1. #461
    Съебёж, Эта Страна
    Получено: 10
    Spook
    VIN Number WVWZZZ3BZ1P214152;
    Sales type 3B33J1;
    Exterior color 8E
    Roof color 8E
    Interior trim code JJ;
    Engine code & No. AWT 40855;
    Transmission code EHV;
    Date of production 07.03.2001;
    Model year 2001;
    PR number:
    Код Опция
    4X0 without side airbag
    0TD front and rear floor mats
    5MD decorative aluminum inserts
    9Q1 multi-function indicator/trip computer
    8T0 without cruise control system (CCS)
    T6V components for base engine, unit 06B.A
    8E2 local interference suppression for FM/AMradio reception
    3L3 manual height adjustment for front seats
    1YA without transmission shafts f. rear axle
    1C2 antifreeze up to -35 degree celsius tolerance up to -40 degree C
    4Q0 no flame retardent materials
    9J0 without supertone system and tone sequence control
    9Y1 outdoor temperature gage
    L0L left-hand drive vehicle
    C4A cast alloy wheels 7J x 15 offset 37 (3B0 601 025 K)
    8TC rear fog light for driving on the right
    7A0 without CD changer/CD player
    G0C 5-speed manual transmission
    7P4 manually adjustable lumbar support in front seats
    4B9 body-colored protective side molding with trim stripe
    1Z2 increase in initial standard fuel filling
    3LJ foamed film door and side panel trim inserts in leatherette
    0FG Mosel manufacturing sequence
    VX0 without hands-free system
    7X0 without park distance control
    8F2 side turn signal lights
    2WA without additional tires
    QA0 without child seat
    B0A component parts set without country-specific design requirement
    7AB electronic alarm system with vehicle immobilization device (for RoW)
    1ZC disc brakes, front (Geomet D)
    1D0 without towing attachment
    1RT nameplate set "1.8 T"
    6SD tufted trunk floor covering (dimensionally stable)
    1KD disc brakes, rear
    0G1 gearshift lever
    4R3 power windows with comfort operation
    7Q0 without navigation device
    8N4 windshield wiper intermittent control with potentiometer (four speeds)
    7B3 12-volt socket(s)
    1SB additional engine guard
    6E3 center armrest front
    9D0 without preparation for two-way radio installation
    4K3 radio remote controlled central locking operated from inside and safe securing
    3MQ Ibolours floor covering
    8NA without parking light warning light
    3FA without roof insert (standard roof)
    7QA without CD ROM
    1T0 w/o first aid kit and warning triangle
    2B2 additional exterior noise suppression
    1E1 activated carbon canister
    2PX leather trimmed sports steering wheel
    E0A no special edition
    4ZB bright moldings
    0GV emissions concept EU 2 (critical vapor pressure)
    4KC side and rear windows tinted
    QJ0 without aluminum/chrome work package
    H6T tires 205/60 R 15 V
    VC0 w/o remote-controlled garage door opener
    8GD alternator 90A
    6U0 without additional seals outside
    6EP additional body covers, stone guard
    9T1 heated washer nozzles, front
    4L2 dipping breakaway inside rear view mirror
    4SD left vanity mirror illuminated
    7K0 without tire pressure warning light
    J1L battery 280 A (60 Ah)
    3NZ rear seat bench unsplit, backrest split folding
    3GK without additional filler for plane trunk floor
    9M0 without auxiliary/parking heater
    4LA without controls
    1EY special identification plate with weight data, but without general operating permit (ROW)
    2JN comfort bumpers with chrome-plated strip
    C02 operating permit, alteration 2
    8WD integrated front fog light
    1N1 power steering
    B37 type approval CIS (without the Baltic States, Ukraine and White Russia)
    U0C instrument insert with tachometer clock and km/h speedometer
    Q4H comfort sports seats, front
    9F0 without sound combination for rotating emergency light and radio antenna preparation
    8X0 without headlight washer system
    4TD right vanity mirror illuminated
    8AA without radio
    MW8 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo base engine is T0L/T16/T6V/T63
    1V0 without duty-free and cost-free tires
    0Y1 standard climatic zones
    1G2 steel spare wheel with original equipment tires
    5C0 without special body measures
    9FA without automatic transmission indicator light
    3X0 without load-through provision
    8Q1 headlight-range adjustment
    4U5 luggage pockets on backrest
    7E0 w/o heat accumulator/auxiliary heating
    6W1 license plate bracket front (large)
    5K0 without paint preservative
    0YD weight category rear axle weight range 4
    1VG installation parts for four-cylinder engine
    3Q1 rear headrests
    4UE airbag f. driver a. front seat passenger
    0JH weight category front axle weight range 8
    3B4 child seat anchor for child seat system ISOFIX
    F0A no special purpose vehicle, standard equipment
    8BG twin headlamp for left-hand drive with integrated high-beam headlight
    K8B notchback
    6A0 without fire extinguisher
    5RQ outer right rear view mirror: convex
    0K0 without alternative drive module
    5D1 carrier frequency 433.92 MHz
    3Y0 without roll-up sun screen
    8R1 center high-mounted stop light
    N7K Alcantara/leather seat covering
    3J7 articulated and height-adjustable headrests for front seats
    1WC transmission shaft w/ 108mm in diameter
    6PC leatherette hand brake lever handle
    0KA without stickers and badges
    9W0 w/o car phone preparation/installation
    8K0 without special low beam mode
    3QT 3-point seat belts with tensioner and height adjustment, front
    8Z5 engine cooling system, type 1
    8RE four loudspeakers (passive)
    3C3 lap belt with retractor for the center rear seat
    5SL outer left rear view mirror: non-spherical
    1X0 front wheel drive
    4GH windshield tinted with windshield sunshield
    6Q2 leather gearshift knob/handle
    1PC wheel bolts with anti-theft protection (unlockable)
    0L2 electric throttle actuation
    4W0 without cassette and CD storage unit
    9P0 without seat belt warning light
    9HA without additional malfunction display
    9A0 without taxi alarm system
    1AH electronic differential lock (EDL)
    0DE installation differentiation for build status of vehicle class B5 (VW Passat)
    8KA w/o catalytic converter warning light
    3CA without partition
    6XN outer rear view mirrors: powered, separately heated
    8S4 two reading lights front, two rear
    V0A tires w/o specification of tire brand
    6Y0 without cruise control warning system
    1Q0 without mass damper for steering wheel
    0SN labels/plates in Russian
    A8S standard equipment
    4P1 rear floor panel module, type 2
    3S0 without roof rails/roof load rack
    8SA taillight assemblies, standard design
    QV0 w/o TV reception/digital radio reception
    4A3 seat heater for front seats separately controlled
    8L3 roof antenna
    QG2 no possibility of activating service interval prolongation
    2G1 insert for the filling up of unleaded fuel
    6R2 leather gearshift boot
    1BB suspension/shock absorption for rough road design
    9AK Climatronic with impact pressure control free of cfc
    1QD special plates/stickers/ safety certificates for CIS
    Нераспознанные коды
    WE1 PH2 PJ1
    Добавлено спустя 7 минут 47 секунд:
    PH2 Air con, “Climatronic”, free of cfc
    WE1 Technical equipment package radio remote control, alarm system, socket, rear, multifunction display
    PJ1 Four alloy wheels 7J x 16 “Montreal” tires 205/55 R 16, wheel locks
    04/AWT/GFY
  2. #462
    Lupo Аватар для Graffer
    Украина, Харьков
    Спасибо!
    Passat B5 1,8T AWT 5МКП 2001
  3. #463
    Россия, Железнодорожный (Моск. обл)
    Расшифруйте, пожалуйста VIN WVWZZZ3BZVE003689 заранее благодарен.
  4. #464
    Съебёж, Эта Страна
    Получено: 10
    Alex-Osl
    VIN Number WVWZZZ3BZVE003689;
    Sales type 3B23J5;
    Exterior color N4
    Roof color N4
    Interior trim code GS;
    Engine code & No. AEB 50807;
    Transmission code DHW;
    Date of production 04.12.1996;
    Model year 1997;
    PR number:
    Код Опция
    5MA decorative inserts
    9Q0 without multi-function indicator/ on-board computer
    4X1 side airbag front
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    9Y0 without outdoor temperature gage
    4B1 protective side molding
    3LD door and side panel trim
    1Z0 initial standard fuel filling
    Q1A standard front seats
    B01 type approval Germany
    0FA standard manufacturing sequence
    7AA electronic vehicle immobilization device
    0G1 gearshift lever
    T8B components for base engine, unit 058.D
    7B0 without socket
    1SA without additional engine guard
    H5Z tires 195/65 R 15 V (ultra-light)
    2PQ steering wheel for airbag system
    7QA without CD ROM
    2B1 additional exterior noise suppression
    6EA without additional side body covers (stone guard)
    1LB disc brakes, front
    1T2 warning triangle
    4ZE black moldings
    8GD alternator 90A
    9T0 without heated washer nozzles
    7CA without label for radio remote control
    2JB standard bumpers
    J1P battery 220 A (44 Ah)
    4E0 tailgate/trunk lid unlocking from outside
    1EX special identification plate for EC
    C00 operating permit, initial registration
    4M6 cup holder
    8AD radio "gamma"
    1G3 alloy spare wheel with original equipment tires
    4U1 luggage nets/pockets on backrests
    4F1 central locking system
    3X1 load-through provision with ski bag
    M9L 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, MVEG 2 base engine is T8B/T8C
    5K1 paint preservative (wax)
    C1A alloy wheels 6J x 15
    3Q1 rear headrests
    3B0 without additional child seat anchor
    K8B notchback
    0RA without ignition/starter switch locking system
    5D0 without carrier frequency
    0YZ without determination of weight categoryfor rear axle
    0JZ without determination of weight categoryfor front axle
    6PA plastic hand brake lever handle
    8JM twin headlamp for left-hand drive with integrated high-beam headlight
    4GF windshield, tinted
    8CC speedometer sensor without seal (electronic speedometer sensor)
    6Q1 plastic gearshift knob/handle
    6XD outer rear view mirrors: powered, heated
    0SB labels/plates in German
    8RM eight loudspeakers (passive)
    4W1 cassette storage unit
    N0U cut pile seat covering
    7V0 standard dashboard illumination
    6QB locking rear seat catch
    0LA without special plates/stickers/ safety certificates
    9X0 without heated door lock cylinder
    4A0 without seat heater
    6R1 leatherette gearshift boot
    1BA standard suspension/shock absorption
    0TA without floor mats
    WC1 "Comfortline" equipment package
    04/AWT/GFY
  5. #465
    и мой, если не трудно - wvwzzz3bzxe169311
  6. #466
    Съебёж, Эта Страна
    Получено: 10
    КвиСац XadEr@x
    VIN Number WVWZZZ3BZXE169311;
    Sales type 3B23H5;
    Exterior color L7
    Roof color L7
    Engine code & No. AFY 4855;
    Transmission code DWB;
    Date of production 28.08.1998;
    Model year 1999;
    PR number:
    Код Опция
    0G1 gearshift lever
    7B0 without socket
    Q2J comfort front seats
    7QA without CD ROM
    4ZE black moldings
    H6S tires 195/65 R 15 V
    8GD alternator 90A
    1LZ front disc brakes, standard ventilation
    8WA without front fog light
    0PG nameplate set "1.8"
    C08 operating permit, alteration 8
    4M6 cup holder
    M8Z 4-cylinder injection engine 1.8 L/88 kW ECE base engine is T5Z
    8AQ radio "beta" with removable operating panel
    C0V steel wheels 6J x 15 offset 45 (five-hole)
    0YC weight category rear axle weight range 3
    0JF weight category front axle weight range 6
    3Q1 rear headrests
    K8B notchback
    1PA standard wheel bolts
    1AC anti-lock brake system (ABS)
    0L0 mechanical throttle actuation
    S8Q free
    T5Z components for base engine, unit 058.B
    9AB manually controlled air conditioning
    2G0 without insert for the filling up of fuel
    WW1 winter package heated front seats heated washer nozzles, front
    Нераспознанные кодыPH1 RBH
    04/AWT/GFY
  7. #467
    вт бы еще узнать что это все означает....
  8. #468
    Съебёж, Эта Страна
    Получено: 10
    Нуу, раз английского не знаешь, то совет один - словарь в зубы и вперед
    04/AWT/GFY
  9. #469
    Россия, Воронеж
    Оставил задаток за Passat Variant 4Motion 2L, 85kw, HIGHL.
    Очень хотелось бы подробнее знать комплектацию
    Пожалуйста, помогите раскодировать VIN -
    WVWZZZ3BZ2E328637
  11. #471
    Получено: 2,315
    Отправлено: 1,372
    WVWZZZ3BZ2E328637
    Батист
    VIN Number WVWZZZ3BZ2E328637;
    Sales type 3B63D7;
    Exterior color 8E
    Roof color 8E
    Engine code & No. AZM 21780;
    Transmission code ENC;
    Date of production 08.01.2002;
    Model year 2002;
    Расшифровка кодов комплектации
    Код Опция
    0LW special plates/stickers/ safety certificates for Germany
    1YC transmission shafts for rear axle diameter 100
    FB3 surface, interior trim, soft-touch paint
    G0G five-speed manual transmission for four-wheel drive vehicle
    9JB smoking version, ashtray front and rear
    T10 components for base engine, unit 06B.J
    0G1 gearshift lever
    6SL tufted trunk floor covering (cut pile)
    C5E steel wheels 6J x 15 offset 37
    0VA without information kit
    4Z2 lockable glove compartment door
    0GG emissions concept EU 4
    7QA without CD ROM
    1DM nameplate set "2.0 4MOTION"
    4ZB bright moldings
    S4V change in design K 384: introduction in block 2
    8GD alternator 90A
    3NW rear seat bench/backrest, split folding with center armrest
    C05 operating permit, alteration 5
    1N1 power steering
    4M6 cup holder
    8AC radio "beta"
    1NC full wheel covers
    0JG weight category front axle weight range 7
    3Q1 rear headrests
    K8D Station Wagon Variant/Avant
    0YS weight category rear axle weight range 16
    1WB transmission shaft w/ 100mm in diameter
    7N0 without tray on roof liner
    1X1 four wheel drive
    1AT electronic stabilization program (ESP)
    3S2 black roof rails
    8L3 roof antenna
    QG1 service interval prolongation
    MK6 4-cylinder gasoline engine 2.0 L/85 kW base engine is T04/T10/T11/T51
    3CX net partition
    Нераспознанные коды
    RBA
  12. #472
    Россия, Воронеж
    Очень большое спасибо! Узнал много интересного, и положительного и нет. Есть вопросы, в частности, 8WA без передней противотуманной фары? Что фары нет я вижу. И в блок-фаре не интегрирована? И второй вопрос -комплектация с ЕСР, но есть ли при этом противопробуксовочная система, (блокировка дифференциала), и как это работает на 4MOTION ? Возможно вопросы глупые, но я в этом деле новичок, пересаживаюсь с ТАЗа. Кто зает, расскажите пожалуйста, или дайте ссылку.
    По авто решение принято, авто оформлено, через неделю доставят из Германии.
    Еще раз спасибо.
  13. #473
    Люди добрые, памажите кто может: номер WVWZZZ3BZXE415250.
    _____________________
    Просто В-5 1998 1,6/AHL
    VW В-5 1998 1,6/AHL был
    Хонда СРВ 2014 есть
  14. #474
    Привет
    Помогите расшифровать ,мой номер:WVWZZZ7MZWV058312
  15. #475
    Съебёж, Эта Страна
    Получено: 10
    Bomj
    VIN Number WVWZZZ3BZXE415250;
    Sales type 3B53C5;
    Exterior color G2
    Roof color G2
    Interior trim code FC;
    Engine code & No. AHL356666;
    Transmission code DWG;
    Date of production 09.03.1999;
    Model year 1999;
    PR number:
    Код Опция
    T6U components for base engine, unit 06B.1
    3L1 manual height adjustment for left front seat
    M4T 4-cylinder gasoline engine 1.6 L/74 kW w/ multi-point injection a. MVEG 2/EU 3Dbase engine is T6U
    7P0 without lumbar support in front and rear seats
    3LC foamed film and fabric door and side panel trim
    1D2 removable and lockable towing attachment
    0NB nameplate set in base trim
    0G1 gearshift lever
    4R2 power windows front, mechanical window regulators rear
    7B2 12-volt socket in luggage boot
    6E0 without center armrest front
    7QA without CD ROM
    3FE electric slide/tilt sunroof with sun screen/sunblind
    2B0 without additional exterior noise suppression
    4ZE black moldings
    8GM alternator 70A
    ST7 model year change, calendar week 02
    4M0 without cup holder
    8AA without radio
    4U0 without luggage nets/pockets on backrests
    C10 operating permit, alteration 10
    SU9 tractor head with ABS for Al-KO company
    0JC weight category front axle weight range 3
    0YE weight category rear axle weight range 5
    3Q1 rear headrests
    8RA without speakers
    N0P woven fabric seat covering
    6QA rear seat catch
    9AA manually controlled heating system
    3CX net partition
    Добавлено спустя 3 минуты 17 секунд:
    RA999
    VIN Number WVWZZZ7MZWV058312;
    Sales type 7M8988;
    Exterior color J8
    Roof color J8
    Interior trim code WA;
    Engine code & No. AFN561080;
    Transmission code DNP;
    Date of production 08.04.1998;
    Model year 1998;
    PR number:
    Код Опция
    1N1 power steering
    U0E instrument insert with tachometer trip-odometer, km/h speedometer
    9ME comfort interior lighting
    3HB leather parts scope
    3A1 swiveling front seats
    4AP door and side panel trim
    9BC display and warning tone f. opened doors
    4B2 body-colored protective side molding
    8M1 rear window wiper and washer system with intermittent control
    VA0 without bolster/pillow
    G0E four-speed automatic transmission
    3AF outer right rear view mirror: convex, powered, heated
    8AY radio/navigation system
    8Y1 two-tone horn
    3Q1 rear headrests
    Q9G comfort front seats, lumbar support adjustment, left
    8BB halogen headlight for left-hand drive
    3U0 without luggage compartment cover
    N3C fabric seat covering
    0Z0 VW marque-specific/class-specific features
    8FA without second battery
    8N2 windshield wiper intermittent control infinitely variable
    5KB 4 rear seats (with armrests)
    7Q2 navigation system with color screen
    3MG tufted fine cut pile floor covering
    H2C tires 215/55 R 16 95H reinforced
    7U3 starter 1.8kW
    K8P MPV
    M6N 4-cyl. turbo diesel eng. 1.9 L/81 kW TDIwith MVEG 2 base engine is T1R
    4K1 radio remote controlled central locking
    9W2 car phone preparation
    1LD disc brakes, front
    3BS outer left rear view mirror: non-spherical, powered, heated
    2XM winter tires 195/65 R 15 95T with steel wheel 6J x 15, offset 55 (C0H) andcover for wheel hubs/wheel bolts
    1PB lockable wheel bolts
    1AE electronic differential lock (EDL/ABS)
    9WA without audio remote control
    8GL alternator 120A
    4GX tinted windshield, heated
    8RX passive speakers
    J1G battery 450 A (92 Ah)
    A8T executive equipment
    0DQ installation differentiation for build status of vehicle class B (MPV) unit components
    V0H DUNLOP tires
    4KX side and rear windows tinted green hinged quarter window operated manually
    C3A alloy wheels 7J x 16
    6FB body-colored outer rear view mirror housings
    9AE Climatronic front (free of cfc) and 2nd heater in passenger compartment
    2JG body-colored bumpers
    2V1 dust and pollen filter
    5XC sun visors with illuminated vanity mirror on driver's and front seat passenger's side
    1MH leather steering wheel
    9M5 auxiliary heater
    Нераспознанные коды
    RHA WWB
    04/AWT/GFY
  16. #476
    Россия, Уфа
    По умолчанию Тоже заинтересовался, особенно после истории с Driver ((
    WVWMA63B2XE509180
    И видел где-то про плагин под Word для расшифровки. Где его взять?
  17. #477
    Спасибо))
    Добавлено спустя 12 минут 21 секунду:
    Я перевел с помощью электронного переводчика ,но ничего не понял, если кто может расшифровать:
    RA999
    Sales type 7M8988;
    Exterior color J8
    Roof color J8
    Model year 1998;
    PR number:
    Код Опция
    1N1 power steering
    8Y1 two-tone horn
    3Q1 rear headrests
    7U3 starter 1.8kW
    K8P MPV
    8GL alternator 120A
    V0H DUNLOP tires
    Нераспознанные коды
    RHA WWB
    Заранее Спасибо)))
  18. #478
    Премного благодарен.
    Хонда СРВ 2014 есть
  19. #479
    WVWZZZ7MZYV016174
    Хочется выяснить какие у меня ремни безопасности, с преднатяжителями или без.
    Спасибо
  20. #480
    Краснодарский край
    Привет мужики!!!
    Не сочтите за труд - расшифруйте и мой VIN!!!
    WVWZZZ3BZWD050092
    Спасибо!!!
Страница 24 из 698 ПерваяПервая ... 1422232425263474124524 ... ПоследняяПоследняя
  1. Расшифруйте пожайлуста VIN
    от никола777 в разделе Архив 2009г.
    Последнее сообщение: 28.05.2009, 21:54
  2. Расшифруйте пожалуйста VIN
    Последнее сообщение: 15.01.2007, 23:32
  3. Расшифруйте пожалуйста VIN WVWZZZ3BZWE181630
    от Клаусщ в разделе Архив 2007г.
    Последнее сообщение: 09.01.2007, 08:43
  4. Расшифруйте пожалуйста VIN
    от Алексей19 в разделе Архив 2006г.
    Последнее сообщение: 08.04.2006, 19:39
  5. Расшифруйте плз. VIN
    от andy77 в разделе Архив 2006г.
    Последнее сообщение: 27.01.2006, 12:34
