NAR
    5K6 paint preservative with additional transit coating measures
    0JH weight category front axle weight range 8
    3B3 child seat anchor
    3Q6 three rear headrests
    F0A no special purpose vehicle, standard equipment
    K8B notchback
    6A0 without fire extinguisher
    0K0 without alternative drive module
    5RR outer right rear view mirror: convex, US
    8BL halogen headlight for left-hand drive US design
    5D2 carrier frequency 315 MHz
    8YA radio for USA
    3Y1 roll-up sun screen for rear window
    5ZH headrests for front seats, articulated and height-adjustable with integrated release function
    8R1 center high-mounted stop light
    9VG sound system "Monsoon" (NAR)
    6PC leatherette hand brake lever handle
    1WD transmission shaft for tripod joints
    0KA without stickers and badges
    9W0 w/o car phone preparation/installation
    5SH outer left rear view mirror: flat (USA)
    7N0 without tray on roof liner
    8K4 daytime running lights mode US version
    8Z6 engine cooling system, type 2
    1X0 front wheel drive
    4GH windshield tinted with windshield sunshield
    6Q2 leather gearshift knob/handle
    3C7 3-point seat belt for center rear seat
    1PC wheel bolts with anti-theft protection (unlockable)
    A8F sports equipment
    0SC labels/plates in English
    0L2 electric throttle actuation
    4W0 without cassette and CD storage unit
    9HA without additional malfunction display
    9A0 without taxi alarm system
    0DE installation differentiation for build status of vehicle class B5 (VW Passat)
    1AJ anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
    8KA w/o catalytic converter warning light
    3CA without partition
    6XN outer rear view mirrors: powered, separately heated
    8S4 two reading lights front, two rear
    9P7 seat belt warning light and acoustic, electric contact in buckle
    N0X part leather seat covering "Sports Grain"
    V0A tires w/o specification of tire brand
    6Y0 without cruise control warning system
    1Q0 without mass damper for steering wheel
    0LB special plates/stickers/ safety certificates for USA
    4P1 rear floor panel module, type 2
    9AB manually controlled air conditioning
    3S0 without roof rails/roof load rack
    8SA taillight assemblies, standard design
    QV0 w/o TV reception/digital radio reception
    4A3 seat heater for front seats separately controlled
    8L3 roof antenna
    QG2 no possibility of activating service interval prolongation
    2G1 insert for the filling up of unleaded fuel
    1BA standard suspension/shock absorption
    6R2 leather gearshift boot
    Нераспознанные коды
    PJ6 RMA PLD PHL
    VOVAN2X
    VIN-номер: WVWZZZ3BZWP400976;
    Название модели: 3B23C5;
    Цвет кузова: Z4;
    Цвет крыши: Z4;
    Код отделки салона: YY;
    Обозначение и № двигателя: AHL135319;
    Код коробки передач: DCN;
    Дата изготовления: 01.04.1998;
    Код страны эксплуатации: X0A;
    Модельный год: 1998;
    Код Опция
    4X1 side airbag front
    T6U components for base engine, unit 06B.1
    9Q2 multi-function indicator/on-board computer with check control
    8T0 without cruise control system (CCS)
    4AB partially leather door and side panel trim
    M4T 4-cylinder gasoline engine 1.6 L/74 kW w/ multi-point injection a. MVEG 2/EU 3Dbase engine is T6U
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    4Q0 no flame retardent materials
    S31 control number (in-plant)
    4B1 protective side molding
    8TC rear fog light for driving on the right
    7A0 without CD changer/CD player
    1Z0 initial standard fuel filling
    Q1A standard front seats
    B01 type approval Germany
    8F2 side turn signal lights
    B0A component parts set without country-specific design requirement
    7AB electronic alarm system with vehicle immobilization device (for RoW)
    0G1 gearshift lever
    7Q1 navigation system
    7B2 12-volt socket in luggage boot
    4K3 radio remote controlled central locking operated from inside and safe securing
    3FA without roof insert (standard roof)
    2B0 without additional exterior noise suppression
    7QB CD ROM (Germany)
    1T2 warning triangle
    1E1 activated carbon canister
    4ZE black moldings
    H6S tires 195/65 R 15 V
    8GD alternator 90A
    N4M partially leather seat covering
    1LZ front disc brakes, standard ventilation
    4SD left vanity mirror illuminated
    7CA without label for radio remote control
    2JB standard bumpers
    J1P battery 220 A (44 Ah)
    4E0 tailgate/trunk lid unlocking from outside
    1EX special identification plate for EC
    8WA without front fog light
    C07 operating permit, alteration 7
    1MR leather steering wheel
    U0C instrument insert with tachometer clock and km/h speedometer
    4TD right vanity mirror illuminated
    4M6 cup holder
    8AC radio "beta"
    5C0 without special body measures
    4U1 luggage nets/pockets on backrests
    8Q1 headlight-range adjustment
    C0V steel wheels 6J x 15 offset 45 (five-hole)
    6W1 license plate bracket front (large)
    5K0 without paint preservative
    0YC weight category rear axle weight range 3
    0JD weight category front axle weight range 4
    3Q1 rear headrests
    4UE airbag f. driver a. front seat passenger
    3B0 without additional child seat anchor
    K8B notchback
    8BG twin headlamp for left-hand drive with integrated high-beam headlight
    5RQ outer right rear view mirror: convex
    0RA without ignition/starter switch locking system
    5D1 carrier frequency 433.92 MHz
    3Y0 without roll-up sun screen
    3J7 articulated and height-adjustable headrests for front seats
    8K0 without special low beam mode
    8CC speedometer sensor without seal (electronic speedometer sensor)
    8Z5 engine cooling system, type 1
    8RE four loudspeakers (passive)
    3C3 lap belt with retractor for the center rear seat
    5SL outer left rear view mirror: non-spherical
    1PA standard wheel bolts
    6XD outer rear view mirrors: powered, heated
    1AC anti-lock brake system (ABS)
    0SB labels/plates in German
    9P0 without seat belt warning light
    7V0 standard dashboard illumination
    A8S standard equipment
    6QB locking rear seat catch
    0LA without special plates/stickers/ safety certificates
    9X0 without heated door lock cylinder
    9AK Climatronic with impact pressure control free of cfc
    Нераспознанные коды
    WE1 PLA RNA PH2 WC1 RBB
  4. #644
    say
    Спасибо,буду переводить.
    Цитата Сообщение от say
    Нераспознанные коды
    Подскажи,пожалуйст,что это такое???
  5. #645
    Россия, Москва, САО
    Цитата Сообщение от VOVAN2X
    say писал(а):
    Нераспознанные коды
    Видимо та база по которой пробиваются коды устарела.
  6. #646
    Съебёж, Эта Страна
    Получено: 10
    WC1 "Comfortline" equipment package
    WE1 Technical equipment package radio remote control, alarm system, socket, rear, multifunction display
    PH2 Air con, “Climatronic”, free of cfc
    04/AWT/GFY
  7. #647
    Есть ли у кого-нибудь перевод всех этих обозначений???
  8. #648
    Съебёж, Эта Страна
    Получено: 10
    Файл со всеми PR кодами в формате Word на английском, несжатый занимает 9 мегабайт Т.к. перевести его весь можно, хоть и сложно
    Какие строки тебя конкретно интересуют?
    04/AWT/GFY
  9. #649
    Passat Аватар для Ratamahatta
    Россия, Москва, ВАО, Перово
    Получено: 18
    ммм.... может выложишь?
  10. #650
    Mex@n!K
    я с помощью переводчика перевел.Но там такой перевод,что....
  11. #651
    Съебёж, Эта Страна
    Получено: 10
    Ratamahatta
    Выкладываю...Я уже предлагал такую идею: Разделить фронт работ, и попытаться перевести его, не обязательно весь. Нужны те кто знает английский, технические термины. Я один этот файл не осилю
    Потом сделать форму для вставки PR и получить русскую расшифровку...Звучит классно, не правда ли? Вот только сделать сложнее чем сказать, хотя...
    http://webfile.ru/1049029 <<доступен>>
    04/AWT/GFY
  12. #652
    Получено: 18
    Mex@n!K
    спасибо! ;)
    там чуть более 9700 записей, правда много повторяется...
    при желании нескольких людей, можно все перевести...
    я могу сделать раскодирование онлайн, типа вводишь на форме список кодов, а тебе на английском и русском все выводится...
    если есть желающие, можно поделить работу, каждому дать свой кусок...
  13. #653
    Ratamahatta
    Я бы помог,только не знаю чем??
  14. #654
    Получено: 18
    лана, щас попробую у себя на хосте что-нибудь сбацать... потом покажу, оцените....
  15. #655
    Съебёж, Эта Страна
    Получено: 10
    Ratamahatta
    Давай доводи идею Нужно что-то перевести - обращайся!
    04/AWT/GFY
  16. #656
    Россия, Королев
    say
    очень благодарен за расшифровку.
    вот только двигатель у меня AEB
  17. #657
    Россия, Москва, САО
    domovenok
    Пробил твою машину через Эльзу, показывает ту же комплектацию. Из этого делаем вывод, что на машине перебиты номера или ты дал не правильный номер.
  18. #658
    Россия, Королев
    say
    У меня возникли такие подозрения, поэтому и попросил пробить.
    Самое страшное начинает сбываться.
  19. #659
    Получено: 23
    Отправлено: 87
    Кстати здесь все прекрасно расшифровывается причем на русском http://www.vw-club.ru/vw/vin/
  20. #660
    Россия, Королев
    Allman
    Спасибо.
    Пора наверное тему закрывать.
Страница 33 из 698 ПерваяПервая ... 2331323334354383133533 ... ПоследняяПоследняя
  1. Расшифруйте пожайлуста VIN
    от никола777 в разделе Архив 2009г.
    Последнее сообщение: 28.05.2009, 21:54
  2. Расшифруйте пожалуйста VIN
    Последнее сообщение: 15.01.2007, 23:32
  3. Расшифруйте пожалуйста VIN WVWZZZ3BZWE181630
    от Клаусщ в разделе Архив 2007г.
    Последнее сообщение: 09.01.2007, 08:43
  4. Расшифруйте пожалуйста VIN
    от Алексей19 в разделе Архив 2006г.
    Последнее сообщение: 08.04.2006, 19:39
  5. Расшифруйте плз. VIN
    от andy77 в разделе Архив 2006г.
    Последнее сообщение: 27.01.2006, 12:34
