1. #321
    Россия, Ногинск
    mitko, буквенное обозначение двигателя или коробки передач не найдено. ЕТКА сама че-то подставила, вот чего вышло:
    VIN Number WVWZZZ3BZYE425024;
    Sales type 3B5375;
    Exterior color 99
    Roof color 80
    Interior trim code 14;
    Engine code & No. ATJ 77667;
    Transmission code DUK;
    Date of production 08.06.2000;
    Model year 2000;
    PR number:
    Код Опция
    S9P installation of five-speed transmission with 1.9L 85kW TDI pump-jet injection
    4X1 side airbag front
    0TD front and rear floor mats
    9Q1 multi-function indicator/trip computer
    5MD decorative aluminum inserts
    8T0 without cruise control system (CCS)
    3L1 manual height adjustment for left front seat
    8E2 local interference suppression for FM/AMradio reception
    1YA without transmission shafts f. rear axle
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    SB0 Sharan promotional measures
    4Q0 no flame retardent materials
    9J0 without supertone system and tone sequence control
    9Y1 outdoor temperature gage
    4B1 protective side molding
    L0L left-hand drive vehicle
    8TC rear fog light for driving on the right
    7P0 without lumbar support in front and rear seats
    3LC foamed film and fabric door and side panel trim
    7A0 without CD changer/CD player
    1Z0 initial standard fuel filling
    Q1A standard front seats
    B01 type approval Germany
    G0C 5-speed manual transmission
    0FA standard manufacturing sequence
    7X0 without park distance control
    8F2 side turn signal lights
    2WA without additional tires
    QA0 without child seat
    B0A component parts set without country-specific design requirement
    N2Z seat covering for special editions
    7AB electronic alarm system with vehicle immobilization device (for RoW)
    1ZC disc brakes, front (Geomet D)
    1D2 removable and lockable towing attachment
    0G1 gearshift lever
    4R2 power windows front, mechanical window regulators rear
    6SL tufted trunk floor covering (cut pile)
    7Q0 without navigation device
    8N4 windshield wiper intermittent control with potentiometer (four speeds)
    AC1 long frame forestructure
    7B2 12-volt socket in luggage boot
    1SA without additional engine guard
    6E0 without center armrest front
    1DG nameplate set "TDI" (pump-jet injection system)
    9D0 without preparation for two-way radio installation
    0GE emissions concept EU 3
    MF0 5-cylinder diesel engine 2.5 L/66 kW TDIwith fuel distributor injection pump base engine is T8Q
    3MQ Ibolours floor covering
    4K3 radio remote controlled central locking operated from inside and safe securing
    8NA without parking light warning light
    3FA without roof insert (standard roof)
    2Q1 modular seat mounting
    7QA without CD ROM
    2B1 additional exterior noise suppression
    1E0 without activated charcoal canister
    1T2 warning triangle
    J0R battery 380 A (80 Ah)
    4ZE black moldings
    H6T tires 205/60 R 15 V
    6U0 without additional seals outside
    6EP additional body covers, stone guard
    C6K alloy wheels 7J x 15 "Adelaide" offset 45 (five-hole)
    9T0 without heated washer nozzles
    8GL alternator 120A
    4L2 dipping breakaway inside rear view mirror
    4SD left vanity mirror illuminated
    7K0 without tire pressure warning light
    2JB standard bumpers
    3NW rear seat bench/backrest, split folding with center armrest
    3GK without additional filler for plane trunk floor
    9M0 without auxiliary/parking heater
    4LA without controls
    4E0 tailgate/trunk lid unlocking from outside
    1EX special identification plate for EC
    8WA without front fog light
    2RB name plate set "CL" with label "Ecomatic"
    TJ0 components for base engine, unit 038.T
    U0C instrument insert with tachometer clock and km/h speedometer
    4M0 without cup holder
    9F0 without sound combination for rotating emergency light and radio antenna preparation
    1MY steering wheel for airbag system
    8X0 without headlight washer system
    4TD right vanity mirror illuminated
    8AC radio "beta"
    1V0 without duty-free and cost-free tires
    0Y1 standard climatic zones
    1G2 steel spare wheel with original equipment tires
    5C0 without special body measures
    4U0 without luggage nets/pockets on backrests
    9FA without automatic transmission indicator light
    3X0 without load-through provision
    0QG nameplate set "20V"
    5C6 additional body measures
    8Q1 headlight-range adjustment
    C15 operating permit, alteration 15
    E2M Edition
    6W1 license plate bracket front (large)
    7E3 sheathed type glow plug heater
    5K0 without paint preservative
    1VG installation parts for four-cylinder engine
    0YE weight category rear axle weight range 5
    0JG weight category front axle weight range 7
    3Q1 rear headrests
    4UE airbag f. driver a. front seat passenger
    CH6 steel wheels 7 1/2J x 17 offset 53
    3B4 child seat anchor for child seat system ISOFIX
    F0A no special purpose vehicle, standard equipment
    T4N components for base engine, unit 038.A
    8BG twin headlamp for left-hand drive with integrated high-beam headlight
    6A0 without fire extinguisher
    5RQ outer right rear view mirror: convex
    K8D Station Wagon Variant/Avant
    0K0 without alternative drive module
    0RA without ignition/starter switch locking system
    5D1 carrier frequency 433.92 MHz
    3Y0 without roll-up sun screen
    S7T SOP for B5 in calendar week 08/2000
    8R1 center high-mounted stop light
    3J7 articulated and height-adjustable headrests for front seats
    6PA plastic hand brake lever handle
    1WD transmission shaft for tripod joints
    0KA without stickers and badges
    9W0 w/o car phone preparation/installation
    S12 KARMANN models, incoming orders as of 02/08/26
    8K0 without special low beam mode
    3QT 3-point seat belts with tensioner and height adjustment, front
    8CC speedometer sensor without seal (electronic speedometer sensor)
    8Z5 engine cooling system, type 1
    8RE four loudspeakers (passive)
    3C3 lap belt with retractor for the center rear seat
    5SL outer left rear view mirror: non-spherical
    1X0 front wheel drive
    4GH windshield tinted with windshield sunshield
    6Q1 plastic gearshift knob/handle
    1PC wheel bolts with anti-theft protection (unlockable)
    0SB labels/plates in German
    0L2 electric throttle actuation
    M3L 4-cyl. turbo diesel engine 1.9 L/85 kW TDI with pump-jet injection system base engine is T4N/TD0
    4W0 without cassette and CD storage unit
    9P0 without seat belt warning light
    9HA without additional malfunction display
    9A0 without taxi alarm system
    0DE installation differentiation for build status of vehicle class B5 (VW Passat)
    8KA w/o catalytic converter warning light
    6XN outer rear view mirrors: powered, separately heated
    8S4 two reading lights front, two rear
    V0A tires w/o specification of tire brand
    6Y0 without cruise control warning system
    6QA rear seat catch
    1B0 without spare wheel bracket
    A8S standard equipment
    0LA without special plates/stickers/ safety certificates
    1AT electronic stabilization program (ESP)
    4P1 rear floor panel module, type 2
    4A0 without seat heater
    8SA taillight assemblies, standard design
    3S2 black roof rails
    8L3 roof antenna
    QG2 no possibility of activating service interval prolongation
    2G0 without insert for the filling up of fuel
    6R1 leatherette gearshift boot
    1BA standard suspension/shock absorption
    3CX net partition
    9AK Climatronic with impact pressure control free of cfc
    Нераспознанные коды
    WE1 WED 000 AQA KE2 024 537 DL0 ATJ 766 980 PH2 ZPH RBA AG0 LM3 Z3B RK8 ZYE 062 LN2 425 WZZ
  2. #322
    Словакия
    Bolsoje spasibo."буквенное обозначение двигателя или коробки передач" cootvetsvujet nastojascej situacii.
  3. #323
    Россия, Москва, САО
    Просьба расшифровать VIN:
    WVWZZZ3BZVE089393
    Заранее благодарен!
  4. #324
    Россия, Ногинск
    borde, на здорОФФье:
    VIN Number WVWZZZ3BZVE089393;
    Sales type 3B23E5;
    Exterior color C3
    Roof color C3
    Interior trim code GQ;
    Engine code & No. ADR266930;
    Transmission code DHZ;
    Date of production 03.04.1997;
    Model year 1997;
    PR number:
    Код Опция
    5MA decorative inserts
    M51 4-cyl. gasoline engine 1.8 L/92 kW 20V with MVEG 2 base engine is T0V/T5Z
    3L3 manual height adjustment for front seats
    3LD door and side panel trim
    7P4 manually adjustable lumbar support in front seats
    SJ1 alloy wheels C0M instead of C6W
    G0R six-speed automatic transmission for four-wheel drive vehicle
    1D0 without towing attachment
    6SD tufted trunk floor covering (dimensionally stable)
    0G1 gearshift lever
    4R3 power windows with comfort operation
    AC0 short frame forestructure
    B0T component parts set, complying with vehicle type for USA and California various parts
    6E3 center armrest front
    2PQ steering wheel for airbag system
    7QA without CD ROM
    1LB disc brakes, front
    1E1 activated carbon canister
    E0A no special edition
    E0F Stella Minus
    4ZE black moldings
    H6S tires 195/65 R 15 V
    8GD alternator 90A
    9T1 heated washer nozzles, front
    7CA without label for radio remote control
    3NZ rear seat bench unsplit, backrest split folding
    J1P battery 220 A (44 Ah)
    0PG nameplate set "1.8"
    8WD integrated front fog light
    C03 operating permit, alteration 3
    1N0 standard steering
    CV0 alloy wheels 7J x 17 offset 38 (1C0 601 025 M)
    4M6 cup holder
    8AD radio "gamma"
    4U1 luggage nets/pockets on backrests
    VE0 without vanity mirror, rear
    AF0 without stowage compartment
    7E0 w/o heat accumulator/auxiliary heating
    C0V steel wheels 6J x 15 offset 45 (five-hole)
    3Q1 rear headrests
    C1B steel wheels 5 1/2J x 14 for SEAT, painted black, offset 35
    3B0 without additional child seat anchor
    K8B notchback
    5D0 without carrier frequency
    0YZ without determination of weight categoryfor rear axle
    0JZ without determination of weight categoryfor front axle
    8JM twin headlamp for left-hand drive with integrated high-beam headlight
    3C0 without center rear seat belts
    4GF windshield, tinted
    1PA standard wheel bolts
    6XD outer rear view mirrors: powered, heated
    1AC anti-lock brake system (ABS)
    8RM eight loudspeakers (passive)
    4W1 cassette storage unit
    N0U cut pile seat covering
    3CA without partition
    7V0 standard dashboard illumination
    T5Z components for base engine, unit 058.B
    6QB locking rear seat catch
    9X0 without heated door lock cylinder
    3S0 without roof rails/roof load rack
    4A3 seat heater for front seats separately controlled
    2G1 insert for the filling up of unleaded fuel
    0TA without floor mats
  5. #325
    Большая просьба расшифровать VIN:
    WWWZZZ3BZWP403008
    заранее огромная благодарность!
  6. #326
    Россия, Ногинск
    Ivan Ryzhov, и Вам без проблем:
    VIN Number WVWZZZ3BZWP403008;
    Sales type 3B23E5;
    Exterior color K1
    Roof color K1
    Interior trim code GP;
    Engine code & No. ADR410487;
    Date of production 07.04.1998;
    Model year 1998;
    PR number:
    Расшифровка кодов комплектации
    Код Опция
    8T1 cruise control system (CCS)
    1K1 mechanical clutch actuation
    G0G five-speed manual transmission for four-wheel drive vehicle
    0FG Mosel manufacturing sequence
    0G1 gearshift lever
    7QA without CD ROM
    2PT leather steering wheel for airbag systemwith additional mass
    2B2 additional exterior noise suppression
    E0F Stella Minus
    4ZE black moldings
    7C0 without entry grab handle on rear pillar
    8GD alternator 90A
    1LZ front disc brakes, standard ventilation
    C07 operating permit, alteration 7
    4M6 cup holder
    8AD radio "gamma"
    0YC weight category rear axle weight range 3
    5K1 paint preservative (wax)
    0JF weight category front axle weight range 6
    3Q1 rear headrests
    K8B notchback
    9W8 car phone preparation
    Нераспознанные коды
    WE1 PK8 008 00K ZU0 ARC PT2 23E FT5 ADR 10D 10J 041 403 048 ZWP PH2 WC1 F0K AG0 1WE UPH BL0 A0L A0P LM5 998 Z3B RCF AWC WZZ
  7. #327
    Россия, Тюмень
    а как такое? мона? WVWZZZ31ZKB059268
    А где вы это пробиваите? простым смертным туда есть доступ?
  8. #328
    Cобираюсь купить VW. Помогите с комплектацией машины по VIN, если такое возможно. VIN - WVWZZZ1JZXW584359. Заранее благодарен!
  9. #329
    mk,
    VIN Number WVWZZZ1JZXW584359;
    Sales type 1J22J3;
    Exterior color X1
    Roof color X1
    Interior trim code RF;
    Engine code & No. AKL458793;
    Transmission code ECT;
    Date of production 22.02.1999;
    Model year 1999;
    Код Опция
    3ZM 3-point seat belts, outer rear
    2G7 filler neck module 1 with insert
    9Q0 without multi-function indicator/ on-board computer
    4AF foamed film and fabric door and side panel trim
    0TQ front and rear floor mats (polypropylene)
    1JD rear shock absorption, basic design 2
    9Y0 without outdoor temperature gage
    0F2 fuel system for carburetor gasoline engine
    4Q1 flame retardent materials
    5N6 folding grab handles at roof frame soft fold-away
    8M0 w/o rear window wiper and washer system
    4B2 body-colored protective side molding
    2W0 fuel filler cap
    G0E four-speed automatic transmission
    0UA without special color trim
    6KC radiator grille
    0N1 standard rear axle
    N2P fabric seat covering
    4J1 floor tray, extension center console
    9JB smoking version, ashtray front and rear
    3M0 without special measures
    7AA electronic vehicle immobilization device
    2P2 trunk sill protection in stainless steel
    ME8 4-cylinder gasoline engine 1.6 L/74 kW with multi-point injection, EU 3D base engine is T6H
    1S7 tool kit and aluminum jack
    0G2 selector lever
    3U0 without luggage compartment cover
    4R4 power windows with comfort operation andcircuit breaker
    6SM needle-punched trunk floor covering (Dilours)
    8N3 windshield wiper intermittent control with rain sensor
    1KP disc brakes, rear
    7QA without CD ROM
    3FE electric slide/tilt sunroof with sun screen/sunblind
    6M3 trunk net
    2B5 additional exterior noise suppression
    2PX leather trimmed sports steering wheel
    9L0 without engine compartment lighting
    4KC side and rear windows tinted
    6EJ additional body cover on sill, without wheel arch
    5A7 comfort trunk lining with service lid
    H6U tires 205/55 R 16 91W
    8GD alternator 90A
    7R3 side turn signal lights (white)
    1LS front disc brakes with integrated adapter
    0A2 four doors
    9E1 luggage compartment lighting
    8W0 without washer fluid level indicator
    3GA without cargo area
    3NS rear seat bench/backrest, split folding locking, with center armrest
    4L6 breakaway inside rear view mirror automatically dimming
    2JC comfort bumpers
    J1L battery 280 A (60 Ah)
    2C5 axial and vertical adjustable steering column
    6FF body-colored outer rear view mirror housings and various add-on parts
    9TB additional warning lights (door area)
    3H0 without backrest release for front seats
    ST7 model year change, calendar week 02
    0AL front stabilizer
    1N1 power steering
    C08 operating permit, alteration 8
    Q4H comfort sports seats, front
    9U0 without brake pad wear indicator
    6NH comfort molding roof liner unsplit roof cutout rear (radio antenna)
    3P1 bracket for first aid kit and warning triangle
    4M6 cup holder
    7L0 without inertia benefit system/ deceleration fuel cut-off/idle stop valve
    8AC radio "beta"
    2D1 complete cd enhancing underbody panel
    0BC rear stabilizer
    0QE nameplate set "1.6"
    4F1 central locking system
    9FB automatic transmission indicator light
    4U5 luggage pockets on backrest
    1GA front shock absorption, basic design 1
    1NU full wheel covers
    8Y1 two-tone horn
    3Q1 rear headrests
    8QC key with light
    2E0 base chassis
    2LB fuel tank with special material treatment (fluorination)
    6P1 license plate bracket rear (ECE)
    1H0 without proportioning valve
    K8B notchback
    U22 suspension range 121
    0RB ignition/starter switch locking system
    8BN halogen headlight for left-hand drive
    0CE vehicle class differentiation 1J0
    C9D steel wheels 6 1/2J x 16
    6PC leatherette hand brake lever handle
    3C1 static lap belt, center rear
    6Q2 leather gearshift knob/handle
    A8C comfort equipment
    0L0 mechanical throttle actuation
    3YR door pockets with insert mats
    8S2 one reading light front, two reading lights rear
    9AB manually controlled air conditioning
    T6H components for base engine, unit 06A.F (aluminum)
    QG0 without service interval prolongation
    8L3 roof antenna
    6R0 selector lever cover
    2V5 fresh air intake system with activated charcoal canister
    Нераспознанные коды
    W02 PH1 RBA PB2
    Добавлено спустя 4 минуты 40 секунд:
    shved, нужен продажный код (Sales type) или тип двигателя и трансмиссии.
  10. #330
    kucap
    Спасибо большое!
  11. #331
    Россия, Тюмень
    кода нет, тип двигателя нацарапан гвоздём - EZ, лично я подзреваю, что RP, коробка механика.
    EZ шли вроде тока 1,6 и с карбюраторами... у меня 1,8 и моновпрыск - Monojetronic.
    ПС Как я запарился с угадываением запчастей для заказов... писец...
  12. #332
    Получено: 9
    И мне расшифруйте пжалуйста!
    WVWZZZ3BZYP436091
  13. #333
    Получено: 2,321
    Отправлено: 1,374
    WVWZZZ3BZYP436091
    Spaze
    VIN Number WVWZZZ3BZYP436091;
    Sales type 3B2355;
    Exterior color K1
    Roof color K1
    Engine code & No. AVG206964;
    Transmission code EEN;
    Date of production 05.05.2000;
    Model year 2000;
    Код Опция
    0NA without nameplate set (without model designation)
    0G1 gearshift lever
    M6N 4-cyl. turbo diesel eng. 1.9 L/81 kW TDIwith MVEG 2 base engine is T1R
    Q2J comfort front seats
    0GD emissions concept EU 2 (MVEG 2)
    7QA without CD ROM
    T1R components for base engine, unit 028.R
    4ZE black moldings
    8GL alternator 120A
    4M6 cup holder
    8AD radio "gamma"
    C14 operating permit, alteration 14
    3Q1 rear headrests
    K8B notchback
    8L3 roof antenna
    QG1 service interval prolongation
    Нераспознанные коды
    WE1 PT2 WW1 WA3 P01 PNE PH2 WC1 RCA
  14. #334
    Получено: 9
    Спасиба басое
  15. #335
    shved, а буквенный код коробки случаем не знаешь?
  16. #336
    Россия, Тюмень
    неа... а где его смотрят?
  17. #337
    Россия, Москва, САО
    Если не сложно скажите какой тип акпп по вин
    wvwzzz1jz2w080946
  18. #338
    Получено: 2,321
    Отправлено: 1,374
    wvwzzz1jz2w080946
    pg011
    VIN Number WVWZZZ1JZ2W080946;
    Sales type 1J20D3;
    Exterior color 1W
    Roof color 1W
    Interior trim code FP;
    Engine code & No. AVU 60802;
    Transmission code FDH;
    Date of production 29.05.2001;
    Model year 2002;
    Код Опция
    4X0 without side airbag
    0TC front floor mats
    FB0 standard paint coating
    0EL installation differentiation for transmission AG4 vehicle components
    1JB rear shock absorption for rough-road design
    1C2 antifreeze up to -35 degree celsius tolerance up to -40 degree C
    3T0 frame headrests, rear
    2W0 fuel filler cap
    6KC radiator grille
    0N5 standard rear axle
    SJ4 control of vehicles with PP.02P051B (fuel cooling system)
    7PA platform group class 1
    G10 front shock absorption
    0G2 selector lever
    3MH Dilours floor covering w/o scuff guard
    0VA without information kit
    AZ0 vehicle with standard production scope
    7QA without CD ROM
    1T0 w/o first aid kit and warning triangle
    6EA without additional side body covers (stone guard)
    0GV emissions concept EU 2 (critical vapor pressure)
    N4C fabric seat covering
    QJ0 without aluminum/chrome work package
    VC0 w/o remote-controlled garage door opener
    C6E steel wheels 6J x 15 offset 38
    8GD alternator 90A
    0A2 four doors
    8W1 washer fluid level indicator
    VK0 air duct, standard
    6FB body-colored outer rear view mirror housings
    1EY special identification plate with weight data, but without general operating permit (ROW)
    0AE front stabilizer
    B37 type approval CIS (without the Baltic States, Ukraine and White Russia)
    1N6 power steering
    9U1 brake pad wear indicator
    SM4 vehicles with manufacture ID number, calendar week 22
    8X1 headlight washer system
    8AA without radio
    QS1 electronic map cooling system
    MW6 4-cylinder gasoline engine 1.6 L/75 kW with multi-point injection base engine is T0B/T53/TC3
    QD2 Bora, lettering for sales name
    2ZJ comfort steering wheel for airbag system
    0BC rear stabilizer
    1NN full wheel covers
    7E2 heated crankcase ventilation system
    L53 suspension range 53
    8Y1 two-tone horn
    K8B notchback
    5ZE frame headrests for front seats
    T53 components for base engine, unit 06A.S
    C20 operating permit, alteration 20
    S0T pre-production series/SOP next MY
    7N0 without tray on roof liner
    8Z7 engine cooling system, type 3
    6Q4 comfort gearshift knob/handle
    2UB rough-road design
    1Q0 without mass damper for steering wheel
    QV0 w/o TV reception/digital radio reception
    8L3 roof antenna
    Нераспознанные коды
    PSW WW1 P04 PH2
  19. #339
    Россия, Москва, САО
    Спасибо!
  20. #340
    Получено: 9
    А вот еще один VIN:
    WVWZZZ3BZYE088538
    Заранее пасиба.
Страница 17 из 698 ПерваяПервая ... 715161718192767117517 ... ПоследняяПоследняя
  1. Расшифруйте пожайлуста VIN
    от никола777 в разделе Архив 2009г.
    Последнее сообщение: 28.05.2009, 21:54
  2. Расшифруйте пожалуйста VIN
    Последнее сообщение: 15.01.2007, 23:32
  3. Расшифруйте пожалуйста VIN WVWZZZ3BZWE181630
    от Клаусщ в разделе Архив 2007г.
    Последнее сообщение: 09.01.2007, 08:43
  4. Расшифруйте пожалуйста VIN
    от Алексей19 в разделе Архив 2006г.
    Последнее сообщение: 08.04.2006, 19:39
  5. Расшифруйте плз. VIN
    от andy77 в разделе Архив 2006г.
    Последнее сообщение: 27.01.2006, 12:34
