1. #181
    Axl
    спасибо
    так бразилец или немец ????? ](*,)
    чето визаутов много, хотя оно есть
    например : динамики, коврики, радио (магнитола ?) ...
  2. #182
    Парни , знаю что достала вас уже эта тема , но пусть я буду последним кто об этом вас попросит ... плиз , расшифруйте и мой ВИНИЩЕ :
    WVWZZZ3BZYP037577
    СПАСИБА ЗАРАНЕЕ !!!!!!!
  3. #183
    Получено: 2,310
    Отправлено: 1,372
    WVWZZZ3BZYP037577
    Miklovan
    VIN Number WVWZZZ3BZYP037577;
    Sales type 3B23W5;
    Exterior color E2
    Roof color E2
    Interior trim code FD;
    Engine code & No. ARG 8261;
    Transmission code DWA;
    Date of production 26.05.1999;
    Model year 2000;
    Расшифровка кодов комплектации
    Код Опция
    5MA decorative inserts
    4X1 side airbag front
    9Q1 multi-function indicator/trip computer
    8T0 without cruise control system (CCS)
    3L1 manual height adjustment for left front seat
    8E2 local interference suppression for FM/AMradio reception
    1YA without transmission shafts f. rear axle
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    S2N service interval prolongation without display in instrument cluster, without oil level sensor
    4Q0 no flame retardent materials
    9J0 without supertone system and tone sequence control
    9Y1 outdoor temperature gage
    D1A 4-cyl. gasoline engine 1.8 L/92 kW 20V EU 3D base engine is T5Z
    4B1 protective side molding
    L0L left-hand drive vehicle
    S32 conquest-sales special edition/trade-in
    8TC rear fog light for driving on the right
    7P0 without lumbar support in front and rear seats
    3LC foamed film and fabric door and side panel trim
    7A0 without CD changer/CD player
    1Z0 initial standard fuel filling
    Q1A standard front seats
    B01 type approval Germany
    G0C 5-speed manual transmission
    0FG Mosel manufacturing sequence
    7X0 without park distance control
    8F2 side turn signal lights
    2WA without additional tires
    QA0 without child seat
    B0A component parts set without country-specific design requirement
    7AB electronic alarm system with vehicle immobilization device (for RoW)
    1D0 without towing attachment
    6SD tufted trunk floor covering (dimensionally stable)
    0G1 gearshift lever
    4R2 power windows front, mechanical window regulators rear
    7Q0 without navigation device
    8N4 windshield wiper intermittent control with potentiometer (four speeds)
    1SA without additional engine guard
    7B2 12-volt socket in luggage boot
    6E0 without center armrest front
    9D0 without preparation for two-way radio installation
    0GF emissions concept D3 (EU 3D)
    3MQ Ibolours floor covering
    4K3 radio remote controlled central locking operated from inside and safe securing
    8NA without parking light warning light
    3FA without roof insert (standard roof)
    2PQ steering wheel for airbag system
    7QA without CD ROM
    2B2 additional exterior noise suppression
    1T2 warning triangle
    1E1 activated carbon canister
    E0A no special edition
    4ZE black moldings
    H6S tires 195/65 R 15 V
    8GD alternator 90A
    6U0 without additional seals outside
    6EP additional body covers, stone guard
    9T0 without heated washer nozzles
    4L2 dipping breakaway inside rear view mirror
    1LZ front disc brakes, standard ventilation
    4SD left vanity mirror illuminated
    7K0 without tire pressure warning light
    2JB standard bumpers
    3NZ rear seat bench unsplit, backrest split folding
    J1P battery 220 A (44 Ah)
    3GK without additional filler for plane trunk floor
    9M0 without auxiliary/parking heater
    4LA without controls
    4E0 tailgate/trunk lid unlocking from outside
    1EX special identification plate for EC
    0PG nameplate set "1.8"
    8WD integrated front fog light
    U0C instrument insert with tachometer clock and km/h speedometer
    4M0 without cup holder
    9F0 without sound combination for rotating emergency light and radio antenna preparation
    8X0 without headlight washer system
    4TD right vanity mirror illuminated
    8AC radio "beta"
    1V0 without duty-free and cost-free tires
    0Y1 standard climatic zones
    1G2 steel spare wheel with original equipment tires
    5C0 without special body measures
    4U0 without luggage nets/pockets on backrests
    9FA without automatic transmission indicator light
    3X0 without load-through provision
    8Q1 headlight-range adjustment
    C11 operating permit, alteration 11
    7E0 w/o heat accumulator/auxiliary heating
    C0V steel wheels 6J x 15 offset 45 (five-hole)
    6W1 license plate bracket front (large)
    5K0 without paint preservative
    0YC weight category rear axle weight range 3
    1VG installation parts for four-cylinder engine
    0JE weight category front axle weight range 5
    3Q1 rear headrests
    4UE airbag f. driver a. front seat passenger
    3B4 child seat anchor for child seat system ISOFIX
    F0A no special purpose vehicle, standard equipment
    K8B notchback
    6A0 without fire extinguisher
    5RQ outer right rear view mirror: convex
    0K0 without alternative drive module
    0RA without ignition/starter switch locking system
    5D1 carrier frequency 433.92 MHz
    3Y0 without roll-up sun screen
    8R1 center high-mounted stop light
    3J7 articulated and height-adjustable headrests for front seats
    6PA plastic hand brake lever handle
    1WC transmission shaft w/ 108mm in diameter
    0KA without stickers and badges
    9W0 w/o car phone preparation/installation
    8JM twin headlamp for left-hand drive with integrated high-beam headlight
    8K0 without special low beam mode
    3QT 3-point seat belts with tensioner and height adjustment, front
    8CC speedometer sensor without seal (electronic speedometer sensor)
    8Z5 engine cooling system, type 1
    8RE four loudspeakers (passive)
    3C3 lap belt with retractor for the center rear seat
    5SL outer left rear view mirror: non-spherical
    1X0 front wheel drive
    4GH windshield tinted with windshield sunshield
    1PA standard wheel bolts
    6Q1 plastic gearshift knob/handle
    1AC anti-lock brake system (ABS)
    0SB labels/plates in German
    0L2 electric throttle actuation
    4W0 without cassette and CD storage unit
    9P0 without seat belt warning light
    N0P woven fabric seat covering
    9HA without additional malfunction display
    9A0 without taxi alarm system
    0DE installation differentiation for build status of vehicle class B5 (VW Passat)
    8KA w/o catalytic converter warning light
    3CA without partition
    SW8 fleet business with Libya
    6XN outer rear view mirrors: powered, separately heated
    8S4 two reading lights front, two rear
    T5Z components for base engine, unit 058.B
    V0A tires w/o specification of tire brand
    6Y0 without cruise control warning system
    A8S standard equipment
    6QB locking rear seat catch
    0LA without special plates/stickers/ safety certificates
    4P1 rear floor panel module, type 2
    4A0 without seat heater
    3S0 without roof rails/roof load rack
    8SA taillight assemblies, standard design
    8L3 roof antenna
    QG2 no possibility of activating service interval prolongation
    2G1 insert for the filling up of unleaded fuel
    6R1 leatherette gearshift boot
    1BA standard suspension/shock absorption
    9AK Climatronic with impact pressure control free of cfc
    0TA without floor mats
    Нераспознанные коды
    WE1 PNE PH2 RBA
  4. #184
    Россия, Тюмень
    а мне можно расшифровать? WVWZZZ3BZXP409732
  5. #185
    Россия, Ногинск
    Phoenix, че-то опять не бьется (нет соединения с сервером).
  6. #186
    Всем привет можно и мне помочь, заранее благодарен
    VIN : WVWZZZ3BZXP137643
  7. #187
    Россия, Ногинск
    evgenih, плиз:
    VIN Number WVWZZZ3BZXP137643;
    Sales type 3B23J5;
    Exterior color N4
    Roof color N4
    Interior trim code FC;
    Engine code & No. AEB257014;
    Transmission code DHW;
    Date of production 14.08.1998;
    Model year 1999;
    PR number:
    Код Опция
    9Q0 without multi-function indicator/ on-board computer
    SB0 Sharan promotional measures
    9Y0 without outdoor temperature gage
    7P5 manually adjustable lumbar support for left front seat
    G0G five-speed manual transmission for four-wheel drive vehicle
    SJ1 alloy wheels C0M instead of C6W
    7AA electronic vehicle immobilization device
    1RT nameplate set "1.8 T"
    0G1 gearshift lever
    T8B components for base engine, unit 058.D
    AC0 short frame forestructure
    7B0 without socket
    7QA without CD ROM
    1LB disc brakes, front
    E0F Stella Minus
    4ZE black moldings
    8GD alternator 90A
    9T1 heated washer nozzles, front
    8WA without front fog light
    C08 operating permit, alteration 8
    CV0 alloy wheels 7J x 17 offset 38 (1C0 601 025 M)
    8AC radio "beta"
    4F1 central locking system
    VE0 without vanity mirror, rear
    AF0 without stowage compartment
    M9L 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, MVEG 2 base engine is T8B/T8C
    5K1 paint preservative (wax)
    0JF weight category front axle weight range 6
    4N4 padded dashboard
    3Q1 rear headrests
    CH6 steel wheels 7 1/2J x 17 offset 53
    QT8 step
    K8B notchback
    8BG twin headlamp for left-hand drive with integrated high-beam headlight
    0RB ignition/starter switch locking system
    5D0 without carrier frequency
    3Y1 roll-up sun screen for rear window
    8C0 without front fog light circuit
    0L0 mechanical throttle actuation
    S8Q free
    1AH electronic differential lock (EDL)
    1Q1 mass damper for steering wheel, 26.5Hz
    1B0 without spare wheel bracket
    9AB manually controlled air conditioning
    LN0 without engine carrier
    4A3 seat heater for front seats separately controlled
    Нераспознанные коды
    643 BU0 AWW PK8 AQA 081 AS8 WW1 23J AEB 10D 10J PH1 RBA F0K AG0 BL0 ZXP 998 701 999 Z3B LM9 PPH 137 WZZ
  8. #188
    Россия, Тюмень
    mark_V а по моему больше не пробовал?
  9. #189
    Россия, Ногинск
    Phoenix
    VIN Number WVWZZZ3BZXP409732;
    Sales type 3B23C5;
    Exterior color J8
    Roof color J8
    Engine code & No. AHL360351;
    Transmission code DWG;
    Date of production 11.03.1999;
    Model year 1999;
    PR number:
    Код Опция
    T6U components for base engine, unit 06B.1
    M4T 4-cylinder gasoline engine 1.6 L/74 kW w/ multi-point injection a. MVEG 2/EU 3Dbase engine is T6U
    0NB nameplate set in base trim
    0G1 gearshift lever
    2Q1 modular seat mounting
    7QA without CD ROM
    2B0 without additional exterior noise suppression
    E0F Stella Minus
    4ZE black moldings
    UU0 engine stop by cable
    VC1 remote-controlled garage door opener
    8GD alternator 90A
    ST7 model year change, calendar week 02
    8AC radio "beta"
    3X1 load-through provision with ski bag
    C10 operating permit, alteration 10
    0JC weight category front axle weight range 3
    3Q1 rear headrests
    K8B notchback
    1WB transmission shaft w/ 100mm in diameter
    Нераспознанные коды
    AHL WE1 TN0 PK8 AQA 732 23C WW1 AST 031 035 10D 7T6 PH2 8J8 409 RBA AG0 BL0 ZXP LM4 999 Z3B 1WW PPH 0E0 WZZ AWE
  10. #190
    mark_V спасибо
  11. #191
    Россия, Тюмень
    mark_V огромное спасибо
  12. #192
    Россия, Ногинск
    Phoenix, J8 - Windsor blue metallic
    evgenih, N4 - royal green pearl effect
  13. #193
    Россия, Красногорск
    Привет Всем ! Пробейте пожалуйста WIN
    WVWZZZ3BZYE184909
  14. #194
    Россия, Красногорск
    Привет Всем ! НУ ЧТО ВАМ ТРУДНО ? А МНЕ ХОЧЕТСЯ Пробейте пожалуйста WIN
    WVWZZZ3BZYE184909
    _________________
    B5 Variant ,2000 г, 1.8T, ANB, Климат, Круиз, ESP
  15. #195
    Получено: 2,310
    Отправлено: 1,372
    Юрий Большой
    VIN Number WVWZZZ3BZYE184909;
    Sales type 3B53L5;
    Exterior color 7D
    Roof color 7D
    Interior trim code GP;
    Engine code & No. ANB 16806;
    Transmission code EHV;
    Date of production 27.10.1999;
    Model year 2000;
    Код Опция
    0TD front and rear floor mats
    8T1 cruise control system (CCS)
    SX7 model year change calendar week 36
    3L3 manual height adjustment for front seats
    3LD door and side panel trim
    7P4 manually adjustable lumbar support in front seats
    0FA standard manufacturing sequence
    0NA without nameplate set (without model designation)
    0G1 gearshift lever
    4R3 power windows with comfort operation
    6SL tufted trunk floor covering (cut pile)
    7B0 without socket
    6E3 center armrest front
    Q2J comfort front seats
    0GH emissions concept D4
    7QA without CD ROM
    4ZE black moldings
    8GD alternator 90A
    3NW rear seat bench/backrest, split folding with center armrest
    1MR leather steering wheel
    4M6 cup holder
    8AD radio "gamma"
    4U5 luggage pockets on backrest
    C12 operating permit, alteration 12
    0YE weight category rear axle weight range 5
    3Q1 rear headrests
    K8D Station Wagon Variant/Avant
    MQ6 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, D4 base engine is T8B
    6PC leatherette hand brake lever handle
    6Q2 leather gearshift knob/handle
    8RM eight loudspeakers (passive)
    N0U cut pile seat covering
    6QA rear seat catch
    1AT electronic stabilization program (ESP)
    3S2 black roof rails
    8L3 roof antenna
    QG1 service interval prolongation
    6R2 leather gearshift boot
    3CX net partition
    Нераспознанные коды
    WW1 PNE PH2 WC1 PA1 RCA
  16. #196
    Господа, купил машину, но не знаю что в ней, если не трудно пробейте VIN
    WVWZZZ3BZXE068427
    Заранее благодарен, а то как слепой котенок.
  17. #197
    Получено: 2,310
    Отправлено: 1,372
    WVWZZZ3BZXE068427
    Игорь МИФ
    VIN Number WVWZZZ3BZXE068427;
    Sales type 3B23J5;
    Exterior color N4
    Roof color N4
    Engine code & No. AEB238724;
    Date of production 25.06.1998;
    Model year 1999;
    Код Опция
    4X0 without side airbag
    1C2 antifreeze up to -35 degree celsius tolerance up to -40 degree C
    0G1 gearshift lever
    7B0 without socket
    1SB additional engine guard
    7QA without CD ROM
    4ZE black moldings
    8GD alternator 90A
    J1L battery 280 A (60 Ah)
    1EY special identification plate with weight data, but without general operating permit (ROW)
    8AA without radio
    4M6 cup holder
    4U1 luggage nets/pockets on backrests
    B47 type approval the Baltic States
    0JG weight category front axle weight range 7
    3Q1 rear headrests
    K8B notchback
    1BB suspension/shock absorption for rough road design
    Нераспознанные коды
    PH2 WC1
  18. #198
    Axl
    Огромное спасибо, особенно за быстроту, а что значит нераспознанные коды
    [/u]
  19. #199
    Съебёж, Эта Страна
    Получено: 10
    Это на сайте они нераспознанные...А на самом деле:
    WC1 “Comfortline equipment package
    PH2 Air con, “Climatronic”, free of cfc
    Добавлено спустя 47 секунд:
    P.S. У меня 200 постов!
    04/AWT/GFY
  20. #200
    Принимайте новенького ;)
    Мне пожалуйста тоже вин расшифруйте: WVWZZZ3BZXX039008
Страница 10 из 698 ПерваяПервая ... 891011122060110510 ... ПоследняяПоследняя
  1. Расшифруйте пожайлуста VIN
    от никола777 в разделе Архив 2009г.
    Последнее сообщение: 28.05.2009, 21:54
  2. Расшифруйте пожалуйста VIN
    Последнее сообщение: 15.01.2007, 23:32
  3. Расшифруйте пожалуйста VIN WVWZZZ3BZWE181630
    от Клаусщ в разделе Архив 2007г.
    Последнее сообщение: 09.01.2007, 08:43
  4. Расшифруйте пожалуйста VIN
    от Алексей19 в разделе Архив 2006г.
    Последнее сообщение: 08.04.2006, 19:39
  5. Расшифруйте плз. VIN
    от andy77 в разделе Архив 2006г.
    Последнее сообщение: 27.01.2006, 12:34
