1. #381
    Lupo Аватар для Graffer
    Украина, Харьков
    Всем привед и зеленой улицы! Приглянулся вот такой вот Пассат В5.
    Парни, пожалуйста, расшифруйте его VIN
    WVWZZZ3BZYP221146
    Пасиба .
    Passat B5 1,8T AWT 5МКП 2001
  2. #382
    Ребята а можете расшифровать вин америкоса WVWRH63B23P446632. Очень надо. Заранее огромное спасибо.
  3. #383
    Россия, Ногинск
    Spook
    VIN Number WVWZZZ3BZYP221146;
    Sales type 3B23J5;
    Exterior color 7D
    Roof color 7D
    Interior trim code GP;
    Engine code & No. APU 52563;
    Transmission code EHV;
    Date of production 12.01.2000;
    Model year 2000;
    PR number:
    Расшифровка кодов комплектации
    Код Опция
    5MA decorative inserts
    4X0 without side airbag
    9Q0 without multi-function indicator/ on-board computer
    8T0 without cruise control system (CCS)
    8E2 local interference suppression for FM/AMradio reception
    3L3 manual height adjustment for front seats
    1YA without transmission shafts f. rear axle
    B75 type approval Ukraine
    1C2 antifreeze up to -35 degree celsius tolerance up to -40 degree C
    SB0 Sharan promotional measures
    9Y0 without outdoor temperature gage
    4Q0 no flame retardent materials
    9J0 without supertone system and tone sequence control
    4B1 protective side molding
    L0L left-hand drive vehicle
    3E0 w/o stacking panel in load compartment
    8TC rear fog light for driving on the right
    3LD door and side panel trim
    7A0 without CD changer/CD player
    1Z0 initial standard fuel filling
    G0C 5-speed manual transmission
    7P4 manually adjustable lumbar support in front seats
    SJ1 alloy wheels C0M instead of C6W
    0FG Mosel manufacturing sequence
    7X0 without park distance control
    8F2 side turn signal lights
    2WA without additional tires
    QA0 without child seat
    B0A component parts set without country-specific design requirement
    7AA electronic vehicle immobilization device
    1ZC disc brakes, front (Geomet D)
    1D0 without towing attachment
    1RT nameplate set "1.8 T"
    6SD tufted trunk floor covering (dimensionally stable)
    T8B components for base engine, unit 058.D
    0G1 gearshift lever
    4R3 power windows with comfort operation
    7Q0 without navigation device
    8N4 windshield wiper intermittent control with potentiometer (four speeds)
    7B0 without socket
    1SA without additional engine guard
    6E3 center armrest front
    Q2J comfort front seats
    0GD emissions concept EU 2 (MVEG 2)
    9D0 without preparation for two-way radio installation
    3MQ Ibolours floor covering
    8NA without parking light warning light
    3FA without roof insert (standard roof)
    2PQ steering wheel for airbag system
    7QA without CD ROM
    1T0 w/o first aid kit and warning triangle
    2B2 additional exterior noise suppression
    1E1 activated carbon canister
    E0A no special edition
    E0F Stella Minus
    4ZE black moldings
    H6S tires 195/65 R 15 V
    VC1 remote-controlled garage door opener
    8GD alternator 90A
    6U0 without additional seals outside
    6EP additional body covers, stone guard
    9T0 without heated washer nozzles
    4L2 dipping breakaway inside rear view mirror
    4SD left vanity mirror illuminated
    7K0 without tire pressure warning light
    2JB standard bumpers
    J1L battery 280 A (60 Ah)
    3NZ rear seat bench unsplit, backrest split folding
    3GK without additional filler for plane trunk floor
    9M0 without auxiliary/parking heater
    4LA without controls
    4E0 tailgate/trunk lid unlocking from outside
    1EY special identification plate with weight data, but without general operating permit (ROW)
    8WA without front fog light
    U0C instrument insert with tachometer clock and km/h speedometer
    CV0 alloy wheels 7J x 17 offset 38 (1C0 601 025 M)
    9F0 without sound combination for rotating emergency light and radio antenna preparation
    8X0 without headlight washer system
    4TD right vanity mirror illuminated
    8AA without radio
    4M6 cup holder
    1V0 without duty-free and cost-free tires
    0Y1 standard climatic zones
    1G2 steel spare wheel with original equipment tires
    5C0 without special body measures
    9FA without automatic transmission indicator light
    3X0 without load-through provision
    4F1 central locking system
    0QG nameplate set "20V"
    8Q1 headlight-range adjustment
    4U5 luggage pockets on backrest
    C13 operating permit, alteration 13
    AF0 without stowage compartment
    7E0 w/o heat accumulator/auxiliary heating
    C0V steel wheels 6J x 15 offset 45 (five-hole)
    6W1 license plate bracket front (large)
    5K0 without paint preservative
    0YC weight category rear axle weight range 3
    M9L 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, MVEG 2 base engine is T8B/T8C
    1VG installation parts for four-cylinder engine
    0JF weight category front axle weight range 6
    3Q1 rear headrests
    4UE airbag f. driver a. front seat passenger
    CH6 steel wheels 7 1/2J x 17 offset 53
    3B4 child seat anchor for child seat system ISOFIX
    F0A no special purpose vehicle, standard equipment
    K8B notchback
    6A0 without fire extinguisher
    8BG twin headlamp for left-hand drive with integrated high-beam headlight
    5RQ outer right rear view mirror: convex
    0RA without ignition/starter switch locking system
    0K0 without alternative drive module
    5D0 without carrier frequency
    3Y0 without roll-up sun screen
    8R1 center high-mounted stop light
    3J7 articulated and height-adjustable headrests for front seats
    6PA plastic hand brake lever handle
    1WC transmission shaft w/ 108mm in diameter
    0KA without stickers and badges
    9W0 w/o car phone preparation/installation
    8K0 without special low beam mode
    3QT 3-point seat belts with tensioner and height adjustment, front
    8CC speedometer sensor without seal (electronic speedometer sensor)
    8Z5 engine cooling system, type 1
    3C3 lap belt with retractor for the center rear seat
    5SL outer left rear view mirror: non-spherical
    1X0 front wheel drive
    4GH windshield tinted with windshield sunshield
    1PA standard wheel bolts
    6Q1 plastic gearshift knob/handle
    0SB labels/plates in German
    0L2 electric throttle actuation
    8RM eight loudspeakers (passive)
    4W0 without cassette and CD storage unit
    9P0 without seat belt warning light
    9HA without additional malfunction display
    9A0 without taxi alarm system
    0DE installation differentiation for build status of vehicle class B5 (VW Passat)
    1AH electronic differential lock (EDL)
    D7D 4-cyl. gasoline engine 1.8 L/180 kW 20V turbo base engine is T6B
    N0U cut pile seat covering
    3CA without partition
    8KA w/o catalytic converter warning light
    6XN outer rear view mirrors: powered, separately heated
    8S4 two reading lights front, two rear
    V0A tires w/o specification of tire brand
    6Y0 without cruise control warning system
    A8S standard equipment
    6QB locking rear seat catch
    0LA without special plates/stickers/ safety certificates
    4P1 rear floor panel module, type 2
    4A0 without seat heater
    3S0 without roof rails/roof load rack
    8SA taillight assemblies, standard design
    LN0 without engine carrier
    8L3 roof antenna
    QG2 no possibility of activating service interval prolongation
    2G1 insert for the filling up of unleaded fuel
    6R1 leatherette gearshift boot
    1BA standard suspension/shock absorption
    9AK Climatronic with impact pressure control free of cfc
    0TA without floor mats
    Нераспознанные коды
    BU0 146 APU AB7 000 221 012 2Q2 23J LK8 256 10D JQA PH2 2T8 WC1 AG0 UPH BL0 Z3B LM9 ZYP AWC WZZ
  4. #384
    Съебёж, Эта Страна
    Получено: 10
    Откуда столько нераспознанных? У меня при пробивки VIN
    Spook было только 2...
    04/AWT/GFY
  5. #385
    Украина, Харьков
    mark_V
    А как бы это пробить и почему их так много?
  6. #386
    Съебёж, Эта Страна
    Получено: 10
    У тебя всё что mark_V написал + еще 2 кода:
    PH2 Air con, “Climatronic”, free of cfc
    WC1 “Comfortline” equipment package
    А так много скорее всего потому, что скрипт глюканул или при применении скрипта курсор не был в начале текста... IMHO
    04/AWT/GFY
  7. #387
    Россия, Ногинск
    Mex@n!K, там часто бывает засада с нулями и "О" буквами. Сортировать их - "в лом".
  8. #388
    Украина, Харьков
    Переделал коды с нулем вместо буквы "О". Может так правильно?
    Или есче разок код пробить? Заранее большое спасибо.
    Выкладываю Replay:
    WVWZZZ3BZYP221146
  9. #389
    Съебёж, Эта Страна
    Получено: 10
    Да тоже самое будет...И дело тут не в нулях, т.к. они(коды) как были нераспознаными так ими и остались (это я все про http://www.degalab.ru/prnumbers/)
    04/AWT/GFY
  10. #390
    Очень нужна комплектация машины WVWRH63B23P446632, а то я её купил и хочу знать что в ней пока она не пришла и меня не нае..ли. Помогите народ.
  11. #391
    Россия, Ногинск
    tankisti, легко:
    VIN Number WVWRH63B23P446632;
    Sales type 3B35S5;
    Exterior color 2A
    Roof color 2A
    Interior trim code VB;
    Engine code & No. ATQ208618;
    Transmission code EZZ;
    Date of production 28.04.2003;
    Model year 2003;
    PR number:
    Код Опция
    0TD front and rear floor mats
    9Q1 multi-function indicator/trip computer
    8T1 cruise control system (CCS)
    5MG decorative burr walnut inserts
    H4B all-weather tires 205/55 R 16 H (NAR)
    4X8 side airbag front with head airbag and optimized head impact elements (USA)
    3L4 electric seat adjustment for both front seats, driver's seat with memory system
    FB3 surface, interior trim, soft-touch paint
    9Y1 outdoor temperature gage
    4Q1 flame retardent materials
    T7F components for base engine, unit 078.2
    8TA without rear fog light
    7A1 CD changer preparation
    4B9 body-colored protective side molding with trim stripe
    G0F five-speed automatic transmission
    3LJ foamed film door and side panel trim inserts in leatherette
    1Z6 increase in initial standard fuel filling
    9JB smoking version, ashtray front and rear
    C4Q cast alloy wheels 7J x 16 offset 37 (3B0 601 025 L)
    VX0 without hands-free system
    9C4 daytime running lights mode and "coming and leaving home" function for NAR
    8F1 side marker lights
    B0D component parts set, complying with vehicle type for USA (without California), various parts
    7AG electronic alarm system with vehicle immobilization device (for USA)
    4QQ 3-point seat belts with tensioner height adjustment and US label front
    1KF disc brakes, rear
    4C0 1 swivel seat w/ longitudinal adjustmenton rail system
    0G7 Tiptronic
    8N3 windshield wiper intermittent control with rain sensor
    0NJ nameplate set "V6"
    7B3 12-volt socket(s)
    4K0 radio remote controlled central locking operated from inside
    M70 6-cyl. gasoline eng. 2.8 L/142 kW V6 5V LEV base engine is T7F
    8US radio "Premium" (double-size standard radio)
    7QA without CD ROM
    3FE electric slide/tilt sunroof with sun screen/sunblind
    0VM information kit in American English
    0GM emissions concept LEV 1
    J0R battery 380 A (80 Ah)
    1E4 activated charcoal canister acc. to ORVRand siphoning device for filling up
    1LE disc brakes, front
    4ZB bright moldings
    4KC side and rear windows tinted
    3G0 without child seat anchor front (ISOFIX)
    QJ0 without aluminum/chrome work package
    6U1 additional dust seal outside
    1EB without identification plate
    8GL alternator 120A
    9T1 heated washer nozzles, front
    4SG left vanity mirror illuminated extractable sun visor
    4L6 breakaway inside rear view mirror automatically dimming
    2JN comfort bumpers with chrome-plated strip
    8WD integrated front fog light
    4LF radio and CCS controls
    B34 legal requirements USA
    1N1 power steering
    C09 operating permit, alteration 9
    U0F instrument insert with tachometer clock and mph speedometer
    4M6 cup holder
    4TG right vanity mirror illuminated extractable sun visor
    2ZB leather trimmed multi-function steering wheel
    1NA without wheel covers
    5C1 body measures for increased safety requirements
    9FB automatic transmission indicator light
    8Q0 without headlight-range adjustment
    0QJ nameplate set "1.8 T" (T in red)
    6W0 without license plate bracket front
    1VH installation parts for six-cylinder engine
    0QV nameplate set "V5 4MOTION"
    0YF weight category rear axle weight range 6
    4UB airbag for NAR
    5K6 paint preservative with additional transit coating measures
    QE0 without tray areas package/box
    2T1 double-sized standard (DIN)
    3B3 child seat anchor
    0JL weight category front axle weight range 11
    3Q6 three rear headrests
    K8B notchback
    5RR outer right rear view mirror: convex, US
    5D2 carrier frequency 315 MHz
    8BL halogen headlight for left-hand drive US design
    3Y1 roll-up sun screen for rear window
    5ZH headrests for front seats, articulated and height-adjustable with integrated release function
    9VG sound system "Monsoon" (NAR)
    1WD transmission shaft for tripod joints
    6PC leatherette hand brake lever handle
    5SH outer left rear view mirror: flat (USA)
    8K4 daytime running lights mode US version
    8Z6 engine cooling system, type 2
    UB0 rear shock absorption, sports design four wheel drive
    3C7 3-point seat belt for center rear seat
    1PC wheel bolts with anti-theft protection (unlockable)
    6Q3 wooden gearshift knob/handle
    0SC labels/plates in English
    1AJ anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
    9P7 seat belt warning light and acoustic, electric contact in buckle
    N0X part leather seat covering "Sports Grain"
    6XQ outer rear view mirrors: powered, separately heated, electrically foldablewith memory function
    1Q0 without mass damper for steering wheel
    A8U executive US equipment
    0LB special plates/stickers/ safety certificates for USA
    QV0 w/o TV reception/digital radio reception
    4A3 seat heater for front seats separately controlled
    QG0 without service interval prolongation
    8L3 roof antenna
    6R0 selector lever cover
    Нераспознанные коды
    XQ2 861 A2A 35S 0N0 003 446 DB3 028 23P BJ0 FU0 ATQ JQA 042 FV0 AFB BL0 WRH LM7 FH4 632 RK8 63B 0T7
  12. #392
    Украина, Харьков
    Mex@n!K
    Засек пеленг, спасибо на добром деле.
  13. #393
    Огромное спасибо! В этом списке боюсь мне и половину не перевести! Эпакована под завязку...
  14. #394
    Пробейте и мне плиз
    WVWZZZ3BZYP172210 (немец)
    Хочется побольше узнать.
    И кстати, где вообще это в тырнэте узнать можно
    а то восновном все америкосы
  15. #395
    Diver
    VIN Number WVWZZZ3BZYP172210;
    Sales type 3B23W8;
    Exterior color T3
    Roof color T3
    Interior trim code JN;
    Engine code & No. ARG 21399;
    Transmission code DMU;
    Date of production 18.11.1999;
    Model year 2000;
    Код Опция
    0G2 selector lever
    0GF emissions concept D3 (EU 3D)
    0JG weight category front axle weight range 7
    0NA without nameplate set (without model designation)
    1AT electronic stabilization program (ESP)
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    1EX special identification plate for EC
    1T2 warning triangle
    1ZJ disc brakes, front (Geomet D)
    2PX leather trimmed sports steering wheel
    3L5 electric seat adjustment for both front seats
    3Q1 rear headrests
    4AB partially leather door and side panel trim
    4K3 radio remote controlled central locking operated from inside and safe securing
    4M6 cup holder
    4X1 side airbag front
    4ZE black moldings
    5D1 carrier frequency 433.92 MHz
    7AB electronic alarm system with vehicle immobilization device (for RoW)
    7B2 12-volt socket in luggage boot
    7QA without CD ROM
    8AD radio "gamma"
    8GD alternator 90A
    8JG headlight with gas discharge lamp for driving on the right
    8L3 roof antenna
    8Q2 automatic headlight-range adjustment static
    8X1 headlight washer system
    B01 type approval Germany
    C12 operating permit, alteration 12
    C6K alloy wheels 7J x 15 "Adelaide" offset 45 (five-hole)
    D1A 4-cyl. gasoline engine 1.8 L/92 kW 20V EU 3D base engine is T5Z
    G0E four-speed automatic transmission
    H6T tires 205/60 R 15 V
    K8B notchback
    N7K Alcantara/leather seat covering
    Q4H comfort sports seats, front
    QG1 service interval prolongation
    S1X special built-in parts (w/o police) in cust. serv. shop contr. distrib. type 02a. calcul. by sep. cust. serv. invoice
    SA0 model year change calendar week 45
    SA2 individualized vehicle
    T5Z components for base engine, unit 058.B
    Нераспознанные коды
    WE1 WHA P01 PH2 RCA PXE PJ1
  16. #396
    Россия, Майкоп
    Уважаемый директор!
    А мне расшифруйте, пожалуйста: WVWZZZ3BZ1E175165
    Заранее благодарен
  17. #397
    чехх Ну пока директора нет на месте...
    VIN Number WVWZZZ3BZ1E175165;
    Sales type 3B6161;
    Exterior color F8
    Roof color F8
    Interior trim code GC;
    Engine code & No. AWX 24677;
    Transmission code FHN;
    Date of production 31.01.2001;
    Model year 2001;
    Код Опция
    0FA standard manufacturing sequence
    0G1 gearshift lever
    0GE emissions concept EU 3
    0JH weight category front axle weight range 8
    0LW special plates/stickers/ safety certificates for Germany
    1D2 removable and lockable towing attachment
    1DG nameplate set "TDI" (pump-jet injection system)
    1E0 without activated charcoal canister
    1KD disc brakes, rear
    1N1 power steering
    1Q1 mass damper for steering wheel, 26.5Hz
    2B1 additional exterior noise suppression
    2G0 without insert for the filling up of fuel
    3CX net partition
    3NW rear seat bench/backrest, split folding with center armrest
    3Q1 rear headrests
    3S2 black roof rails
    4ZB bright moldings
    6SL tufted trunk floor covering (cut pile)
    7E3 sheathed type glow plug heater
    7QA without CD ROM
    8AC radio "beta"
    8GL alternator 120A
    8L3 roof antenna
    8RE four loudspeakers (passive)
    C02 operating permit, alteration 2
    C5E steel wheels 6J x 15 offset 37
    D3E 4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system, EU 3base engine is T9J/TG0
    K8D Station Wagon Variant/Avant
    T9J components for base engine, unit 038.K
    VC0 w/o remote-controlled garage door opener
    Нераспознанные коды
    WE1 PH5 RBA
  18. #398
    Россия, Рязань
    А я тоже хочу WVWZZZ3BZWE111217
  19. #399
    Получено: 2,316
    Отправлено: 1,372
    Mobil
    VIN Number WVWZZZ3BZWE111217;
    Sales type 3B53C8;
    Exterior color X1
    Roof color X1
    Engine code & No. AHL 63062;
    Date of production 26.08.1997;
    Model year 1998;
    Код Опция
    T6U components for base engine, unit 06B.1
    M4T 4-cylinder gasoline engine 1.6 L/74 kW w/ multi-point injection a. MVEG 2/EU 3Dbase engine is T6U
    Q1A standard front seats
    0NB nameplate set in base trim
    0G2 selector lever
    8N1 windshield wiper intermittent control
    7QA without CD ROM
    2B0 without additional exterior noise suppression
    4ZE black moldings
    8GD alternator 90A
    1LZ front disc brakes, standard ventilation
    7CA without label for radio remote control
    C04 operating permit, alteration 4
    4M6 cup holder
    8AD radio "gamma"
    1G3 alloy spare wheel with original equipment tires
    4U1 luggage nets/pockets on backrests
    3Q1 rear headrests
    3B0 without additional child seat anchor
    0YZ without determination of weight categoryfor rear axle
    0JZ without determination of weight categoryfor front axle
    8JM twin headlamp for left-hand drive with integrated high-beam headlight
    4GF windshield, tinted
    6XD outer rear view mirrors: powered, heated
    1AC anti-lock brake system (ABS)
    4W1 cassette storage unit
    7V0 standard dashboard illumination
    6QA rear seat catch
    9X0 without heated door lock cylinder
    3CX net partition
    Нераспознанные коды
    WE1 PNW PH2 WC1 RCF PJ1
  20. #400
    Украина, Харьков
    Всем превед! Помогите расшифровать VIN американца!
    WVWP063B53P298186
    Огромное спасибо.
Страница 20 из 698 ПерваяПервая ... 1018192021223070120520 ... ПоследняяПоследняя
  1. Расшифруйте пожайлуста VIN
    от никола777 в разделе Архив 2009г.
    Последнее сообщение: 28.05.2009, 21:54
  2. Расшифруйте пожалуйста VIN
    Последнее сообщение: 15.01.2007, 23:32
  3. Расшифруйте пожалуйста VIN WVWZZZ3BZWE181630
    от Клаусщ в разделе Архив 2007г.
    Последнее сообщение: 09.01.2007, 08:43
  4. Расшифруйте пожалуйста VIN
    от Алексей19 в разделе Архив 2006г.
    Последнее сообщение: 08.04.2006, 19:39
  5. Расшифруйте плз. VIN
    от andy77 в разделе Архив 2006г.
    Последнее сообщение: 27.01.2006, 12:34
