1. #281
    Россия, г.Москва & МО, г.Кашира
    Ребята, помогите пробить VIN:
    WVWZZZ1JZ1W524034
  2. #282
    Получено: 2,323
    Отправлено: 1,375
    Цитата Сообщение от MOV
    Пробейте please
    WVWZZZ3BZVE039703
    MOV
    VIN Number WVWZZZ3BZVE039703;
    Sales type 3B2355;
    Exterior color C3
    Roof color C3
    Interior trim code GP;
    Engine code & No. AFN158647;
    Transmission code DHF;
    Date of production 17.12.1996;
    Model year 1997;
    Расшифровка кодов комплектации
    Код Опция
    5MA decorative inserts
    4X1 side airbag front
    9Q1 multi-function indicator/trip computer
    8T0 without cruise control system (CCS)
    8E2 local interference suppression for FM/AMradio reception
    3L3 manual height adjustment for front seats
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    4Q0 no flame retardent materials
    9J0 without supertone system and tone sequence control
    9Y1 outdoor temperature gage
    4B1 protective side molding
    L0L left-hand drive vehicle
    2VP nameplate set "TDI" "I"
    8TC rear fog light for driving on the right
    3LD door and side panel trim
    7A0 without CD changer/CD player
    1Z0 initial standard fuel filling
    Q1A standard front seats
    B01 type approval Germany
    G0C 5-speed manual transmission
    7P4 manually adjustable lumbar support in front seats
    0FA standard manufacturing sequence
    8F2 side turn signal lights
    B0A component parts set without country-specific design requirement
    7AB electronic alarm system with vehicle immobilization device (for RoW)
    1D0 without towing attachment
    6SD tufted trunk floor covering (dimensionally stable)
    0G1 gearshift lever
    4R3 power windows with comfort operation
    7Q0 without navigation device
    1SA without additional engine guard
    7B2 12-volt socket in luggage boot
    6E3 center armrest front
    M6N 4-cyl. turbo diesel eng. 1.9 L/81 kW TDIwith MVEG 2 base engine is T1R
    9D0 without preparation for two-way radio installation
    3MQ Ibolours floor covering
    4K3 radio remote controlled central locking operated from inside and safe securing
    8NA without parking light warning light
    3FA without roof insert (standard roof)
    2PQ steering wheel for airbag system
    7QA without CD ROM
    2XB winter tires 195/65 R 15 91H with steel wheel 6J x 15, offset 45 (5-hole) without full wheel cover (C0V)
    2B1 additional exterior noise suppression
    1T2 warning triangle
    1LB disc brakes, front
    1E0 without activated charcoal canister
    E0A no special edition
    T1R components for base engine, unit 028.R
    J0R battery 380 A (80 Ah)
    4ZE black moldings
    H6S tires 195/65 R 15 V
    6U0 without additional seals outside
    6EP additional body covers, stone guard
    8GL alternator 120A
    9T1 heated washer nozzles, front
    4SD left vanity mirror illuminated
    7CA without label for radio remote control
    2JB standard bumpers
    3NZ rear seat bench unsplit, backrest split folding
    3GK without additional filler for plane trunk floor
    4E0 tailgate/trunk lid unlocking from outside
    1EX special identification plate for EC
    C01 operating permit, alteration 1
    8WD integrated front fog light
    U0C instrument insert with tachometer clock and km/h speedometer
    9F0 without sound combination for rotating emergency light and radio antenna preparation
    8X0 without headlight washer system
    4TD right vanity mirror illuminated
    4M6 cup holder
    8AD radio "gamma"
    1V0 without duty-free and cost-free tires
    1G2 steel spare wheel with original equipment tires
    5C0 without special body measures
    4U1 luggage nets/pockets on backrests
    9FA without automatic transmission indicator light
    3X0 without load-through provision
    8Q1 headlight-range adjustment
    C0V steel wheels 6J x 15 offset 45 (five-hole)
    6W1 license plate bracket front (large)
    7E3 sheathed type glow plug heater
    5K0 without paint preservative
    1VG installation parts for four-cylinder engine
    3Q1 rear headrests
    4UE airbag f. driver a. front seat passenger
    3B0 without additional child seat anchor
    F0A no special purpose vehicle, standard equipment
    K8B notchback
    5RQ outer right rear view mirror: convex
    0RA without ignition/starter switch locking system
    5D0 without carrier frequency
    SV3 double cab for the Netherlands with later installed floor covering
    3Y0 without roll-up sun screen
    8R1 center high-mounted stop light
    0YZ without determination of weight categoryfor rear axle
    0JZ without determination of weight categoryfor front axle
    6PA plastic hand brake lever handle
    0KA without stickers and badges
    9W0 w/o car phone preparation/installation
    8JM twin headlamp for left-hand drive with integrated high-beam headlight
    8K0 without special low beam mode
    4GF windshield, tinted
    8CC speedometer sensor without seal (electronic speedometer sensor)
    8Z5 engine cooling system, type 1
    3C3 lap belt with retractor for the center rear seat
    5SL outer left rear view mirror: non-spherical
    1X0 front wheel drive
    1PA standard wheel bolts
    6Q1 plastic gearshift knob/handle
    6XD outer rear view mirrors: powered, heated
    1AC anti-lock brake system (ABS)
    0SB labels/plates in German
    8RM eight loudspeakers (passive)
    9P0 without seat belt warning light
    4W1 cassette storage unit
    9HA without additional malfunction display
    9A0 without taxi alarm system
    0DE installation differentiation for build status of vehicle class B5 (VW Passat)
    N0U cut pile seat covering
    3CA without partition
    8KA w/o catalytic converter warning light
    7V0 standard dashboard illumination
    8S4 two reading lights front, two rear
    V0A tires w/o specification of tire brand
    6Y0 without cruise control warning system
    A8S standard equipment
    6QB locking rear seat catch
    0LA without special plates/stickers/ safety certificates
    9X0 without heated door lock cylinder
    3S0 without roof rails/roof load rack
    8SA taillight assemblies, standard design
    4A3 seat heater for front seats separately controlled
    2G0 without insert for the filling up of fuel
    6R1 leatherette gearshift boot
    1BA standard suspension/shock absorption
    9AK Climatronic with impact pressure control free of cfc
    0TA without floor mats
    Нераспознанные коды
    WE1 WWA PH2 WC1 RCF
    WVWZZZ1JZ1W524034
    Evdokim
    VIN Number WVWZZZ1JZ1W524034;
    Sales type 1J60D3;
    Exterior color 5Z
    Roof color 5Z
    Interior trim code 15;
    Engine code & No. AVU 29285;
    Transmission code FDH;
    Date of production 14.12.2000;
    Model year 2001;
    Код Опция
    2G7 filler neck module 1 with insert
    9Q0 without multi-function indicator/ on-board computer
    0TD front and rear floor mats
    5MD decorative aluminum inserts
    4AF foamed film and fabric door and side panel trim
    FB0 standard paint coating
    0EL installation differentiation for transmission AG4 vehicle components
    G08 front shock absorption
    9Y0 without outdoor temperature gage
    0F2 fuel system for carburetor gasoline engine
    1JH rear shock absorption
    5N6 folding grab handles at roof frame soft fold-away
    3T0 frame headrests, rear
    8M1 rear window wiper and washer system with intermittent control
    2W0 fuel filler cap
    7P0 without lumbar support in front and rear seats
    G0E four-speed automatic transmission
    6KC radiator grille
    0UA without special color trim
    L16 suspension range 16
    4J1 floor tray, extension center console
    0N5 standard rear axle
    9JB smoking version, ashtray front and rear
    3M0 without special measures
    7X0 without park distance control
    2WA without additional tires
    QA0 without child seat
    7PA platform group class 1
    7AA electronic vehicle immobilization device
    2P2 trunk sill protection in stainless steel
    N2Z seat covering for special editions
    1S7 tool kit and aluminum jack
    0G2 selector lever
    4R4 power windows with comfort operation andcircuit breaker
    3U2 sliding trunk cover
    6SM needle-punched trunk floor covering (Dilours)
    8N4 windshield wiper intermittent control with potentiometer (four speeds)
    1KP disc brakes, rear
    6E0 without center armrest front
    3MH Dilours floor covering w/o scuff guard
    0GG emissions concept EU 4
    AZ0 vehicle with standard production scope
    7QA without CD ROM
    1E1 activated carbon canister
    2B5 additional exterior noise suppression
    2PX leather trimmed sports steering wheel
    9L0 without engine compartment lighting
    4KC side and rear windows tinted
    6EJ additional body cover on sill, without wheel arch
    5A7 comfort trunk lining with service lid
    QJ1 chrome work package
    VC0 w/o remote-controlled garage door opener
    H6U tires 205/55 R 16 91W
    3NE rear seat bench/backrest, split folding with center armrest
    8GD alternator 90A
    7R3 side turn signal lights (white)
    1LS front disc brakes with integrated adapter
    0A2 four doors
    4L2 dipping breakaway inside rear view mirror
    8W1 washer fluid level indicator
    VK0 air duct, standard
    J1L battery 280 A (60 Ah)
    2C5 axial and vertical adjustable steering column
    6FE body-colored outer rear view mirror housings and tailgate grab strip
    9M0 without auxiliary/parking heater
    9TB additional warning lights (door area)
    4LA without controls
    3GN variable cargo area concept
    0AE front stabilizer
    8WA without front fog light
    3H0 without backrest release for front seats
    1N6 power steering
    9U1 brake pad wear indicator
    8X1 headlight washer system
    3P1 bracket for first aid kit and warning triangle
    QS1 electronic map cooling system
    MW6 4-cylinder gasoline engine 1.6 L/75 kW with multi-point injection base engine is T0B/T53/TC3
    4M6 cup holder
    7L0 without inertia benefit system/ deceleration fuel cut-off/idle stop valve
    8AC radio "beta"
    QD2 Bora, lettering for sales name
    2D1 complete cd enhancing underbody panel
    0BC rear stabilizer
    0QE nameplate set "1.6"
    4F1 central locking system
    9FB automatic transmission indicator light
    4U5 luggage pockets on backrest
    7E0 w/o heat accumulator/auxiliary heating
    C18 operating permit, alteration 18
    1NU full wheel covers
    5K1 paint preservative (wax)
    E2S Bora Edition
    8Y1 two-tone horn
    2LB fuel tank with special material treatment (fluorination)
    6P1 license plate bracket rear (ECE)
    1H0 without proportioning valve
    6A0 without fire extinguisher
    0RB ignition/starter switch locking system
    5ZE frame headrests for front seats
    T53 components for base engine, unit 06A.S
    8BN halogen headlight for left-hand drive
    0CE vehicle class differentiation 1J0
    K8M Bora station wagon/Jetta station wagon
    C9D steel wheels 6 1/2J x 16
    6PC leatherette hand brake lever handle
    3C1 static lap belt, center rear
    3QT 3-point seat belts with tensioner and height adjustment, front
    8RE four loudspeakers (passive)
    7N2 spectacle tray/bracket
    6Q2 leather gearshift knob/handle
    A8C comfort equipment
    4W0 without cassette and CD storage unit
    0L2 electric throttle actuation
    3YR door pockets with insert mats
    8S2 one reading light front, two reading lights rear
    2UA standard design
    1Q0 without mass damper for steering wheel
    6QA rear seat catch
    1AT electronic stabilization program (ESP)
    SA0 model year change calendar week 45
    9AB manually controlled air conditioning
    4P3 rear floor panel module, type 4
    QV0 w/o TV reception/digital radio reception
    8L3 roof antenna
    QG1 service interval prolongation
    3S5 black roof rails
    3ZG 3-point seat belts, outer rear with height adjustment
    6R0 selector lever cover
    2V5 fresh air intake system with activated charcoal canister
    3CX net partition
    Нераспознанные коды
    WED WW1 RBA
  3. #283
    Axl
    Спасибо. С меня причитается.
  4. #284
    Россия, Белгород
    спасибо
    WV Passat 1.9 TDI 1996г.в. AFN МКПП сlima.
  5. #285
    Россия, Нижний Новгород
    Пробейте плиз номерок WVWZZZ6NZYY002836, Спасибо
  6. #286
    Беларусь
    Пробейте плз WVWZZZ3BZYP109429
  7. #287
    И для Ауди WAUZZZ4BX3N102021
  8. #288
    Получено: 2,323
    Отправлено: 1,375
    Aqwer
    Так это Polo по ходу?
    VIN Number WVWZZZ6NZYY002836;
    Sales type 6N10F4;
    Exterior color X1
    Roof color X1
    Interior trim code EK;
    Engine code & No. APQ412899;
    Transmission code DKF;
    Date of production 19.05.1999;
    Model year 1999;
    Код Опция
    4X0 without side airbag
    M0V 4-cylinder gasoline engine 1.4 L/44 kW w/ MPI, MVEG 2 a. closed-loop cat. conv.base engine is T3L/T4M
    C06 operating permit, alteration 6
    1N1 power steering
    8E0 without interference suppression
    5J1 rear spoiler
    0TL front and rear floor mats (leatherette trim)
    4M0 without cup holder
    1MZ steering wheel for airbag system
    6Z2 white turn signal lights
    8AA without radio
    T3L components for base engine, unit 030.H
    1NC full wheel covers
    0Y1 standard climatic zones
    0BA without rear stabilizer
    1G6 space-saving spare wheel
    6KA radiator grille
    1K1 mechanical clutch actuation
    4F4 central locking system
    B08 type approval France
    0FB Pamplona manufacturing sequence
    3AD outer right rear view mirror: convex, manually adjustable from inside
    C8E steel wheels 6J x 14 offset 43
    8F6 dark colored side turn signal lights
    4N2 standard dashboard
    8QA key without LED
    3Q1 rear headrests
    5VA without cargo area front
    Q1W standard front seats with integrated storage trays
    8BB halogen headlight for left-hand drive
    6SE flat needle-punched trunk floor covering
    0NB nameplate set in base trim
    4R2 power windows front, mechanical window regulators rear
    1KH drum brakes, rear
    3U1 foldable trunk cover
    K8G hatchback
    8R0 without center high-mounted stop light
    S0B veh. w/ engineering build status of current model year a. vehicle identification no. of next model year
    GP0 vehicles w/o special upgrade measures
    5L0 without front spoiler
    7QA without CD ROM
    2B0 without additional exterior noise suppression
    1T0 w/o first aid kit and warning triangle
    6EA without additional side body covers (stone guard)
    8RA without speakers
    3BR left outside rear view mirror adjustable from inside, non-spheric
    H2Y tires 185/55 R 14 H
    0L0 mechanical throttle actuation
    3NC rear seat bench/backrest, split folding
    1LM disc brakes, front
    8GD alternator 90A
    0SG labels/plates in French
    0DH vehicle class differentiation 6N0
    9T0 without heated washer nozzles
    0A2 four doors
    3GA without cargo area
    6N0 without mud flaps
    4A0 without seat heater
    6FA components without special surface appearance
    3ZB 3-point seat belts, outer rear with ECE label
    8SB taillight assembly w/ dark colored lens
    2JG body-colored bumpers
    0AA without front stabilizer
    2V1 dust and pollen filter
    2G1 insert for the filling up of unleaded fuel
    6R2 leather gearshift boot
    N1L woven fabric seat covering
    Нераспознанные коды
    WDV PE1 PTB PB7
    Добавлено спустя 4 минуты 30 секунд:
    1454MAK
    VIN Number WVWZZZ3BZYP109429;
    Sales type 3B2355;
    Exterior color X1
    Roof color X1
    Engine code & No. AVG201592;
    Transmission code EEN;
    Date of production 01.09.1999;
    Model year 2000;
    Код Опция
    1YA without transmission shafts f. rear axle
    8TD rear fog light for driving on the left
    L0R right-hand drive vehicle
    1Z2 increase in initial standard fuel filling
    B09 type approval Great Britain and NorthernIreland
    0FG Mosel manufacturing sequence
    0G1 gearshift lever
    7AH electronic vehicle immobilization devicewith alarm system, passenger compartmentcontrol and backup horn
    B0N component parts set, complying with vehicle type for Great Britain, various parts
    Q2J comfort front seats
    0GD emissions concept EU 2 (MVEG 2)
    7QA without CD ROM
    4ZE black moldings
    8GL alternator 120A
    7K0 without tire pressure warning light
    4M6 cup holder
    U0L instrument insert with tachometer clock and mph speedometer
    8AD radio "gamma"
    C11 operating permit, alteration 11
    0YC weight category rear axle weight range 3
    0JG weight category front axle weight range 7
    3Q1 rear headrests
    3B4 child seat anchor for child seat system ISOFIX
    K8B notchback
    0K0 without alternative drive module
    5D1 carrier frequency 433.92 MHz
    8BK twin headlamp for right-hand drive with integrated high-beam headlight
    5RV outer right rear view mirror: non-spherical
    3J7 articulated and height-adjustable headrests for front seats
    1WD transmission shaft for tripod joints
    5SJ outer left rear view mirror: convex
    4GH windshield tinted with windshield sunshield
    0SC labels/plates in English
    SW8 fleet business with Libya
    6XN outer rear view mirrors: powered, separately heated
    4P1 rear floor panel module, type 2
    9AD Climatronic, free of cfc
    8L3 roof antenna
    QG2 no possibility of activating service interval prolongation
    0LL special plates/stickers/ safety certificates for England
    Нераспознанные коды
    WE6 WAE WC1 RCA
    airborn
    VIN Number WAUZZZ4BX3N102021;
    Sales type 4B50CZ;
    Exterior color 4Z
    Roof color 4Z
    Interior trim code MB;
    Engine code & No. BDV 62267;
    Transmission code FAM;
    Date of production 08.04.2003;
    Model year 2003;
    Код Опция
    9B0 without telepay device
    4X3 side airbag front with curtain airbag
    9Q2 multi-function indicator/on-board computer with check control
    0LW special plates/stickers/ safety certificates for Germany
    FQ0 standard production wheels
    1YC transmission shafts for rear axle diameter 100
    1BV sports suspension/shock absorption
    QH0 without voice control
    7P1 power adjustable lumbar support in frontseats
    8ED bi-functional headlight with gas discharge lamp, for driving on the right
    7A2 CD changer
    Q1D sports front seats
    T7T components for base engine, unit 078.7
    0N6 rear axle with reduced tread
    VX0 without hands-free system
    7X1 ultrasonic park distance control
    G0Q five-speed automatic transmission for four-wheel drive vehicle
    FC0 without customized installation
    2A4 delivery equipment for shipment (transitcoating) with thick seat cover
    1KD disc brakes, rear
    6SJ trunk floor covering, reversible mat (rubber/fabric)
    0G7 Tiptronic
    CL6 alloy wheels 7 1/2J x 17 nine-spoke style, offset 43
    7Q2 navigation system with color screen
    0VC information kit in German
    VY0 without danger alarm system
    4K4 radio remote controlled central locking operated from inside and separate trunk release
    VJ1 reinforced bumpers
    3FE electric slide/tilt sunroof with sun screen/sunblind
    7QB CD ROM (Germany)
    J0L battery 340 A (70 Ah)
    6M1 tie down straps
    2PV leather trimmed sports steering wheel
    1T3 first aid kit and warning triangle
    0W1 label for central electric German-speaking countries
    H6M tires 235/45 R 17 tire width restricted
    4ZB bright moldings
    3V0 without child bench seat
    5A5 trunk lining, with stowage trays
    1LT disc brakes, front
    8GL alternator 120A
    3GD plane rear cargo area
    6FB body-colored outer rear view mirror housings
    6V1 rear trim panel (ECE)
    1N1 power steering
    2Z7 type sign and company logo without displacement data
    NT0 transit coating (type 1)
    5J0 without rear spoiler
    3HA without leather parts scope
    1G3 alloy spare wheel with original equipment tires
    D5B 6-cyl. gasoline engine 2.4 L/125 kW 30V base engine is: T7T
    3X1 load-through provision with ski bag
    8Q3 automatic headlight-range adjustment dynamic (self-adjusting while driving)
    3PF electric height adjustment for both front seats
    8AY radio/navigation system
    6W5 front license plate bracket
    1VH installation parts for six-cylinder engine
    4N0 standard dashboard
    5K5 transit protective film (instead of paint preservative)
    2T1 double-sized standard (DIN)
    0JK weight category front axle weight range 10
    7M1 scuff plates in door apertures with metal inserts
    3Q6 three rear headrests
    A00 no self-collection
    K8D Station Wagon Variant/Avant
    0YS weight category rear axle weight range 16
    5RU outer right rear view mirror: convex (large viewing field)
    9VD speaker (active)
    3Y3 roll-up sun screen for rear window and rear side windows
    C22 operating permit, alteration 22
    9NX without electronic logbook
    U2B instrument insert with km/h speedometer,radio-controlled clock, tachometer, tripodometer and additional instruments
    1X1 four wheel drive
    3C7 3-point seat belt for center rear seat
    1PC wheel bolts with anti-theft protection (unlockable)
    6XE outer rear view mirrors: powered, heatedelectrically foldable
    5E6 sill top with door cover
    3CB removable net partition
    FA0 control of standard production
    0ST labels/plates in German and French
    0DS installation differentiation for build status of vehicle class 4B0 (AUDI)
    3S2 black roof rails
    N1H leather seat covering
    5TM decorative aluminum inserts "check gray"
    Нераспознанные коды
    PQT PLD PSV PNB P16 PPA WS1 WDD
  9. #289
    Украина, Одесса
    Пробейте и мне плз
    Wvwzzz3BZWP364240
    Заранее благодарен.
  10. #290
    Россия, Ногинск
    Vladman, please:
    VIN Number WVWZZZ3BZWP364240;
    Sales type 3B23C5;
    Exterior color Z4
    Roof color Z4
    Engine code & No. AHL131341;
    Transmission code DCN;
    Date of production 17.03.1998;
    Model year 1998;
    PR number:
    Код Опция
    T6U components for base engine, unit 06B.1
    M4T 4-cylinder gasoline engine 1.6 L/74 kW w/ multi-point injection a. MVEG 2/EU 3Dbase engine is T6U
    SB0 Sharan promotional measures
    4Q1 flame retardent materials
    S31 control number (in-plant)
    G0G five-speed manual transmission for four-wheel drive vehicle
    0G1 gearshift lever
    AC0 short frame forestructure
    7B0 without socket
    H5Z tires 195/65 R 15 V (ultra-light)
    4Z4 glove compartment door without light
    7QA without CD ROM
    1T6 emergency lantern, warning triangle and first aid kit
    E0F Stella Minus
    4ZE black moldings
    UU0 engine stop by cable
    8GD alternator 90A
    7C1 entry grab handle on rear pillar left
    1LZ front disc brakes, standard ventilation
    J1P battery 220 A (44 Ah)
    AE0 without camping stove
    C07 operating permit, alteration 7
    CV0 alloy wheels 7J x 17 offset 38 (1C0 601 025 M)
    4M6 cup holder
    8AC radio "beta"
    AF0 without stowage compartment
    0JD weight category front axle weight range 4
    C1A alloy wheels 6J x 15
    3Q1 rear headrests
    CH5 alloy wheels 7 1/2J x17
    K8B notchback
    8BG twin headlamp for left-hand drive with integrated high-beam headlight
    1B0 without spare wheel bracket
    D0K 4-cylinder diesel engine 2.0 L/51 kW SDIpump-jet injection system base engine is T1A
    Нераспознанные коды
    AHL TN0 364 PK8 00K ARB 23C WW1 240 031 10D 10J ZWP PH1 WC1 RBB BS3 AG0 UPH BL0 A0L LM4 ZJ1 998 Z3B 1WW 1PJ 134 AWC WZZ PJ4
  11. #291
    Украина, Одесса
    mark_V
    Спасибо огромное.
    Пустой как барабан
  12. #292
    Россия, Ногинск
    Vladman, типа того, через строчку "without". Упакуешь и все будет
  13. #293
    Пробейте пожалуйста VIN VW BORA
    wvwzzz1jzxw584350
  14. #294
    Passat Аватар для striker
    Получено: 25
    Отправлено: 20
    А мне можно расшифровать, а то я почитал и самому стало интерестно что у меня там есть.
    VIN WVWZZZ3BZXE113343
    Зарание благодарин
    Ford explorer V limited
  15. #295
    striker
    VIN Number WVWZZZ3BZXE113343;
    Sales type 3B53C5;
    Exterior color L7
    Roof color L7
    Interior trim code YY;
    Engine code & No. AHL308384;
    Date of production 20.07.1998;
    Model year 1999;
    Код Опция
    4AB partially leather door and side panel trim
    5MG decorative burr walnut inserts
    8T1 cruise control system (CCS)
    0NA without nameplate set (without model designation)
    0G1 gearshift lever
    6SL tufted trunk floor covering (cut pile)
    7QA without CD ROM
    4ZE black moldings
    8GD alternator 90A
    N4M partially leather seat covering
    3NW rear seat bench/backrest, split folding with center armrest
    ST5 vehicles with double-size standard radio
    1MR leather steering wheel
    C08 operating permit, alteration 8
    4M6 cup holder
    8AD radio "gamma"
    8Q2 automatic headlight-range adjustment static
    0YE weight category rear axle weight range 5
    0JE weight category front axle weight range 5
    3Q1 rear headrests
    8JG headlight with gas discharge lamp for driving on the right
    1WB transmission shaft w/ 100mm in diameter
    6Q3 wooden gearshift knob/handle
    6QA rear seat catch
    3CX net partition
    Нераспознанные коды
    WE1 PLB PH2 WC1 RCA PXE
  16. #296
    Получено: 25
    Отправлено: 20
    kucap
    Огромное тебе спасибо
  17. #297
    Polak
    VIN Number WVWZZZ1JZXW584350;
    Sales type 1J22J4;
    Exterior color G9
    Roof color G9
    Interior trim code EL;
    Engine code & No. AKL251116;
    Transmission code DUU;
    Date of production 18.02.1999;
    Model year 1999;
    Код Опция
    3ZM 3-point seat belts, outer rear
    3L1 manual height adjustment for left front seat
    0TQ front and rear floor mats (polypropylene)
    1JD rear shock absorption, basic design 2
    8M0 w/o rear window wiper and washer system
    2W0 fuel filler cap
    6KA radiator grille
    0N1 standard rear axle
    ME8 4-cylinder gasoline engine 1.6 L/74 kW with multi-point injection, EU 3D base engine is T6H
    B0K component parts set, complying with vehicle type for France, various parts
    0G3 gearshift linkage
    3U0 without luggage compartment cover
    7QA without CD ROM
    6M3 trunk net
    N4C fabric seat covering
    C6E steel wheels 6J x 15 offset 38
    8GM alternator 70A
    0A2 four doors
    9E1 luggage compartment lighting
    8W0 without washer fluid level indicator
    3NS rear seat bench/backrest, split folding locking, with center armrest
    ST7 model year change, calendar week 02
    0AL front stabilizer
    1MP steering wheel for airbag system
    1N1 power steering
    9U0 without brake pad wear indicator
    6NH comfort molding roof liner unsplit roof cutout rear (radio antenna)
    8AA without radio
    4M6 cup holder
    0BC rear stabilizer
    1NN full wheel covers
    1GA front shock absorption, basic design 1
    8Y1 two-tone horn
    3Q1 rear headrests
    8QC key with light
    2E0 base chassis
    U20 suspension range 119
    K8B notchback
    6Q4 comfort gearshift knob/handle
    9AA manually controlled heating system
    T6H components for base engine, unit 06A.F (aluminum)
    QG0 without service interval prolongation
    8L3 roof antenna
    Нераспознанные коды
    P04
  18. #298
    kucap
    Огромное спаибо
  19. #299
    Расшифруйте пожалуйста WVWZZZ31ZNB285961
  20. #300
    Получено: 2,323
    Отправлено: 1,375
    Павлуня
    VIN Number WVWZZZ31ZNB285961;
    Sales type 315255;
    Exterior color R8
    Roof color R8
    Interior trim code DU;
    Engine code & No. ABS215314;
    Transmission code ;
    Date of production 07.04.1992;
    Model year 1992;
    Код Опция
    0MA without label for starting an automatic
    9BA w/o additional electric safety package
    3LA fabric door and side panel trim
    M5G 4-cylinder gasoline engine 1.8 L/66 kW Monomotronic, catalytic converter base engine is T5C
    1K2 hydraulic clutch actuation
    0FC Brussels manufacturing sequence
    8U0 without additional instruments for distance measurement
    9C3 daytime running lights mode and "coming and leaving home" function for ROW
    6SC tufted trunk floor covering
    1KC drum brakes, rear
    4YA without stowage box rear (door and side panel)
    4R0 mechanical window regulator
    0ND nameplate set "TDI"
    8N1 windshield wiper intermittent control
    3MB velveted fleece floor covering
    J0C battery 220 A (45 Ah)
    8V1 cigarette lighter
    3FD electric sliding/pop-up sunroof
    6EB additional body covers, stone guard and partial trim plate
    4S0 without armrests for front seats
    8GC alternator 65A
    2J1 impact bar in doors
    1EC special identification plate
    1TE fuel tank vent line with gravity valve and second vent line with PVC breather hoses
    3NN rear seat bench unsplit, backrest split folding
    2C0 standard steering column
    1ME steering wheel (hollow rim)
    8A0 standard calibration (ECE)
    1N1 power steering
    6NA unsplit molding roof liner
    U0B instrument insert with clock km/h speedometer
    3P0 without bracket for first aid kit and warning triangle
    8AC radio "beta"
    1G7 space-saving spare wheel (radial tire)
    C0P steel wheels 6J x 14
    9V0 without anti-theft protection system
    H1L tires 185/65 R 14 T
    8Y0 single-tone horn
    3Q1 rear headrests
    8QA key without LED
    8C0 without front fog light circuit
    3QC 3-point seat belts, front
    3BC outer left rear view mirror: flat, manually adjustable from inside
    T5C components for base engine, unit 051.2
    8CA speedometer cable without seal
    3YH door pockets, front
    1AB power brake
    0DB installation differentiation for build status of vehicle class B3 (VW Passat) unit components
    N0P woven fabric seat covering
    8S0 without reading light
    2V0 fresh air intake without air cleaner
    8L4 window antenna
    Нераспознанные коды
    PS1 RBE
Страница 15 из 698 ПерваяПервая ... 513141516172565115515 ... ПоследняяПоследняя
  1. Расшифруйте пожайлуста VIN
    от никола777 в разделе Архив 2009г.
    Последнее сообщение: 28.05.2009, 21:54
  2. Расшифруйте пожалуйста VIN
    Последнее сообщение: 15.01.2007, 23:32
  3. Расшифруйте пожалуйста VIN WVWZZZ3BZWE181630
    от Клаусщ в разделе Архив 2007г.
    Последнее сообщение: 09.01.2007, 08:43
  4. Расшифруйте пожалуйста VIN
    от Алексей19 в разделе Архив 2006г.
    Последнее сообщение: 08.04.2006, 19:39
  5. Расшифруйте плз. VIN
    от andy77 в разделе Архив 2006г.
    Последнее сообщение: 27.01.2006, 12:34
