1. #241
    Люберцы МО
    Получено: 123
    Отправлено: 279
    Цитата Сообщение от evaks Посмотреть сообщение
    (FSI)
    Колпаки для легкосплавных дисков
    Все остальное вроде совпадает
  2. #242
    Беларусь,Молодечно
    Получено: 61
    OMEN, держи оригинал-
    Номера PR
    0DJ Vehicle class differentiation -350-
    0EG Installation differentiation for
    twin-clutch gearbox DQ 200
    Vehicle components
    0FA Standard manufacturing sequence
    0G7 Tiptronic
    0GG Emission standard EU4
    0NB Nameplate set in base trim
    0SN Labels/plates in Russian
    0TD Front and rear floor mats
    0VU Information kit in Russian
    0Y3 Cold zones
    0YB Weight range 2
    installation control only, no
    requirement forecast
    1A2 Fuel system for SI engine with direct
    injection (FSI)
    1AT Electronic stabilization program (ESP)
    1D0 Without trailer hitch
    1E1 Activated carbon canister
    1EY Special identification plate
    with weight data, but without general
    operating permit (ROW)
    1G3 Alloy spare wheel with original
    equipment tires
    1KW Disc brakes, rear
    1N3 Speed-related variable steering assist
    (Servotronic)
    1NL Covers for alloy wheels
    1PE Wheel bolts with anti-theft protection
    (unlockable)
    1Q1 Mass damper for steering wheel, 26.5Hz
    1S1 Tool kit and jack
    1SB Additional engine and transmission guard
    1T2 Warning triangle
    1VG Installation parts for four-cylinder
    engine
    1X0 Front wheel drive
    1Z0 Initial standard fuel filling
    1ZM Disc brakes, front (Geomet D)
    2A0 Without delivery equipment
    2G1 Insert for the filling up of unleaded
    fuel
    2H0 Without "drive select"
    2JC Comfort bumpers
    2P1 Plastic trunk sill protection
    2PP Leather multi-function steering wheel
    2WA Without additional tires
    3B4 Child seat anchor for
    child seat system ISOFIX
    3CA Without partition
    3D5 Center console
    3FA Without roof insert (standard roof)
    3GA Without cargo area
    3H0 Without backrest release for front seats
    3L3 Manual height adjustment for front seats
    3LC Door and side trim panel in foam film
    and woven fabric
    3M0 Without special measures
    3NN Rear seat bench unsplit, backrest split
    folding
    3P1 Bracket for
  3. #243
    Сочи
    Люди, а где можно на гольфа расшифровку получить? Может кто здесь подскажет:Golf4 Vin: WVWZZZ1JZYB118879.
    Заранее спасибо.
  4. #244
    Polo Аватар для Skang
    Заранее спасибо.
    Ваша расшифровка:
    КОМПЛЕКТАЦИЯ АВТОМОБИЛЯ
    VIN : WVWZZZ1JZYB118879
    Код автомобиля: 1J12K3
    Двигатель : APF № 000000
    мощность = 74 КВт ( 100 лс.)
    : раб.объем= 1.60 л.
    Коды цветов : X1 X1 KL
    Код КПП : FDH
    Код страны : X0A
    Дата изготовл.: 15.03.2000
    Модельный год : 2000
    1 . 0A2 4 двери
    2 . 0AL Стабилизатор передний
    3 . 0BC Стабилизатор задний
    4 . 0CE СПЕЦКОМПЛЕКТ ДЛЯ ДАННОГО КЛАССА А/М -1J0-
    5 . 0F2 ВПРЫСКОВАЯ СИСТЕМА ПИТАНИЯ БЕНЗ. ДВ-ЛЯ
    6 . 0FC ПРОИЗВОДСТВО BRUSSEL
    7 . 0G2 Рычаг механизма автоматического переключения передач
    8 . 0GH Соответствие нормам токсичности ОГ, D4
    9 . 0KA Без наклеек и эмблем
    10 . 0L2 Электрический привод дросс. заслонки
    11 . 0N1 Задняя ось "Standard"
    12 . 0QE Надпись "1.6"
    13 . 0RB Система блокировки замка зажигания и стартера
    14 . 0SB Наклейки/таблички на нем. языке
    15 . 0TQ Коврики передн. и задн., с цветным обрамлением из иск. кожи
    16 . 0UA Без особых цветовых отделок
    17 . 0YZ БЕЗ ОПРЕДЕЛЕНИЯ КЛАССА ГРУЗОПОДЪЕМНОСТИ ДЛЯ ЗАДНЕЙ ОСИ
    18 . 1AT Электронная программа стабилизации (ESP), включая тормозной ассистент, ABS, EDS и ASR
    19 . 1C1 Антифриз с темп. замерз. до -25 град. С, допуск до -30 град. С
    20 . 1D0 Без тягово-сцепного устройства
    21 . 1E1 Противопылевой фильтр с угольным фильтром
    22 . 1EX Табличка с VIN-номером
    23 . 1G2 Полноразмерное запасное колесо, стальной диск
    24 . 1GA Передняя комфортн.ход.часть
    25 . 1H0 Без регулятора тормозных сил
    26 . 1JA Задняя комфортная подвеска
    27 . 1KK Задние дисковые тормоза
    28 . 1LQ Передние вентилируемые дисковые тормоза
    29 . 1MP Рулевое колесо (4 спицы)
    30 . 1N6 Усилитель руля (в режиме ЕСО функция стоп/старт не поддерживается)
    31 . 1NC Колесные колпаки
    32 . 1PA Стандартные колесные болты
    33 . 1S7 Инструменты и алюминиевый домкрат
    34 . 1SA Без дополнительной защиты картера
    35 . 1T0 Без аптечки, без знака аварийной остановки
    36 . 1X0 Передний привод
    37 . 1Z0 Первая заправка серийным топливом
    38 . 2B5 ДОПОЛНИТЕЛЬНАЯ ШУМОИЗОЛЯЦИЯ
    39 . 2C5 РЕГУЛИРОВКА ВЫСОТЫ И ПРОДОЛЬНОГО ПОЛОЖЕНИЯ РУЛЕВОЙ КОЛОНКИ
    40 . 2D1 ПОЛНЫЙ АЭРОДИНАМИЧЕСКИЙ ПАКЕТ
    41 . 2G7 Заливная горловина 1 со вставкой
    42 . 2JB Бамперы в цвет кузова
    43 . 2LB Топливный бак со спец. обработкой материала (фторирование)
    44 . 2P0 Без защитной окантовки груз. отсека
    45 . 2V5 Противопыльн.и антиаллерг. возд.фильтр с активн.угольн.фильтром
    46 . 2W0 Крышка топливного бака
    47 . 2WA Без дополнительной резины
    48 . 3B0 Без подготовки для постзаводской установки системы креплений детских сидений Isofix сзади
    49 . 3C1 Поясной ремень безопасности для центрального заднего сиденья
    50 . 3CA Без перегородки
    51 . 3FE Сдвижной/откидной стеклянный электролюк
    52 . 3GA Без пола груз. отсека
    53 . 3H0 Без разблокировки спинки передних сидений
    54 . 3J7 2 активных передних подголовника
    55 . 3L3 Передние сиденья с регулировкой высоты
    56 . 3M0 Без спец. исполнения
    57 . 3MH Ковровый настил пола
    58 . 3NW Откидная, асимметрично разделенная, спинка заднего сиденья с центр.подлокотником
    59 . 3P1 Держатель аптечки и знака аварийной остановки
    60 . 3Q1 2 задних подголовника
    61 . 3S0 Без релингов крыши
    62 . 3U1 Крышка багажника
    63 . 3Y0 Без солнцезащитной шторки
    64 . 3YR Вещ. карманы в обивке дверей (спереди с держат. бутылки объемом 1л)
    65 . 3ZG ЗАДНИЕ ТРЕХТОЧЕЧН. РЕМНИ БЕЗОП. С АВТОМАТ.КАТУШКОЙ
    66 . 4A0 БЕЗ ОБОГРЕВА СИДЕНИЙ
    67 . 4AR Тканевая обивка дверей и боковин
    68 . 4B1 Черные боковые защитные накладки
    69 . 4E0 Дистанц. отпирание крышки топл. бака
    70 . 4GF Теплозащитное ветровое стекло
    71 . 4J1 Центр. консоль
    72 . 4K3 Центральный замок с радиоуправлением, 2 складных радиоключа
    73 . 4KC Зеленое теплозащитное остекление
    74 . 4L2 Затемняемое зеркало в салоне
    75 . 4LA Без элемента управления
    76 . 4M6 Держатель для напитков
    77 . 4P0 Модульное напольное покрытие, сзади, исп. 1
    78 . 4Q1 Трудно-воспламеняемые материалы
    79 . 4R4 Задние электростеклоподъемники
    80 . 4SD Косметическое зеркало с подсветкой в водит.солнцезащитн. козырьке
    81 . 4TD Космет.зеркало с подсветкой в солнцезащ.козырьке передн.пасс.
    82 . 4U5 Карманы на спинках передних сидений
    83 . 4UE Подушка безоп.водителя и пер.пасс.
    84 . 4W0 Без отсека для кассет/компакт-дисков
    85 . 4X1 Бок. подушка безоп. водителя и передн.пасс.
    86 . 5A7 Облиц.баг.отдел. с ящичками для крышкой
    87 . 5C0 Кузов без особых мероприятий
    88 . 5D1 Дистанционное управление и блокировка дверей
    89 . 5K1 Консервация окрашенной поверхности (воск)
    90 . 5MA Декоративные вставки, блестящий пластик
    91 . 5N6 Поручни с демпфером
    92 . 5RQ Сферич.наружн.прав.зеркало со стор.передн.пасс.
    93 . 5SL Асферич.наружн.зеркало на стороне водителя
    94 . 6A0 Без огнетушителя
    95 . 6E3 Центральный передний подлокотник с вещевым отсеком
    96 . 6EJ Доп.облицовка порогов, без облицовки арки колес
    97 . 6FE Корпуса наружных зеркал в цвет кузова
    98 . 6KG Решетка радиатора в цвет кузова
    99 . 6P1 Задний держатель номерн. знака (ЕЭК)
    100 . 6PA Пластиковая рукоятка рычага стояночного тормоза
    101 . 6Q4 Рукоятка/шаровая головка рычага КП типа Komfort
    102 . 6QA Блокировка заднего сиденья
    103 . 6R0 Отделка рычага АКП
    104 . 6SC Игольчатый флис в качестве настила пола багажн. отделения
    105 . 6U0 Без доп. наружн. уплотнителей
    106 . 6W1 Передний держатель номерн. знака (Италия)
    107 . 6XD Электрорегулировка и обогрев наружн. зеркал
    108 . 7A0 Без CD-чейнджера/проигрывателя CD
    109 . 7AB Противоугонная система
    110 . 7B2 Электророзетка в багажнике
    111 . 7E0 Без накопителя тепла/доп. обогрева
    112 . 7L0 Без инерционной автоматики (Schwung-Nutz-Automatic)/принудительного х.х./расцепления в неподвижном состоянии
    113 . 7P4 Опора поясничного позвонка в спинках передних сидений
    114 . 7Q0 Без прибора навигации
    115 . 7QA Без CD-Rom
    116 . 7R3 Белые боковые указатели поворотов
    117 . 7X0 Без парковочного ассистента
    118 . 8AC Магнитола ?beta?
    119 . 8CC СПИДОМЕТР НЕ ОПЛОМБИРОВАН (ЭЛЕКТРОННЫЙ СПИДОМЕТР)
    120 . 8GD Генератор 90 А
    121 . 8JS Двойная фара и указатель поворотов под общим прозрачным стеклом
    122 . 8K0 Без спец. включения ближнего света
    123 . 8L3 АНТЕННА КРЫШИ С ЭЛЕКТРОННЫМ УСИЛИТЕЛЕМ
    124 . 8M1 Омыватель/очиститель заднего стекла с прерывистым включением
    125 . 8N4 Прерывистое включение стеклоочистителя ветрового стекла
    126 . 8Q1 Регулировка угла наклона фар
    127 . 8RE 4 передних динамика: 2 х 2 канала
    128 . 8S2 1 плафон для чтения спереди, 2 плафона для чтения сзади
    129 . 8SA КОМБИНИРОВАННЫЙ ФОНАРЬ (СТОП-СИГНАЛ, УКАЗАТЕЛЬ ПОВОРОТА, СТОЯН. ФОНАРЬ И ФОНАРЬ З.Х.), СТАНДАРТНОЕ ИСПОЛНЕНИЕ
    130 . 8T0 Без системы GRA
    131 . 8TC Задний противотуманный фонарь
    132 . 8W0 Без индикатора уровня жидкости в бачке омывателя
    133 . 8WD Противотуманные фары
    134 . 8X0 Без очистителя фар
    135 . 8Y1 Звуковой сигнал с двойным тоном
    136 . 8Z5 Система охл. дв-ля, исполнение 1
    137 . 9A0 Без тревожн.сигнал.для такси
    138 . 9AB Кондиционер
    139 . 9D0 БЕЗ ПОДГОТОВКИ ДЛЯ ПОСТЗАВОДСКОЙ УСТАНОВКИ РАЦИИ
    140 . 9F0 Без подготовки для постзаводской установки комбинации спецсигналов и без антенны для рации
    141 . 9FB Индикация'включенной передачи
    142 . 9J0 Без высокого звук.сигнала/регулировкой последовательности включения звука
    143 . 9JB Пепельница спереди, прикуриватель
    144 . 9L0 Без подсветки моторного отсека
    145 . 9M0 БЕЗ ДОПОЛНИТЕЛЬНОГО/АВТОНОМНОГО ОТОПИТЕЛЯ
    146 . 9P0 Без контроля ремней безопасности
    147 . 9Q1 Многофункциональный дисплей (MFA)
    148 . 9T0 Без обогреваемых жиклеров стеклоомывателя
    149 . 9TB Лампы порогов/предупр. лампы в дверях
    150 . 9U1 Контроль износа торм. колодок
    151 . 9W0 БЕЗ ПОДГОТОВКИ ДЛЯ ПОСТЗАВОДСКОЙ УСТАНОВКИ АВТОТЕЛЕФОНА/АВТОТЕЛЕФОНА
    152 . 9Y0 Без индикации наружной температуры
    153 . A8C Исполнение Komfort
    154 . B01 Одобрение типа ТС по внутр.регламенту, но в соотв.с реглам. ЕС в ФРГ
    155 . B0A Деталировка без спец. конструктивных предписаний для страны
    156 . C14 Разрешение на эксплуатацию, приложение 14
    157 . C6D Стальные диски 6 J x 14
    158 . E0A Отсутствует исполнение в рамках акции
    159 . F0A Не спец. а/м, стандартное исполнение
    160 . FB0 Стандартная окраска
    161 . G0E 4-ступ. АКП
    162 . H1T ШИНЫ 175/80 R 14 88 H
    163 . J1L АКБ 280 А (60 А*ч)
    164 . K8G Полностью оцинкованный кузов
    165 . L0L LHD vehicle
    166 . MP9 4-ЦИЛ.БЕНЗ. ДВ-ЛЬ 1.6 Л/74 КВТ MPI БАЗ. ДВИГАТЕЛЬ: T6H/T69
    167 . N0U Велюровая обивка сидений, рисунок "Maxima"
    168 . PT1 Audi telematics for NAR
    169 . PTB four doors
    170 . Q2J Передн.сиденья Komfort
    171 . QA0 без встроенных детских сидений
    172 . QD1 Golf, надпись для обозначения модели
    173 . QG1 Продление интервала ТО
    174 . QS1 С управляемым термостатом
    175 . RBA radio system "beta"
    176 . S15 Заводская установка спец. оборудования
    177 . S3B WA Rabatt дочерние предприятия (Польша)
    178 . SE8 Спецкомплект "7V1" вместо "7V2" (подсветка комбинации инстр.с регулир. яркости)
    179 . T6H 4-цил. бенз.двиг. 1,6 л агрег. 06A.F (алюм.)
    180 . U0C Панель приборов с электронным спидометром, суммирующий и суточный счетчик пройденного пути в км, тахометр
    181 . U22 Характеристика пружины 121
    182 . V0A Шины без определения марки производителя
    183 . W02 heated front seats
    184 . WD3 anti-theft alarm system
    185 . X0A Программа продаж для ФРГ
    Последний раз редактировалось Skang; 09.09.2010 в 20:15.
    VW PASSAT B5GP 1.8T AWT 2001г продан.
    VW PASSAT B6 2009г 1.8 TSI AКПП6 Highline.
  5. #245
    Здравствуйте, расшифруйте пожалуйста мой VIN WVWZZZ3CZ7E094878
  6. #246
    Россия, Углич
    расшифруйте пожалуйста мой vin на b6 WVWZZZ3CZ6Е228582
    Спасибо.
    ________________________________
    2.0 TDI
  7. #247
    Россия, Москва
    А можно мне расшифровать XW8ZZZ3CZ8G001028
    Заранее Огромное Спасибо!
  8. #248
    Ваш Vin
    Вложения Вложения
  9. #249
    Спасибо.
    2.0 TDI
    Ваш Vin
    Вложения Вложения
  10. #250
    Россия, Москва
    Цитата Сообщение от Skang Посмотреть сообщение
    Ваш Vin
    Здравствуйте! Некоторые пунки не совподают, вот например : 63 . 4L6 Автоматически затемняющееся зеркало салона. У меня его нету, как то странно. Мож вообще токое быть?
  11. #251
    где-то в ваг
    Получено: 58
    может типо неправ перевод.
    смотри на табличку есть такой код у тебя в серв книге или шильдик где зап колесо.
    2.0 TFSI Tiptron 2006 был, есть и радует 2,0 TFSi 2008 LUX
    история ремонта и обслуживания автомобилей концерна ВАГ
  12. #252
    Эстония. Таллин.
    Skang, Здраствуйте уважаемый,помогите пожалуйста. Жене покупаю гольфа продавец какойто мутный,пробей мне если не в напряг wvwzzz1jzyw396401 Заранее благодарю.
  13. #253
    Россия, Москва
    Извините ребята моя ошибочка, была в последней цифре
    А можно мне расшифровать XW8ZZZ3CZ8G001026
  14. #254
    Хочу взять B6 помогите узнать о ней по вину WVWZZZ3CZE077418
  15. #255
    Беларусь, Минск
    По умолчанию Помогите расшифровать вин код на Б6 пассат
    WVWZZZ3CZ6E016002
    Заранее огромное спасибо!!
  16. #256
    Россия, Нижний Новгород
    Расшифруйте пожалуйста vin моей радости
    wvwzzz3cz7p031331
  17. #257
    wvwzzz3cz7p031331
    Ваш
    Вложения Вложения
  18. #258
    Беларусь, Минск
    WVWZZZ3CZ6E016002
  19. #259
    Здравствуйте!
    А возможно ли мне тоже получить расшифровку Passat 2006, 2L, TFSI?
    WVWAK73C86P128841
    БЛАГОДАРСТВУЮ!
  20. #260
    WVWZZZ3CZ6E016002
    Ваш
    Вложения Вложения
Страница 13 из 88 ПерваяПервая ... 311121314152363 ... ПоследняяПоследняя
  1. расшифровка vin
    от Евгений2008 в разделе Архив 2010г.
    Последнее сообщение: 12.12.2010, 20:49
  2. Расшифровка VIN
    от slider115 в разделе Архив 2010г.
    Последнее сообщение: 24.01.2010, 14:43
  3. Ответов: 0
    Последнее сообщение: 15.06.2007, 22:55
  4. Ответов: 19
    Последнее сообщение: 11.01.2006, 11:00
  5. Расшифровка VIN
    Ответов: 26
    Последнее сообщение: 04.11.2004, 20:48
