1. #301
    Съебёж, Эта Страна
    Получено: 10
    Это Б3? Как это возможно?
    04/AWT/GFY
  2. #302
    Получено: 2,315
    Отправлено: 1,372
    Mex@n!K
    Не знаю, ЕТКА пробила!
  3. #303
    Можно и мой пробить WVWZZZ3BZXP206979
  4. #304
    Получено: 2,315
    Отправлено: 1,372
    adv
    VIN Number WVWZZZ3BZXP206979;
    Sales type 3B23J9;
    Exterior color B4
    Roof color B4
    Interior trim code GP;
    Engine code & No. AEB276316;
    Transmission code CJQ;
    Date of production 07.10.1998;
    Model year 1999;
    Расшифровка кодов комплектации
    Код Опция
    5MA decorative inserts
    9Q0 without multi-function indicator/ on-board computer
    4X1 side airbag front
    8T0 without cruise control system (CCS)
    8E2 local interference suppression for FM/AMradio reception
    3L3 manual height adjustment for front seats
    1YA without transmission shafts f. rear axle
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    9Y0 without outdoor temperature gage
    4Q0 no flame retardent materials
    9J0 without supertone system and tone sequence control
    4B1 protective side molding
    L0L left-hand drive vehicle
    8TC rear fog light for driving on the right
    3LD door and side panel trim
    7A0 without CD changer/CD player
    1Z0 initial standard fuel filling
    7P4 manually adjustable lumbar support in front seats
    G0F five-speed automatic transmission
    0FG Mosel manufacturing sequence
    7X0 without park distance control
    8F2 side turn signal lights
    2WA without additional tires
    QA0 without child seat
    7AA electronic vehicle immobilization device
    1D0 without towing attachment
    1RT nameplate set "1.8 T"
    B0F component parts set, complying with vehicle type for Switzerland, various parts
    6SD tufted trunk floor covering (dimensionally stable)
    T8B components for base engine, unit 058.D
    4R3 power windows with comfort operation
    0G7 Tiptronic
    7Q0 without navigation device
    8N4 windshield wiper intermittent control with potentiometer (four speeds)
    7B0 without socket
    B13 type approval Switzerland
    1SA without additional engine guard
    6E3 center armrest front
    Q2J comfort front seats
    9D0 without preparation for two-way radio installation
    3MQ Ibolours floor covering
    8NA without parking light warning light
    3FA without roof insert (standard roof)
    2PQ steering wheel for airbag system
    7QA without CD ROM
    2B2 additional exterior noise suppression
    1LB disc brakes, front
    1T2 warning triangle
    1E1 activated carbon canister
    E0A no special edition
    4ZE black moldings
    H6S tires 195/65 R 15 V
    8GD alternator 90A
    6U0 without additional seals outside
    6EP additional body covers, stone guard
    9T0 without heated washer nozzles
    4L2 dipping breakaway inside rear view mirror
    4SD left vanity mirror illuminated
    2JB standard bumpers
    J1L battery 280 A (60 Ah)
    3NZ rear seat bench unsplit, backrest split folding
    3GK without additional filler for plane trunk floor
    4LA without controls
    4E0 tailgate/trunk lid unlocking from outside
    1EY special identification plate with weight data, but without general operating permit (ROW)
    8WA without front fog light
    C09 operating permit, alteration 9
    U0C instrument insert with tachometer clock and km/h speedometer
    9F0 without sound combination for rotating emergency light and radio antenna preparation
    8X0 without headlight washer system
    4TD right vanity mirror illuminated
    8AA without radio
    4M6 cup holder
    1V0 without duty-free and cost-free tires
    0Y1 standard climatic zones
    1G2 steel spare wheel with original equipment tires
    5C0 without special body measures
    3X0 without load-through provision
    4F1 central locking system
    9FB automatic transmission indicator light
    4U5 luggage pockets on backrest
    8Q1 headlight-range adjustment
    7E0 w/o heat accumulator/auxiliary heating
    C0V steel wheels 6J x 15 offset 45 (five-hole)
    6W1 license plate bracket front (large)
    M9L 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, MVEG 2 base engine is T8B/T8C
    0YC weight category rear axle weight range 3
    5K1 paint preservative (wax)
    1VG installation parts for four-cylinder engine
    3Q1 rear headrests
    4UE airbag f. driver a. front seat passenger
    0JH weight category front axle weight range 8
    3B4 child seat anchor for child seat system ISOFIX
    F0A no special purpose vehicle, standard equipment
    K8B notchback
    8BG twin headlamp for left-hand drive with integrated high-beam headlight
    5RQ outer right rear view mirror: convex
    0RA without ignition/starter switch locking system
    0K0 without alternative drive module
    5D0 without carrier frequency
    3Y0 without roll-up sun screen
    8R1 center high-mounted stop light
    3J7 articulated and height-adjustable headrests for front seats
    6PA plastic hand brake lever handle
    1WD transmission shaft for tripod joints
    0KA without stickers and badges
    9W0 w/o car phone preparation/installation
    8K0 without special low beam mode
    3QT 3-point seat belts with tensioner and height adjustment, front
    8CC speedometer sensor without seal (electronic speedometer sensor)
    8Z5 engine cooling system, type 1
    3C3 lap belt with retractor for the center rear seat
    5SL outer left rear view mirror: non-spherical
    1X0 front wheel drive
    4GH windshield tinted with windshield sunshield
    1PA standard wheel bolts
    6Q1 plastic gearshift knob/handle
    0L0 mechanical throttle actuation
    0SB labels/plates in German
    4W0 without cassette and CD storage unit
    8RM eight loudspeakers (passive)
    9P0 without seat belt warning light
    S8Q free
    9HA without additional malfunction display
    9A0 without taxi alarm system
    1AH electronic differential lock (EDL)
    0DE installation differentiation for build status of vehicle class B5 (VW Passat)
    N0U cut pile seat covering
    3CA without partition
    8KA w/o catalytic converter warning light
    6XN outer rear view mirrors: powered, separately heated
    8S4 two reading lights front, two rear
    V0A tires w/o specification of tire brand
    6Y0 without cruise control warning system
    A8S standard equipment
    6QB locking rear seat catch
    4P1 rear floor panel module, type 2
    4A0 without seat heater
    0LF special plates/stickers/ safety certificates for Switzerland
    3S0 without roof rails/roof load rack
    8SA taillight assemblies, standard design
    2G1 insert for the filling up of unleaded fuel
    6R0 selector lever cover
    1BA standard suspension/shock absorption
    9AK Climatronic with impact pressure control free of cfc
    0TA without floor mats
    Нераспознанные коды
    WC1
  5. #305
    Россия, Владимир
    И мне, пожалуйста: WAUZZZ4BZWN103901
    Заранее благодарен.
  6. #306
    Пожалуйста, расшифруйте и мне, заранее спасибо WVWNA63BXXE515149
  7. #307
    Получено: 2,315
    Отправлено: 1,372
    Заранее благодарен.
    Asmyan
    VIN Number WAUZZZ4BZWN103901;
    Sales type 4B20B4;
    Exterior color G5
    Roof color G5
    Interior trim code BP;
    Engine code & No. AJP 1949;
    Transmission code DDU;
    Date of production 07.02.1998;
    Model year 1998;
    Код Опция
    0TC front floor mats
    5MB decorative aluminum inserts "stars titanium"
    2K1 reinforced bumpers
    C04 operating permit, alteration 4
    9B0 without telepay device
    6V1 rear trim panel (ECE)
    1N1 power steering
    0LW special plates/stickers/ safety certificates for Germany
    T6W components for base engine, unit 06B.B
    4M0 without cup holder
    M8Y 4-cylinder gasoline engine 1.8 L/92 kW with multi-point injection, MVEG 2 base engine is T6W
    1G3 alloy spare wheel with original equipment tires
    7P0 without lumbar support in front and rear seats
    Q1A standard front seats
    G0C 5-speed manual transmission
    3PF electric height adjustment for both front seats
    5K0 without paint preservative
    U1C instrument insert with km/h speedometer,clock, tachometer, trip odometer and add. instruments (volt., oil temperat.)
    6W5 front license plate bracket
    0YD weight category rear axle weight range 4
    B0A component parts set without country-specific design requirement
    0JF weight category front axle weight range 6
    3B0 without additional child seat anchor
    2A5 delivery equipment (transit coating) with thin seat cover
    1KD disc brakes, rear
    0G1 gearshift lever
    7M1 scuff plates in door apertures with metal inserts
    3Q6 three rear headrests
    K8B notchback
    8UD radio "concert"
    5D1 carrier frequency 433.92 MHz
    9VD speaker (active)
    2PG steering wheel
    0VC information kit in German
    4K1 radio remote controlled central locking
    1WC transmission shaft w/ 108mm in diameter
    7QA without CD ROM
    2B0 without additional exterior noise suppression
    F0Y vehicle with optional features
    6M1 tie down straps
    1T3 first aid kit and warning triangle
    B99 type approval EC
    3V0 without child bench seat
    4KC side and rear windows tinted
    3C7 3-point seat belt for center rear seat
    5A5 trunk lining, with stowage trays
    6XD outer rear view mirrors: powered, heated
    3ND rear seat bench/backrest, unfolding
    N4G fabric seat covering "Basic"
    5E2 sill top with door cover
    6U1 additional dust seal outside
    8GL alternator 120A
    FA0 control of standard production
    C6U forged alloy wheels 6J x 15 polished, offset 45
    0ST labels/plates in German and French
    7CA without label for radio remote control
    0DS installation differentiation for build status of vehicle class 4B0 (AUDI)
    6N0 without mud flaps
    J1P battery 220 A (44 Ah)
    9M0 without auxiliary/parking heater
    SA9 inventory control model 4
    1EX special identification plate for EC
    6R1 leatherette gearshift boot
    2Z0 deletion of model designation
    Нераспознанные коды
    WM1 PH5 RCL
    Добавлено спустя 1 минуту 18 секунд:
    Klokus
    Модель не найдена...
    Правильно VIN написал?
  8. #308
    Отец, пробей вин:
    WAUZZZ4AZVN060459
  9. #309
    Получено: 2,315
    Отправлено: 1,372
    Цитата Сообщение от airborn
    Отец, пробей вин:
    WAUZZZ4AZVN060459
    airborn
    VIN Number WAUZZZ4AZVN060459;
    Sales type 4A5859;
    Exterior color Z9
    Roof color Z9
    Interior trim code HE;
    Engine code & No. AAN 21986;
    Transmission code DPH;
    Date of production 20.05.1997;
    Model year 1997;
    Код Опция
    1BE sports suspension/shock absorption
    0TD front and rear floor mats
    0EC installation differentiation for transmission C90 vehicle components
    9Q1 multi-function indicator/trip computer
    5MG decorative burr walnut inserts
    8LB additional instruments (voltage, oil pressure and temperature)
    6RB dashboard and door trim panel multi-piece, single-color, multi-colored
    1YD transmission shafts for rear axle diameter 108
    9Y1 outdoor temperature gage
    9BA w/o additional electric safety package
    0F4 fuel system for turbo gasoline engine
    1Z2 increase in initial standard fuel filling
    Q1D sports front seats
    6D1 center armrest rear
    6KG radiator grille
    9R2 WITH CONTROL CHECK PACKAGE (AUDI OVERSEAS)
    8U0 without additional instruments for distance measurement
    G0L six-speed manual transmission for four-wheel drive vehicle
    1KE disc brakes, rear
    0G1 gearshift lever
    8FA without second battery
    6T0 without interior light in foot area
    B14 type approval Italy (San Marino, Vatican City)
    6E4 WITH COLLAPSABLE CENTRE ARMREST FRONT, WITH BACK SUPPORT
    9S0 WITHOUT PROVISION FOR RADIO SET
    5H3 tailgate lining for station wagon Avant
    2PL leather trimmed sports steering wheel for airbag system with "S" badge
    0VG information kit in Italian
    3N0 without stowage box in luggage boot
    8G0 without antenna cable for radio system
    8NB parking light indicator light
    C5T alloy wheels 9J x 19
    J0J battery 300 A (63 Ah)
    1T0 w/o first aid kit and warning triangle
    6M0 without tie down straps/net/pocket
    1LC disc brakes, front
    6EE WITH ADDITIONAL BODY COVER PANELS ON WHEEL HOUSE FOR WIDER TYRES
    9SA WITHOUT PROGRAMMING PLUG
    4ZB bright moldings
    3NC rear seat bench/backrest, split folding
    8GL alternator 120A
    9T1 heated washer nozzles, front
    1EG special identification plate (Italy)
    3GB cargo area with continuous cross panel
    8WB front fog lights
    C00 operating permit, initial registration
    2Z1 type sign at rear and "Quattro" nameplates respectively
    9EG wire assembly for five-cylinder turbo charged gasoline engine
    2CB central hydraulic system
    1N1 power steering
    6G1 defroster nozzles for side windows snap shut
    6V3 rear trim panel
    4U1 luggage nets/pockets on backrests
    5C2 body measures for increased safety requirements
    T3V components for base engine, unit 034.K
    3X1 load-through provision with ski bag
    M1S 5-cyl. gasoline engine 2.2 L/169 kW 20V closed-loop catalytic converter base engine is T3V
    2L0 without lower fuel tank protection
    8AV without radio, with loudspeaker connections
    1VB installation parts for five-cylinder engine
    5RD outer right rear view mirror: convex, powered, heated, electrically foldable
    9G0 without preparation for roof attachments
    8Y1 two-tone horn
    9V7 electronic vehicle immobilization devicewith anti-theft alarm system and passenger compartment control
    K8D Station Wagon Variant/Avant
    3J1 height-adjustable headrests for front seats
    8R4 center high-mounted stop light
    2TD radiator grille and bumper, ROW version with 230 PS engine
    8JH ellipsoidal headlight for driving on the right
    3BJ outer left rear view mirror: non-spherical, powered, heated, electrically foldable
    3YB door pockets, front
    8Z2 engine cooling system with heavy-duty fan and radiator
    N0E woven fabric seat covering
    1X1 four wheel drive
    6Q2 leather gearshift knob/handle
    1PC wheel bolts with anti-theft protection (unlockable)
    H3F TYRES 225/50 ZR 16
    0SU labels/plates in Spanish and Italian
    0DT installation differentiation for build status of vehicle class C (AUDI) unit components
    A8Y image-pull model equipment
    9PB windshield wiper arms/blades with additional guide vanes
    9X4 without heated door lock cylinder with micro switch
    3ZB 3-point seat belts, outer rear with ECE label
    3S2 black roof rails
    2V1 dust and pollen filter
    8L3 roof antenna
    0LK special plates/stickers/ safety certificates for Italy
    6R2 leather gearshift boot
    6C1 door window seal as molded part
  10. #310
    Спасибо большое, буду теперь хоть знать что у меня должно быть
  11. #311
    Россия, Владимир
    Спасибо!
  12. #312
    VIN правильный, а влияет-ли что он американец?
  13. #313
    Получено: 2,315
    Отправлено: 1,372
    Klokus
    Очень влияет...
    Тогда через ЕТКА не пробить...
    Жди Wert-a!
    Он пробьёт! =D>
  14. #314
    Россия, Пенза
    Не сочтите за наглость :WVWZZZ3BZXE159477
    Хотя бы ответ ЕТКИ. Спасибо.
  15. #315
    Получено: 2,315
    Отправлено: 1,372
    VicNick
    VIN Number WVWZZZ3BZXE159477;
    Sales type 3B53E5;
    Exterior color E2
    Roof color E2
    Interior trim code HX;
    Engine code & No. ADR466066;
    Transmission code DWA;
    Date of production 20.08.1998;
    Model year 1999;
    Код Опция
    5MD decorative aluminum inserts
    M51 4-cyl. gasoline engine 1.8 L/92 kW 20V with MVEG 2 base engine is T0V/T5Z
    S31 control number (in-plant)
    3LC foamed film and fabric door and side panel trim
    B01 type approval Germany
    0FA standard manufacturing sequence
    7AB electronic alarm system with vehicle immobilization device (for RoW)
    0NA without nameplate set (without model designation)
    0G1 gearshift lever
    6SL tufted trunk floor covering (cut pile)
    7B2 12-volt socket in luggage boot
    4K3 radio remote controlled central locking operated from inside and safe securing
    7QA without CD ROM
    2PX leather trimmed sports steering wheel
    4ZE black moldings
    8GD alternator 90A
    1LZ front disc brakes, standard ventilation
    3NW rear seat bench/backrest, split folding with center armrest
    ST2 reduced price for special edition Lupo "Euro" (for Austria)
    C08 operating permit, alteration 8
    Q4H comfort sports seats, front
    4M6 cup holder
    8AC radio "beta"
    9FA without automatic transmission indicator light
    3Q1 rear headrests
    6PC leatherette hand brake lever handle
    8RE four loudspeakers (passive)
    1AC anti-lock brake system (ABS)
    N0N woven fabric seat covering
    S8Q free
    T5Z components for base engine, unit 058.B
    6QA rear seat catch
    0LA without special plates/stickers/ safety certificates
    9AB manually controlled air conditioning
    4A3 seat heater for front seats separately controlled
    3CX net partition
    Нераспознанные коды
    WT1 WE1 WW1 PH1 RBA
  16. #316
    Данные по автомобилю Марка: V VIN-номер: WVWNA63BXXE515149 Код страны: USA
    Модельный год: 2000 Описание: Passat Wag. GLS 110TLEV5at Регион: 444
    Название модели: 3B54K9 Дата изготовления: 1999-07-26 Номер дилера: 26028
    Бук.обоз.дв.: AEB-0356542
    Дата поставки: 1999-09-08
    Бук.обоз.КП: DDT
    Цветовое исполнение Тип Код цвета Описание
    наружн. N7/N7 elegant green metallic/elegant green metallic
    внутр. GQ flanel gray/dark platinum/flanel gray
    Коды комплектаций Текущий номер № Происхождение Серия Описание
    1 0DE L AED installation differentiation for build status of vehicle class B5 (VW Passat)
    2 0FA L FAD standard manufacturing sequence
    3 0G7 L GES Tiptronic
    4 0GL L AGM emissions concept TLEV
    5 0JH L GKV weight category front axle weight range 8
    6 0K0 L ASY without alternative drive module
    7 0KA L KAE without stickers and badges
    8 0L0 L GAB mechanical throttle actuation
    9 0LB L SIZ special plates/stickers/ safety certificates for USA
    10 0NB L SZU nameplate set in base trim
    11 0RB L ZSS ignition/starter switch locking system
    12 0SC L SAU labels/plates in English
    13 0TD L ZFM front and rear floor mats
    14 0Y1 L KLZ standard climatic zones
    15 0YE L GKH weight category rear axle weight range 5
    16 1AH L BRS electronic differential lock (EDL)
    17 1BA L DAE standard suspension/shock absorption
    18 1C2 L FRO antifreeze up to -35 degree celsius tolerance up to -40 degree C
    19 1D0 L AHV without towing attachment
    20 1E4 L AKB activated charcoal canister acc. to ORVRand siphoning device for filling up
    21 1EB L TYP without identification plate
    22 1G3 E RER alloy spare wheel with original equipment tires
    23 1PC P ABR wheel bolts with anti-theft protection (unlockable)
    24 1SA L TWU without additional engine guard
    25 1T0 L VBK Without first aid kit and warning triangle
    26 1V0 L ZRE without duty-free and cost-free tires
    27 1VG L TWL installation parts for four-cylinder engine
    28 1WD L GFW transmission shaft for tripod joints
    29 1X0 L ATA front wheel drive
    30 1YA L GFH without transmission shafts f. rear axle
    31 1Z6 L KRM increase in initial standard fuel filling
    32 1ZC L BAV disc brakes, front (Geomet D)
    33 2B2 L GRD additional exterior noise suppression
    34 2G1 L EBB insert for the filling up of unleaded fuel
    35 2JC L STF comfort bumpers
    36 2PQ L LRA steering wheel for airbag system
    37 2WA L ZBR without additional tires
    38 3B1 L ZKV child seat anchor according to Canadian requirements
    39 3C7 L SHM 3-point seat belt for center rear seat
    40 3CA L TRW without partition
    41 3FE P DEI electric slide/tilt sunroof with sun screen/sunblind
    42 3GK L LBH without additional filler for plane trunk floor
    43 3L3 L SIE manual height adjustment for front seats
    44 3LD L TSV door and side panel trim
    45 3MQ L BOB Ibolours floor covering
    46 3NC L HIS rear seat bench/backrest, split folding
    47 3Q6 L KOH three rear headrests
    48 3S2 L DAR black roof rails
    49 3X0 L DLS without load-through provision
    50 3Y0 L SSR without roll-up sun screen
    51 4A0 L SIH without seat heater
    52 4B2 L SSL body-colored protective side molding
    53 4E0 L SDH tailgate/trunk lid unlocking from outside
    54 4GH L WSS windshield tinted with windshield sunshield
    55 4K0 L TKV radio remote controlled central locking operated from inside
    56 4L2 L IRS dipping breakaway inside rear view mirror
    57 4LA L BED without controls
    58 4M6 L BEH cup holder
    59 4P1 L PBH rear floor panel module, type 2
    60 4Q1 L SES flame retardent materials
    61 4QQ L RSV 3-point seat belts with tensioner height adjustment and US label front
    62 4R3 L FEH power windows with comfort operation
    63 4SD L MSL left vanity mirror illuminated
    64 4TD L MSR right vanity mirror illuminated
    65 4U5 L GNF luggage pockets on backrest
    66 4UB L AIB airbag for NAR
    67 4W0 L KBO without cassette and CD storage unit
    68 4X1 L SAB side airbag front
    69 4ZE L ZIE black moldings
    70 5C1 L KSA body measures for increased safety requirements
    71 5D2 L TRF carrier frequency 315 MHz
    72 5K2 L LAC paint preservative
    73 5MA L EIH decorative inserts
    74 5RR L ASR outer right rear view mirror: convex, US
    75 5SH L ASL outer left rear view mirror: flat (USA)
    76 5ZH L KOV headrests for front seats, articulated and height-adjustable with integrated release function
    77 6A0 L FEU without fire extinguisher
    78 6E3 L MAS center armrest front
    79 6EP L ZKS additional body covers, stone guard
    80 6PA L HBV plastic hand brake lever handle
    81 6Q1 L SAG plastic gearshift knob/handle
    82 6QA L VRH rear seat catch
    83 6R0 L SHV selector lever cover
    84 6SL L KBB tufted trunk floor covering (cut pile)
    85 6U0 L ZTD without additional seals outside
    86 6W0 L KZV without license plate bracket front
    87 6XN L ASE outer rear view mirrors: powered, separately heated
    88 6Y0 L GWA without cruise control warning system
    89 7A1 L CDW CD changer preparation
    90 7B2 L STD 12-volt socket in luggage boot
    91 7E0 L WSA w/o heat accumulator/auxiliary heating
    92 7K0 L RDK without tire pressure warning light
    93 7P4 L LOR manually adjustable lumbar support in front seats
    94 7Q0 L NAV without navigation device
    95 7QA L CDR without CD ROM
    96 7X0 L EPH without park distance control (parking pilot)
    97 8CC L TWP speedometer sensor without seal (electronic speedometer sensor)
    98 8E2 L ENT local interference suppression for FM/AMradio reception
    99 8F1 L SLE side marker lights
    100 8GD L GEN alternator 90A
    101 8JL L HSW twin-headlamp for driving on the right w/ integrated high-beam headlight US design
    102 8K4 L FLS Daytime running lights mode NAR
    103 8KA L KUE w/o catalytic converter warning light
    104 8L3 L ANT roof antenna
    105 8N4 L SWS windshield wiper intermittent control with potentiometer (four speeds)
    106 8NA L STK without parking light warning light
    107 8Q0 L LWR without headlight-range adjustment
    108 8R1 L HBL center high-mounted stop light
    109 8RM L LSE eight loudspeakers (passive)
    110 8S4 L LEL two reading lights front, two rear
    111 8SB L SBR taillight assembly w/ dark colored lens
    112 8T1 L GRA cruise control system (CCS)
    113 8TA L NEL without rear fog light
    114 8WD L NES integrated front fog light
    115 8X0 L SWR without headlight washer system
    116 8YA P RAO radio for USA
    117 8Z6 L MKU engine cooling system, type 2
    118 9A0 L TAA without taxi alarm system
    119 9AB L HKA manually controlled air conditioning
    120 9D0 L VEF without preparation for two-way radio installation
    121 9F0 L VRT without sound combination for rotating emergency light and radio antenna preparation
    122 9FB L AKA automatic transmission indicator light
    123 9HA L FFA without additional malfunction display
    124 9J0 L STA without supertone system and tone sequence control
    125 9M0 L ZUH without auxiliary/parking heater
    126 9P1 L SGK seat belt warning light, electric contact in buckle
    127 9Q1 L MFA multi-function indicator/trip computer
    128 9T0 L BWD without heated washer nozzles
    129 9V3 L EDW anti-theft protection system (EATAS) forUSA
    130 9W0 L VTV w/o car phone preparation/installation
    131 9Y1 L ATE outdoor temperature gage
    132 A8F I AUS sports equipment
    133 B0W E BLB component parts set, complying with vehicle type for California, various parts
    134 B38 E TPL legal requirements California
    135 C11 E COC operating permit, alteration 11
    136 C6K P RAD alloy wheels 7J x 15 "Adelaide" offset 45 (five-hole)
    137 E0A L AAU no special edition
    138 F0A L FZS no special purpose vehicle, standard equipment
    139 G0F I GSP five-speed automatic transmission
    140 H5B L REI all-weather tires 195/65 R 15 H (NAR)
    141 J0L L BAT battery 340 A (70 Ah)
    142 K8D I KAR Station Wagon Variant/Avant
    143 L0L L LEA left-hand drive vehicle
    144 M98 I MOT 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo base engine is T8B/T8C
    145 N0U L SIB cut pile seat covering
    146 PJ6 G luxury package for NAR
    147 Q2J L VOS comfort front seats
    148 QA0 L KIS without child seat
    149 QG2 L WIV no possibility of activating service interval prolongation
    150 RGA G radio "Premium" for USA
    151 S3T E SNR current MY, previous year vehicle identification number
    152 SW8 E SNR model change 18th calendar week 1999
    153 T8B I GMO 4-cylinder gasoline engine 1.8 L unit 058.D
    154 U0F L INS instrument insert with tachometer clock and mph speedometer
    155 V0A L REL tires w/o specification of tire brand
    156 X9A G Landessetzung USA
  17. #317
    Россия, Ростов-на-Дону
    И мне пробей VIN, пожалуйста, братцкое сердце!
    WVWZZZ3BZYP113184
    Заранее спасибо!
  18. #318
    Получено: 2,315
    Отправлено: 1,372
    WVWZZZ3BZYP113184
    Заранее спасибо!
    Koler
    VIN Number WVWZZZ3BZYP113184;
    Sales type 3B23W5;
    Exterior color C3
    Roof color C3
    Interior trim code GQ;
    Engine code & No. ARG 17239;
    Date of production 09.09.1999;
    Model year 2000;
    Код Опция
    D1A 4-cyl. gasoline engine 1.8 L/92 kW 20V EU 3D base engine is T5Z
    0G1 gearshift lever
    0GF emissions concept D3 (EU 3D)
    7QA without CD ROM
    4ZE black moldings
    8GD alternator 90A
    7K0 without tire pressure warning light
    0PG nameplate set "1.8"
    4M6 cup holder
    8AD radio "gamma"
    C12 operating permit, alteration 12
    3Q1 rear headrests
    K8B notchback
    6A0 without fire extinguisher
    0L2 electric throttle actuation
    SW8 fleet business with Libya
    8L3 roof antenna
    QG1 service interval prolongation
    Нераспознанные коды
    WE1 PH2 WC1 RCA
  19. #319
    Весьма благодарен тебе, дружище!!!
    Красавчик!!!
  20. #320
    Словакия
    Please, WVWZZZ3BZYE425024
Страница 16 из 698 ПерваяПервая ... 614151617182666116516 ... ПоследняяПоследняя
  1. Расшифруйте пожайлуста VIN
    от никола777 в разделе Архив 2009г.
    Последнее сообщение: 28.05.2009, 21:54
  2. Расшифруйте пожалуйста VIN
    Последнее сообщение: 15.01.2007, 23:32
  3. Расшифруйте пожалуйста VIN WVWZZZ3BZWE181630
    от Клаусщ в разделе Архив 2007г.
    Последнее сообщение: 09.01.2007, 08:43
  4. Расшифруйте пожалуйста VIN
    от Алексей19 в разделе Архив 2006г.
    Последнее сообщение: 08.04.2006, 19:39
  5. Расшифруйте плз. VIN
    от andy77 в разделе Архив 2006г.
    Последнее сообщение: 27.01.2006, 12:34
