1. #261
    Эстония
    Axel, большое спасибо тебе, я у вас читал что так же можно по VIN коду определить историю машины, у меня большое сомнение что она не битая, прошу прощения может пишу не в той ТЕМЕ, если можно то пробей
  2. #262
    Получено: 2,315
    Отправлено: 1,372
    Samers
    Смотри ЛС.
  3. #263
    Эстония
    Axl,
    Примного благодарен
  4. #264
    Здравствуйте, а можно и мой расшифровать:
    wvwzzz3bzye416991
  5. #265
    Получено: 2,315
    Отправлено: 1,372
    wvwzzz3bzye416991
    leon_mar
    VIN Number WVWZZZ3BZYE416991;
    Sales type 3B53A5;
    Exterior color Z4
    Roof color Z4
    Interior trim code 14;
    Engine code & No. ANA 26509;
    Transmission code DWG;
    Date of production 24.05.2000;
    Model year 2000;
    Расшифровка кодов комплектации
    Код Опция
    9Q0 without multi-function indicator/ on-board computer
    4X1 side airbag front
    0TD front and rear floor mats
    5MD decorative aluminum inserts
    T6U components for base engine, unit 06B.1
    8T0 without cruise control system (CCS)
    3L1 manual height adjustment for left front seat
    8E2 local interference suppression for FM/AMradio reception
    1YA without transmission shafts f. rear axle
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    9Y0 without outdoor temperature gage
    4Q0 no flame retardent materials
    9J0 without supertone system and tone sequence control
    4B1 protective side molding
    L0L left-hand drive vehicle
    8TC rear fog light for driving on the right
    7P0 without lumbar support in front and rear seats
    3LC foamed film and fabric door and side panel trim
    7A0 without CD changer/CD player
    1Z0 initial standard fuel filling
    Q1A standard front seats
    B01 type approval Germany
    G0C 5-speed manual transmission
    0FA standard manufacturing sequence
    7X0 without park distance control
    8F2 side turn signal lights
    2WA without additional tires
    QA0 without child seat
    B0A component parts set without country-specific design requirement
    7AA electronic vehicle immobilization device
    N2Z seat covering for special editions
    1D0 without towing attachment
    0NB nameplate set in base trim
    0G1 gearshift lever
    4R2 power windows front, mechanical window regulators rear
    1ZJ disc brakes, front (Geomet D)
    6SL tufted trunk floor covering (cut pile)
    7Q0 without navigation device
    8N4 windshield wiper intermittent control with potentiometer (four speeds)
    7B0 without socket
    1SA without additional engine guard
    6E0 without center armrest front
    9D0 without preparation for two-way radio installation
    3MQ Ibolours floor covering
    8NA without parking light warning light
    3FA without roof insert (standard roof)
    0GH emissions concept D4
    2PQ steering wheel for airbag system
    7QA without CD ROM
    2B0 without additional exterior noise suppression
    1T2 warning triangle
    1E1 activated carbon canister
    4ZE black moldings
    H6T tires 205/60 R 15 V
    8GD alternator 90A
    6U0 without additional seals outside
    6EP additional body covers, stone guard
    C6K alloy wheels 7J x 15 "Adelaide" offset 45 (five-hole)
    9T0 without heated washer nozzles
    4L2 dipping breakaway inside rear view mirror
    4SD left vanity mirror illuminated
    7K0 without tire pressure warning light
    2JB standard bumpers
    3NW rear seat bench/backrest, split folding with center armrest
    J1P battery 220 A (44 Ah)
    3GK without additional filler for plane trunk floor
    9M0 without auxiliary/parking heater
    4LA without controls
    4E0 tailgate/trunk lid unlocking from outside
    1EX special identification plate for EC
    8WA without front fog light
    U0C instrument insert with tachometer clock and km/h speedometer
    4M0 without cup holder
    9F0 without sound combination for rotating emergency light and radio antenna preparation
    8X0 without headlight washer system
    4TD right vanity mirror illuminated
    8AC radio "beta"
    1V0 without duty-free and cost-free tires
    0Y1 standard climatic zones
    1G2 steel spare wheel with original equipment tires
    5C0 without special body measures
    4U0 without luggage nets/pockets on backrests
    9FA without automatic transmission indicator light
    3X0 without load-through provision
    4F1 central locking system
    8Q1 headlight-range adjustment
    C14 operating permit, alteration 14
    7E0 w/o heat accumulator/auxiliary heating
    E2M Edition
    6W1 license plate bracket front (large)
    5K1 paint preservative (wax)
    1VG installation parts for four-cylinder engine
    0JD weight category front axle weight range 4
    0YE weight category rear axle weight range 5
    3Q1 rear headrests
    4UE airbag f. driver a. front seat passenger
    3B4 child seat anchor for child seat system ISOFIX
    F0A no special purpose vehicle, standard equipment
    6A0 without fire extinguisher
    8BG twin headlamp for left-hand drive with integrated high-beam headlight
    5RQ outer right rear view mirror: convex
    K8D Station Wagon Variant/Avant
    0K0 without alternative drive module
    0RA without ignition/starter switch locking system
    5D0 without carrier frequency
    3Y0 without roll-up sun screen
    8R1 center high-mounted stop light
    MQ5 4-cylinder gasoline engine 1.6 L/74 kW with multi-point injection and D4 base engine is T6U
    1WB transmission shaft w/ 100mm in diameter
    3J7 articulated and height-adjustable headrests for front seats
    6PA plastic hand brake lever handle
    0KA without stickers and badges
    9W0 w/o car phone preparation/installation
    8K0 without special low beam mode
    3QT 3-point seat belts with tensioner and height adjustment, front
    8CC speedometer sensor without seal (electronic speedometer sensor)
    8Z5 engine cooling system, type 1
    8RE four loudspeakers (passive)
    3C3 lap belt with retractor for the center rear seat
    5SL outer left rear view mirror: non-spherical
    1X0 front wheel drive
    4GH windshield tinted with windshield sunshield
    6Q1 plastic gearshift knob/handle
    1PC wheel bolts with anti-theft protection (unlockable)
    0SB labels/plates in German
    0L2 electric throttle actuation
    4W0 without cassette and CD storage unit
    9P0 without seat belt warning light
    9HA without additional malfunction display
    9A0 without taxi alarm system
    0DE installation differentiation for build status of vehicle class B5 (VW Passat)
    8KA w/o catalytic converter warning light
    6XN outer rear view mirrors: powered, separately heated
    8S4 two reading lights front, two rear
    V0A tires w/o specification of tire brand
    6Y0 without cruise control warning system
    6QA rear seat catch
    A8S standard equipment
    0LA without special plates/stickers/ safety certificates
    1AT electronic stabilization program (ESP)
    4P1 rear floor panel module, type 2
    4A0 without seat heater
    8SA taillight assemblies, standard design
    3S2 black roof rails
    8L3 roof antenna
    QG1 service interval prolongation
    2G1 insert for the filling up of unleaded fuel
    6R1 leatherette gearshift boot
    1BA standard suspension/shock absorption
    3CX net partition
    9AK Climatronic with impact pressure control free of cfc
    Нераспознанные коды
    WED PH2 RBA
  6. #266
    Спасибо! Буду разбираться.
  7. #267
    Россия, Прокопьевск
    Господин директор ,ОГРОМНОЕ СПАСИБО!!!!
  8. #268
    Россия, Королев
    VIN WVWZZZ31ZLE023119
    Всем здрасьте...помогите плиззз
    Срочно надо полную инфу по комплектации ,да и вообще чем больше ее будет тем лучше...
    Это В3 Пассат 89 г.в. 1.8 моно...Вариант
    Народ кто может пробейте...
  9. #269
    Съебёж, Эта Страна
    Получено: 10
    Да не пробъется B3...
    04/AWT/GFY
  10. #270
    Россия, Королев
    Mex@n!K Почему?все реально,Я думаю...
  11. #271
    Данные по автомобилю Марка: V VIN-номер: WVWZZZ31ZLE023119 Код страны: DEU
    Модельный год: 1990 Описание: PASSAT (VAR) CL L466 GKAT5GS Регион: 136
    Название модели: 315255 Дата изготовления: 1989-07-28 Номер дилера: 37401
    Бук.обоз.дв.: RP-0296097
    Дата поставки: 1989-09-29
    Бук.обоз.КП:
    Цветовое исполнение Тип Код цвета Описание
    наружн. Y6/Y6 ROYALBLAUMETALLIC/ROYALBLAUMETALLIC
    внутр. EE SCHWARZSIL./SCHW./SCHW.
    Коды комплектаций Текущий номер № Происхождение Серия Описание
    1 1ME STEERING WHEEL, HOLLOW RIM WITH REDUCED DIAMETER, POWER ASSISTED STEERING
    2 1N1 POWER-ASSISTED STEERING VERSION 1
    3 3L3 LEFT AND RIGHT, MECHANICAL SEAT HEIGHT, BACKREST AND LONGITUDINAL ADJUSTMENT
    4 3NG WITH REAR SEAT AND RAISED BACK REST DIVIDED, CAN BE COMPLETELY FOLDED
    5 3S2 WITH BLACK ROOF RAIL
    6 3U2 WITH MOVABLE LUGGAGE BOOT COVER
    7 8Q1 WITH HEADLIGHT RANGE ADJUSTMENT SYSTEM, ELECTRICAL
    8 PS1 ELECTRIC SLIDING / TILTING ROOF
    9 RBC RADIO "BETA" WITH TELESCOP AERIAL
    10 U0C INSTRUMENT CLUSTER WITH KM/H, DIGITAL CLOCK, REV COUNTER AND TRIP RECORDER
    11 X0A Landessetzung Deutschland
  12. #272
    Россия, Череповец
    По умолчанию Расшифровка VIN
    Дайте,плиз,комплектацию авто
    WVWZZZ3BZ4P247753
  13. #273
    Получено: 2,315
    Отправлено: 1,372
    WVWZZZ3BZ4P247753
    MadHeaD
    VIN Number WVWZZZ3BZ4P247753;
    Sales type 3B33J5;
    Exterior color A1
    Roof color A1
    Interior trim code GT;
    Engine code & No. AWT146140;
    Transmission code FEV;
    Date of production 13.02.2004;
    Model year 2004;
    Код Опция
    4X0 without side airbag
    T6V components for base engine, unit 06B.A
    3L3 manual height adjustment for front seats
    FB3 surface, interior trim, soft-touch paint
    1C2 antifreeze up to -35 degree celsius tolerance up to -40 degree C
    3LD door and side panel trim
    7P4 manually adjustable lumbar support in front seats
    4B9 body-colored protective side molding with trim stripe
    1Z2 increase in initial standard fuel filling
    G0F five-speed automatic transmission
    9JB smoking version, ashtray front and rear
    0FG Mosel manufacturing sequence
    VX0 without hands-free system
    1ZC disc brakes, front (Geomet D)
    1RT nameplate set "1.8 T"
    6SD tufted trunk floor covering (dimensionally stable)
    1KD disc brakes, rear
    4R3 power windows with comfort operation
    0G7 Tiptronic
    C5E steel wheels 6J x 15 offset 37
    1SB additional engine guard
    7B6 12-volt socket(s)
    6E3 center armrest front
    Q2J comfort front seats
    4K3 radio remote controlled central locking operated from inside and safe securing
    7QA without CD ROM
    6M0 without tie down straps/net/pocket
    2B2 additional exterior noise suppression
    2PX leather trimmed sports steering wheel
    E0A no special edition
    0VU information kit in Russian
    4ZB bright moldings
    0GV emissions concept EU 2 (critical vapor pressure)
    4KC side and rear windows tinted
    H6S tires 195/65 R 15 V
    QJ0 without aluminum/chrome work package
    VC0 w/o remote-controlled garage door opener
    8GD alternator 90A
    9T1 heated washer nozzles, front
    J1L battery 280 A (60 Ah)
    3NZ rear seat bench unsplit, backrest split folding
    1EY special identification plate with weight data, but without general operating permit (ROW)
    2JN comfort bumpers with chrome-plated strip
    1N1 power steering
    N5N cut pile fabric seat covering
    B37 type approval CIS (without the Baltic States, Ukraine and White Russia)
    4M5 cup holder
    8AA without radio
    MW8 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo base engine is T0L/T16/T6V/T63
    1NC full wheel covers
    9FB automatic transmission indicator light
    4U5 luggage pockets on backrest
    C11 operating permit, alteration 11
    5K0 without paint preservative
    0YC weight category rear axle weight range 3
    3Q1 rear headrests
    4UF driver's and front passenger airbag with front passenger airbag deactivation
    2T0 without double-sized standard (DIN)
    0JJ weight category front axle weight range 9
    K8B notchback
    5D1 carrier frequency 433.92 MHz
    1WD transmission shaft for tripod joints
    6PC leatherette hand brake lever handle
    8RA without speakers
    1PA standard wheel bolts
    6Q2 leather gearshift knob/handle
    9WC without "Multimedia" in rear compartment
    1AH electronic differential lock (EDL)
    3CA without partition
    1Q0 without mass damper for steering wheel
    0SN labels/plates in Russian
    A8T executive equipment
    3S0 without roof rails/roof load rack
    QV0 w/o TV reception/digital radio reception
    4A3 seat heater for front seats separately controlled
    8L3 roof antenna
    QG2 no possibility of activating service interval prolongation
    6R0 selector lever cover
    1BB suspension/shock absorption for rough road design
    1QD special plates/stickers/ safety certificates for CIS
    Нераспознанные коды
    PSW PH2 WKA
  14. #274
    Россия, Королев
    Wert Спасибо...большое....хотя б это....
  15. #275
    Россия, Кандалакша
    А мне плиз... WVWZZZ3BZXE291223 [-o<
  16. #276
    Получено: 2,315
    Отправлено: 1,372
    TAXI
    VIN Number WVWZZZ3BZXE291223;
    Sales type 3B53J5;
    Exterior color K1
    Roof color K1
    Interior trim code JN;
    Engine code & No. AEB298115;
    Transmission code DVX;
    Date of production 17.11.1998;
    Model year 1999;
    Код Опция
    9Q1 multi-function indicator/trip computer
    4AB partially leather door and side panel trim
    5MG decorative burr walnut inserts
    9Y1 outdoor temperature gage
    7AB electronic alarm system with vehicle immobilization device (for RoW)
    1D2 removable and lockable towing attachment
    0G1 gearshift lever
    T8B components for base engine, unit 058.D
    7B2 12-volt socket in luggage boot
    7QA without CD ROM
    1LB disc brakes, front
    4ZE black moldings
    8GD alternator 90A
    ST6 engine with new build status
    C09 operating permit, alteration 9
    Q4H comfort sports seats, front
    8X1 headlight washer system
    4M6 cup holder
    8AD radio "gamma"
    8Q2 automatic headlight-range adjustment static
    C0V steel wheels 6J x 15 offset 45 (five-hole)
    M9L 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, MVEG 2 base engine is T8B/T8C
    0JG weight category front axle weight range 7
    3Q1 rear headrests
    8JG headlight with gas discharge lamp for driving on the right
    N7K Alcantara/leather seat covering
    1WC transmission shaft w/ 108mm in diameter
    6Q3 wooden gearshift knob/handle
    0L0 mechanical throttle actuation
    8RM eight loudspeakers (passive)
    6QA rear seat catch
    6R2 leather gearshift boot
    3CX net partition
    Нераспознанные коды
    WE1 WHA PH2 RCA PXE
  17. #277
    Россия, Нижний Новгород
    Здрасти. Вопрос наверное к Wert'у. Собираюсь брать америкоса подскажите по VINам, пжлста. Спасиба
    Добавлено спустя 1 минуту 47 секунд:
    Хм, забыл. а вот и VINы: WVWPD63B91P195639, WVWAC63B61P028292.
  18. #278
    Огромнейшее спасибо за расшифровку, но есть один вопрос, в "вашей" расшифровке у меня 2 двери, что соответствует в действительности, а при расшифровке наклейки в багажнике их 4? это опечатка или что?
  19. #279
    Россия, Сургут
    Ребята просветите безграмотного! Дело в том, что у меня в тех. паспорте на моего пасю указан типдвигателя - AHU, а мощность двигателя 80,9кВт/110 л.с. VIN: WVWZZZ3BZWPO52218. Но я так понимаю, что у AHU должно быть 90 л.с. как же так оказалось что у меня их 110? Если кто-нибудь расшифрует мой VIN, буду очень признателен! Заранее благодарен!
  20. #280
    Россия, Белгород
    Пробейте please
    WVWZZZ3BZVE039703
    WV Passat 1.9 TDI 1996г.в. AFN МКПП сlima.
Страница 14 из 698 ПерваяПервая ... 412131415162464114514 ... ПоследняяПоследняя
  1. Расшифруйте пожайлуста VIN
    от никола777 в разделе Архив 2009г.
    Последнее сообщение: 28.05.2009, 21:54
  2. Расшифруйте пожалуйста VIN
    Последнее сообщение: 15.01.2007, 23:32
  3. Расшифруйте пожалуйста VIN WVWZZZ3BZWE181630
    от Клаусщ в разделе Архив 2007г.
    Последнее сообщение: 09.01.2007, 08:43
  4. Расшифруйте пожалуйста VIN
    от Алексей19 в разделе Архив 2006г.
    Последнее сообщение: 08.04.2006, 19:39
  5. Расшифруйте плз. VIN
    от andy77 в разделе Архив 2006г.
    Последнее сообщение: 27.01.2006, 12:34
