1. #201
    Россия, Красногорск
    Axl - Спасибо
  2. #202
    Украина, Киев
    А не будет ли любезен, дорогой Господин Директор,
    Расшифровать мой ВИН?
    WVWZZZ3BZWP238231
    ЗАРАНЕЕ ПРЕМНОГО БЛАГОДАРЕН
  3. #203
    Получено: 2,308
    Отправлено: 1,372
    Цитата Сообщение от SaSMuS
    Принимайте новенького ;)
    Мне пожалуйста тоже вин расшифруйте: WVWZZZ3BZXX039008
    SaSMuS
    VIN Number WVWZZZ3BZXX039008;
    Sales type 3B23J5;
    Exterior color X1
    Roof color X1
    Interior trim code FC;
    Engine code & No. APU 14414;
    Transmission code EHV;
    Date of production 01.04.1999;
    Model year 1999;
    Расшифровка кодов комплектации
    Код Опция
    5MA decorative inserts
    4X0 without side airbag
    9Q0 without multi-function indicator/ on-board computer
    8T0 without cruise control system (CCS)
    3L1 manual height adjustment for left front seat
    8E2 local interference suppression for FM/AMradio reception
    1YA without transmission shafts f. rear axle
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    9Y0 without outdoor temperature gage
    4Q0 no flame retardent materials
    9J0 without supertone system and tone sequence control
    4B1 protective side molding
    L0L left-hand drive vehicle
    8TC rear fog light for driving on the right
    7P0 without lumbar support in front and rear seats
    3LC foamed film and fabric door and side panel trim
    7A0 without CD changer/CD player
    1Z0 initial standard fuel filling
    Q1A standard front seats
    G0C 5-speed manual transmission
    0FG Mosel manufacturing sequence
    7X0 without park distance control
    8F2 side turn signal lights
    2WA without additional tires
    QA0 without child seat
    B0A component parts set without country-specific design requirement
    7AA electronic vehicle immobilization device
    1D0 without towing attachment
    1RT nameplate set "1.8 T"
    6SD tufted trunk floor covering (dimensionally stable)
    0G1 gearshift lever
    T8B components for base engine, unit 058.D
    4R2 power windows front, mechanical window regulators rear
    7Q0 without navigation device
    8N4 windshield wiper intermittent control with potentiometer (four speeds)
    7B0 without socket
    1SA without additional engine guard
    6E0 without center armrest front
    B17 type approval Poland
    9D0 without preparation for two-way radio installation
    3MQ Ibolours floor covering
    8NA without parking light warning light
    3FA without roof insert (standard roof)
    2PQ steering wheel for airbag system
    7QA without CD ROM
    2B2 additional exterior noise suppression
    1LB disc brakes, front
    1T2 warning triangle
    1E1 activated carbon canister
    E0A no special edition
    4ZE black moldings
    H6S tires 195/65 R 15 V
    8GD alternator 90A
    6U0 without additional seals outside
    6EP additional body covers, stone guard
    9T0 without heated washer nozzles
    4L2 dipping breakaway inside rear view mirror
    4SD left vanity mirror illuminated
    S5E SKD control for Poland
    2JB standard bumpers
    3NZ rear seat bench unsplit, backrest split folding
    J1P battery 220 A (44 Ah)
    3GK without additional filler for plane trunk floor
    4LA without controls
    4E0 tailgate/trunk lid unlocking from outside
    8WA without front fog light
    U0C instrument insert with tachometer clock and km/h speedometer
    1FF special identification plate (Poland)
    4M0 without cup holder
    9F0 without sound combination for rotating emergency light and radio antenna preparation
    8X0 without headlight washer system
    4TD right vanity mirror illuminated
    8AA without radio
    1V0 without duty-free and cost-free tires
    0Y1 standard climatic zones
    1G2 steel spare wheel with original equipment tires
    5C0 without special body measures
    4U0 without luggage nets/pockets on backrests
    9FA without automatic transmission indicator light
    3X0 without load-through provision
    4F1 central locking system
    C10 operating permit, alteration 10
    8Q1 headlight-range adjustment
    7E0 w/o heat accumulator/auxiliary heating
    C0V steel wheels 6J x 15 offset 45 (five-hole)
    6W1 license plate bracket front (large)
    5K0 without paint preservative
    0YC weight category rear axle weight range 3
    M9L 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, MVEG 2 base engine is T8B/T8C
    1VG installation parts for four-cylinder engine
    0JF weight category front axle weight range 6
    3Q1 rear headrests
    4UE airbag f. driver a. front seat passenger
    3B4 child seat anchor for child seat system ISOFIX
    F0A no special purpose vehicle, standard equipment
    K8B notchback
    8BG twin headlamp for left-hand drive with integrated high-beam headlight
    5RQ outer right rear view mirror: convex
    0RA without ignition/starter switch locking system
    0K0 without alternative drive module
    5D0 without carrier frequency
    3Y0 without roll-up sun screen
    8R1 center high-mounted stop light
    3J7 articulated and height-adjustable headrests for front seats
    6PA plastic hand brake lever handle
    1WC transmission shaft w/ 108mm in diameter
    0KA without stickers and badges
    9W0 w/o car phone preparation/installation
    8K0 without special low beam mode
    3QT 3-point seat belts with tensioner and height adjustment, front
    8CC speedometer sensor without seal (electronic speedometer sensor)
    8Z5 engine cooling system, type 1
    3C3 lap belt with retractor for the center rear seat
    5SL outer left rear view mirror: non-spherical
    8RE four loudspeakers (passive)
    1X0 front wheel drive
    4GH windshield tinted with windshield sunshield
    1PA standard wheel bolts
    6Q1 plastic gearshift knob/handle
    0SB labels/plates in German
    0L2 electric throttle actuation
    4W0 without cassette and CD storage unit
    9P0 without seat belt warning light
    N0P woven fabric seat covering
    9HA without additional malfunction display
    9A0 without taxi alarm system
    0DE installation differentiation for build status of vehicle class B5 (VW Passat)
    1AH electronic differential lock (EDL)
    3CA without partition
    8KA w/o catalytic converter warning light
    6XN outer rear view mirrors: powered, separately heated
    8S4 two reading lights front, two rear
    V0A tires w/o specification of tire brand
    6Y0 without cruise control warning system
    A8S standard equipment
    6QB locking rear seat catch
    0LA without special plates/stickers/ safety certificates
    4P1 rear floor panel module, type 2
    4A0 without seat heater
    3S0 without roof rails/roof load rack
    8SA taillight assemblies, standard design
    2G1 insert for the filling up of unleaded fuel
    6R1 leatherette gearshift boot
    1BA standard suspension/shock absorption
    9AK Climatronic with impact pressure control free of cfc
    0TA without floor mats
    Нераспознанные коды
    PH2
    Добавлено спустя 1 минуту 44 секунды:
    WVWZZZ3BZWP238231
    YES
    VIN Number WVWZZZ3BZWP238231;
    Sales type 3B23E5;
    Exterior color B4
    Roof color B4
    Interior trim code GP;
    Engine code & No. ADR350435;
    Transmission code DHZ;
    Date of production 29.10.1997;
    Model year 1998;
    Код Опция
    9Q1 multi-function indicator/trip computer
    M51 4-cyl. gasoline engine 1.8 L/92 kW 20V with MVEG 2 base engine is T0V/T5Z
    3L3 manual height adjustment for front seats
    9Y1 outdoor temperature gage
    3LD door and side panel trim
    B03 type approval Czech Republic
    7P4 manually adjustable lumbar support in front seats
    7AB electronic alarm system with vehicle immobilization device (for RoW)
    0G1 gearshift lever
    4R3 power windows with comfort operation
    SR6 Multivan demonstration campaign for Europe
    7B2 12-volt socket in luggage boot
    6E3 center armrest front
    4K3 radio remote controlled central locking operated from inside and safe securing
    7QA without CD ROM
    2B1 additional exterior noise suppression
    4ZE black moldings
    8GD alternator 90A
    1LZ front disc brakes, standard ventilation
    7CD label for radio remote control for
    1EW special identification plate (Czech Republic)
    0PG nameplate set "1.8"
    C05 operating permit, alteration 5
    8AA without radio
    4M6 cup holder
    4U1 luggage nets/pockets on backrests
    0JE weight category front axle weight range 5
    3Q1 rear headrests
    3B0 without additional child seat anchor
    K8B notchback
    5D1 carrier frequency 433.92 MHz
    6XD outer rear view mirrors: powered, heated
    1AC anti-lock brake system (ABS)
    N0U cut pile seat covering
    7V0 standard dashboard illumination
    T5Z components for base engine, unit 058.B
    9X0 without heated door lock cylinder
    Нераспознанные коды
    WE1 PH2 WC1
  4. #204
    Axl - спасибо большое
    Sales type 3B23J5;
    Exterior color X1
    Roof color X1
    Model year 1999
    Странно... по птс и техпаспорту 2000г.в.
    И датчик наружной температуры есть... и зеркало сферическое левое... хм... ну да буду ее принимать такой какая она есть
  5. #205
    Россия, Иваново
    Друзья, поможите и мне плиз..
    WVWZZZ3BZXP301336
    заранее премного благодарен.
  6. #206
    Получено: 2,308
    Отправлено: 1,372
    WVWZZZ3BZXP301336
    AlexW
    VIN Number WVWZZZ3BZXP301336;
    Sales type 3B23C5;
    Exterior color J8
    Roof color J8
    Engine code & No. AHL343344;
    Transmission code DWG;
    Date of production 11.12.1998;
    Model year 1999;
    Код Опция
    4X1 side airbag front
    T6U components for base engine, unit 06B.1
    M4T 4-cylinder gasoline engine 1.6 L/74 kW w/ multi-point injection a. MVEG 2/EU 3Dbase engine is T6U
    B01 type approval Germany
    1D2 removable and lockable towing attachment
    0NB nameplate set in base trim
    0G1 gearshift lever
    7B0 without socket
    7QA without CD ROM
    2B0 without additional exterior noise suppression
    4ZE black moldings
    8GD alternator 90A
    1EX special identification plate for EC
    ST6 engine with new build status
    C09 operating permit, alteration 9
    8AC radio "beta"
    SU9 tractor head with ABS for Al-KO company
    0JC weight category front axle weight range 3
    3Q1 rear headrests
    K8B notchback
    1WB transmission shaft w/ 100mm in diameter
    0L0 mechanical throttle actuation
    9AB manually controlled air conditioning
    Нераспознанные коды
    PH1 RBA
  7. #207
    Латвия, Рига
    Народ помогите плззз пробить историю американца. Знаю некоторым это бесплатно.
    3VWСС21С9XM408509
  8. #208
    Возможно для младшего брата Passat узнать комплектацию?
    VW Bora
    WVWZZZ1JZXW676889
    Заранее спасибо!
  9. #209
    Получено: 2,308
    Отправлено: 1,372
    VW Bora
    WVWZZZ1JZXW676889
    Заранее спасибо!
    Nordo
    Легко...
    VIN Number WVWZZZ1JZXW676889;
    Sales type 1J22B4;
    Exterior color 7D
    Roof color 7D
    Interior trim code KM;
    Engine code & No. AQY 24657;
    Transmission code EGC;
    Date of production 20.03.1999;
    Model year 1999;
    Код Опция
    3ZM 3-point seat belts, outer rear
    2G7 filler neck module 1 with insert
    SX6 control of vehicles according to change request V98K07 (hood lock)
    T6Y components for base engine, unit 06A.D
    0TQ front and rear floor mats (polypropylene)
    1JD rear shock absorption, basic design 2
    0F2 fuel system for carburetor gasoline engine
    4Q1 flame retardent materials
    5N6 folding grab handles at roof frame soft fold-away
    4AR foamed film and circular-knit door and side panel trim
    ML1 4-cylinder gasoline engine 2.0 L/85 kW multi-point injection, EU 4/D4 base engine is T6Y
    8M0 w/o rear window wiper and washer system
    4B2 body-colored protective side molding
    2W0 fuel filler cap
    0UA without special color trim
    6KC radiator grille
    0N1 standard rear axle
    0FA standard manufacturing sequence
    4J1 floor tray, extension center console
    9JB smoking version, ashtray front and rear
    3M0 without special measures
    2P2 trunk sill protection in stainless steel
    1S7 tool kit and aluminum jack
    0G4 cable gearshift
    3U0 without luggage compartment cover
    4R4 power windows with comfort operation andcircuit breaker
    6SM needle-punched trunk floor covering (Dilours)
    8N3 windshield wiper intermittent control with rain sensor
    1KP disc brakes, rear
    1DB nameplate set "2.0"
    Q2J comfort front seats
    7QA without CD ROM
    6M3 trunk net
    2PX leather trimmed sports steering wheel
    2B7 additional exterior noise suppression
    9L0 without engine compartment lighting
    4KC side and rear windows tinted
    6EJ additional body cover on sill, without wheel arch
    5A7 comfort trunk lining with service lid
    H6U tires 205/55 R 16 91W
    8GD alternator 90A
    7R3 side turn signal lights (white)
    1LS front disc brakes with integrated adapter
    0A2 four doors
    9E1 luggage compartment lighting
    8W0 without washer fluid level indicator
    3GA without cargo area
    3NS rear seat bench/backrest, split folding locking, with center armrest
    4L6 breakaway inside rear view mirror automatically dimming
    2JC comfort bumpers
    J1L battery 280 A (60 Ah)
    2C5 axial and vertical adjustable steering column
    9M0 without auxiliary/parking heater
    6FF body-colored outer rear view mirror housings and various add-on parts
    9TB additional warning lights (door area)
    3H0 without backrest release for front seats
    ST7 model year change, calendar week 02
    0AL front stabilizer
    1N1 power steering
    9U0 without brake pad wear indicator
    6NH comfort molding roof liner unsplit roof cutout rear (radio antenna)
    3P1 bracket for first aid kit and warning triangle
    4M6 cup holder
    7L0 without inertia benefit system/ deceleration fuel cut-off/idle stop valve
    8AC radio "beta"
    2D1 complete cd enhancing underbody panel
    0BC rear stabilizer
    4U5 luggage pockets on backrest
    1GC front shock absorption, basic design 3
    1NU full wheel covers
    5K1 paint preservative (wax)
    8Y1 two-tone horn
    3Q1 rear headrests
    8QC key with light
    2E0 base chassis
    2LB fuel tank with special material treatment (fluorination)
    6P1 license plate bracket rear (ECE)
    1H0 without proportioning valve
    6A0 without fire extinguisher
    K8B notchback
    U27 suspension range 126
    8BN halogen headlight for left-hand drive
    0CE vehicle class differentiation 1J0
    0YZ without determination of weight categoryfor rear axle
    C9D steel wheels 6 1/2J x 16
    6PC leatherette hand brake lever handle
    3C1 static lap belt, center rear
    4GF windshield, tinted
    6Q2 leather gearshift knob/handle
    A8C comfort equipment
    3YR door pockets with insert mats
    8S2 one reading light front, two reading lights rear
    QG0 without service interval prolongation
    8L3 roof antenna
    2V5 fresh air intake system with activated charcoal canister
    6R2 leather gearshift boot
    Нераспознанные коды
    W02 PH2 RBA
  10. #210
    Axlвот и я WAUZZZP8DZYA088615
  11. #211
    Получено: 2,308
    Отправлено: 1,372
    эклизиаст
    Модель не найдена!
    З.Ы. Когда наконец излечишь меня от сидучей болезни???
  12. #212
    Axl
    твои слова прям напугали меня,что за болезнь такая??
    неужели сбываются самые худьшие предполажения и ты не сможеш по долгу сидеть перед компом и писать мудрые расшифровки винов
    Добавлено спустя 13 минут 3 секунды:
    директор позволь создать отдельную ветку и всем клубом постараемся вылечить тебя от болезни
  13. #213
    Получено: 2,308
    Отправлено: 1,372
    эклизиаст
    Вот забаню, будешь знать, как насмехаться!!!
  14. #214
    Украина, Киев
    Axl Ура, спасибо, и бАльшой Респект! =D>
  15. #215
    Россия, Пенза
    По умолчанию Расшифруйте VIN please
    wvwzzz3bzxe161858
  16. #216
    Vic
    переправь свой вопрос вот сюда -
    http://www.passat-b5.ru/phpBB2/viewtopi ... &start=200
    ну и заодно - привет...
  17. #217
    Получено: 2,308
    Отправлено: 1,372
    Vic
    Тему переношу в общую!
    VIN Number WVWZZZ3BZXE161858;
    Sales type 3B53E5;
    Exterior color E2
    Roof color E2
    Engine code & No. ADR462607;
    Transmission code DWA;
    Date of production 08.09.1998;
    Model year 1999;
    Код Опция
    8T1 cruise control system (CCS)
    S31 control number (in-plant)
    0G1 gearshift lever
    6SL tufted trunk floor covering (cut pile)
    7B0 without socket
    7QA without CD ROM
    4ZE black moldings
    8GD alternator 90A
    9T1 heated washer nozzles, front
    3NW rear seat bench/backrest, split folding with center armrest
    ST2 reduced price for special edition Lupo "Euro" (for Austria)
    8WD integrated front fog light
    C08 operating permit, alteration 8
    4M6 cup holder
    8AC radio "beta"
    0YD weight category rear axle weight range 4
    3Q1 rear headrests
    K8D Station Wagon Variant/Avant
    8JM twin headlamp for left-hand drive with integrated high-beam headlight
    S8Q free
    6QA rear seat catch
    4A3 seat heater for front seats separately controlled
    3S2 black roof rails
    3CX net partition
    Нераспознанные коды
    WW1 PH1 RBA WC1
  18. #218
    Россия, Пенза
    директору огромное спасибо
    Добавлено спустя 6 минут 25 секунд:
    тока чет расшифровка по движку не совпадает с наклейкой .... че та мысли сразу в голову полезли
  19. #219
    Получено: 2,308
    Отправлено: 1,372
    Vic
    Сильно не совпадает?
    С наклейкой в нише запаски?
    Тогда стОит задуматься...
  20. #220
    Россия, Пенза
    в том то и дело ... стоит движок с турбиной, а по расшифровке безт нее
    Добавлено спустя 5 минут 33 секунды:
    у меня комплектация с подогревом сидений, омыватель фар, все 4 электростеклоподъемники...
Страница 11 из 698 ПерваяПервая ... 9101112132161111511 ... ПоследняяПоследняя
  1. Расшифруйте пожайлуста VIN
    от никола777 в разделе Архив 2009г.
    Последнее сообщение: 28.05.2009, 21:54
  2. Расшифруйте пожалуйста VIN
    Последнее сообщение: 15.01.2007, 23:32
  3. Расшифруйте пожалуйста VIN WVWZZZ3BZWE181630
    от Клаусщ в разделе Архив 2007г.
    Последнее сообщение: 09.01.2007, 08:43
  4. Расшифруйте пожалуйста VIN
    от Алексей19 в разделе Архив 2006г.
    Последнее сообщение: 08.04.2006, 19:39
  5. Расшифруйте плз. VIN
    от andy77 в разделе Архив 2006г.
    Последнее сообщение: 27.01.2006, 12:34
