1. #7041
    Нижегородская обл.
    Получено: 109
    Отправлено: 48
    Цитата Сообщение от RazzoR Посмотреть сообщение
    гляньте, ради интереса
    А на аудиклубе что не такие не смотрят?
    VW PASSAT 5+ VARIANT 2001 г AZM 2.0 VW PASSAT 2000 г ARG
  2. #7042
    Беларусь
    Посмотрите пожалуйста лог
    ,Group A:,'003,,,,Group B:,'010,,,,Group C:,'011
    ,,Engine speed,MAF (specified),MAF (actual),EGR duty cycle,,Mass Air Flow,Barometric Pressure,Manifold Pressure,Throttle,,Engine speed,Specified MAP,Actual MAP,Duty cycle
    ,TIME,861-945,240-340,240-340,4-84,TIME,,,,?,TIME,,?,?,Regulator valve?
    MARKER,STAMP, /мин, мг/R, мг/R, %,STAMP, мг/R, мБар, мБар,%,STAMP, /мин, мБар, мБар, %
    ,0.00,1197,240.0,235.0,57.0,0.34,245.0,989.4,999.6,4.7,0.68,1197,999.6,999.6,24.7
    ,1.00,1218,260.0,290.0,53.4,1.32,290.0,989.4,999.6,12.9,1.66,1239,1071.0,999.6,32.3
    ,1.98,1260,695.0,480.0,19.9,2.32,525.0,989.4,1101.6,100.0,2.66,1365,1662.6,1183.2,24.7
    ,2.98,1449,830.0,630.0,4.8,3.32,715.0,989.4,1438.2,100.0,3.66,1617,1795.2,1611.6,34.7
    ,3.98,1722,795.0,835.0,4.8,4.32,920.0,989.4,1938.0,100.0,4.66,1911,1948.2,2080.8,56.6
    ,5.00,2016,790.0,970.0,4.8,5.32,985.0,989.4,2213.4,100.0,5.64,2184,1948.2,2244.0,68.5
    ,5.98,2289,790.0,975.0,4.8,6.30,980.0,989.4,2254.2,100.0,6.64,2457,1948.2,2254.2,78.1
    ,6.98,2541,795.0,935.0,4.8,7.30,905.0,989.4,2162.4,100.0,7.64,2709,1948.2,1989.0,72.9
    ,7.96,2793,800.0,720.0,4.8,8.30,665.0,989.4,1642.2,100.0,8.64,2919,1948.2,1550.4,55.0
    ,8.98,2982,805.0,635.0,4.8,9.30,645.0,989.4,1540.2,100.0,9.64,3108,1948.2,1581.0,55.0
    ,9.98,3171,810.0,675.0,4.8,10.30,685.0,989.4,1672.8,100.0,10.62,3297,1948.2,1703.4,58.2
    ,10.96,3360,815.0,705.0,4.8,11.28,710.0,989.4,1764.6,100.0,11.62,3465,1948.2,1795.2,59.0
    ,11.96,3528,830.0,715.0,4.8,12.28,720.0,989.4,1846.2,100.0,12.62,3633,1948.2,1876.8,59.4
    ,12.96,3696,850.0,730.0,4.8,13.28,735.0,989.4,1917.6,100.0,13.60,3822,1948.2,1938.0,62.2
    ,13.94,3864,850.0,730.0,4.8,14.26,725.0,989.4,1958.4,100.0,14.60,3969,1948.2,1958.4,63.8
    ,14.92,4011,850.0,715.0,4.8,15.24,710.0,989.4,1958.4,92.5,15.57,3927,1081.2,1897.2,53.4
    ,15.89,3570,690.0,460.0,4.8,16.23,460.0,989.4,1193.4,0.0,16.56,2415,1009.8,1132.2,48.6
    ,16.88,1953,245.0,485.0,84.5,17.21,430.0,989.4,1071.0,0.0,17.53,1281,999.6,1050.6,38.3
    ,17.87,945,230.0,380.0,84.5,18.22,420.0,989.4,1020.0,0.0,18.53,840,999.6,1020.0,24.7
    B5 2000г.в. 1.9TDI (90л.с. AHH) МКПП
    был Б3 1991г.в. 1,8 моновпрыск + газ
  3. #7043
    Доброго времени суток всем) Выставляю на показ свои логи.
    passat 02г AWM с чипом и фронтальником.
    Допустим, что дырок во впуске нету (опрессовку делал, но нужно сделать ещё раз, впуск снимался), байпас новый. Турбина раздувается поздно. Интересует именно работа клапана N75 (как я понял это именно он в 114 группе в последне поле), т.к. подозрения остались только на него. Вообще, как в идеале он должен вести себя?
    Название: Турба 3 замер.jpg
  4. #7044
    Калмыкия, Городовиковск
    Получено: 1,621
    Отправлено: 480
    Andrio48, снимай с него подозрения, он работает нормально... хотя запрос и факт наддува расходятся, да и турба чуть подустала... По n75 - чем меньше %, тем лучше: он регулирует клапан вестгейта, чтобы выхлопные газа летели/не летели мимо горячей крыльчатки. Контроллер регулирует наддув изменяя скважность клапана (%): 0% - клапан вестгейта открыт (ОГ в обход крыльчатки), 100% - закрыт (ОГ - на крыльчатку, набор наддува). С "усталостью" турбы % растет. На новой, без чипа, с момента выхода на наддув (после 2200) падает примерно до 50% или даже ниже. На чипе - в районе 70%, как-то так...
  5. #7045
    Passat Аватар для славик111
    щербинка м/о
    Получено: 13
    Отправлено: 63
    подскажите..делал тест АВС ошибка 18256-считать данные из памяти неисправностей блока управления двигателя Р-1848-35-10...что это? чек по этому поводу не горит...ошибку показывает ток во время когда залазию в 03гр абс
    и еще никак немогу разобраться с ошибкой..сдвиг фаз газораспределения в более раннюю сторону...метки ровно..на гнц тож ровно.. .. и всплывает еще вент топ бака..то высокая то низкая пропускаемость..можно ее какниб удалить (перепрошить мозги) ???
    1.8T AWM АКПП типтроник 2003г америкос WVWPD63B03P206630 был..стал АУДИ А6С6 3,0ТДИ Кватро/пневмо s-line..
  6. #7046
    Беларусь
    может и у меня N 75 глючит. давление наддува упало в с 2900 до 3400 обор. в мин. !!?????
  7. #7047
    Lupo Аватар для ШЭФ
    г. Краснодар
    добрый день товарищи)
    Я взялся за это дело. Это будет честный детектив)
    Имеем AWT 2001 год. Мкпп. Совсем не радует расход топлива (15 - 16 литров) после моего бывшего АЕВ который при любой езде 11-12 кушал не больше.
    Ну и приём.. тут вроде получше обстановка. но что то на низах уж очень туповат.. потом аж де то после 3000 начинает крутиться (интуитивно)
    так вот. кстати если важно лью 95-й. Масло прошлый хозяин залил eneos 10w40 ( o_0 ) возд.фильтр новый..
    вот вчера снял Логи по пяти группам.. Если что то не так поправьте (я по одному параметру снимал может это моя ошибка?)
    суть в чем.. хочу понять что не так.. может чип уже стоит? 0_о судя по аккуратно выведенному двойному выхлопу позапрошлый хозяин любил экспериментировать с машиной))
    ну и вообще посмотрите пожалуйста.. если логи как то по другому надо снять подскажите, может еще какие группы (первый раз в жизни таким занимался =))
    Заранее спасибо)
    ЗЫ.. Ошибок по двигателю нет
  8. #7048
    Получено: 1,621
    Отправлено: 480
    ШЭФ, привет, а старинного АЕВа куда дел? И ту тему не закончил, исчез
    зря...
    на 3 передаче с 1500 до не менее 5700, педаль в пол, группы
    003-115-020
    003-115-114
    003-115-211
    логи не смотрел, потом..
  9. #7049
    Lupo Аватар для ШЭФ
    г. Краснодар
    003-115-020
    003-115-114
    003-115-211
    ну я так и снимал, только та
    001
    003
    032
    115
    211
    еле продал бедолагу)) а что за тема? отошел я на время от форума прррростите и поймите)
  10. #7050
    Получено: 1,621
    Отправлено: 480
    ШЭФ, переснимай логи группами, 114 и 020 обязательно ... чип есть, но не едет она у тебя совсем... опрессовку делал?
  11. #7051
    Lupo Аватар для ШЭФ
    г. Краснодар
    komsernik,обязательно сниму эти группы. на днях разберу посмотрю всю систему вкг и опрессовку сделаю.
    но потерь мощности когда турба уже дует вроде особо нет... а вот когда логи снимал и с 1500 оборотов на третьей в пол... ооооочень долго тупит...
    (а как видно что чип есть объясните плиз? вроде када дует подхват прям хороший и двигатель слышно легко работает.. но как это в цифрах?) =)
  12. #7052
    Получено: 1,621
    Отправлено: 480
    ШЭФ, по наддуву запрос как на чипе (на 2040 об/мин - 2020 в 115, 3-е поле), но фактически недодув (на 2040 - 1270),
  13. #7053
    Lupo Аватар для ШЭФ
    г. Краснодар
    значит где то утечка может быть пральна понимаю? каковы еще могут быть причины чтоб я сразу уделил внимание?
  14. #7054
    Получено: 1,621
    Отправлено: 480
    ШЭФ, причин много... главные: негерметичность, большой ретард, ты его не показал - надо 020 (на это и твой большой расход указывает, почитай предыдущие пару-тройку страниц темы), ну, и уставшая турба. В общем, для начала давай нормальные логи, а так гадать будем долго.
  15. #7055
    Lupo Аватар для Andla
    52 регион
    Получено: 13
    Отправлено: 15
    Цитата Сообщение от Osechkin Посмотреть сообщение
    Сообщение от Andla от 05.05.2013, 19:57 #6925
    Добрый день.
    Посмотрите, пожалуйста, логи.
    AWT.zip
    По воздуху занижение есть. 031-020-003 гр надо снимать по топливу.
    Посмотрите,добавил.
    Вложения Вложения
    Последний раз редактировалось Andla; 25.05.2013 в 21:58.
    VW Passat B5+,2001г.в.,1.8T,AWT,150hp,мкпп
  16. #7056
    Lupo Аватар для Serg 034
    Волжский Волгоградская Обл
    VW Passat B5.5 2004, 1.8 T,AWT ,АКПП, WVWZZZ3BZ5P017804
    VW Touareg 2008 3.0 TDI
  17. #7057
    Passat Аватар для Podpal
    Смоленск
    Получено: 56
    Цитата Сообщение от Serg 034 Посмотреть сообщение
    Перезалей правильно
  18. #7058
    Чет я не пойму как
    Вложения Вложения
  19. #7059
    Получено: 1,621
    Отправлено: 480
    Serg 034, а чего ты с ними сделал? Из папки ваг-кома "логи" нужные в формате csv архивируй в zip-архив и сюда
  20. #7060
    Рига, Латвия
    Отправлено: 17
    Доброго!
    Суть проблемы: при покупке машины на ней стоял убитый расходомер воздуха (все говорило о нем, включая косвенные признаки, чтение логов тут и диагностику в офф BOSCH центре). После замены на новый BOSCH для моего двигателя, выросла тяга (что и должно было), но появилась проблема - расход вырос на 4-5 литров, появился запах бензина в выхлопе. Опять к диагностам ехать дорого. По каким группам посоветуете снять логи, чтоб можно было попытаться выявить проблему? Заранее спасибо!
Страница 353 из 842 ПерваяПервая ... 253303343351352353354355363403453 ... ПоследняяПоследняя
  1. Ответов: 10551
    Последнее сообщение: 22.01.2017, 23:19
  2. Ответов: 14415
  3. Ответов: 2132
    Ответов: 39
