    Polo Аватар для z17atlet
    Россия, Киров
    Отправлено: 13
    По умолчанию Отличие Vag Com 311 от 409
    Всем привет.
    Сильно не пинайте... чем отличаются программы Vag com 311 от 409, кроме всплывающих подсказок и наличия русского языка?
    VW Passat B6, 2.0 FSI BVY, АКПП, 2006
    VW Passat B5, 1.6 AHL, МКПП, 1998
    Питер
    Получено: 3,817
    Отправлено: 86
    Release 409 posted 03 October 2004
    • Clear All DTCs functions
    • Support for Transport Mode ON/OFF for Golf-5 Platform and Audi A8(4E) chassis cars.
    • Fixed incompatibility with older Sharan (7M platform) 09 modules.
    • CODES file enhanced with texts for 2005 models.
    • Ability to decode Readiness bits for modern TDI engines
    • Support for selectable window sizes for higher-resolution laptops.
    • New Label File redirection methods
    • New Version 1.7 VAG-Scope
    • New Version 1.3E of TDI-Graph
    • SAVE CODES button on Fault Codes Screen.
    • This version is no longer supported. Customers using "dongle" type interfaces should update to the current version of VCDS. Customers using obsolete "dumb" or third-party interfaces should update to VCDS-Lite.
    Release 404 posted 29 April 2004
    • Support for HEX+CAN interfaces and all 2005 Model VW/Audi/Seat/Skoda passenger vehicles including those requiring a direct CAN connection for diagnostics with an appropriate CAN-capable interface.
    • Includes all additional enhancements introduced in Beta versions 401.2, 402.3, and 403.1.
    • Adds support for the KEY-COM and KEY-USB Interfaces.
    • Adds enhanced labels for Measuring Blocks, Adaptation Channels, and Recode screens.
    • Adds suggested coding values for Airbag controllers.
    • This version is no longer supported. Users should update to a newer version.
    Release 311 posted 16 November 2003
    • Support for all 2004 Model VW/Audi/Seat/Skoda passenger vehicles using the K-Line for diagnostics.
    • "Turbo" mode in Measuring Blocks for ME7 and EDC16 ECUs using KWP-2000 protocol for diagnostics. Up to 34 samples per second. Requires HEX-COM or HEX-USB interface.
    • Enhanced keyboard support throughout VAG-COM
    • Browse function when opening Log files.
    • Ability to Log Measuring Block Group 000.
    • New "Tabbed" Select Control Module Interface with buttons for all control module addresses currently supported by the VAS-5051/5052.
    • Enhanced Measuring Block formulas. Adds support for a number of new data-types, and fixes all known bugs in formulas. All formulas have been verified against our VAS-5052 with latest software.
    • Adds Freeze Frame data for Fault Codes on control modules using the KWP-2000 protocols.
    • Adds Advanced ID function for control modules using the KWP-2000 Protocols.
    • Assorted Bug Fixes.
    • Adds Support for the HEX-USB Interface, including updated USB Drivers compatible with both the TWIN-USB and the HEX-USB.
    • Completely rewritten KWP-2000 routines. Compatible with numerous new control modules found in Touareg, Phaeton and others including EDC-16 and MED-9.
    • Adds Output Test (03), Adaptation (10) and Access Authorization (16) for control modules using KWP-2000.
    Россия, Киров
    Отправлено: 13
    Seregas, получается в версии 311 нельзя удалять ошибки?
    Питер
    Получено: 3,817
    Отправлено: 86
    C чего бы это? Можно. Тебе версии 311 более чем достаточно.
    Россия, Киров
    Отправлено: 13
    Отлично, а Вася диагност (та что K-Line) в принципе то же самое, что Vag Com 311?
    Питер
    Получено: 3,817
    Отправлено: 86
    Тоже самое
  1. Настройки VAG-COM 311.2
    от Fox в разделе Архив 2007г.
    Последнее сообщение: 21.12.2007, 19:59
  2. VAG COM 311 RUS
    от Vyacheslav в разделе Архив 2006г.
    Последнее сообщение: 11.11.2006, 18:10
  3. Нужна помощь в регистрации Vag-com 311.2N rus
    от itpb в разделе Архив 2006г.
    Последнее сообщение: 11.09.2006, 11:33
  4. Как с помощью VAG-COM 311.2 сбросить Oilservis
    от Fox в разделе Архив 2006г.
    Последнее сообщение: 24.08.2006, 22:26
  5. Плохо рулит VAG-COM 311.2 RUS
    Последнее сообщение: 24.08.2006, 11:35
