1. #401
    Lupo Аватар для Graffer
    Украина, Харьков
    Axl
    Плиз, помогите с VIN кодом!!!
    Passat B5 1,8T AWT 5МКП 2001
  2. #402
    Получено: 2,310
    Отправлено: 1,372
    Цитата Сообщение от Spook
    Всем превед! Помогите расшифровать VIN американца!
    Spook
    C Американцем не поможем... [-X
    Не бьются они стандартными методами...
    Жди Wert!
  3. #403
    расшифруйте плиз тоже
    wvwzzz3bz1p278754
    спасибо.
  4. #404
    Россия, Ухта
    и мне расшифруйте, может что нового узнаю WVWZZZ3BZVE089523
  5. #405
    Якупов Рамиль
    VIN Number WVWZZZ3BZ1P278754;
    Sales type 3B31J1;
    Exterior color 3P
    Roof color 3P
    Interior trim code GA;
    Engine code & No. AWT 45213;
    Transmission code EHV;
    Date of production 29.03.2001;
    Model year 2001;
    Расшифровка кодов комплектации
    Код Опция
    4X3 side airbag front with curtain airbag
    9Q2 multi-function indicator/on-board computer with check control
    T6V components for base engine, unit 06B.A
    8T1 cruise control system (CCS)
    5MG decorative burr walnut inserts
    8E2 local interference suppression for FM/AMradio reception
    3L3 manual height adjustment for front seats
    1YA without transmission shafts f. rear axle
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    4Q0 no flame retardent materials
    9J0 without supertone system and tone sequence control
    9Y1 outdoor temperature gage
    4B1 protective side molding
    L0L left-hand drive vehicle
    C4A cast alloy wheels 7J x 15 offset 37 (3B0 601 025 K)
    8TC rear fog light for driving on the right
    3LD door and side panel trim
    7A0 without CD changer/CD player
    1Z1 increase in initial standard fuel filling by 4 liters
    G0C 5-speed manual transmission
    7P4 manually adjustable lumbar support in front seats
    VX0 without hands-free system
    0FG Mosel manufacturing sequence
    7X0 without park distance control
    8F2 side turn signal lights
    2WA without additional tires
    B0A component parts set without country-specific design requirement
    1ZC disc brakes, front (Geomet D)
    1D0 without towing attachment
    1RT nameplate set "1.8 T"
    QA6 two integrated child seats
    6SD tufted trunk floor covering (dimensionally stable)
    1KD disc brakes, rear
    0G1 gearshift lever
    4R3 power windows with comfort operation
    7Q0 without navigation device
    8N3 windshield wiper intermittent control with rain sensor
    1SA without additional engine guard
    7B3 12-volt socket(s)
    6E3 center armrest front
    Q2J comfort front seats
    9D0 without preparation for two-way radio installation
    4K3 radio remote controlled central locking operated from inside and safe securing
    3MQ Ibolours floor covering
    8NA without parking light warning light
    3FA without roof insert (standard roof)
    7QA without CD ROM
    2B2 additional exterior noise suppression
    1T2 warning triangle
    1E1 activated carbon canister
    E0A no special edition
    4ZB bright moldings
    0GV emissions concept EU 2 (critical vapor pressure)
    4KC side and rear windows tinted
    QJ0 without aluminum/chrome work package
    H6T tires 205/60 R 15 V
    VC0 w/o remote-controlled garage door opener
    B20 type approval Turkey
    8GD alternator 90A
    6U0 without additional seals outside
    6EP additional body covers, stone guard
    9T0 without heated washer nozzles
    4SD left vanity mirror illuminated
    4L6 breakaway inside rear view mirror automatically dimming
    7K0 without tire pressure warning light
    2JB standard bumpers
    J1L battery 280 A (60 Ah)
    3NZ rear seat bench unsplit, backrest split folding
    3GK without additional filler for plane trunk floor
    9M0 without auxiliary/parking heater
    1EY special identification plate with weight data, but without general operating permit (ROW)
    C02 operating permit, alteration 2
    8WD integrated front fog light
    4LF radio and CCS controls
    1N1 power steering
    U0C instrument insert with tachometer clock and km/h speedometer
    9F0 without sound combination for rotating emergency light and radio antenna preparation
    8X0 without headlight washer system
    4TD right vanity mirror illuminated
    2ZB leather trimmed multi-function steering wheel
    MW8 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo base engine is T0L/T16/T6V/T63
    1V0 without duty-free and cost-free tires
    0Y1 standard climatic zones
    1G2 steel spare wheel with original equipment tires
    5C0 without special body measures
    9FA without automatic transmission indicator light
    3X0 without load-through provision
    8Q1 headlight-range adjustment
    4U5 luggage pockets on backrest
    8AR radio "gamma" with removable operating panel
    7E0 w/o heat accumulator/auxiliary heating
    6W1 license plate bracket front (large)
    5K1 paint preservative (wax)
    0YD weight category rear axle weight range 4
    1VG installation parts for four-cylinder engine
    3Q1 rear headrests
    4UE airbag f. driver a. front seat passenger
    0JH weight category front axle weight range 8
    9V7 electronic vehicle immobilization devicewith anti-theft alarm system and passenger compartment control
    3B4 child seat anchor for child seat system ISOFIX
    F0A no special purpose vehicle, standard equipment
    8BG twin headlamp for left-hand drive with integrated high-beam headlight
    K8B notchback
    6A0 without fire extinguisher
    5RQ outer right rear view mirror: convex
    0K0 without alternative drive module
    5D1 carrier frequency 433.92 MHz
    3Y0 without roll-up sun screen
    8R1 center high-mounted stop light
    3J7 articulated and height-adjustable headrests for front seats
    1WC transmission shaft w/ 108mm in diameter
    6PC leatherette hand brake lever handle
    0KA without stickers and badges
    9W0 w/o car phone preparation/installation
    8K0 without special low beam mode
    3QT 3-point seat belts with tensioner and height adjustment, front
    3C3 lap belt with retractor for the center rear seat
    5SL outer left rear view mirror: non-spherical
    8Z6 engine cooling system, type 2
    1X0 front wheel drive
    4GH windshield tinted with windshield sunshield
    6Q2 leather gearshift knob/handle
    1PC wheel bolts with anti-theft protection (unlockable)
    0SC labels/plates in English
    0L2 electric throttle actuation
    8RM eight loudspeakers (passive)
    4W0 without cassette and CD storage unit
    9P0 without seat belt warning light
    9HA without additional malfunction display
    9A0 without taxi alarm system
    0DE installation differentiation for build status of vehicle class B5 (VW Passat)
    8KA w/o catalytic converter warning light
    N0U cut pile seat covering
    3CA without partition
    6XN outer rear view mirrors: powered, separately heated
    8S4 two reading lights front, two rear
    V0A tires w/o specification of tire brand
    6Y0 without cruise control warning system
    1Q0 without mass damper for steering wheel
    A8S standard equipment
    0LA without special plates/stickers/ safety certificates
    1AT electronic stabilization program (ESP)
    4P1 rear floor panel module, type 2
    4A0 without seat heater
    3S0 without roof rails/roof load rack
    8SA taillight assemblies, standard design
    QV0 w/o TV reception/digital radio reception
    8L3 roof antenna
    QG2 no possibility of activating service interval prolongation
    2G1 insert for the filling up of unleaded fuel
    1BA standard suspension/shock absorption
    6R2 leather gearshift boot
    9AK Climatronic with impact pressure control free of cfc
    0TA without floor mats
    Нераспознанные коды
    WE5 PM2 P15 PH2 RCH PJ1
    Добавлено спустя 2 минуты 31 секунду:
    ZOC, у тебя машина старше моей на 1 день
    VIN Number WVWZZZ3BZVE089523;
    Sales type 3B23C5;
    Exterior color C3
    Roof color C3
    Interior trim code HX;
    Engine code & No. AHL 45012;
    Transmission code DCN;
    Date of production 03.04.1997;
    Model year 1997;
    Код Опция
    9Q0 without multi-function indicator/ on-board computer
    4X1 side airbag front
    5MD decorative aluminum inserts
    T6U components for base engine, unit 06B.1
    8T0 without cruise control system (CCS)
    M4T 4-cylinder gasoline engine 1.6 L/74 kW w/ multi-point injection a. MVEG 2/EU 3Dbase engine is T6U
    9Y0 without outdoor temperature gage
    3LC foamed film and fabric door and side panel trim
    1Z0 initial standard fuel filling
    B01 type approval Germany
    0FA standard manufacturing sequence
    7AA electronic vehicle immobilization device
    0NB nameplate set in base trim
    0G1 gearshift lever
    7B0 without socket
    7QA without CD ROM
    2B0 without additional exterior noise suppression
    2PX leather trimmed sports steering wheel
    4ZE black moldings
    8GD alternator 90A
    C6K alloy wheels 7J x 15 "Adelaide" offset 45 (five-hole)
    9T1 heated washer nozzles, front
    1LZ front disc brakes, standard ventilation
    7CA without label for radio remote control
    J1P battery 220 A (44 Ah)
    4E0 tailgate/trunk lid unlocking from outside
    1EX special identification plate for EC
    C03 operating permit, alteration 3
    Q4H comfort sports seats, front
    4M6 cup holder
    8AD radio "gamma"
    1G3 alloy spare wheel with original equipment tires
    4U1 luggage nets/pockets on backrests
    4F1 central locking system
    5K0 without paint preservative
    3Q1 rear headrests
    3B0 without additional child seat anchor
    K8B notchback
    0RA without ignition/starter switch locking system
    5D0 without carrier frequency
    0YZ without determination of weight categoryfor rear axle
    0JZ without determination of weight categoryfor front axle
    8JM twin headlamp for left-hand drive with integrated high-beam headlight
    4GF windshield, tinted
    8CC speedometer sensor without seal (electronic speedometer sensor)
    8Z5 engine cooling system, type 1
    6XD outer rear view mirrors: powered, heated
    1AC anti-lock brake system (ABS)
    0SB labels/plates in German
    N0N woven fabric seat covering
    7V0 standard dashboard illumination
    6QB locking rear seat catch
    9X0 without heated door lock cylinder
    9AB manually controlled air conditioning
    4A3 seat heater for front seats separately controlled
    Нераспознанные коды
    WT1 WW1 PH1 RCF PJ1
  6. #406
    Латвия
    Mozno mne toze uznatj info o moej mashine. WVWZZZ3BZYE241733
  7. #407
    Россия, Ногинск
    Begemot
    VIN Number WVWZZZ3BZYE241733;
    Sales type 3B5375;
    Exterior color K1
    Roof color K1
    Interior trim code GP;
    Engine code & No. AJM119735;
    Transmission code DUK;
    Date of production 10.12.1999;
    Model year 2000;
    PR number:
    Код Опция
    5MA decorative inserts
    0TD front and rear floor mats
    SB0 Sharan promotional measures
    1K1 mechanical clutch actuation
    7A3 CD player
    SJ0 identification of zero series vehicles
    QA0 without child seat
    0NA without nameplate set (without model designation)
    0G1 gearshift lever
    6SL tufted trunk floor covering (cut pile)
    8N4 windshield wiper intermittent control with potentiometer (four speeds)
    AC0 short frame forestructure
    7B0 without socket
    0GE emissions concept EU 3
    2PN audio leather steering wheel for airbag system
    7QA without CD ROM
    2B1 additional exterior noise suppression
    1E0 without activated charcoal canister
    J0R battery 380 A (80 Ah)
    4ZE black moldings
    H6S tires 195/65 R 15 V
    VC1 remote-controlled garage door opener
    8GL alternator 120A
    4L2 dipping breakaway inside rear view mirror
    3NW rear seat bench/backrest, split folding with center armrest
    4LA without controls
    1MY steering wheel for airbag system
    4M6 cup holder
    8AC radio "beta"
    C12 operating permit, alteration 12
    AF0 without stowage compartment
    C0V steel wheels 6J x 15 offset 45 (five-hole)
    7E3 sheathed type glow plug heater
    0YE weight category rear axle weight range 5
    3Q1 rear headrests
    CH6 steel wheels 7 1/2J x 17 offset 53
    2E0 base chassis
    T4N components for base engine, unit 038.A
    K8D Station Wagon Variant/Avant
    6PA plastic hand brake lever handle
    1WD transmission shaft for tripod joints
    9W8 car phone preparation
    8RE four loudspeakers (passive)
    1PA standard wheel bolts
    6Q1 plastic gearshift knob/handle
    M3L 4-cyl. turbo diesel engine 1.9 L/85 kW TDI with pump-jet injection system base engine is T4N/TD0
    6QA rear seat catch
    1B0 without spare wheel bracket
    SA0 model year change calendar week 45
    LN0 without engine carrier
    3S2 black roof rails
    8L3 roof antenna
    2G0 without insert for the filling up of fuel
    6R1 leatherette gearshift boot
    3CX net partition
    Нераспознанные коды
    000 733 AJM 2Q2 PT2 WW1 241 537 973 PNE DL0 JQA EPT PH2 RBA WC1 AG0 121 UPH LM3 999 Z3B RK8 ZYE WZZ
  8. #408
    Россия, Сосновый Бор (Лен. обл)
    Помогите с расшифровкой WIN и мне пожалуйста.wvwma63b2we301010
    Или дайте ссылку где это можно самому посмотреть.
  9. #409
    Лукьянов Алексей, с америкосами помочь не могу. Жди Wert!
  10. #410
    Гость
    WVWZZZ3BZYE464015
    Добавлено спустя 8 минут 13 секунд:
    Расшифруйте VIN пожайлуста WVWZZZ3BZYE464015
  11. #411
    Россия, Ногинск
    tarasbulba
    VIN Number WVWZZZ3BZYE464015;
    Sales type 3B5338;
    Exterior color 96
    Roof color 18
    Interior trim code FC;
    Engine code & No. AHU463432;
    Transmission code EPU;
    Date of production 18.07.2000;
    Model year 2000;
    PR number:
    Код Опция
    7P0 without lumbar support in front and rear seats
    Q1A standard front seats
    1RB nameplate set "CSX"
    G0E four-speed automatic transmission
    0G2 selector lever
    6SH rubber trunk floor covering
    T0T components for base engine, unit 028.M
    4R2 power windows front, mechanical window regulators rear
    1ZJ disc brakes, front (Geomet D)
    7B0 without socket
    6E0 without center armrest front
    0GD emissions concept EU 2 (MVEG 2)
    2PQ steering wheel for airbag system
    7QA without CD ROM
    E0F Stella Minus
    4ZE black moldings
    H6R tires 195/65 R 15 T
    8GD alternator 90A
    2QK nameplate set "TDI"
    8WA without front fog light
    M0T 4-cyl. turbo diesel engine 1.9 L/66 kW direct injection base engine is T0T
    CV0 alloy wheels 7J x 17 offset 38 (1C0 601 025 M)
    4M0 without cup holder
    8AC radio "beta"
    4U0 without luggage nets/pockets on backrests
    0QG nameplate set "20V"
    9FB automatic transmission indicator light
    C14 operating permit, alteration 14
    0JG weight category front axle weight range 7
    3Q1 rear headrests
    N0P woven fabric seat covering
    1Q1 mass damper for steering wheel, 26.5Hz
    6QA rear seat catch
    8L3 roof antenna
    QG1 service interval prolongation
    6R0 selector lever cover
    3CX net partition
    Нераспознанные коды
    TN0 AHU 072 000 AQA 015 EH6 533 464 AT0 DL0 618 PH1 RJ0 RBA AG0 A0D LM0 343 Z3B PPH RK8 ZYE WZZ TU0
  12. #412
    Съебёж, Эта Страна
    Получено: 10
    Слушай, да настрой ты ETKУ!
    Опять куча нераспознанных "кодов"...
    Там их 2 всего.
    04/AWT/GFY
  13. #413
    Россия, Ногинск
    Mex@n!K
    поправился:
    Sales type 3B5338;
    Exterior color 96
    Roof color 18
    Model year 2000;
    PR number:
    Код Опция
    0G2 selector lever
    7B0 without socket
    7QA without CD ROM
    4ZE black moldings
    8GD alternator 90A
    8AC radio "beta"
    3Q1 rear headrests
    6QA rear seat catch
    8L3 roof antenna
    3CX net partition
    Нераспознанные коды
    PH1 RBA
  14. #414
    Golf Аватар для Heinz Viktor
    Караганда до 95-того/Германия, Регенсбург
    Получено: 33
    Отправлено: 13
    Расшифруйте VIN пожалуйста !
    wvwzzz3bzwp286829 5
    VW Passat Limosine B5 AFN уехал в Румынию /Vw Passat Variant B5.5​ AVF
  15. #415
    Heinz Viktor
    VIN Number WVWZZZ3BZWP286829;
    Sales type 3B2358;
    Exterior color X1
    Roof color X1
    Engine code & No. AFN259545;
    Transmission code DMX;
    Date of production 07.01.1998;
    Model year 1998;
    Код Опция
    9Q1 multi-function indicator/trip computer
    2VP nameplate set "TDI" "I"
    7AB electronic alarm system with vehicle immobilization device (for RoW)
    0G2 selector lever
    7B2 12-volt socket in luggage boot
    M6N 4-cyl. turbo diesel eng. 1.9 L/81 kW TDIwith MVEG 2 base engine is T1R
    7QA without CD ROM
    1LB disc brakes, front
    T1R components for base engine, unit 028.R
    4ZE black moldings
    8GD alternator 90A
    C07 operating permit, alteration 7
    4M6 cup holder
    8AD radio "gamma"
    0YC weight category rear axle weight range 3
    3Q1 rear headrests
    K8B notchback
    Нераспознанные коды
    WT1 WE1 WW1 PH2 RCF
  16. #416
    Россия, Ухта
    kucap
    Огромное спасибо! Расшифруйте ещё плиз у знакомого B3 WVWZZZ31ZLE126474
  17. #417
    ZOC, с В3 сложнее там надо знать продажный код (SALE type)
  18. #418
    Данные по автомобилю
    Данные по автомобилю Марка: V VIN-номер: WVWMA63B2WE301010 Код страны: USA
    Модельный год: 1998 Описание: PASSAT Lim. GLS L4110 OBD5G Регион: 444
    Название модели: 3B24K5 Дата изготовления: 1998-01-17 Номер дилера: 08313
    Бук.обоз.дв.: AEB-0179060
    Дата поставки: 1998-03-06
    Бук.обоз.КП: DHW
    Цветовое исполнение Тип Код цвета Описание
    наружн. E2/E2 Nebio Blue Metallic/Nebio Blue Metallic
    внутр. GQ flannelgrey/platin-flannelgr./flannelgre
    Коды комплектаций Текущий номер № Происхождение Серия Описание
    1 0DE L AED Installation identification for build conditiuon - B5 vehicle class VW Passat
    2 0FA L FAD Production sequence standard
    3 0G1 L GES With manual gear selector
    4 0JG L GKV Weight class front axle range of weight 7
    5 0K0 L ASY Without alternative drive-system
    6 0KA L KAE Without Customer Specific Stickers and Emblems
    7 0LB L SIZ With Specific Signs/Labels/Security Certificate for USA
    8 0NB L SZU Insignia Set,Basic Version
    9 0RA L ZSS Without Steering Wheel Locking System
    10 0SC L SAU Specific sticker/plates in english
    11 0TD L ZFM Floor mats, front and rear
    12 0Y1 L KLZ Standard climate zone ( Passat: Steeringwith engine cooling system Pr. 8Z* )
    13 0YC L GKH Rear suspension weight category - weight range 3
    14 1AH L BRS With anti-block-system(ABS) and electr.differential-lock (EDS)
    15 1BA L DAE Suspension/shock absorber, standard
    16 1C2 L FRO Antifreeze-down to -35 degrees celsius tolerance upto -40 degrees celsius
    17 1D0 L AHV Without Towbar
    18 1E4 L AKB Activated Charcoal Filter ORVR and scavening divice for refuelling
    19 1EB L TYP Without Data Plate
    20 1G2 L RER Standard Spare Wheel,Steel
    21 1PA L ABR Wheel bolts, standard
    22 1SA L TWU Without Additional Drive Train Plates
    23 1T0 L VBK Without First-Aid Box, without Warning (Breakdown) Triangle
    24 1V0 L ZRE Tyres without Duty or Cost
    25 1VG L TWL Engine Mounting for 4 Cylinder Engine
    26 1X0 L ATA Front Wheel Drive Only
    27 1Z6 L KRM Increase in standard fuel filling quantity
    28 1ZC L BAV Scheibenbremsen vorn (Geomet D)
    29 2B2 L GRD With Noise Capsule,Version 2
    30 2G1 L EBB Insert for lead-free refueling
    31 2JC L STF With bumper comfort
    32 2PQ L LRA Comfort steering wheel for Airbag System
    33 2WA L ZBR Without additional tyres
    34 3B0 L ZKV Without child seat attatchment
    35 3C3 L SHM Windable Lap Belt Centre Raer
    36 3CA L TRW Without Luggage Net
    37 3FE E DEI electric glass sunroof
    38 3GK L LBH Without Additional Tyre Space, Luggage Compartment
    39 3J7 E KOV With headrestraints front,left and rightadjustable in height and inclination
    40 3L3 L SIE Left and right seats with mechanical height adjustment
    41 3LD L TSV Door and Side Trim
    42 3MQ L BOB Iboluors Floor Covering
    43 3NZ L HIS Rear Seat with Splitt Folding Backrest With Centre Armrest
    44 3Q1 L KOH With Head Restraints,Rear hight adjustable
    45 3S0 L DAR Without Roof Rails
    46 3X0 L DLS Without Ski-Bag
    47 3Y0 L SSR Without Sun Blind
    48 4A0 L SIH Without seat heating
    49 4B2 L SSL Side protective strip in body colour
    50 4E2 L SDH (electric) inner locking of rear boot/ tailgate
    51 4GH L WSS Combination glass windscreen, tinted with additional heat protection measures
    52 4K0 L TKV Central locking system,radio control with operating lever
    53 4L2 L IRS with dip-dim rear view mirror
    54 4M6 L BEH cup holder
    55 4Q1 L SES flame-resistant materials
    56 4R3 L FEH electrical window lifters with comfort operation
    57 4SD L MSL make-up-mirror,left,illuminated
    58 4TD L MSR make-up-mirror,right,illuminated
    59 4U1 L GNF with storage-net on seatback of left + right front seats
    60 4UB L AIB airbag with knee bar
    61 4W0 L KBO without cassette/cd box
    62 4X1 L SAB Side airbag front
    63 4ZJ L ZIE Zierleisten in Wagenfarbe
    64 5C1 L KSA with body reinforcements for special safety requirements
    65 5D2 L TRF With carrier frequency 315 MHz for radio control
    66 5K2 L LAC With paint preservation,ACRYL-material
    67 5MA L EIH padded dashboard
    68 5RR L ASR Right outer mirror,convex (US)
    69 5SH L ASL Left outer mirror,flat (US)
    70 6E3 L MAS centre armrest front, without back support
    71 6EP L ZKS Zus.Karosserieabdeckungen Steinschlag- schutz
    72 6PA L HBV handbrake grip,plastic,version 1
    73 6Q1 L SAG gear lever knob, standard
    74 6QB L VRH Catch rear seat,lockable
    75 6R1 L SHV gear shift lever trim in leatherette
    76 6SD L KBB needle loom (moulded) luggage boot floorcovering
    77 6U1 L ZTD with additional dust protection outer seal
    78 6W0 L KZV without licence plate carrier front
    79 6XD L ASE Exterior mirror, electrically adjustable/heated
    80 6Y0 L GWA without speed warning system
    81 7A1 L CDW Preparation for disc change
    82 7B2 L STD 12 Volt socket in luggage area
    83 7CA L AKF Without sticker radio control
    84 7E0 L WSA without accumulator/auxiliary heating
    85 7P4 L LOR Backbone matching in backrest for front seats, manuel adjustable
    86 7Q0 L NAV Without navigation system
    87 7QA L CDR Without CD-Rom
    88 7V0 L BEL Standard instrument lighting
    89 8CC L TWP Speed sensor without seal (electronic speed sensor)
    90 8E2 L ENT with vhf/short-distance interference suppression (radio interfer.supp.)
    91 8F1 L SLE with side marker lights
    92 8GD L GEN generator 90 A
    93 8JL L HSW Double headlights, LHD, white, (US-Version)
    94 8K4 L FLS Day driving headlights -- USA version --
    95 8KA L KUE without catalyst monitor
    96 8N4 L SWS Windscreen interval wiper with 4 position potentiometer.
    97 8NA L STK without parking light,warning lamp
    98 8Q0 L LWR without headlight range adjustment system
    99 8R1 L HBL with raised brake light
    100 8RM L LSE with 8 loudspeakers (passive)
    101 8S4 L LEL with 2 reading lights front and 2 additional reading lights rear
    102 8SB L SBR Rear combination lamp, dark tinted
    103 8T1 L GRA Cruise control system
    104 8TA L NEL Without rear fog lamp,LHD
    105 8WD L NES with intergrated front fog lights
    106 8X0 L SWR without headlamp washer system
    107 8YA P RAO US-Radio Premium
    108 8Z5 L MKU Engine cooling system version 1
    109 9A0 L TAA without taxi alarm system
    110 9AB L HKA air conditioning with mechanical control
    111 9D0 L VEF Without Preparation For Two-Way Radio Installation
    112 9F0 L VRT without installation provision for combibeacon/alarm signal device + antenna
    113 9FA L AKA Without automatic gear indicator
    114 9HA L FFA without fault display for onboard carb diagnosis system
    115 9J0 L STA without emergency horn (without preparation)
    116 9P1 L SGK with seatbelt warning lamp + without ignition interlock system
    117 9Q1 L MFA with multi-function display system
    118 9T0 L BWD with non-heated washer jets
    119 9V3 L EDW with anti-theft warning system for USA
    120 9W0 L VTV Without preparation/installation for car phone
    121 9X0 L BTS without heatable door lock cylinder
    122 9Y1 L ATE with exterior temperature indicator
    123 A8F I AUS Sport-equipment
    124 B0D L BLB Construction regulation, USA
    125 B55 E TPL Lawful necessary equipment States N.York
    126 C07 E COC Control general operat.permit addition 7
    127 C0V L RAD Steel wheel 6J x 15 ET 45 (5-hole)
    128 E0A L AAU No sales promotion version
    129 F0A L FZS No special vehicle,standard version
    130 G0C I GSP 5-speed manual gearbox
    131 H5B L REI All-Weather Tyres 195/65 R 15H
    132 J0L L BAT Battery 340A(70AH)
    133 K8B I KAR Saloon
    134 L0L L LEA Left-hand drive
    135 M98 I MOT 4-cyl.Otto engine ( Turbo ) 1,8 L/110 KWwith TLEV and Bosch-Motronic
    136 N0U L SIB Cloth-seat cover
    137 Q1A L VOS Normal seats front
    138 RGA G US-Radio "premium"
    139 T8B I GMO Components for Basic engine-Aggr.058.D
    140 U0F L INS Instrument cluster with MPH,digital clock,rev counter and trip recorder
    141 V0A L REL Tyres without determined tyre mark
    142 X9A G Landessetzung USA
  19. #419
    Везде
    WVWZZZ3BZVP048228
    Пробейте ОЧЕНЬ СРОЧНО!
    нету у меня пассата.
  20. #420
    Россия, Ногинск
    RussoTuristo, Руслан, легко:
    VIN Number WVWZZZ3BZVP048228;
    Sales type 3B23C5;
    Exterior color J8
    Roof color J8
    Interior trim code FD;
    Engine code & No. AHL 22650;
    Date of production 16.12.1996;
    Model year 1997;
    PR number:
    Код Опция
    3L1 manual height adjustment for left front seat
    0G1 gearshift lever
    7B0 without socket
    7QA without CD ROM
    2XB winter tires 195/65 R 15 91H with steel wheel 6J x 15, offset 45 (5-hole) without full wheel cover (C0V)
    4ZE black moldings
    8GD alternator 90A
    C01 operating permit, alteration 1
    8AC radio "beta"
    3Q1 rear headrests
    K8B notchback
    Нераспознанные коды
    WWA PH1 RBB
Страница 21 из 698 ПерваяПервая ... 1119202122233171121521 ... ПоследняяПоследняя
  1. Расшифруйте пожайлуста VIN
    от никола777 в разделе Архив 2009г.
    Последнее сообщение: 28.05.2009, 21:54
  2. Расшифруйте пожалуйста VIN
    Последнее сообщение: 15.01.2007, 23:32
  3. Расшифруйте пожалуйста VIN WVWZZZ3BZWE181630
    от Клаусщ в разделе Архив 2007г.
    Последнее сообщение: 09.01.2007, 08:43
  4. Расшифруйте пожалуйста VIN
    от Алексей19 в разделе Архив 2006г.
    Последнее сообщение: 08.04.2006, 19:39
  5. Расшифруйте плз. VIN
    от andy77 в разделе Архив 2006г.
    Последнее сообщение: 27.01.2006, 12:34
