1. #561
    Россия, Пенза
    И мне пригнали!!!!!!УРА млять!!!!''
    расшифруйте пажалуста!
    WVWZZZ3BZYP093381
  2. #562
    Passat Аватар для Ratamahatta
    Россия, Москва, ВАО, Перово
    Получено: 18
    а как пробег мона пробить по вину?
    к официалам?
  3. #563
    sawer, лови
    VIN Number WVWZZZ3BZYP093381;
    Sales type 3B23W5;
    Exterior color T3
    Roof color T3
    Interior trim code GQ;
    Engine code & No. ARG 11518;
    Transmission code DWA;
    Date of production 26.07.1999;
    Model year 2000;
    Расшифровка кодов комплектации
    Код Опция
    5MA decorative inserts
    4X1 side airbag front
    9Q1 multi-function indicator/trip computer
    8T0 without cruise control system (CCS)
    8E2 local interference suppression for FM/AMradio reception
    3L3 manual height adjustment for front seats
    1YA without transmission shafts f. rear axle
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    4Q0 no flame retardent materials
    9J0 without supertone system and tone sequence control
    9Y1 outdoor temperature gage
    D1A 4-cyl. gasoline engine 1.8 L/92 kW 20V EU 3D base engine is T5Z
    4B1 protective side molding
    L0L left-hand drive vehicle
    8TC rear fog light for driving on the right
    3LD door and side panel trim
    1Z0 initial standard fuel filling
    B01 type approval Germany
    G0C 5-speed manual transmission
    7P4 manually adjustable lumbar support in front seats
    7A2 CD changer
    0FG Mosel manufacturing sequence
    7X0 without park distance control
    8F2 side turn signal lights
    2WA without additional tires
    QA0 without child seat
    B0A component parts set without country-specific design requirement
    7AB electronic alarm system with vehicle immobilization device (for RoW)
    6SD tufted trunk floor covering (dimensionally stable)
    1D2 removable and lockable towing attachment
    0G1 gearshift lever
    4R3 power windows with comfort operation
    7Q0 without navigation device
    8N4 windshield wiper intermittent control with potentiometer (four speeds)
    1SA without additional engine guard
    7B2 12-volt socket in luggage boot
    6E3 center armrest front
    Q2J comfort front seats
    9D0 without preparation for two-way radio installation
    0GF emissions concept D3 (EU 3D)
    3MQ Ibolours floor covering
    4K3 radio remote controlled central locking operated from inside and safe securing
    8NA without parking light warning light
    3FA without roof insert (standard roof)
    2PQ steering wheel for airbag system
    7QA without CD ROM
    2B2 additional exterior noise suppression
    1T2 warning triangle
    1E1 activated carbon canister
    E0A no special edition
    4ZE black moldings
    H6S tires 195/65 R 15 V
    8GD alternator 90A
    6U0 without additional seals outside
    6EP additional body covers, stone guard
    9T0 without heated washer nozzles
    4L2 dipping breakaway inside rear view mirror
    1LZ front disc brakes, standard ventilation
    4SD left vanity mirror illuminated
    7K0 without tire pressure warning light
    2JB standard bumpers
    3NZ rear seat bench unsplit, backrest split folding
    J1P battery 220 A (44 Ah)
    3GK without additional filler for plane trunk floor
    9M0 without auxiliary/parking heater
    4LA without controls
    4E0 tailgate/trunk lid unlocking from outside
    1EX special identification plate for EC
    0PG nameplate set "1.8"
    8WD integrated front fog light
    U0C instrument insert with tachometer clock and km/h speedometer
    9F0 without sound combination for rotating emergency light and radio antenna preparation
    8X0 without headlight washer system
    4TD right vanity mirror illuminated
    4M6 cup holder
    8AD radio "gamma"
    1V0 without duty-free and cost-free tires
    0Y1 standard climatic zones
    1G2 steel spare wheel with original equipment tires
    5C0 without special body measures
    9FA without automatic transmission indicator light
    3X0 without load-through provision
    8Q1 headlight-range adjustment
    4U5 luggage pockets on backrest
    C11 operating permit, alteration 11
    7E0 w/o heat accumulator/auxiliary heating
    C0V steel wheels 6J x 15 offset 45 (five-hole)
    6W1 license plate bracket front (large)
    5K0 without paint preservative
    0YD weight category rear axle weight range 4
    1VG installation parts for four-cylinder engine
    0JE weight category front axle weight range 5
    3Q1 rear headrests
    4UE airbag f. driver a. front seat passenger
    3B4 child seat anchor for child seat system ISOFIX
    F0A no special purpose vehicle, standard equipment
    K8B notchback
    6A0 without fire extinguisher
    5RQ outer right rear view mirror: convex
    0K0 without alternative drive module
    0RA without ignition/starter switch locking system
    5D1 carrier frequency 433.92 MHz
    3Y0 without roll-up sun screen
    8R1 center high-mounted stop light
    3J7 articulated and height-adjustable headrests for front seats
    6PA plastic hand brake lever handle
    1WC transmission shaft w/ 108mm in diameter
    0KA without stickers and badges
    9W0 w/o car phone preparation/installation
    8JM twin headlamp for left-hand drive with integrated high-beam headlight
    8K0 without special low beam mode
    3QT 3-point seat belts with tensioner and height adjustment, front
    8CC speedometer sensor without seal (electronic speedometer sensor)
    8Z5 engine cooling system, type 1
    3C3 lap belt with retractor for the center rear seat
    5SL outer left rear view mirror: non-spherical
    1X0 front wheel drive
    4GH windshield tinted with windshield sunshield
    1PA standard wheel bolts
    6Q1 plastic gearshift knob/handle
    1AC anti-lock brake system (ABS)
    0SB labels/plates in German
    0L2 electric throttle actuation
    8RM eight loudspeakers (passive)
    4W0 without cassette and CD storage unit
    9P0 without seat belt warning light
    9HA without additional malfunction display
    9A0 without taxi alarm system
    0DE installation differentiation for build status of vehicle class B5 (VW Passat)
    8KA w/o catalytic converter warning light
    N0U cut pile seat covering
    3CA without partition
    SW8 fleet business with Libya
    6XN outer rear view mirrors: powered, separately heated
    8S4 two reading lights front, two rear
    T5Z components for base engine, unit 058.B
    V0A tires w/o specification of tire brand
    6Y0 without cruise control warning system
    A8S standard equipment
    6QB locking rear seat catch
    0LA without special plates/stickers/ safety certificates
    4P1 rear floor panel module, type 2
    4A0 without seat heater
    9AB manually controlled air conditioning
    3S0 without roof rails/roof load rack
    8SA taillight assemblies, standard design
    8L3 roof antenna
    QG1 service interval prolongation
    2G1 insert for the filling up of unleaded fuel
    6R1 leatherette gearshift boot
    1BA standard suspension/shock absorption
    0TA without floor mats
    Нераспознанные коды
    WE1 PNE PH1 WC1 RCA
  4. #564
    расшифруйте пожалуйста и мой "VIN кот"
    wvwzzz3bzve063017
  5. #565
    Россия, Пенза
    шпасиба!
  6. #566
    Московская область
    расшифруйте пожалуйста и мой VIN (американец)
    WVWMA63B9XE368334
  7. #567
    Будьте добры расшифруйте пожалуйста wvwzzz3bzwp083516
    Спасибо.
  8. #568
    VIT@LYCH
    VIN Number WVWZZZ3BZVE063017;
    Sales type 3B23J5;
    Exterior color L7
    Roof color L7
    Interior trim code FC;
    Engine code & No. AEB 76997;
    Transmission code DHW;
    Date of production 14.02.1997;
    Model year 1997;
    Код Опция
    4X0 without side airbag
    3L1 manual height adjustment for left front seat
    7P0 without lumbar support in front and rear seats
    3LC foamed film and fabric door and side panel trim
    7A0 without CD changer/CD player
    Q1A standard front seats
    0FA standard manufacturing sequence
    1D0 without towing attachment
    1RT nameplate set "1.8 T"
    T8B components for base engine, unit 058.D
    0G1 gearshift lever
    6E0 without center armrest front
    7QA without CD ROM
    2B1 additional exterior noise suppression
    1LB disc brakes, front
    4ZE black moldings
    8GM alternator 70A
    7CA without label for radio remote control
    C02 operating permit, alteration 2
    B32 type approval Luxembourg
    4M0 without cup holder
    8AA without radio
    4U0 without luggage nets/pockets on backrests
    M9L 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, MVEG 2 base engine is T8B/T8C
    3Q1 rear headrests
    3B0 without additional child seat anchor
    K8B notchback
    5D0 without carrier frequency
    0YZ without determination of weight categoryfor rear axle
    0JZ without determination of weight categoryfor front axle
    4GF windshield, tinted
    8RE four loudspeakers (passive)
    6XD outer rear view mirrors: powered, heated
    N0P woven fabric seat covering
    1AH electronic differential lock (EDL)
    7V0 standard dashboard illumination
    9X0 without heated door lock cylinder
    9AA manually controlled heating system
    Нераспознанные коды
    WE1
    Добавлено спустя 2 минуты 11 секунд:
    sanka1
    VIN Number WVWZZZ3BZWP083516;
    Sales type 3B23E5;
    Exterior color N4
    Roof color N4
    Interior trim code JN;
    Engine code & No. ADR305803;
    Transmission code DHZ;
    Date of production 09.07.1997;
    Model year 1998;
    Код Опция
    0TD front and rear floor mats
    4AB partially leather door and side panel trim
    5MG decorative burr walnut inserts
    M51 4-cyl. gasoline engine 1.8 L/92 kW 20V with MVEG 2 base engine is T0V/T5Z
    0G1 gearshift lever
    B0J component parts set, complying with vehicle type for Italy, various parts
    8N1 windshield wiper intermittent control
    B14 type approval Italy (San Marino, Vatican City)
    7QA without CD ROM
    2PX leather trimmed sports steering wheel
    4ZE black moldings
    H6T tires 205/60 R 15 V
    8GD alternator 90A
    C6K alloy wheels 7J x 15 "Adelaide" offset 45 (five-hole)
    7CC label for radio remote control for
    C04 operating permit, alteration 4
    Q4H comfort sports seats, front
    8AA without radio
    4M6 cup holder
    1G3 alloy spare wheel with original equipment tires
    4U1 luggage nets/pockets on backrests
    3X1 load-through provision with ski bag
    3Q1 rear headrests
    K8B notchback
    N7K Alcantara/leather seat covering
    6PC leatherette hand brake lever handle
    6Q3 wooden gearshift knob/handle
    1PC wheel bolts with anti-theft protection (unlockable)
    0SK labels/plates in Italian
    0LK special plates/stickers/ safety certificates for Italy
    6R2 leather gearshift boot
    9AK Climatronic with impact pressure control free of cfc
    Нераспознанные коды
    WE1 WH1 PH2 PJ1
    Добавлено спустя 45 секунд:
    Serg, с американцем не помогу
  9. #569
    kucap Бальшой Спасиб
  10. #570
    Украина
    Буду признателен за оказании помощи в расшифровке VINа: WVWZZZ3BZWP288492
    Заранее благодарен!
  11. #571
    Беларусь
    Расшифруйте плз. VWVZZZ3BZXP268483
  12. #572
    M@X
    VIN Number WVWZZZ3BZWP288492;
    Sales type 3B23J9;
    Exterior color B4
    Roof color B4
    Interior trim code FD;
    Engine code & No. AEB170373;
    Transmission code CJQ;
    Date of production 10.01.1998;
    Model year 1998;
    Код Опция
    9Q0 without multi-function indicator/ on-board computer
    9Y0 without outdoor temperature gage
    G0F five-speed automatic transmission
    7AA electronic vehicle immobilization device
    4R2 power windows front, mechanical window regulators rear
    0G7 Tiptronic
    7B0 without socket
    7QA without CD ROM
    1T0 w/o first aid kit and warning triangle
    4ZE black moldings
    8GD alternator 90A
    9T1 heated washer nozzles, front
    J1L battery 280 A (60 Ah)
    1EY special identification plate with weight data, but without general operating permit (ROW)
    8WA without front fog light
    C07 operating permit, alteration 7
    8AD radio "gamma"
    4F1 central locking system
    9FB automatic transmission indicator light
    B47 type approval the Baltic States
    0YC weight category rear axle weight range 3
    3Q1 rear headrests
    0JH weight category front axle weight range 8
    K8B notchback
    8BG twin headlamp for left-hand drive with integrated high-beam headlight
    6R0 selector lever cover
    Нераспознанные коды
    PH2 RCF
    Добавлено спустя 3 минуты 48 секунд:
    1454MAK, первые буквы напутал
    VIN Number WVWZZZ3BZXP268483;
    Sales type 3B2355;
    Exterior color N7
    Roof color N7
    Engine code & No. AFN722216;
    Transmission code EEN;
    Date of production 04.12.1998;
    Model year 1999;
    Код Опция
    8T1 cruise control system (CCS)
    0NA without nameplate set (without model designation)
    0G1 gearshift lever
    M6N 4-cyl. turbo diesel eng. 1.9 L/81 kW TDIwith MVEG 2 base engine is T1R
    7QA without CD ROM
    1E0 without activated charcoal canister
    T1R components for base engine, unit 028.R
    J0R battery 380 A (80 Ah)
    4ZE black moldings
    8GL alternator 120A
    ST6 engine with new build status
    C09 operating permit, alteration 9
    4M6 cup holder
    8AD radio "gamma"
    SU9 tractor head with ABS for Al-KO company
    7E3 sheathed type glow plug heater
    0JG weight category front axle weight range 7
    3Q1 rear headrests
    K8B notchback
    1WD transmission shaft for tripod joints
    9W8 car phone preparation
    2G0 without insert for the filling up of fuel
    Нераспознанные коды
    WE1 PT2 PH2 WC1 RCA
  13. #573
    Украина
    [quote="kucap"]M@X
    Сенкъю вери мач!
  14. #574
    kucap Большое спасибо!
  15. #575
    Passat Аватар для SNeg
    Мск (ЮЗАО) - Члб (СЗ)
    Получено: 32
    Отправлено: 136
    расшифруйте плиз!
    WVWZZZ3BZXP394473
  16. #576
    SNeg, лезь сюда
    http://www.vw-club.ru/vw/vin/
    там все поймешь, удачи
  17. #577
    Россия, Череповец
    Расшифруйте VIN,плиз! Audi A4
    WAUZZZ8EX2A136843
  18. #578
    Цитата Сообщение от Mad_Maxx
    SNeg, лезь сюда
    MadHeaD, нажми туда
  19. #579
    Россия, Череповец
    Mad_Maxx Мне нужна полная расшифровка!
  20. #580
    SNeg
    VIN Number WVWZZZ3BZXP394473;
    Sales type 3B2358;
    Exterior color X1
    Roof color X1
    Interior trim code JJ;
    Engine code & No. AFN847431;
    Transmission code DMX;
    Date of production 05.02.1999;
    Model year 1999;
    Код Опция
    9Q2 multi-function indicator/on-board computer with check control
    7A2 CD changer
    G0E four-speed automatic transmission
    0G2 selector lever
    7Q2 navigation system with color screen
    3FE electric slide/tilt sunroof with sun screen/sunblind
    7QB CD ROM (Germany)
    4ZE black moldings
    H6U tires 205/55 R 16 91W
    8GD alternator 90A
    ST7 model year change, calendar week 02
    1MN wood sports steering wheel
    8X1 headlight washer system
    4M6 cup holder
    C0J alloy wheels 7J x 16 "Montreal" offset 45
    C10 operating permit, alteration 10
    8AY radio/navigation system
    5K1 paint preservative (wax)
    3Q1 rear headrests
    K8B notchback
    3Y1 roll-up sun screen for rear window
    4A3 seat heater for front seats separately controlled
    Нераспознанные коды
    WE1 PT2 WHB RHA PNW PH2 PJ2
    Добавлено спустя 1 минуту 28 секунд:
    MadHeaD
    VIN Number WAUZZZ8EX2A136843;
    Sales type 8E2015;
    Exterior color A2
    Roof color A2
    Interior trim code LA;
    Engine code & No. AVJ 23587;
    Transmission code FPT;
    Date of production 19.10.2001;
    Model year 2002;
    Код Опция
    4X3 side airbag front with curtain airbag
    9Q3 multi-function indicator, without on-board computer and check control
    FQ0 standard production wheels
    3L5 electric seat adjustment for both front seats
    1BR comfort rough-road suspension
    1YE transmission shafts for rear axle diameter 70,7
    1C2 antifreeze up to -35 degree celsius tolerance up to -40 degree C
    0F2 fuel system for carburetor gasoline engine
    QH0 without voice control
    7P1 power adjustable lumbar support in frontseats
    G0G five-speed manual transmission for four-wheel drive vehicle
    1Z5 increase in initial standard fuel filling
    FC0 without customized installation
    T0L components for base engine, unit 06B.G
    1KD disc brakes, rear
    0G1 gearshift lever
    7AL anti-theft alarm system, passenger compartment control, backup horn and towing protection
    4R4 power windows with comfort operation andcircuit breaker
    8UD radio "concert"
    7B0 without socket
    6SS luggage compartment floor covering
    1SB additional engine guard
    4K4 radio remote controlled central locking operated from inside and separate trunk release
    QQ1 additional lights (interior lighting)
    7QA without CD ROM
    J0L battery 340 A (70 Ah)
    6M0 without tie down straps/net/pocket
    1T3 first aid kit and warning triangle
    0W1 label for central electric German-speaking countries
    0VU information kit in Russian
    0GV emissions concept EU 2 (critical vapor pressure)
    4ZE black moldings
    4KC side and rear windows tinted
    VR0 without impact protection measures
    VC0 w/o remote-controlled garage door opener
    3ND rear seat bench/backrest, unfolding
    8GL alternator 120A
    6FB body-colored outer rear view mirror housings
    C00 operating permit, initial registration
    2Z1 type sign at rear and "Quattro" nameplates respectively
    FM0 basic equipment variant
    2K1 reinforced bumpers
    6V1 rear trim panel (ECE)
    1MR leather steering wheel
    1N1 power steering
    B37 type approval CIS (without the Baltic States, Ukraine and White Russia)
    NT1 transit coating (type 2)
    MW8 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo base engine is T0L/T16/T6V/T63
    8Q3 automatic headlight-range adjustment dynamic (self-adjusting while driving)
    U1A instrument insert with km/h speedometer,clock, tachometer and trip odometer
    6W5 front license plate bracket
    4N0 standard dashboard
    5K5 transit protective film (instead of paint preservative)
    3Q1 rear headrests
    QE0 without tray areas package/box
    2T0 without double-sized standard (DIN)
    0JJ weight category front axle weight range 9
    0YL weight category rear axle weight range 23
    7M0 plastic scuff plates in door apertures
    1W0 without refrigerator/glove compartment cooling system
    A00 no self-collection
    K8B notchback
    5RU outer right rear view mirror: convex (large viewing field)
    9VD speaker (active)
    9NX without electronic logbook
    C1W forged alloy wheels 7J x 15 type 1, offset 39
    8JG headlight with gas discharge lamp for driving on the right
    1WG transmission shaft w/ 88mm in diameter
    0CS vehicle class differentiation 8E0
    3C1 static lap belt, center rear
    1X1 four wheel drive
    6Q2 leather gearshift knob/handle
    FA0 control of standard production
    0SN labels/plates in Russian
    4P2 rear floor panel module, type 3
    QV0 w/o TV reception/digital radio reception
    2V1 dust and pollen filter
    N1H leather seat covering
    1QD special plates/stickers/ safety certificates for CIS
    Нераспознанные коды
    PLD P15 PX1
Страница 29 из 698 ПерваяПервая ... 1927282930313979129529 ... ПоследняяПоследняя
  1. Расшифруйте пожайлуста VIN
    от никола777 в разделе Архив 2009г.
    Последнее сообщение: 28.05.2009, 21:54
  2. Расшифруйте пожалуйста VIN
    Последнее сообщение: 15.01.2007, 23:32
  3. Расшифруйте пожалуйста VIN WVWZZZ3BZWE181630
    от Клаусщ в разделе Архив 2007г.
    Последнее сообщение: 09.01.2007, 08:43
  4. Расшифруйте пожалуйста VIN
    от Алексей19 в разделе Архив 2006г.
    Последнее сообщение: 08.04.2006, 19:39
  5. Расшифруйте плз. VIN
    от andy77 в разделе Архив 2006г.
    Последнее сообщение: 27.01.2006, 12:34
